root/radiance/ray/src/util/rpiece.c
Fri Feb 28 05:18:49 2020 UTC (4 years, 2 months ago) by greg
Changes since 2.57: +2 -1 lines
Diff to previous 2.57 , to selected 2.52
Tue Aug 21 17:46:09 2018 UTC (5 years, 8 months ago) by greg
Diff to previous 2.56 , to selected 2.52
Clarified wording on warning
Thu Dec 5 03:02:56 2013 UTC (10 years, 5 months ago) by greg
Changes since 2.55: +5 -5 lines
Diff to previous 2.55 , to selected 2.52
Fixed bug where -R option would cause finished pieces to be re-rendered
Fri Nov 8 18:08:07 2013 UTC (10 years, 5 months ago) by greg
Changes since 2.54: +11 -7 lines
Diff to previous 2.54 , to selected 2.52
Minor fixes that should not affect operation
Fri Jun 1 22:55:14 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.53: +10 -2 lines
Diff to previous 2.53 , to selected 2.52
Added number of processes control to trad
Sat Jan 21 22:04:02 2012 UTC (12 years, 3 months ago) by greg
Changes since 2.52: +20 -3 lines
Diff to previous 2.52
Added warning about altered output resolution
Revision 2.52 - (view) (download) (annotate) - [selected]
Fri May 28 22:36:19 2010 UTC (13 years, 11 months ago) by greg
Changes since 2.51: +2 -1 lines
Diff to previous 2.51
Added date to rpiece header output
Mon May 17 17:03:53 2010 UTC (13 years, 11 months ago) by greg
Changes since 2.50: +8 -2 lines
Diff to previous 2.50 , to selected 2.52
Prevent use of -pm option, which can mess up results
Sat Feb 7 05:40:47 2009 UTC (15 years, 3 months ago) by greg
Diff to previous 2.49 , to selected 2.52
Added missing newline to error statement
Thu Apr 24 10:28:25 2008 UTC (16 years ago) by schorsch
Changes since 2.48: +3 -2 lines
Diff to previous 2.48 , to selected 2.52
Tue Mar 11 02:21:47 2008 UTC (16 years, 1 month ago) by greg
Changes since 2.47: +23 -11 lines
Diff to previous 2.47 , to selected 2.52
Wed Aug 22 18:46:36 2007 UTC (16 years, 8 months ago) by greg
Diff to previous 2.46 , to selected 2.52
Fixed bug in bug fix...
Wed Aug 22 17:49:54 2007 UTC (16 years, 8 months ago) by greg
Changes since 2.45: +5 -1 lines
Diff to previous 2.45 , to selected 2.52
Added error check for -X exceeding -y (or -Y exceeding -y)
Sat Oct 23 18:55:53 2004 UTC (19 years, 6 months ago) by schorsch
CVS Tags: rad3R6P1, rad3R7P1, rad3R7P2, rad3R8
Changes since 2.44: +4 -2 lines
Diff to previous 2.44 , to selected 2.52
Tue Jun 8 19:48:31 2004 UTC (19 years, 11 months ago) by greg
Changes since 2.43: +2 -3 lines
Diff to previous 2.43 , to selected 2.52
Fri Mar 26 21:36:20 2004 UTC (20 years, 1 month ago) by schorsch
Changes since 2.42: +68 -37 lines
Diff to previous 2.42 , to selected 2.52
Continued ANSIfication.
Mon Oct 20 16:01:55 2003 UTC (20 years, 6 months ago) by greg
Changes since 2.41: +4 -3 lines
Diff to previous 2.41 , to selected 2.52
Sun Jul 27 22:12:04 2003 UTC (20 years, 9 months ago) by schorsch
Diff to previous 2.40 , to selected 2.52
Diff to previous 2.39 , to selected 2.52
Changes since 2.38: +7 -5 lines
Diff to previous 2.38 , to selected 2.52
Sun Jun 8 12:03:11 2003 UTC (20 years, 11 months ago) by schorsch
Diff to previous 2.37 , to selected 2.52
Changes since 2.36: +13 -18 lines
Diff to previous 2.36 , to selected 2.52
Thu Jun 18 09:23:49 1998 UTC (25 years, 10 months ago) by gwlarson
Diff to previous 2.35 , to selected 2.52
moved declarations of lseek() and ftell() to standard.h
Tue Jul 29 11:27:49 1997 UTC (26 years, 9 months ago) by gregl
Changes since 2.34: +1 -1 lines
Diff to previous 2.34 , to selected 2.52
fixed bug in -pa argument processing
Wed May 28 17:22:52 1997 UTC (26 years, 11 months ago) by gregl
Changes since 2.33: +5 -3 lines
Diff to previous 2.33 , to selected 2.52
fix for Alpha Linux
Tue May 20 11:54:55 1997 UTC (26 years, 11 months ago) by gregl
Diff to previous 2.32 , to selected 2.52
fixed transference of view shift and lift parameters
Thu Nov 30 14:21:48 1995 UTC (28 years, 5 months ago) by greg
Changes since 2.31: +9 -4 lines
Diff to previous 2.31 , to selected 2.52
added VT_CYL view type to rpiece() routine
Thu Nov 30 09:26:20 1995 UTC (28 years, 5 months ago) by greg
Changes since 2.30: +9 -1 lines
Diff to previous 2.30 , to selected 2.52
added -T option to limit execution time
Mon Apr 11 14:44:10 1994 UTC (30 years, 1 month ago) by greg
Changes since 2.29: +4 -0 lines
Diff to previous 2.29 , to selected 2.52
added check for memory error in rvrpiece()
Mon Feb 28 09:22:32 1994 UTC (30 years, 2 months ago) by greg
Diff to previous 2.28 , to selected 2.52
added newheader() call
Tue Oct 19 16:02:39 1993 UTC (30 years, 6 months ago) by greg
Changes since 2.27: +5 -2 lines
Diff to previous 2.27 , to selected 2.52
fixed bug in opening non-existent sync file
added lock failure report
Mon Oct 18 13:17:47 1993 UTC (30 years, 6 months ago) by greg
Diff to previous 2.26 , to selected 2.52
removed use of hpux for sighold() and sigrelse(), linking problem
Sat Aug 7 08:43:32 1993 UTC (30 years, 9 months ago) by greg
Changes since 2.25: +19 -15 lines
Diff to previous 2.25 , to selected 2.52
fixed minor bug in nextpiece() and improved error detection and reporting
Fri Aug 6 17:19:52 1993 UTC (30 years, 9 months ago) by greg
Changes since 2.24: +109 -40 lines
Diff to previous 2.24 , to selected 2.52
added -R option to recover incomplete picture
Fri Aug 6 12:58:43 1993 UTC (30 years, 9 months ago) by greg
Changes since 2.23: +4 -0 lines
Diff to previous 2.23 , to selected 2.52
added mention of piece beginning to verbose output
Wed Aug 4 13:20:45 1993 UTC (30 years, 9 months ago) by greg
Changes since 2.22: +36 -18 lines
Diff to previous 2.22 , to selected 2.52
fixed bug in rpict resolution setting and changed -x and -y to full resolution
Wed Aug 4 10:08:47 1993 UTC (30 years, 9 months ago) by greg
Changes since 2.21: +7 -0 lines
Diff to previous 2.21 , to selected 2.52
added option expansion
Fri Jun 4 17:03:29 1993 UTC (30 years, 11 months ago) by greg
Changes since 2.20: +0 -1 lines
Diff to previous 2.20 , to selected 2.52
Tue May 4 09:30:27 1993 UTC (31 years ago) by greg
Diff to previous 2.19 , to selected 2.52
made rpiece hold off on verbose reporting until piece is written
Sat Apr 17 13:13:58 1993 UTC (31 years ago) by greg
Changes since 2.18: +5 -4 lines
Diff to previous 2.18 , to selected 2.52
made lock boundaries tighter for output file
Fri Apr 16 12:03:59 1993 UTC (31 years ago) by greg
Changes since 2.17: +15 -2 lines
Diff to previous 2.17 , to selected 2.52
added signal blocking for SYSV during freadcolrs() call
Sat Feb 20 17:07:35 1993 UTC (31 years, 2 months ago) by greg
Diff to previous 2.16 , to selected 2.52
changed format of sync to avoid trailing characters
Fri Jan 29 11:56:09 1993 UTC (31 years, 3 months ago) by greg
Changes since 2.15: +15 -0 lines
Diff to previous 2.15 , to selected 2.52
put in conditional compilation for systems without NFS lock manager
Thu Jan 21 17:46:31 1993 UTC (31 years, 3 months ago) by greg
Changes since 2.14: +9 -6 lines
Diff to previous 2.14 , to selected 2.52
minor bug fixes and changes for -PP option
Wed Dec 2 17:07:00 1992 UTC (31 years, 5 months ago) by greg
Diff to previous 2.13 , to selected 2.52
added ability to create synchronization file if nonexistent
Thu Nov 12 10:13:35 1992 UTC (31 years, 6 months ago) by greg
Diff to previous 2.12 , to selected 2.52
minor bug fix for compilers that don't handle variable arguments
Fri Aug 21 12:31:27 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.11: +13 -0 lines
Diff to previous 2.11 , to selected 2.52
added NFS define for multiprocessor systems w/o NFS
Sun Aug 9 23:05:17 1992 UTC (31 years, 9 months ago) by greg
Changes since 2.10: +30 -29 lines
Diff to previous 2.10 , to selected 2.52
slight optimization in rpiece()
Sun Aug 9 18:09:46 1992 UTC (31 years, 9 months ago) by greg
Changes since 2.9: +13 -13 lines
Diff to previous 2.9 , to selected 2.52
minor improvements
Sun Aug 9 13:31:30 1992 UTC (31 years, 9 months ago) by greg
Changes since 2.8: +50 -19 lines
Diff to previous 2.8 , to selected 2.52
added process forking
Sun Aug 9 12:12:48 1992 UTC (31 years, 9 months ago) by greg
Changes since 2.7: +45 -34 lines
Diff to previous 2.7 , to selected 2.52
improved locking with use of local buffer for picture piece
Sat Aug 8 18:47:39 1992 UTC (31 years, 9 months ago) by greg
Changes since 2.6: +8 -1 lines
Diff to previous 2.6 , to selected 2.52
added lock calls to get around NFS bug in writing adjacent blocks
Fri Aug 7 11:34:27 1992 UTC (31 years, 9 months ago) by greg
Changes since 2.5: +9 -2 lines
Diff to previous 2.5 , to selected 2.52
added SIGALRM handling for graceful bowing out
Fri Aug 7 11:05:30 1992 UTC (31 years, 9 months ago) by greg
Changes since 2.4: +67 -10 lines
Diff to previous 2.4 , to selected 2.52
added -F option for sync file
Thu Aug 6 18:49:40 1992 UTC (31 years, 9 months ago) by greg
Diff to previous 2.3 , to selected 2.52
fixed default setting of -pa
Thu Aug 6 17:56:40 1992 UTC (31 years, 9 months ago) by greg
Changes since 2.2: +10 -5 lines
Diff to previous 2.2 , to selected 2.52
added missing -vth type
Thu Aug 6 17:16:29 1992 UTC (31 years, 9 months ago) by greg
Diff to previous 2.1 , to selected 2.52
Thu Aug 6 16:45:01 1992 UTC (31 years, 9 months ago) by greg
Diff to selected 2.52
