--- ray/src/util/rpiece.c 1992/08/07 11:34:27 2.6 +++ ray/src/util/rpiece.c 1992/08/09 18:09:46 2.10 @@ -15,12 +15,17 @@ static char SCCSid[] = "$SunId$ LBL"; #include "view.h" #include "resolu.h" + /* set the following to 0 to forgo forking */ +#ifndef MAXFORK +#define MAXFORK 3 /* allotment of duped processes */ +#endif + /* rpict command */ char *rpargv[128] = {"rpict", "-S", "1", "-x", "512", "-y", "512", "-pa", "1"}; int rpargc = 9; int rpd[3]; FILE *torp, *fromrp; -COLR *scanline; +COLR *pbuf; /* our view parameters */ VIEW ourview = STDVIEW; double pixaspect = 1.0; @@ -30,6 +35,7 @@ char *outfile = NULL; int outfd; long scanorig; int syncfd = -1; /* lock file descriptor */ +int nforked = 0; char *progname; int verbose = 0; @@ -117,7 +123,7 @@ char *argv[]; } init(argc, argv); rpiece(); - rval = cleanup(); + rval = cleanup(0); exit(rval); } @@ -161,18 +167,19 @@ char **av; getheader(fp, NULL); /* skip header */ if (fscnresolu(&hr, &vr, fp) < 0 || /* check resolution */ hr != hres*hmult || vr != vres*vmult) { - fprintf(stderr, "%s: picture resolution mismatch\n", - outfile); + fprintf(stderr, "%s: resolution mismatch on file \"%s\"\n", + progname, outfile); exit(1); } } else { - fprintf(stderr, "%s: cannot open\n", outfile); + fprintf(stderr, "%s: cannot open file \"%s\"\n", + progname, outfile); exit(1); } scanorig = ftell(fp); /* record position of first scanline */ if (fclose(fp) == -1) /* done with stream i/o */ goto filerr; - sync(); /* avoid NFS buffering */ + sync(); /* flush NFS buffers */ /* start rpict process */ if (open_process(rpd, rpargv) <= 0) { fprintf(stderr, "%s: cannot start %s\n", progname, rpargv[0]); @@ -184,14 +191,14 @@ char **av; progname, rpargv[0]); exit(1); } - if ((scanline = (COLR *)malloc(hres*sizeof(COLR))) == NULL) { + if ((pbuf = (COLR *)malloc(hres*vres*sizeof(COLR))) == NULL) { fprintf(stderr, "%s: out of memory\n", progname); exit(1); } signal(SIGALRM, onalrm); return; filerr: - fprintf(stderr, "%s: file i/o error\n", outfile); + fprintf(stderr, "%s: i/o error on file \"%s\"\n", progname, outfile); exit(1); } @@ -215,12 +222,12 @@ int *xp, *yp; lseek(syncfd, 0L, 0); buf[read(syncfd, buf, sizeof(buf)-1)] = '\0'; if (sscanf(buf, "%*d %*d %d %d", xp, yp) < 2) { - *xp = hmult; - *yp = vmult-1; - } - if (--(*xp) < 0) { /* decrement position */ *xp = hmult-1; - if (--(*yp) < 0) { /* all done! */ + *yp = vmult; + } + if (--(*yp) < 0) { /* decrement position */ + *yp = vmult-1; + if (--(*xp) < 0) { /* all done! */ close(syncfd); return(0); } @@ -237,22 +244,23 @@ int *xp, *yp; if (sscanf(buf, "%d %d", xp, yp) == 2) return(1); fprintf(stderr, "%s: input format error\n", progname); - exit(1); + exit(cleanup(1)); } int -cleanup() /* close rpict process and clean up */ +cleanup(rstat) /* close rpict process and clean up */ +int rstat; { - register int rpstat; + int status; - free((char *)scanline); + free((char *)pbuf); fclose(torp); fclose(fromrp); - rpstat = close_process(rpd); - if (rpstat == -1) - rpstat = 0; - return(rpstat); + while (wait(&status) != -1) + if (rstat == 0) + rstat = status>>8 & 0xff; + return(rstat); } @@ -284,7 +292,7 @@ rpiece() /* render picture piece by piece */ default: fprintf(stderr, "%s: unknown view type '-vt%c'\n", progname, ourview.type); - exit(1); + exit(cleanup(1)); } pview.hoff += xorg - 0.5*(hmult-1); pview.voff += yorg - 0.5*(vmult-1); @@ -301,40 +309,81 @@ rpiece() /* render picture piece by piece */ } +int putpiece(xpos, ypos) /* get next piece from rpict */ int xpos, ypos; { + struct flock fls; + int pid, status; int hr, vr; - int y; - + register int y; + /* check bounds */ if (xpos < 0 | ypos < 0 | xpos >= hmult | ypos >= vmult) { fprintf(stderr, "%s: requested piece (%d,%d) out of range\n", progname, xpos, ypos); - exit(1); + exit(cleanup(1)); } - getheader(fromrp, NULL); /* discard header info. */ - if (fscnresolu(&hr, &vr, fromrp) < 0 || /* check resolution */ - hr != hres || vr != vres) { + /* check header from rpict */ + getheader(fromrp, NULL); + if (fscnresolu(&hr, &vr, fromrp) < 0 || hr != hres || vr != vres) { fprintf(stderr, "%s: resolution mismatch from %s\n", progname, rpargv[0]); - exit(1); + exit(cleanup(1)); } - for (y = 0; y < vr; y++) { /* transfer scanlines */ - if (freadcolrs(scanline, hr, fromrp) < 0) { + /* load new piece into buffer */ + for (y = 0; y < vr; y++) + if (freadcolrs(pbuf+y*hr, hr, fromrp) < 0) { fprintf(stderr, "%s: read error from %s\n", progname, rpargv[0]); - exit(1); + exit(cleanup(1)); } - if ((y == 0 || hmult != 1) && lseek(outfd, -scanorig+((long)((vmult-1-ypos)*vres+y)*hmult*hres+xpos*hres)*sizeof(COLR), - 0) == -1) { - fprintf(stderr, "%s: seek error\n", outfile); - exit(1); +#if MAXFORK + /* fork so we don't slow rpict down */ + if ((pid = fork()) > 0) { + if (++nforked >= MAXFORK) { + wait(&status); /* reap a child */ + if (status) + exit(cleanup(status>>8 & 0xff)); + nforked--; } - if (writebuf(outfd, (char *)scanline, hr*sizeof(COLR)) != - hr*sizeof(COLR)) { - fprintf(stderr, "%s: write error\n", outfile); - exit(1); + return(pid); + } +#else + pid = -1; /* no forking */ +#endif + /* lock file section so NFS doesn't mess up */ + fls.l_whence = 0; + fls.l_len = (long)vres*hmult*hres*sizeof(COLR); + fls.l_start = scanorig + (vmult-1-ypos)*fls.l_len; + fls.l_type = F_WRLCK; + fcntl(outfd, F_SETLKW, &fls); + /* write new piece to file */ + if (lseek(outfd, fls.l_start+(long)xpos*hres*sizeof(COLR), 0) == -1) + goto seekerr; + if (hmult == 1) { + if (writebuf(outfd, (char *)pbuf, + vr*hr*sizeof(COLR)) != vr*hr*sizeof(COLR)) + goto writerr; + } else + for (y = 0; y < vr; y++) { + if (writebuf(outfd, (char *)(pbuf+y*hr), + hr*sizeof(COLR)) != hr*sizeof(COLR)) + goto writerr; + if (y < vr-1 && lseek(outfd, + (long)(hmult-1)*hr*sizeof(COLR), + 1) == -1) + goto seekerr; } + if (pid == -1) { /* fork failed */ + fls.l_type = F_UNLCK; /* release lock */ + fcntl(outfd, F_SETLKW, &fls); + return(0); } + _exit(0); /* else exit child process (releasing lock) */ +seekerr: + fprintf(stderr, "%s: seek error on file \"%s\"\n", progname, outfile); + _exit(1); +writerr: + fprintf(stderr, "%s: write error on file \"%s\"\n", progname, outfile); + _exit(1); }
