--- ray/src/util/rpiece.c 1992/08/06 17:16:29 2.2 +++ ray/src/util/rpiece.c 1992/08/08 18:47:39 2.7 @@ -10,31 +10,36 @@ static char SCCSid[] = "$SunId$ LBL"; #include "standard.h" #include +#include #include "color.h" #include "view.h" #include "resolu.h" /* rpict command */ -char *rpargv[128] = {"rpict", "-S", "1", "-x", "512", "-y", "512", }; -int rpargc = 7; +char *rpargv[128] = {"rpict", "-S", "1", "-x", "512", "-y", "512", "-pa", "1"}; +int rpargc = 9; int rpd[3]; FILE *torp, *fromrp; COLR *scanline; /* our view parameters */ VIEW ourview = STDVIEW; -double pixaspect = 0.0; +double pixaspect = 1.0; int hres = 512, vres = 512, hmult = 2, vmult = 2; /* output file */ char *outfile = NULL; int outfd; long scanorig; +int syncfd = -1; /* lock file descriptor */ char *progname; int verbose = 0; extern long lseek(), ftell(); +int gotalrm = 0; +int onalrm() { gotalrm++; } + main(argc, argv) int argc; char *argv[]; @@ -88,6 +93,15 @@ char *argv[]; break; vmult = atoi(argv[++i]); continue; + case 'F': /* syncronization file */ + if (argv[i][2]) + break; + if ((syncfd = open(argv[++i], O_RDWR)) < 0) { + fprintf(stderr, "%s: cannot open\n", + argv[i]); + exit(1); + } + continue; case 'o': /* output file */ if (argv[i][2]) break; @@ -121,6 +135,11 @@ char **av; fprintf(stderr, "%s: %s\n", progname, err); exit(1); } + if (syncfd != -1) { + char buf[32]; + buf[read(syncfd, buf, sizeof(buf)-1)] = '\0'; + sscanf(buf, "%d %d", &hmult, &vmult); + } normaspect(viewaspect(&ourview)*hmult/vmult, &pixaspect, &hres, &vres); /* open output file */ if ((outfd = open(outfile, O_WRONLY|O_CREAT|O_EXCL, 0666)) >= 0) { @@ -137,7 +156,6 @@ char **av; putc('\n', fp); fprtresolu(hres*hmult, vres*vmult, fp); } else if ((outfd = open(outfile, O_RDWR)) >= 0) { - sleep(30); /* wait for header */ if ((fp = fdopen(dup(outfd), "r+")) == NULL) goto filerr; getheader(fp, NULL); /* skip header */ @@ -156,7 +174,7 @@ char **av; goto filerr; /* start rpict process */ if (open_process(rpd, rpargv) <= 0) { - fprintf(stderr, "%s: cannot start\n", rpargv[0]); + fprintf(stderr, "%s: cannot start %s\n", progname, rpargv[0]); exit(1); } if ((fromrp = fdopen(rpd[0], "r")) == NULL || @@ -169,6 +187,7 @@ char **av; fprintf(stderr, "%s: out of memory\n", progname); exit(1); } + signal(SIGALRM, onalrm); return; filerr: fprintf(stderr, "%s: file i/o error\n", outfile); @@ -177,6 +196,51 @@ filerr: int +nextpiece(xp, yp) /* get next piece assignment */ +int *xp, *yp; +{ + extern char *fgets(); + struct flock fls; + char buf[64]; + + if (gotalrm) /* someone wants us to quit */ + return(0); + if (syncfd != -1) { /* use sync file */ + fls.l_type = F_WRLCK; /* gain exclusive access */ + fls.l_whence = 0; + fls.l_start = 0L; + fls.l_len = 0L; + fcntl(syncfd, F_SETLKW, &fls); + lseek(syncfd, 0L, 0); + buf[read(syncfd, buf, sizeof(buf)-1)] = '\0'; + if (sscanf(buf, "%*d %*d %d %d", xp, yp) < 2) { + *xp = hmult; + *yp = vmult-1; + } + if (--(*xp) < 0) { /* decrement position */ + *xp = hmult-1; + if (--(*yp) < 0) { /* all done! */ + close(syncfd); + return(0); + } + } + sprintf(buf, "%d %d\n%d %d\n", hmult, vmult, *xp, *yp); + lseek(syncfd, 0L, 0); /* write new position */ + write(syncfd, buf, strlen(buf)); + fls.l_type = F_UNLCK; /* release sync file */ + fcntl(syncfd, F_SETLKW, &fls); + return(1); + } + if (fgets(buf, sizeof(buf), stdin) == NULL) /* use stdin */ + return(0); + if (sscanf(buf, "%d %d", xp, yp) == 2) + return(1); + fprintf(stderr, "%s: input format error\n", progname); + exit(1); +} + + +int cleanup() /* close rpict process and clean up */ { register int rpstat; @@ -193,16 +257,10 @@ cleanup() /* close rpict process and clean up */ rpiece() /* render picture piece by piece */ { - extern char *gets(), *strcat(); VIEW pview; - char buf[48]; int xorg, yorg; - while (gets(buf) != NULL) { - if (sscanf(buf, "%d %d", &xorg, &yorg) != 2) { - fprintf(stderr, "%s: input format error\n", progname); - exit(1); - } + while (nextpiece(&xorg, &yorg)) { copystruct(&pview, &ourview); /* compute view for piece */ switch (ourview.type) { case VT_PER: @@ -217,6 +275,11 @@ rpiece() /* render picture piece by piece */ pview.vert = ourview.vert / vmult; break; case VT_HEM: + pview.horiz = 2.*180./PI*asin( + sin(PI/180./2.*ourview.horiz)/hmult ); + pview.vert = 2.*180./PI*asin( + sin(PI/180./2.*ourview.vert)/vmult ); + break; default: fprintf(stderr, "%s: unknown view type '-vt%c'\n", progname, ourview.type); @@ -230,8 +293,8 @@ rpiece() /* render picture piece by piece */ fflush(torp); /* assign piece to rpict */ putpiece(xorg, yorg); /* place piece in output */ if (verbose) { /* notify caller */ - strcat(buf, " done\n"); - writebuf(fileno(stdout), buf, strlen(buf)); + printf("%d %d done\n", xorg, yorg); + fflush(stdout); } } } @@ -240,20 +303,29 @@ rpiece() /* render picture piece by piece */ putpiece(xpos, ypos) /* get next piece from rpict */ int xpos, ypos; { + struct flock fls; int hr, vr; int y; + if (xpos < 0 | ypos < 0 | xpos >= hmult | ypos >= vmult) { + fprintf(stderr, "%s: requested piece (%d,%d) out of range\n", + progname, xpos, ypos); + exit(1); + } getheader(fromrp, NULL); /* discard header info. */ if (fscnresolu(&hr, &vr, fromrp) < 0 || /* check resolution */ hr != hres || vr != vres) { - fprintf(stderr, "%s: resolution mismatch from rpict\n", - progname); + fprintf(stderr, "%s: resolution mismatch from %s\n", + progname, rpargv[0]); exit(1); } + fls.l_whence = 1; + fls.l_start = 0L; + fls.l_len = hr*sizeof(COLR); for (y = 0; y < vr; y++) { /* transfer scanlines */ if (freadcolrs(scanline, hr, fromrp) < 0) { - fprintf(stderr, "%s: read error from rpict\n", - progname); + fprintf(stderr, "%s: read error from %s\n", + progname, rpargv[0]); exit(1); } if ((y == 0 || hmult != 1) && lseek(outfd, @@ -262,10 +334,14 @@ scanorig+((long)((vmult-1-ypos)*vres+y)*hmult*hres+xpo fprintf(stderr, "%s: seek error\n", outfile); exit(1); } + fls.l_type = F_WRLCK; + fcntl(outfd, F_SETLKW, &fls); if (writebuf(outfd, (char *)scanline, hr*sizeof(COLR)) != hr*sizeof(COLR)) { fprintf(stderr, "%s: write error\n", outfile); exit(1); } + fls.l_type = F_UNLCK; + fcntl(outfd, F_SETLKW, &fls); } }
