root/radiance/ray/src/util/rpiece.c
Revision: 2.49
Committed: Thu Apr 24 10:28:25 2008 UTC (17 years, 2 months ago) by schorsch
Changes since 2.48: +3 -2 lines
2 static const char RCSid[] = "$Id: rpiece.c,v 2.48 2008/03/11 02:21:47 greg Exp $";
5 * Generate sections of a picture.
6 */
7
8
9 #include <stdio.h>
10 #include <signal.h>
11 #include <sys/types.h>
12
13 #include "platform.h"
14 #ifndef NON_POSIX /* XXX need abstraction for process management */
15 #include <sys/wait.h>
16 #endif
17
18 #include "standard.h"
19 #include "color.h"
20 #include "view.h"
21 #include "rtprocess.h"
22
23 #ifndef F_SETLKW
24
25 int
26 main(
27 int argc,
28 char *argv[]
29 )
30 {
31 fprintf(stderr, "%s: no NFS lock manager on this machine\n", argv[0]);
32 exit(1);
33 }
34
35 #else
36
37 #ifndef NFS
38 #define NFS 1
39 #endif
40 /* set the following to 0 to forgo forking */
41 #ifndef MAXFORK
42 #if NFS
43 #define MAXFORK 3 /* allotment of duped processes */
44 #else
45 #define MAXFORK 0
46 #endif
47 #endif
48 /* protection from SYSV signals(!) */
49 #if defined(sgi)
50 #define guard_io() sighold(SIGALRM)
51 #define unguard() sigrelse(SIGALRM)
52 #endif
53 #ifndef guard_io
54 #define guard_io()
55 #define unguard()
56 #endif
57
58 extern char *strerror();
59
60 /* rpict command */
61 char *rpargv[128] = {"rpict", "-S", "1"};
62 int rpargc = 3;
63 FILE *torp, *fromrp;
64 COLR *pbuf;
65 /* our view parameters */
66 VIEW ourview = STDVIEW;
67 double pixaspect = 1.0;
68 int hres = 1024, vres = 1024, hmult = 4, vmult = 4;
69 /* output file */
70 char *outfile = NULL;
71 int outfd;
72 long scanorig;
73 FILE *syncfp = NULL; /* synchronization file pointer */
74 int synclst = F_UNLCK; /* synchronization file lock status */
75 int nforked = 0;
76
77 #define sflock(t) if ((t)!=synclst) dolock(fileno(syncfp),synclst=t)
78
79 char *progname;
80 int verbose = 0;
81 unsigned timelim = 0;
82 int rvrlim = -1;
83
84 int gotalrm = 0;
85 void onalrm(int i) { gotalrm++; }
86
87 static void dolock(int fd, int ltyp);
88 static void init(int ac, char **av);
89 static int nextpiece(int *xp, int *yp);
90 static int rvrpiece(int *xp, int *yp);
91 static int cleanup(int rstat);
92 static void rpiece(void);
93 static int putpiece(int xpos, int ypos);
94 static void filerr(char *t);
95
96
97 int
98 main(
99 int argc,
100 char *argv[]
101 )
102 {
103 register int i, rval;
104
105 progname = argv[0];
106 for (i = 1; i < argc; i++) {
107 /* expand arguments */
108 while ((rval = expandarg(&argc, &argv, i)) > 0)
109 ;
110 if (rval < 0) {
111 fprintf(stderr, "%s: cannot expand '%s'",
112 argv[0], argv[i]);
113 exit(1);
114 }
115 if (argv[i][0] == '-')
116 switch (argv[i][1]) {
117 case 'v':
118 switch (argv[i][2]) {
119 case '\0': /* verbose option */
120 verbose = !verbose;
121 continue;
122 case 'f': /* view file */
123 if (viewfile(argv[++i], &ourview, NULL) <= 0) {
124 fprintf(stderr,
125 "%s: not a view file\n", argv[i]);
126 exit(1);
127 }
128 continue;
129 default: /* view option? */
130 rval = getviewopt(&ourview, argc-i, argv+i);
131 if (rval >= 0) {
132 i += rval;
133 continue;
134 }
135 break;
136 }
137 break;
138 case 'p': /* pixel aspect ratio? */
139 if (argv[i][2] != 'a' || argv[i][3])
140 break;
141 pixaspect = atof(argv[++i]);
142 continue;
143 case 'T': /* time limit (hours) */
144 if (argv[i][2])
145 break;
146 timelim = atof(argv[++i])*3600. + .5;
147 break;
148 case 'x': /* overall x resolution */
149 if (argv[i][2])
150 break;
151 hres = atoi(argv[++i]);
152 continue;
153 case 'y': /* overall y resolution */
154 if (argv[i][2])
155 break;
156 vres = atoi(argv[++i]);
157 continue;
158 case 'X': /* horizontal multiplier */
159 if (argv[i][2])
160 break;
161 hmult = atoi(argv[++i]);
162 continue;
163 case 'Y': /* vertical multiplier */
164 if (argv[i][2])
165 break;
166 vmult = atoi(argv[++i]);
167 continue;
168 case 'R': /* recover */
169 if (argv[i][2])
170 break;
171 rvrlim = 0;
172 /* fall through */
173 case 'F': /* syncronization file */
174 if (argv[i][2])
175 break;
176 if ((syncfp =
177 fdopen(open(argv[++i],O_RDWR|O_CREAT,0666),"r+")) == NULL) {
178 fprintf(stderr, "%s: cannot open\n",
179 argv[i]);
180 exit(1);
181 }
182 continue;
183 case 'z': /* z-file ist verbotten */
184 fprintf(stderr, "%s: -z option not allowed\n",
185 argv[0]);
186 exit(1);
187 case 'o': /* output file */
188 if (argv[i][2])
189 break;
190 outfile = argv[++i];
191 continue;
192 } else if (i >= argc-1)
193 break;
194 rpargv[rpargc++] = argv[i];
195 }
196 if (i >= argc) {
197 fprintf(stderr, "%s: missing octree argument\n", argv[0]);
198 exit(1);
199 }
200 if (outfile == NULL) {
201 fprintf(stderr, "%s: missing output file\n", argv[0]);
202 exit(1);
203 }
204 init(argc, argv);
205 rpiece();
206 exit(cleanup(0));
207 }
208
209
210 static void
211 dolock( /* lock or unlock a file */
212 int fd,
213 int ltyp
214 )
215 {
216 static struct flock fls; /* static so initialized to zeroes */
217
218 fls.l_type = ltyp;
219 if (fcntl(fd, F_SETLKW, &fls) < 0) {
220 fprintf(stderr, "%s: cannot lock/unlock file: %s\n",
221 progname, strerror(errno));
222 exit(1);
223 }
224 }
225
226
227 static void
228 init( /* set up output file and start rpict */
229 int ac,
230 char **av
231 )
232 {
233 static char hrbuf[16], vrbuf[16];
234 extern char VersionID[];
235 char *err;
236 FILE *fp;
237 int hr, vr;
238 SUBPROC rpd; /* since we don't close_process(), this can be local */
239 /* set up view */
240 if ((err = setview(&ourview)) != NULL) {
241 fprintf(stderr, "%s: %s\n", progname, err);
242 exit(1);
243 }
244 if (syncfp != NULL) {
245 sflock(F_RDLCK);
246 fscanf(syncfp, "%d %d", &hmult, &vmult);
247 sflock(F_UNLCK);
248 }
249 /* compute piece size */
250 hres /= hmult;
251 vres /= vmult;
252 if (hres <= 0 || vres <= 0) {
253 fprintf(stderr, "%s: illegal resolution/subdivision\n", progname);
254 exit(1);
255 }
256 normaspect(viewaspect(&ourview)*hmult/vmult, &pixaspect, &hres, &vres);
257 sprintf(hrbuf, "%d", hres);
258 rpargv[rpargc++] = "-x"; rpargv[rpargc++] = hrbuf;
259 sprintf(vrbuf, "%d", vres);
260 rpargv[rpargc++] = "-y"; rpargv[rpargc++] = vrbuf;
261 rpargv[rpargc++] = "-pa"; rpargv[rpargc++] = "0";
262 rpargv[rpargc++] = av[ac-1];
263 rpargv[rpargc] = NULL;
264 /* open output file */
265 if ((outfd = open(outfile, O_WRONLY|O_CREAT|O_EXCL, 0666)) >= 0) {
266 dolock(outfd, F_WRLCK);
267 if ((fp = fdopen(dup(outfd), "w")) == NULL)
268 goto filerr;
269 newheader("RADIANCE", fp); /* create header */
270 printargs(ac, av, fp);
271 fprintf(fp, "SOFTWARE= %s\n", VersionID);
272 fputs(VIEWSTR, fp);
273 fprintview(&ourview, fp);
274 putc('\n', fp);
275 if (pixaspect < .99 || pixaspect > 1.01)
276 fputaspect(pixaspect, fp);
277 fputformat(COLRFMT, fp);
278 putc('\n', fp);
279 fprtresolu(hres*hmult, vres*vmult, fp);
280 } else if ((outfd = open(outfile, O_RDWR)) >= 0) {
281 dolock(outfd, F_RDLCK);
282 if ((fp = fdopen(dup(outfd), "r+")) == NULL)
283 goto filerr;
284 getheader(fp, NULL, NULL); /* skip header */
285 if (!fscnresolu(&hr, &vr, fp) || /* check resolution */
286 hr != hres*hmult || vr != vres*vmult) {
287 fprintf(stderr, "%s: resolution mismatch on file \"%s\"\n",
288 progname, outfile);
289 exit(1);
290 }
291 } else {
292 fprintf(stderr, "%s: cannot open file \"%s\"\n",
293 progname, outfile);
294 exit(1);
295 }
296 scanorig = ftell(fp); /* record position of first scanline */
297 if (fclose(fp) == -1) /* done with stream i/o */
298 goto filerr;
299 dolock(outfd, F_UNLCK);
300 /* start rpict process */
301 if (open_process(&rpd, rpargv) <= 0) {
302 fprintf(stderr, "%s: cannot start %s\n", progname, rpargv[0]);
303 exit(1);
304 }
305 if ((fromrp = fdopen(rpd.r, "r")) == NULL ||
306 (torp = fdopen(rpd.w, "w")) == NULL) {
307 fprintf(stderr, "%s: cannot open stream to %s\n",
308 progname, rpargv[0]);
309 exit(1);
310 }
311 if ((pbuf = (COLR *)bmalloc(hres*vres*sizeof(COLR))) == NULL) {
312 fprintf(stderr, "%s: out of memory\n", progname);
313 exit(1);
314 }
315 signal(SIGALRM, onalrm);
316 if (timelim)
317 alarm(timelim);
318 return;
319 filerr:
320 fprintf(stderr, "%s: i/o error on file \"%s\"\n", progname, outfile);
321 exit(1);
322 }
323
324
325 static int
326 nextpiece( /* get next piece assignment */
327 int *xp,
328 int *yp
329 )
330 {
331 if (gotalrm) /* someone wants us to quit */
332 return(0);
333 if (syncfp != NULL) { /* use sync file */
334 /*
335 * So we don't necessarily have to lock and unlock the file
336 * multiple times (very slow), we establish an exclusive
337 * lock at the beginning on our synchronization file and
338 * maintain it in the subroutine rvrpiece().
339 */
340 sflock(F_WRLCK);
341 fseek(syncfp, 0L, 0); /* read position */
342 if (fscanf(syncfp, "%*d %*d %d %d", xp, yp) < 2) {
343 *xp = hmult-1;
344 *yp = vmult;
345 }
346 if (rvrlim == 0) /* initialize recovery limit */
347 rvrlim = *xp*vmult + *yp;
348 if (rvrpiece(xp, yp)) { /* do stragglers first */
349 sflock(F_UNLCK);
350 return(1);
351 }
352 if (--(*yp) < 0) { /* decrement position */
353 *yp = vmult-1;
354 if (--(*xp) < 0) { /* all done */
355 sflock(F_UNLCK);
356 return(0);
357 }
358 }
359 fseek(syncfp, 0L, 0); /* write new position */
360 fprintf(syncfp, "%4d %4d\n%4d %4d\n\n", hmult, vmult, *xp, *yp);
361 fflush(syncfp);
362 sflock(F_UNLCK); /* release sync file */
363 return(1);
364 }
365 return(scanf("%d %d", xp, yp) == 2); /* use stdin */
366 }
367
368
369 static int
370 rvrpiece( /* check for recoverable pieces */
371 register int *xp,
372 register int *yp
373 )
374 {
375 static char *pdone = NULL; /* which pieces are done */
376 static long readpos = -1; /* how far we've read */
377 register int i;
378 /*
379 * This routine is called by nextpiece() with an
380 * exclusive lock on syncfp and the file pointer at the
381 * appropriate position to read in the finished pieces.
382 */
383 if (rvrlim < 0)
384 return(0); /* only check if asked */
385 if (pdone == NULL) /* first call */
386 pdone = calloc(hmult*vmult, sizeof(char));
387 if (pdone == NULL) {
388 fprintf(stderr, "%s: out of memory\n", progname);
389 exit(1);
390 }
391 if (readpos != -1) /* mark what's been done */
392 fseek(syncfp, readpos, 0);
393 while (fscanf(syncfp, "%d %d", xp, yp) == 2)
394 pdone[*xp*vmult+*yp] = 1;
395 if (!feof(syncfp)) {
396 fprintf(stderr, "%s: format error in sync file\n", progname);
397 exit(1);
398 }
399 readpos = ftell(syncfp);
400 i = hmult*vmult; /* find an unaccounted for piece */
401 while (i-- > rvrlim)
402 if (!pdone[i]) {
403 *xp = i / vmult;
404 *yp = i % vmult;
405 pdone[i] = 1; /* consider it done */
406 return(1);
407 }
408 rvrlim = -1; /* nothing left to recover */
409 free(pdone);
410 pdone = NULL;
411 return(0);
412 }
413
414
415 static int
416 cleanup( /* close rpict process and clean up */
417 int rstat
418 )
419 {
420 int status;
421
422 bfree((char *)pbuf, hres*vres*sizeof(COLR));
423 fclose(torp);
424 fclose(fromrp);
425 while (wait(&status) != -1)
426 if (rstat == 0)
427 rstat = status>>8 & 0xff;
428 return(rstat);
429 }
430
431
432 static void
433 rpiece(void) /* render picture piece by piece */
434 {
435 VIEW pview;
436 int xorg, yorg;
437 /* compute view parameters */
438 pview = ourview;
439 switch (ourview.type) {
440 case VT_PER:
441 pview.horiz = (2.*180./PI)*atan(
442 tan((PI/180./2.)*ourview.horiz)/hmult );
443 pview.vert = (2.*180./PI)*atan(
444 tan((PI/180./2.)*ourview.vert)/vmult );
445 break;
446 case VT_PAR:
447 case VT_ANG:
448 pview.horiz = ourview.horiz / hmult;
449 pview.vert = ourview.vert / vmult;
450 break;
451 case VT_CYL:
452 pview.horiz = ourview.horiz / hmult;
453 pview.vert = (2.*180./PI)*atan(
454 tan((PI/180./2.)*ourview.vert)/vmult );
455 break;
456 case VT_HEM:
457 pview.horiz = (2.*180./PI)*asin(
458 sin((PI/180./2.)*ourview.horiz)/hmult );
459 pview.vert = (2.*180./PI)*asin(
460 sin((PI/180./2.)*ourview.vert)/vmult );
461 break;
462 case VT_PLS:
463 pview.horiz = sin((PI/180./2.)*ourview.horiz) /
464 (1.0 + cos((PI/180./2.)*ourview.horiz)) / hmult;
465 pview.horiz *= pview.horiz;
466 pview.horiz = (2.*180./PI)*acos((1. - pview.horiz) /
467 (1. + pview.horiz));
468 pview.vert = sin((PI/180./2.)*ourview.vert) /
469 (1.0 + cos((PI/180./2.)*ourview.vert)) / vmult;
470 pview.vert *= pview.vert;
471 pview.vert = (2.*180./PI)*acos((1. - pview.vert) /
472 (1. + pview.vert));
473 break;
474 default:
475 fprintf(stderr, "%s: unknown view type '-vt%c'\n",
476 progname, ourview.type);
477 exit(cleanup(1));
478 }
479 /* render each piece */
480 while (nextpiece(&xorg, &yorg)) {
481 pview.hoff = ourview.hoff*hmult + xorg - 0.5*(hmult-1);
482 pview.voff = ourview.voff*vmult + yorg - 0.5*(vmult-1);
483 fputs(VIEWSTR, torp);
484 fprintview(&pview, torp);
485 putc('\n', torp);
486 fflush(torp); /* assigns piece to rpict */
487 putpiece(xorg, yorg); /* place piece in output */
488 }
489 }
490
491
492 static int
493 putpiece( /* get next piece from rpict */
494 int xpos,
495 int ypos
496 )
497 {
498 struct flock fls;
499 int pid, status;
500 int hr, vr;
501 register int y;
502 /* check bounds */
503 if ((xpos < 0) | (ypos < 0) | (xpos >= hmult) | (ypos >= vmult)) {
504 fprintf(stderr, "%s: requested piece (%d,%d) out of range\n",
505 progname, xpos, ypos);
506 exit(cleanup(1));
507 }
508 /* check header from rpict */
509 guard_io();
510 getheader(fromrp, NULL, NULL);
511 if (!fscnresolu(&hr, &vr, fromrp) || (hr != hres) | (vr != vres)) {
512 fprintf(stderr, "%s: resolution mismatch from %s\n",
513 progname, rpargv[0]);
514 exit(cleanup(1));
515 }
516 if (verbose) { /* notify caller */
517 printf("%d %d begun\n", xpos, ypos);
518 fflush(stdout);
519 }
520 unguard();
521 /* load new piece into buffer */
522 for (y = 0; y < vr; y++) {
523 guard_io();
524 if (freadcolrs(pbuf+y*hr, hr, fromrp) < 0) {
525 fprintf(stderr, "%s: read error from %s\n",
526 progname, rpargv[0]);
527 exit(cleanup(1));
528 }
529 unguard();
530 }
531 #if MAXFORK
532 /* fork so we don't slow rpict down */
533 if ((pid = fork()) > 0) {
534 if (++nforked >= MAXFORK) {
535 wait(&status); /* reap a child */
536 if (status)
537 exit(cleanup(status>>8 & 0xff));
538 nforked--;
539 }
540 return(pid);
541 }
542 #else
543 pid = -1; /* no forking */
544 #endif
545 fls.l_start = scanorig +
546 ((long)(vmult-1-ypos)*vres*hmult+xpos)*hres*sizeof(COLR);
547 #if NFS
548 fls.l_len = ((long)(vres-1)*hmult+1)*hres*sizeof(COLR);
549 /* lock file section so NFS doesn't mess up */
550 fls.l_whence = 0;
551 fls.l_type = F_WRLCK;
552 if (fcntl(outfd, F_SETLKW, &fls) < 0)
553 filerr("lock");
554 #endif
555 /* write new piece to file */
556 if (lseek(outfd, (off_t)fls.l_start, SEEK_SET) < 0)
557 filerr("seek");
558 if (hmult == 1) {
559 if (writebuf(outfd, (char *)pbuf,
560 vr*hr*sizeof(COLR)) != vr*hr*sizeof(COLR))
561 filerr("write");
562 } else
563 for (y = 0; y < vr; y++) {
564 if (writebuf(outfd, (char *)(pbuf+y*hr),
565 hr*sizeof(COLR)) != hr*sizeof(COLR))
566 filerr("write");
567 if (y < vr-1 && lseek(outfd,
568 (off_t)(hmult-1)*hr*sizeof(COLR),
569 SEEK_CUR) < 0)
570 filerr("seek");
571 }
572 #if NFS
573 fls.l_type = F_UNLCK; /* release lock */
574 if (fcntl(outfd, F_SETLKW, &fls) < 0)
575 filerr("lock");
576 #endif
577 if (verbose) { /* notify caller */
578 printf("%d %d done\n", xpos, ypos);
579 fflush(stdout);
580 }
581 if (syncfp != NULL) { /* record what's been done */
582 sflock(F_WRLCK);
583 fseek(syncfp, 0L, 2); /* append index */
584 fprintf(syncfp, "%4d %4d\n", xpos, ypos);
585 fflush(syncfp);
586 /*** Unlock not necessary, since
587 sflock(F_UNLCK); _exit() or nextpiece() is next ***/
588 }
589 if (pid == -1) /* didn't fork or fork failed */
590 return(0);
591 _exit(0); /* else exit child process (releasing locks) */
592 }
593
594
595 static void
596 filerr( /* report file error and exit */
597 char *t
598 )
599 {
600 fprintf(stderr, "%s: %s error on file \"%s\": %s\n",
601 progname, t, outfile, strerror(errno));
602 _exit(1);
603 }
604
605 #endif
