--- ray/src/util/rpiece.c 1998/06/18 09:23:49 2.36 +++ ray/src/util/rpiece.c 2009/02/07 05:40:47 2.50 @@ -1,20 +1,32 @@ -/* Copyright (c) 1995 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: rpiece.c,v 2.50 2009/02/07 05:40:47 greg Exp $"; #endif - /* * Generate sections of a picture. */ + +#include +#include +#include + +#include "platform.h" +#ifndef NON_POSIX /* XXX need abstraction for process management */ + #include +#endif + #include "standard.h" +#include "color.h" +#include "view.h" +#include "rtprocess.h" #ifndef F_SETLKW -main(argc, argv) -int argc; -char *argv[]; +int +main( + int argc, + char *argv[] +) { fprintf(stderr, "%s: no NFS lock manager on this machine\n", argv[0]); exit(1); @@ -22,11 +34,6 @@ char *argv[]; #else -#include -#include "color.h" -#include "view.h" -#include "resolu.h" - #ifndef NFS #define NFS 1 #endif @@ -44,18 +51,15 @@ char *argv[]; #define unguard() sigrelse(SIGALRM) #endif #ifndef guard_io -#define guard_io() 0 -#define unguard() 0 +#define guard_io() +#define unguard() #endif -#ifndef linux -extern char *sys_errlist[]; -#endif +extern char *strerror(); /* rpict command */ char *rpargv[128] = {"rpict", "-S", "1"}; int rpargc = 3; -int rpd[3]; FILE *torp, *fromrp; COLR *pbuf; /* our view parameters */ @@ -78,24 +82,36 @@ unsigned timelim = 0; int rvrlim = -1; int gotalrm = 0; -int onalrm() { gotalrm++; } +void onalrm(int i) { gotalrm++; } +static void dolock(int fd, int ltyp); +static void init(int ac, char **av); +static int nextpiece(int *xp, int *yp); +static int rvrpiece(int *xp, int *yp); +static int cleanup(int rstat); +static void rpiece(void); +static int putpiece(int xpos, int ypos); +static void filerr(char *t); -main(argc, argv) -int argc; -char *argv[]; + +int +main( + int argc, + char *argv[] +) { register int i, rval; progname = argv[0]; for (i = 1; i < argc; i++) { /* expand arguments */ - while (rval = expandarg(&argc, &argv, i)) - if (rval < 0) { - fprintf(stderr, "%s: cannot expand '%s'", - argv[0], argv[i]); - exit(1); - } + while ((rval = expandarg(&argc, &argv, i)) > 0) + ; + if (rval < 0) { + fprintf(stderr, "%s: cannot expand '%s'\n", + argv[0], argv[i]); + exit(1); + } if (argv[i][0] == '-') switch (argv[i][1]) { case 'v': @@ -191,30 +207,35 @@ char *argv[]; } -dolock(fd, ltyp) /* lock or unlock a file */ -int fd; -int ltyp; +static void +dolock( /* lock or unlock a file */ + int fd, + int ltyp +) { static struct flock fls; /* static so initialized to zeroes */ fls.l_type = ltyp; if (fcntl(fd, F_SETLKW, &fls) < 0) { fprintf(stderr, "%s: cannot lock/unlock file: %s\n", - progname, sys_errlist[errno]); + progname, strerror(errno)); exit(1); } } -init(ac, av) /* set up output file and start rpict */ -int ac; -char **av; +static void +init( /* set up output file and start rpict */ + int ac, + char **av +) { static char hrbuf[16], vrbuf[16]; extern char VersionID[]; char *err; FILE *fp; int hr, vr; + SUBPROC rpd; /* since we don't close_process(), this can be local */ /* set up view */ if ((err = setview(&ourview)) != NULL) { fprintf(stderr, "%s: %s\n", progname, err); @@ -228,6 +249,10 @@ char **av; /* compute piece size */ hres /= hmult; vres /= vmult; + if (hres <= 0 || vres <= 0) { + fprintf(stderr, "%s: illegal resolution/subdivision\n", progname); + exit(1); + } normaspect(viewaspect(&ourview)*hmult/vmult, &pixaspect, &hres, &vres); sprintf(hrbuf, "%d", hres); rpargv[rpargc++] = "-x"; rpargv[rpargc++] = hrbuf; @@ -273,12 +298,12 @@ char **av; goto filerr; dolock(outfd, F_UNLCK); /* start rpict process */ - if (open_process(rpd, rpargv) <= 0) { + if (open_process(&rpd, rpargv) <= 0) { fprintf(stderr, "%s: cannot start %s\n", progname, rpargv[0]); exit(1); } - if ((fromrp = fdopen(rpd[0], "r")) == NULL || - (torp = fdopen(rpd[1], "w")) == NULL) { + if ((fromrp = fdopen(rpd.r, "r")) == NULL || + (torp = fdopen(rpd.w, "w")) == NULL) { fprintf(stderr, "%s: cannot open stream to %s\n", progname, rpargv[0]); exit(1); @@ -297,9 +322,11 @@ filerr: } -int -nextpiece(xp, yp) /* get next piece assignment */ -int *xp, *yp; +static int +nextpiece( /* get next piece assignment */ + int *xp, + int *yp +) { if (gotalrm) /* someone wants us to quit */ return(0); @@ -339,9 +366,11 @@ int *xp, *yp; } -int -rvrpiece(xp, yp) /* check for recoverable pieces */ -register int *xp, *yp; +static int +rvrpiece( /* check for recoverable pieces */ + register int *xp, + register int *yp +) { static char *pdone = NULL; /* which pieces are done */ static long readpos = -1; /* how far we've read */ @@ -383,9 +412,10 @@ register int *xp, *yp; } -int -cleanup(rstat) /* close rpict process and clean up */ -int rstat; +static int +cleanup( /* close rpict process and clean up */ + int rstat +) { int status; @@ -399,18 +429,19 @@ int rstat; } -rpiece() /* render picture piece by piece */ +static void +rpiece(void) /* render picture piece by piece */ { VIEW pview; int xorg, yorg; /* compute view parameters */ - copystruct(&pview, &ourview); + pview = ourview; switch (ourview.type) { case VT_PER: - pview.horiz = 2.*180./PI*atan( - tan(PI/180./2.*ourview.horiz)/hmult ); - pview.vert = 2.*180./PI*atan( - tan(PI/180./2.*ourview.vert)/vmult ); + pview.horiz = (2.*180./PI)*atan( + tan((PI/180./2.)*ourview.horiz)/hmult ); + pview.vert = (2.*180./PI)*atan( + tan((PI/180./2.)*ourview.vert)/vmult ); break; case VT_PAR: case VT_ANG: @@ -419,15 +450,27 @@ rpiece() /* render picture piece by piece */ break; case VT_CYL: pview.horiz = ourview.horiz / hmult; - pview.vert = 2.*180./PI*atan( - tan(PI/180./2.*ourview.vert)/vmult ); + pview.vert = (2.*180./PI)*atan( + tan((PI/180./2.)*ourview.vert)/vmult ); break; case VT_HEM: - pview.horiz = 2.*180./PI*asin( - sin(PI/180./2.*ourview.horiz)/hmult ); - pview.vert = 2.*180./PI*asin( - sin(PI/180./2.*ourview.vert)/vmult ); + pview.horiz = (2.*180./PI)*asin( + sin((PI/180./2.)*ourview.horiz)/hmult ); + pview.vert = (2.*180./PI)*asin( + sin((PI/180./2.)*ourview.vert)/vmult ); break; + case VT_PLS: + pview.horiz = sin((PI/180./2.)*ourview.horiz) / + (1.0 + cos((PI/180./2.)*ourview.horiz)) / hmult; + pview.horiz *= pview.horiz; + pview.horiz = (2.*180./PI)*acos((1. - pview.horiz) / + (1. + pview.horiz)); + pview.vert = sin((PI/180./2.)*ourview.vert) / + (1.0 + cos((PI/180./2.)*ourview.vert)) / vmult; + pview.vert *= pview.vert; + pview.vert = (2.*180./PI)*acos((1. - pview.vert) / + (1. + pview.vert)); + break; default: fprintf(stderr, "%s: unknown view type '-vt%c'\n", progname, ourview.type); @@ -446,16 +489,18 @@ rpiece() /* render picture piece by piece */ } -int -putpiece(xpos, ypos) /* get next piece from rpict */ -int xpos, ypos; +static int +putpiece( /* get next piece from rpict */ +int xpos, +int ypos +) { struct flock fls; int pid, status; int hr, vr; register int y; /* check bounds */ - if (xpos < 0 | ypos < 0 | xpos >= hmult | ypos >= vmult) { + if ((xpos < 0) | (ypos < 0) | (xpos >= hmult) | (ypos >= vmult)) { fprintf(stderr, "%s: requested piece (%d,%d) out of range\n", progname, xpos, ypos); exit(cleanup(1)); @@ -463,7 +508,7 @@ int xpos, ypos; /* check header from rpict */ guard_io(); getheader(fromrp, NULL, NULL); - if (!fscnresolu(&hr, &vr, fromrp) || hr != hres | vr != vres) { + if (!fscnresolu(&hr, &vr, fromrp) || (hr != hres) | (vr != vres)) { fprintf(stderr, "%s: resolution mismatch from %s\n", progname, rpargv[0]); exit(cleanup(1)); @@ -508,7 +553,7 @@ int xpos, ypos; filerr("lock"); #endif /* write new piece to file */ - if (lseek(outfd, fls.l_start, 0) < 0) + if (lseek(outfd, (off_t)fls.l_start, SEEK_SET) < 0) filerr("seek"); if (hmult == 1) { if (writebuf(outfd, (char *)pbuf, @@ -520,8 +565,8 @@ int xpos, ypos; hr*sizeof(COLR)) != hr*sizeof(COLR)) filerr("write"); if (y < vr-1 && lseek(outfd, - (long)(hmult-1)*hr*sizeof(COLR), - 1) < 0) + (off_t)(hmult-1)*hr*sizeof(COLR), + SEEK_CUR) < 0) filerr("seek"); } #if NFS @@ -547,11 +592,13 @@ int xpos, ypos; } -filerr(t) /* report file error and exit */ -char *t; +static void +filerr( /* report file error and exit */ + char *t +) { fprintf(stderr, "%s: %s error on file \"%s\": %s\n", - progname, t, outfile, sys_errlist[errno]); + progname, t, outfile, strerror(errno)); _exit(1); }
