root/radiance/ray/src/util/rpiece.c
Revision: 2.22
Committed: Wed Aug 4 10:08:47 1993 UTC (32 years ago) by greg
Changes since 2.21: +7 -0 lines
added option expansion
1 /* Copyright (c) 1993 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Generate sections of a picture.
9 */
10
11 #include "standard.h"
12 #include <fcntl.h>
13
14 #ifndef F_SETLKW
15
16 main(argc, argv)
17 int argc;
18 char *argv[];
19 {
20 fprintf(stderr, "%s: no NFS lock manager on this machine\n", argv[0]);
21 exit(1);
22 }
23
24 #else
25
26 #include <signal.h>
27 #include "color.h"
28 #include "view.h"
29 #include "resolu.h"
30
31 #ifndef NFS
32 #define NFS 1
33 #endif
34 /* set the following to 0 to forgo forking */
35 #ifndef MAXFORK
36 #if NFS
37 #define MAXFORK 3 /* allotment of duped processes */
38 #else
39 #define MAXFORK 0
40 #endif
41 #endif
42 /* protection from SYSV signals(!) */
43 #if defined(sgi) || defined(hpux)
44 #define guard_io() sighold(SIGALRM)
45 #define unguard() sigrelse(SIGALRM)
46 #endif
47 #ifndef guard_io
48 #define guard_io() 0
49 #define unguard() 0
50 #endif
51 /* rpict command */
52 char *rpargv[128] = {"rpict", "-S", "1", "-x", "512", "-y", "512", "-pa", "1"};
53 int rpargc = 9;
54 int rpd[3];
55 FILE *torp, *fromrp;
56 COLR *pbuf;
57 /* our view parameters */
58 VIEW ourview = STDVIEW;
59 double pixaspect = 1.0;
60 int hres = 512, vres = 512, hmult = 2, vmult = 2;
61 /* output file */
62 char *outfile = NULL;
63 int outfd;
64 long scanorig;
65 int syncfd = -1; /* lock file descriptor */
66 int nforked = 0;
67
68 char *progname;
69 int verbose = 0;
70
71 extern long lseek(), ftell();
72
73 int gotalrm = 0;
74 int onalrm() { gotalrm++; }
75
76
77 main(argc, argv)
78 int argc;
79 char *argv[];
80 {
81 register int i, rval;
82
83 progname = argv[0];
84 for (i = 1; i < argc; i++) {
85 /* expand arguments */
86 while (rval = expandarg(&argc, &argv, i))
87 if (rval < 0) {
88 fprintf(stderr, "%s: cannot expand '%s'",
89 argv[0], argv[i]);
90 exit(1);
91 }
92 if (argv[i][0] == '-')
93 switch (argv[i][1]) {
94 case 'v':
95 switch (argv[i][2]) {
96 case '\0': /* verbose option */
97 verbose = !verbose;
98 continue;
99 case 'f': /* view file */
100 if (viewfile(argv[++i], &ourview, NULL) <= 0) {
101 fprintf(stderr,
102 "%s: not a view file\n", argv[i]);
103 exit(1);
104 }
105 continue;
106 default: /* view option? */
107 rval = getviewopt(&ourview, argc-i, argv+i);
108 if (rval >= 0) {
109 i += rval;
110 continue;
111 }
112 break;
113 }
114 break;
115 case 'p': /* pixel aspect ratio? */
116 if (argv[i][2] == 'a' && !argv[i][3])
117 pixaspect = atof(argv[i+1]);
118 break;
119 case 'x': /* piece x resolution */
120 if (!argv[i][2])
121 hres = atoi(argv[i+1]);
122 break;
123 case 'y': /* piece y resolution */
124 if (!argv[i][2])
125 vres = atoi(argv[i+1]);
126 break;
127 case 'X': /* horizontal multiplier */
128 if (argv[i][2])
129 break;
130 hmult = atoi(argv[++i]);
131 continue;
132 case 'Y': /* vertical multiplier */
133 if (argv[i][2])
134 break;
135 vmult = atoi(argv[++i]);
136 continue;
137 case 'F': /* syncronization file */
138 if (argv[i][2])
139 break;
140 if ((syncfd = open(argv[++i],
141 O_RDWR|O_CREAT, 0666)) < 0) {
142 fprintf(stderr, "%s: cannot open\n",
143 argv[i]);
144 exit(1);
145 }
146 continue;
147 case 'z': /* z-file ist verbotten */
148 fprintf(stderr, "%s: -z option not allowed\n",
149 argv[0]);
150 exit(1);
151 case 'o': /* output file */
152 if (argv[i][2])
153 break;
154 outfile = argv[++i];
155 continue;
156 }
157 rpargv[rpargc++] = argv[i];
158 }
159 rpargv[rpargc] = NULL;
160 if (outfile == NULL) {
161 fprintf(stderr, "%s: missing output file\n", argv[0]);
162 exit(1);
163 }
164 init(argc, argv);
165 rpiece();
166 exit(cleanup(0));
167 }
168
169
170 init(ac, av) /* set up output file and start rpict */
171 int ac;
172 char **av;
173 {
174 extern char VersionID[];
175 char *err;
176 FILE *fp;
177 int hr, vr;
178 /* set up view */
179 if ((err = setview(&ourview)) != NULL) {
180 fprintf(stderr, "%s: %s\n", progname, err);
181 exit(1);
182 }
183 if (syncfd != -1) {
184 char buf[32];
185 buf[read(syncfd, buf, sizeof(buf)-1)] = '\0';
186 sscanf(buf, "%d %d", &hmult, &vmult);
187 }
188 normaspect(viewaspect(&ourview)*hmult/vmult, &pixaspect, &hres, &vres);
189 /* open output file */
190 if ((outfd = open(outfile, O_WRONLY|O_CREAT|O_EXCL, 0666)) >= 0) {
191 if ((fp = fdopen(dup(outfd), "w")) == NULL)
192 goto filerr;
193 printargs(ac, av, fp); /* write header */
194 fprintf(fp, "SOFTWARE= %s\n", VersionID);
195 fputs(VIEWSTR, fp);
196 fprintview(&ourview, fp);
197 putc('\n', fp);
198 if (pixaspect < .99 || pixaspect > 1.01)
199 fputaspect(pixaspect, fp);
200 fputformat(COLRFMT, fp);
201 putc('\n', fp);
202 fprtresolu(hres*hmult, vres*vmult, fp);
203 } else if ((outfd = open(outfile, O_RDWR)) >= 0) {
204 if ((fp = fdopen(dup(outfd), "r+")) == NULL)
205 goto filerr;
206 getheader(fp, NULL, NULL); /* skip header */
207 if (!fscnresolu(&hr, &vr, fp) || /* check resolution */
208 hr != hres*hmult || vr != vres*vmult) {
209 fprintf(stderr, "%s: resolution mismatch on file \"%s\"\n",
210 progname, outfile);
211 exit(1);
212 }
213 } else {
214 fprintf(stderr, "%s: cannot open file \"%s\"\n",
215 progname, outfile);
216 exit(1);
217 }
218 scanorig = ftell(fp); /* record position of first scanline */
219 if (fclose(fp) == -1) /* done with stream i/o */
220 goto filerr;
221 #if NFS
222 sync(); /* flush NFS buffers */
223 #endif
224 /* start rpict process */
225 if (open_process(rpd, rpargv) <= 0) {
226 fprintf(stderr, "%s: cannot start %s\n", progname, rpargv[0]);
227 exit(1);
228 }
229 if ((fromrp = fdopen(rpd[0], "r")) == NULL ||
230 (torp = fdopen(rpd[1], "w")) == NULL) {
231 fprintf(stderr, "%s: cannot open stream to %s\n",
232 progname, rpargv[0]);
233 exit(1);
234 }
235 if ((pbuf = (COLR *)malloc(hres*vres*sizeof(COLR))) == NULL) {
236 fprintf(stderr, "%s: out of memory\n", progname);
237 exit(1);
238 }
239 signal(SIGALRM, onalrm);
240 return;
241 filerr:
242 fprintf(stderr, "%s: i/o error on file \"%s\"\n", progname, outfile);
243 exit(1);
244 }
245
246
247 int
248 nextpiece(xp, yp) /* get next piece assignment */
249 int *xp, *yp;
250 {
251 struct flock fls;
252 char buf[64];
253
254 if (gotalrm) /* someone wants us to quit */
255 return(0);
256 if (syncfd != -1) { /* use sync file */
257 fls.l_type = F_WRLCK; /* gain exclusive access */
258 fls.l_whence = 0;
259 fls.l_start = 0L;
260 fls.l_len = 0L;
261 fcntl(syncfd, F_SETLKW, &fls);
262 lseek(syncfd, 0L, 0);
263 buf[read(syncfd, buf, sizeof(buf)-1)] = '\0';
264 if (sscanf(buf, "%*d %*d %d %d", xp, yp) < 2) {
265 *xp = hmult-1;
266 *yp = vmult;
267 }
268 if (--(*yp) < 0) { /* decrement position */
269 *yp = vmult-1;
270 if (--(*xp) < 0) { /* all done! */
271 close(syncfd);
272 return(0);
273 }
274 }
275 sprintf(buf, "%4d %4d\n%4d %4d\n", hmult, vmult, *xp, *yp);
276 lseek(syncfd, 0L, 0); /* write new position */
277 write(syncfd, buf, strlen(buf));
278 fls.l_type = F_UNLCK; /* release sync file */
279 fcntl(syncfd, F_SETLKW, &fls);
280 return(1);
281 }
282 if (fgets(buf, sizeof(buf), stdin) == NULL) /* use stdin */
283 return(0);
284 if (sscanf(buf, "%d %d", xp, yp) == 2)
285 return(1);
286 fprintf(stderr, "%s: input format error\n", progname);
287 exit(cleanup(1));
288 }
289
290
291 int
292 cleanup(rstat) /* close rpict process and clean up */
293 int rstat;
294 {
295 int status;
296
297 free((char *)pbuf);
298 fclose(torp);
299 fclose(fromrp);
300 while (wait(&status) != -1)
301 if (rstat == 0)
302 rstat = status>>8 & 0xff;
303 return(rstat);
304 }
305
306
307 rpiece() /* render picture piece by piece */
308 {
309 VIEW pview;
310 int xorg, yorg;
311 /* compute view parameters */
312 copystruct(&pview, &ourview);
313 switch (ourview.type) {
314 case VT_PER:
315 pview.horiz = 2.*180./PI*atan(
316 tan(PI/180./2.*ourview.horiz)/hmult );
317 pview.vert = 2.*180./PI*atan(
318 tan(PI/180./2.*ourview.vert)/vmult );
319 break;
320 case VT_PAR:
321 case VT_ANG:
322 pview.horiz = ourview.horiz / hmult;
323 pview.vert = ourview.vert / vmult;
324 break;
325 case VT_HEM:
326 pview.horiz = 2.*180./PI*asin(
327 sin(PI/180./2.*ourview.horiz)/hmult );
328 pview.vert = 2.*180./PI*asin(
329 sin(PI/180./2.*ourview.vert)/vmult );
330 break;
331 default:
332 fprintf(stderr, "%s: unknown view type '-vt%c'\n",
333 progname, ourview.type);
334 exit(cleanup(1));
335 }
336 /* render each piece */
337 while (nextpiece(&xorg, &yorg)) {
338 pview.hoff = ourview.hoff + xorg - 0.5*(hmult-1);
339 pview.voff = ourview.voff + yorg - 0.5*(vmult-1);
340 fputs(VIEWSTR, torp);
341 fprintview(&pview, torp);
342 putc('\n', torp);
343 fflush(torp); /* assigns piece to rpict */
344 putpiece(xorg, yorg); /* place piece in output */
345 }
346 }
347
348
349 int
350 putpiece(xpos, ypos) /* get next piece from rpict */
351 int xpos, ypos;
352 {
353 struct flock fls;
354 int pid, status;
355 int hr, vr;
356 register int y;
357 /* check bounds */
358 if (xpos < 0 | ypos < 0 | xpos >= hmult | ypos >= vmult) {
359 fprintf(stderr, "%s: requested piece (%d,%d) out of range\n",
360 progname, xpos, ypos);
361 exit(cleanup(1));
362 }
363 /* check header from rpict */
364 guard_io();
365 getheader(fromrp, NULL, NULL);
366 if (!fscnresolu(&hr, &vr, fromrp) || hr != hres | vr != vres) {
367 fprintf(stderr, "%s: resolution mismatch from %s\n",
368 progname, rpargv[0]);
369 exit(cleanup(1));
370 }
371 unguard();
372 /* load new piece into buffer */
373 for (y = 0; y < vr; y++) {
374 guard_io();
375 if (freadcolrs(pbuf+y*hr, hr, fromrp) < 0) {
376 fprintf(stderr, "%s: read error from %s\n",
377 progname, rpargv[0]);
378 exit(cleanup(1));
379 }
380 unguard();
381 }
382 #if MAXFORK
383 /* fork so we don't slow rpict down */
384 if ((pid = fork()) > 0) {
385 if (++nforked >= MAXFORK) {
386 wait(&status); /* reap a child */
387 if (status)
388 exit(cleanup(status>>8 & 0xff));
389 nforked--;
390 }
391 return(pid);
392 }
393 #else
394 pid = -1; /* no forking */
395 #endif
396 fls.l_start = scanorig +
397 ((long)(vmult-1-ypos)*vres*hmult+xpos)*hres*sizeof(COLR);
398 #if NFS
399 fls.l_len = ((long)(vres-1)*hmult+1)*hres*sizeof(COLR);
400 /* lock file section so NFS doesn't mess up */
401 fls.l_whence = 0;
402 fls.l_type = F_WRLCK;
403 fcntl(outfd, F_SETLKW, &fls);
404 #endif
405 /* write new piece to file */
406 if (lseek(outfd, fls.l_start, 0) == -1)
407 goto seekerr;
408 if (hmult == 1) {
409 if (writebuf(outfd, (char *)pbuf,
410 vr*hr*sizeof(COLR)) != vr*hr*sizeof(COLR))
411 goto writerr;
412 } else
413 for (y = 0; y < vr; y++) {
414 if (writebuf(outfd, (char *)(pbuf+y*hr),
415 hr*sizeof(COLR)) != hr*sizeof(COLR))
416 goto writerr;
417 if (y < vr-1 && lseek(outfd,
418 (long)(hmult-1)*hr*sizeof(COLR),
419 1) == -1)
420 goto seekerr;
421 }
422 if (verbose) { /* notify caller */
423 printf("%d %d done\n", xpos, ypos);
424 fflush(stdout);
425 }
426 if (pid == -1) { /* didn't fork or fork failed */
427 #if NFS
428 fls.l_type = F_UNLCK; /* release lock */
429 fcntl(outfd, F_SETLKW, &fls);
430 #endif
431 return(0);
432 }
433 _exit(0); /* else exit child process (releasing lock) */
434 seekerr:
435 fprintf(stderr, "%s: seek error on file \"%s\"\n", progname, outfile);
436 _exit(1);
437 writerr:
438 fprintf(stderr, "%s: write error on file \"%s\"\n", progname, outfile);
439 _exit(1);
440 }
441
442 #endif
