root/radiance/ray/src/util/rpiece.c
Revision: 2.45
Committed: Sat Oct 23 18:55:53 2004 UTC (20 years, 4 months ago) by schorsch
CVS Tags: rad3R7P2, rad3R7P1, rad3R6P1, rad3R8
Changes since 2.44: +4 -2 lines
2 static const char RCSid[] = "$Id: rpiece.c,v 2.44 2004/06/08 19:48:31 greg Exp $";
5 * Generate sections of a picture.
6 */
7
8
9 #include <stdio.h>
10 #include <signal.h>
11 #include <sys/types.h>
12 #ifndef NON_POSIX /* XXX need abstraction for process management */
13 #include <sys/wait.h>
14 #endif
15
16 #include "platform.h"
17 #include "standard.h"
18 #include "color.h"
19 #include "view.h"
20 #include "rtprocess.h"
21
22 #ifndef F_SETLKW
23
24 int
25 main(
26 int argc,
27 char *argv[]
28 )
29 {
30 fprintf(stderr, "%s: no NFS lock manager on this machine\n", argv[0]);
31 exit(1);
32 }
33
34 #else
35
36 #ifndef NFS
37 #define NFS 1
38 #endif
39 /* set the following to 0 to forgo forking */
40 #ifndef MAXFORK
41 #if NFS
42 #define MAXFORK 3 /* allotment of duped processes */
43 #else
44 #define MAXFORK 0
45 #endif
46 #endif
47 /* protection from SYSV signals(!) */
48 #if defined(sgi)
49 #define guard_io() sighold(SIGALRM)
50 #define unguard() sigrelse(SIGALRM)
51 #endif
52 #ifndef guard_io
53 #define guard_io()
54 #define unguard()
55 #endif
56
57 extern char *strerror();
58
59 /* rpict command */
60 char *rpargv[128] = {"rpict", "-S", "1"};
61 int rpargc = 3;
62 FILE *torp, *fromrp;
63 COLR *pbuf;
64 /* our view parameters */
65 VIEW ourview = STDVIEW;
66 double pixaspect = 1.0;
67 int hres = 1024, vres = 1024, hmult = 4, vmult = 4;
68 /* output file */
69 char *outfile = NULL;
70 int outfd;
71 long scanorig;
72 FILE *syncfp = NULL; /* synchronization file pointer */
73 int synclst = F_UNLCK; /* synchronization file lock status */
74 int nforked = 0;
75
76 #define sflock(t) if ((t)!=synclst) dolock(fileno(syncfp),synclst=t)
77
78 char *progname;
79 int verbose = 0;
80 unsigned timelim = 0;
81 int rvrlim = -1;
82
83 int gotalrm = 0;
84 void onalrm(int i) { gotalrm++; }
85
86 static void dolock(int fd, int ltyp);
87 static void init(int ac, char **av);
88 static int nextpiece(int *xp, int *yp);
89 static int rvrpiece(int *xp, int *yp);
90 static int cleanup(int rstat);
91 static void rpiece(void);
92 static int putpiece(int xpos, int ypos);
93 static void filerr(char *t);
94
95
96 int
97 main(
98 int argc,
99 char *argv[]
100 )
101 {
102 register int i, rval;
103
104 progname = argv[0];
105 for (i = 1; i < argc; i++) {
106 /* expand arguments */
107 while ((rval = expandarg(&argc, &argv, i)) > 0)
108 ;
109 if (rval < 0) {
110 fprintf(stderr, "%s: cannot expand '%s'",
111 argv[0], argv[i]);
112 exit(1);
113 }
114 if (argv[i][0] == '-')
115 switch (argv[i][1]) {
116 case 'v':
117 switch (argv[i][2]) {
118 case '\0': /* verbose option */
119 verbose = !verbose;
120 continue;
121 case 'f': /* view file */
122 if (viewfile(argv[++i], &ourview, NULL) <= 0) {
123 fprintf(stderr,
124 "%s: not a view file\n", argv[i]);
125 exit(1);
126 }
127 continue;
128 default: /* view option? */
129 rval = getviewopt(&ourview, argc-i, argv+i);
130 if (rval >= 0) {
131 i += rval;
132 continue;
133 }
134 break;
135 }
136 break;
137 case 'p': /* pixel aspect ratio? */
138 if (argv[i][2] != 'a' || argv[i][3])
139 break;
140 pixaspect = atof(argv[++i]);
141 continue;
142 case 'T': /* time limit (hours) */
143 if (argv[i][2])
144 break;
145 timelim = atof(argv[++i])*3600. + .5;
146 break;
147 case 'x': /* overall x resolution */
148 if (argv[i][2])
149 break;
150 hres = atoi(argv[++i]);
151 continue;
152 case 'y': /* overall y resolution */
153 if (argv[i][2])
154 break;
155 vres = atoi(argv[++i]);
156 continue;
157 case 'X': /* horizontal multiplier */
158 if (argv[i][2])
159 break;
160 hmult = atoi(argv[++i]);
161 continue;
162 case 'Y': /* vertical multiplier */
163 if (argv[i][2])
164 break;
165 vmult = atoi(argv[++i]);
166 continue;
167 case 'R': /* recover */
168 if (argv[i][2])
169 break;
170 rvrlim = 0;
171 /* fall through */
172 case 'F': /* syncronization file */
173 if (argv[i][2])
174 break;
175 if ((syncfp =
176 fdopen(open(argv[++i],O_RDWR|O_CREAT,0666),"r+")) == NULL) {
177 fprintf(stderr, "%s: cannot open\n",
178 argv[i]);
179 exit(1);
180 }
181 continue;
182 case 'z': /* z-file ist verbotten */
183 fprintf(stderr, "%s: -z option not allowed\n",
184 argv[0]);
185 exit(1);
186 case 'o': /* output file */
187 if (argv[i][2])
188 break;
189 outfile = argv[++i];
190 continue;
191 } else if (i >= argc-1)
192 break;
193 rpargv[rpargc++] = argv[i];
194 }
195 if (i >= argc) {
196 fprintf(stderr, "%s: missing octree argument\n", argv[0]);
197 exit(1);
198 }
199 if (outfile == NULL) {
200 fprintf(stderr, "%s: missing output file\n", argv[0]);
201 exit(1);
202 }
203 init(argc, argv);
204 rpiece();
205 exit(cleanup(0));
206 }
207
208
209 static void
210 dolock( /* lock or unlock a file */
211 int fd,
212 int ltyp
213 )
214 {
215 static struct flock fls; /* static so initialized to zeroes */
216
217 fls.l_type = ltyp;
218 if (fcntl(fd, F_SETLKW, &fls) < 0) {
219 fprintf(stderr, "%s: cannot lock/unlock file: %s\n",
220 progname, strerror(errno));
221 exit(1);
222 }
223 }
224
225
226 static void
227 init( /* set up output file and start rpict */
228 int ac,
229 char **av
230 )
231 {
232 static char hrbuf[16], vrbuf[16];
233 extern char VersionID[];
234 char *err;
235 FILE *fp;
236 int hr, vr;
237 SUBPROC rpd; /* since we don't close_process(), this can be local */
238 /* set up view */
239 if ((err = setview(&ourview)) != NULL) {
240 fprintf(stderr, "%s: %s\n", progname, err);
241 exit(1);
242 }
243 if (syncfp != NULL) {
244 sflock(F_RDLCK);
245 fscanf(syncfp, "%d %d", &hmult, &vmult);
246 sflock(F_UNLCK);
247 }
248 /* compute piece size */
249 hres /= hmult;
250 vres /= vmult;
251 normaspect(viewaspect(&ourview)*hmult/vmult, &pixaspect, &hres, &vres);
252 sprintf(hrbuf, "%d", hres);
253 rpargv[rpargc++] = "-x"; rpargv[rpargc++] = hrbuf;
254 sprintf(vrbuf, "%d", vres);
255 rpargv[rpargc++] = "-y"; rpargv[rpargc++] = vrbuf;
256 rpargv[rpargc++] = "-pa"; rpargv[rpargc++] = "0";
257 rpargv[rpargc++] = av[ac-1];
258 rpargv[rpargc] = NULL;
259 /* open output file */
260 if ((outfd = open(outfile, O_WRONLY|O_CREAT|O_EXCL, 0666)) >= 0) {
261 dolock(outfd, F_WRLCK);
262 if ((fp = fdopen(dup(outfd), "w")) == NULL)
263 goto filerr;
264 newheader("RADIANCE", fp); /* create header */
265 printargs(ac, av, fp);
266 fprintf(fp, "SOFTWARE= %s\n", VersionID);
267 fputs(VIEWSTR, fp);
268 fprintview(&ourview, fp);
269 putc('\n', fp);
270 if (pixaspect < .99 || pixaspect > 1.01)
271 fputaspect(pixaspect, fp);
272 fputformat(COLRFMT, fp);
273 putc('\n', fp);
274 fprtresolu(hres*hmult, vres*vmult, fp);
275 } else if ((outfd = open(outfile, O_RDWR)) >= 0) {
276 dolock(outfd, F_RDLCK);
277 if ((fp = fdopen(dup(outfd), "r+")) == NULL)
278 goto filerr;
279 getheader(fp, NULL, NULL); /* skip header */
280 if (!fscnresolu(&hr, &vr, fp) || /* check resolution */
281 hr != hres*hmult || vr != vres*vmult) {
282 fprintf(stderr, "%s: resolution mismatch on file \"%s\"\n",
283 progname, outfile);
284 exit(1);
285 }
286 } else {
287 fprintf(stderr, "%s: cannot open file \"%s\"\n",
288 progname, outfile);
289 exit(1);
290 }
291 scanorig = ftell(fp); /* record position of first scanline */
292 if (fclose(fp) == -1) /* done with stream i/o */
293 goto filerr;
294 dolock(outfd, F_UNLCK);
295 /* start rpict process */
296 if (open_process(&rpd, rpargv) <= 0) {
297 fprintf(stderr, "%s: cannot start %s\n", progname, rpargv[0]);
298 exit(1);
299 }
300 if ((fromrp = fdopen(rpd.r, "r")) == NULL ||
301 (torp = fdopen(rpd.w, "w")) == NULL) {
302 fprintf(stderr, "%s: cannot open stream to %s\n",
303 progname, rpargv[0]);
304 exit(1);
305 }
306 if ((pbuf = (COLR *)bmalloc(hres*vres*sizeof(COLR))) == NULL) {
307 fprintf(stderr, "%s: out of memory\n", progname);
308 exit(1);
309 }
310 signal(SIGALRM, onalrm);
311 if (timelim)
312 alarm(timelim);
313 return;
314 filerr:
315 fprintf(stderr, "%s: i/o error on file \"%s\"\n", progname, outfile);
316 exit(1);
317 }
318
319
320 static int
321 nextpiece( /* get next piece assignment */
322 int *xp,
323 int *yp
324 )
325 {
326 if (gotalrm) /* someone wants us to quit */
327 return(0);
328 if (syncfp != NULL) { /* use sync file */
329 /*
330 * So we don't necessarily have to lock and unlock the file
331 * multiple times (very slow), we establish an exclusive
332 * lock at the beginning on our synchronization file and
333 * maintain it in the subroutine rvrpiece().
334 */
335 sflock(F_WRLCK);
336 fseek(syncfp, 0L, 0); /* read position */
337 if (fscanf(syncfp, "%*d %*d %d %d", xp, yp) < 2) {
338 *xp = hmult-1;
339 *yp = vmult;
340 }
341 if (rvrlim == 0) /* initialize recovery limit */
342 rvrlim = *xp*vmult + *yp;
343 if (rvrpiece(xp, yp)) { /* do stragglers first */
344 sflock(F_UNLCK);
345 return(1);
346 }
347 if (--(*yp) < 0) { /* decrement position */
348 *yp = vmult-1;
349 if (--(*xp) < 0) { /* all done */
350 sflock(F_UNLCK);
351 return(0);
352 }
353 }
354 fseek(syncfp, 0L, 0); /* write new position */
355 fprintf(syncfp, "%4d %4d\n%4d %4d\n\n", hmult, vmult, *xp, *yp);
356 fflush(syncfp);
357 sflock(F_UNLCK); /* release sync file */
358 return(1);
359 }
360 return(scanf("%d %d", xp, yp) == 2); /* use stdin */
361 }
362
363
364 static int
365 rvrpiece( /* check for recoverable pieces */
366 register int *xp,
367 register int *yp
368 )
369 {
370 static char *pdone = NULL; /* which pieces are done */
371 static long readpos = -1; /* how far we've read */
372 register int i;
373 /*
374 * This routine is called by nextpiece() with an
375 * exclusive lock on syncfp and the file pointer at the
376 * appropriate position to read in the finished pieces.
377 */
378 if (rvrlim < 0)
379 return(0); /* only check if asked */
380 if (pdone == NULL) /* first call */
381 pdone = calloc(hmult*vmult, sizeof(char));
382 if (pdone == NULL) {
383 fprintf(stderr, "%s: out of memory\n", progname);
384 exit(1);
385 }
386 if (readpos != -1) /* mark what's been done */
387 fseek(syncfp, readpos, 0);
388 while (fscanf(syncfp, "%d %d", xp, yp) == 2)
389 pdone[*xp*vmult+*yp] = 1;
390 if (!feof(syncfp)) {
391 fprintf(stderr, "%s: format error in sync file\n", progname);
392 exit(1);
393 }
394 readpos = ftell(syncfp);
395 i = hmult*vmult; /* find an unaccounted for piece */
396 while (i-- > rvrlim)
397 if (!pdone[i]) {
398 *xp = i / vmult;
399 *yp = i % vmult;
400 pdone[i] = 1; /* consider it done */
401 return(1);
402 }
403 rvrlim = -1; /* nothing left to recover */
404 free(pdone);
405 pdone = NULL;
406 return(0);
407 }
408
409
410 static int
411 cleanup( /* close rpict process and clean up */
412 int rstat
413 )
414 {
415 int status;
416
417 bfree((char *)pbuf, hres*vres*sizeof(COLR));
418 fclose(torp);
419 fclose(fromrp);
420 while (wait(&status) != -1)
421 if (rstat == 0)
422 rstat = status>>8 & 0xff;
423 return(rstat);
424 }
425
426
427 static void
428 rpiece(void) /* render picture piece by piece */
429 {
430 VIEW pview;
431 int xorg, yorg;
432 /* compute view parameters */
433 pview = ourview;
434 switch (ourview.type) {
435 case VT_PER:
436 pview.horiz = 2.*180./PI*atan(
437 tan(PI/180./2.*ourview.horiz)/hmult );
438 pview.vert = 2.*180./PI*atan(
439 tan(PI/180./2.*ourview.vert)/vmult );
440 break;
441 case VT_PAR:
442 case VT_ANG:
443 pview.horiz = ourview.horiz / hmult;
444 pview.vert = ourview.vert / vmult;
445 break;
446 case VT_CYL:
447 pview.horiz = ourview.horiz / hmult;
448 pview.vert = 2.*180./PI*atan(
449 tan(PI/180./2.*ourview.vert)/vmult );
450 break;
451 case VT_HEM:
452 pview.horiz = 2.*180./PI*asin(
453 sin(PI/180./2.*ourview.horiz)/hmult );
454 pview.vert = 2.*180./PI*asin(
455 sin(PI/180./2.*ourview.vert)/vmult );
456 break;
457 default:
458 fprintf(stderr, "%s: unknown view type '-vt%c'\n",
459 progname, ourview.type);
460 exit(cleanup(1));
461 }
462 /* render each piece */
463 while (nextpiece(&xorg, &yorg)) {
464 pview.hoff = ourview.hoff*hmult + xorg - 0.5*(hmult-1);
465 pview.voff = ourview.voff*vmult + yorg - 0.5*(vmult-1);
466 fputs(VIEWSTR, torp);
467 fprintview(&pview, torp);
468 putc('\n', torp);
469 fflush(torp); /* assigns piece to rpict */
470 putpiece(xorg, yorg); /* place piece in output */
471 }
472 }
473
474
475 static int
476 putpiece( /* get next piece from rpict */
477 int xpos,
478 int ypos
479 )
480 {
481 struct flock fls;
482 int pid, status;
483 int hr, vr;
484 register int y;
485 /* check bounds */
486 if ((xpos < 0) | (ypos < 0) | (xpos >= hmult) | (ypos >= vmult)) {
487 fprintf(stderr, "%s: requested piece (%d,%d) out of range\n",
488 progname, xpos, ypos);
489 exit(cleanup(1));
490 }
491 /* check header from rpict */
492 guard_io();
493 getheader(fromrp, NULL, NULL);
494 if (!fscnresolu(&hr, &vr, fromrp) || (hr != hres) | (vr != vres)) {
495 fprintf(stderr, "%s: resolution mismatch from %s\n",
496 progname, rpargv[0]);
497 exit(cleanup(1));
498 }
499 if (verbose) { /* notify caller */
500 printf("%d %d begun\n", xpos, ypos);
501 fflush(stdout);
502 }
503 unguard();
504 /* load new piece into buffer */
505 for (y = 0; y < vr; y++) {
506 guard_io();
507 if (freadcolrs(pbuf+y*hr, hr, fromrp) < 0) {
508 fprintf(stderr, "%s: read error from %s\n",
509 progname, rpargv[0]);
510 exit(cleanup(1));
511 }
512 unguard();
513 }
514 #if MAXFORK
515 /* fork so we don't slow rpict down */
516 if ((pid = fork()) > 0) {
517 if (++nforked >= MAXFORK) {
518 wait(&status); /* reap a child */
519 if (status)
520 exit(cleanup(status>>8 & 0xff));
521 nforked--;
522 }
523 return(pid);
524 }
525 #else
526 pid = -1; /* no forking */
527 #endif
528 fls.l_start = scanorig +
529 ((long)(vmult-1-ypos)*vres*hmult+xpos)*hres*sizeof(COLR);
530 #if NFS
531 fls.l_len = ((long)(vres-1)*hmult+1)*hres*sizeof(COLR);
532 /* lock file section so NFS doesn't mess up */
533 fls.l_whence = 0;
534 fls.l_type = F_WRLCK;
535 if (fcntl(outfd, F_SETLKW, &fls) < 0)
536 filerr("lock");
537 #endif
538 /* write new piece to file */
539 if (lseek(outfd, (off_t)fls.l_start, SEEK_SET) < 0)
540 filerr("seek");
541 if (hmult == 1) {
542 if (writebuf(outfd, (char *)pbuf,
543 vr*hr*sizeof(COLR)) != vr*hr*sizeof(COLR))
544 filerr("write");
545 } else
546 for (y = 0; y < vr; y++) {
547 if (writebuf(outfd, (char *)(pbuf+y*hr),
548 hr*sizeof(COLR)) != hr*sizeof(COLR))
549 filerr("write");
550 if (y < vr-1 && lseek(outfd,
551 (off_t)(hmult-1)*hr*sizeof(COLR),
552 SEEK_CUR) < 0)
553 filerr("seek");
554 }
555 #if NFS
556 fls.l_type = F_UNLCK; /* release lock */
557 if (fcntl(outfd, F_SETLKW, &fls) < 0)
558 filerr("lock");
559 #endif
560 if (verbose) { /* notify caller */
561 printf("%d %d done\n", xpos, ypos);
562 fflush(stdout);
563 }
564 if (syncfp != NULL) { /* record what's been done */
565 sflock(F_WRLCK);
566 fseek(syncfp, 0L, 2); /* append index */
567 fprintf(syncfp, "%4d %4d\n", xpos, ypos);
568 fflush(syncfp);
569 /*** Unlock not necessary, since
570 sflock(F_UNLCK); _exit() or nextpiece() is next ***/
571 }
572 if (pid == -1) /* didn't fork or fork failed */
573 return(0);
574 _exit(0); /* else exit child process (releasing locks) */
575 }
576
577
578 static void
579 filerr( /* report file error and exit */
580 char *t
581 )
582 {
583 fprintf(stderr, "%s: %s error on file \"%s\": %s\n",
584 progname, t, outfile, strerror(errno));
585 _exit(1);
586 }
587
588 #endif
