--- ray/src/util/rpiece.c 2010/05/28 22:36:19 2.52 +++ ray/src/util/rpiece.c 2013/12/05 03:02:56 2.56 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rpiece.c,v 2.52 2010/05/28 22:36:19 greg Exp $"; +static const char RCSid[] = "$Id: rpiece.c,v 2.56 2013/12/05 03:02:56 greg Exp $"; #endif /* * Generate sections of a picture. @@ -37,7 +37,11 @@ main( #ifndef NFS #define NFS 1 #endif - /* set the following to 0 to forgo forking */ + +#ifndef RHAS_FORK_EXEC +#undef MAXFORK +#define MAXFORK 0 +#endif #ifndef MAXFORK #if NFS #define MAXFORK 3 /* allotment of duped processes */ @@ -78,6 +82,7 @@ int nforked = 0; char *progname; int verbose = 0; +int nowarn = 0; unsigned timelim = 0; int rvrlim = -1; @@ -100,7 +105,7 @@ main( char *argv[] ) { - register int i, rval; + int i, rval; progname = argv[0]; for (i = 1; i < argc; i++) { @@ -114,6 +119,14 @@ main( } if (argv[i][0] == '-') switch (argv[i][1]) { + case 'w': + if (!argv[i][2]) + nowarn = !nowarn; + else if (argv[i][2] == '+') + nowarn = 0; + else if (argv[i][2] == '-') + nowarn = 1; + break; case 'v': switch (argv[i][2]) { case '\0': /* verbose option */ @@ -195,8 +208,9 @@ main( break; outfile = argv[++i]; continue; - } else if (i >= argc-1) - break; + } + else if (i >= argc-1) + break; rpargv[rpargc++] = argv[i]; } if (i >= argc) { @@ -225,7 +239,7 @@ dolock( /* lock or unlock a file */ if (fcntl(fd, F_SETLKW, &fls) < 0) { fprintf(stderr, "%s: cannot lock/unlock file: %s\n", progname, strerror(errno)); - exit(1); + _exit(1); } } @@ -253,6 +267,9 @@ init( /* set up output file and start rpict */ sflock(F_UNLCK); } /* compute piece size */ + hr = hres; vr = vres; + if (pixaspect > FTINY) + normaspect(viewaspect(&ourview), &pixaspect, &hr, &vr); hres /= hmult; vres /= vmult; if (hres <= 0 || vres <= 0) { @@ -260,6 +277,10 @@ init( /* set up output file and start rpict */ exit(1); } normaspect(viewaspect(&ourview)*hmult/vmult, &pixaspect, &hres, &vres); + if (!nowarn && (hr != hres*hmult) | (vr != vres*vmult)) + fprintf(stderr, + "%s: warning - resolution changed from %dx%d to %dx%d\n", + progname, hr, vr, hres*hmult, vres*vmult); sprintf(hrbuf, "%d", hres); rpargv[rpargc++] = "-x"; rpargv[rpargc++] = hrbuf; sprintf(vrbuf, "%d", vres); @@ -375,13 +396,13 @@ nextpiece( /* get next piece assignment */ static int rvrpiece( /* check for recoverable pieces */ - register int *xp, - register int *yp + int *xp, + int *yp ) { static char *pdone = NULL; /* which pieces are done */ static long readpos = -1; /* how far we've read */ - register int i; + int px, py, i; /* * This routine is called by nextpiece() with an * exclusive lock on syncfp and the file pointer at the @@ -390,15 +411,15 @@ rvrpiece( /* check for recoverable pieces */ if (rvrlim < 0) return(0); /* only check if asked */ if (pdone == NULL) /* first call */ - pdone = calloc(hmult*vmult, sizeof(char)); + pdone = (char *)calloc(hmult*vmult, sizeof(char)); if (pdone == NULL) { fprintf(stderr, "%s: out of memory\n", progname); exit(1); } if (readpos != -1) /* mark what's been done */ fseek(syncfp, readpos, 0); - while (fscanf(syncfp, "%d %d", xp, yp) == 2) - pdone[*xp*vmult+*yp] = 1; + while (fscanf(syncfp, "%d %d", &px, &py) == 2) + pdone[px*vmult+py] = 1; if (!feof(syncfp)) { fprintf(stderr, "%s: format error in sync file\n", progname); exit(1); @@ -505,7 +526,7 @@ int ypos struct flock fls; int pid, status; int hr, vr; - register int y; + int y; /* check bounds */ if ((xpos < 0) | (ypos < 0) | (xpos >= hmult) | (ypos >= vmult)) { fprintf(stderr, "%s: requested piece (%d,%d) out of range\n", @@ -556,9 +577,13 @@ int ypos /* lock file section so NFS doesn't mess up */ fls.l_whence = 0; fls.l_type = F_WRLCK; +#if 0 if (fcntl(outfd, F_SETLKW, &fls) < 0) filerr("lock"); +#else + dolock(outfd, F_WRLCK); #endif +#endif /* write new piece to file */ if (lseek(outfd, (off_t)fls.l_start, SEEK_SET) < 0) filerr("seek"); @@ -578,8 +603,12 @@ int ypos } #if NFS fls.l_type = F_UNLCK; /* release lock */ +#if 0 if (fcntl(outfd, F_SETLKW, &fls) < 0) filerr("lock"); +#else + dolock(outfd, F_UNLCK); +#endif #endif if (verbose) { /* notify caller */ printf("%d %d done\n", xpos, ypos);
