--- ray/src/util/rpiece.c 1992/08/09 18:09:46 2.10 +++ ray/src/util/rpiece.c 1993/04/16 12:03:59 2.18 @@ -10,16 +10,44 @@ static char SCCSid[] = "$SunId$ LBL"; #include "standard.h" #include + +#ifndef F_SETLKW + +main(argc, argv) +int argc; +char *argv[]; +{ + fprintf(stderr, "%s: no NFS lock manager on this machine\n", argv[0]); + exit(1); +} + +#else + #include #include "color.h" #include "view.h" #include "resolu.h" +#ifndef NFS +#define NFS 1 +#endif /* set the following to 0 to forgo forking */ #ifndef MAXFORK +#if NFS #define MAXFORK 3 /* allotment of duped processes */ +#else +#define MAXFORK 0 #endif - +#endif + /* protection from SYSV signals(!) */ +#if defined(sgi) || defined(hpux) +#define guard_io() sighold(SIGALRM) +#define unguard() sigrelse(SIGALRM) +#endif +#ifndef guard_io +#define guard_io() 0 +#define unguard() 0 +#endif /* rpict command */ char *rpargv[128] = {"rpict", "-S", "1", "-x", "512", "-y", "512", "-pa", "1"}; int rpargc = 9; @@ -102,12 +130,17 @@ char *argv[]; case 'F': /* syncronization file */ if (argv[i][2]) break; - if ((syncfd = open(argv[++i], O_RDWR)) < 0) { + if ((syncfd = open(argv[++i], + O_RDWR|O_CREAT, 0666)) < 0) { fprintf(stderr, "%s: cannot open\n", argv[i]); exit(1); } continue; + case 'z': /* z-file ist verbotten */ + fprintf(stderr, "%s: -z option not allowed\n", + argv[0]); + exit(1); case 'o': /* output file */ if (argv[i][2]) break; @@ -123,8 +156,7 @@ char *argv[]; } init(argc, argv); rpiece(); - rval = cleanup(0); - exit(rval); + exit(cleanup(0)); } @@ -164,8 +196,8 @@ char **av; } else if ((outfd = open(outfile, O_RDWR)) >= 0) { if ((fp = fdopen(dup(outfd), "r+")) == NULL) goto filerr; - getheader(fp, NULL); /* skip header */ - if (fscnresolu(&hr, &vr, fp) < 0 || /* check resolution */ + getheader(fp, NULL, NULL); /* skip header */ + if (!fscnresolu(&hr, &vr, fp) || /* check resolution */ hr != hres*hmult || vr != vres*vmult) { fprintf(stderr, "%s: resolution mismatch on file \"%s\"\n", progname, outfile); @@ -179,7 +211,9 @@ char **av; scanorig = ftell(fp); /* record position of first scanline */ if (fclose(fp) == -1) /* done with stream i/o */ goto filerr; +#if NFS sync(); /* flush NFS buffers */ +#endif /* start rpict process */ if (open_process(rpd, rpargv) <= 0) { fprintf(stderr, "%s: cannot start %s\n", progname, rpargv[0]); @@ -232,7 +266,7 @@ int *xp, *yp; return(0); } } - sprintf(buf, "%d %d\n%d %d\n", hmult, vmult, *xp, *yp); + sprintf(buf, "%4d %4d\n%4d %4d\n", hmult, vmult, *xp, *yp); lseek(syncfd, 0L, 0); /* write new position */ write(syncfd, buf, strlen(buf)); fls.l_type = F_UNLCK; /* release sync file */ @@ -268,38 +302,39 @@ rpiece() /* render picture piece by piece */ { VIEW pview; int xorg, yorg; - + /* compute view parameters */ + copystruct(&pview, &ourview); + switch (ourview.type) { + case VT_PER: + pview.horiz = 2.*180./PI*atan( + tan(PI/180./2.*ourview.horiz)/hmult ); + pview.vert = 2.*180./PI*atan( + tan(PI/180./2.*ourview.vert)/vmult ); + break; + case VT_PAR: + case VT_ANG: + pview.horiz = ourview.horiz / hmult; + pview.vert = ourview.vert / vmult; + break; + case VT_HEM: + pview.horiz = 2.*180./PI*asin( + sin(PI/180./2.*ourview.horiz)/hmult ); + pview.vert = 2.*180./PI*asin( + sin(PI/180./2.*ourview.vert)/vmult ); + break; + default: + fprintf(stderr, "%s: unknown view type '-vt%c'\n", + progname, ourview.type); + exit(cleanup(1)); + } + /* render each piece */ while (nextpiece(&xorg, &yorg)) { - copystruct(&pview, &ourview); /* compute view for piece */ - switch (ourview.type) { - case VT_PER: - pview.horiz = 2.*180./PI*atan( - tan(PI/180./2.*ourview.horiz)/hmult ); - pview.vert = 2.*180./PI*atan( - tan(PI/180./2.*ourview.vert)/vmult ); - break; - case VT_PAR: - case VT_ANG: - pview.horiz = ourview.horiz / hmult; - pview.vert = ourview.vert / vmult; - break; - case VT_HEM: - pview.horiz = 2.*180./PI*asin( - sin(PI/180./2.*ourview.horiz)/hmult ); - pview.vert = 2.*180./PI*asin( - sin(PI/180./2.*ourview.vert)/vmult ); - break; - default: - fprintf(stderr, "%s: unknown view type '-vt%c'\n", - progname, ourview.type); - exit(cleanup(1)); - } - pview.hoff += xorg - 0.5*(hmult-1); - pview.voff += yorg - 0.5*(vmult-1); + pview.hoff = ourview.hoff + xorg - 0.5*(hmult-1); + pview.voff = ourview.voff + yorg - 0.5*(vmult-1); fputs(VIEWSTR, torp); fprintview(&pview, torp); putc('\n', torp); - fflush(torp); /* assign piece to rpict */ + fflush(torp); /* assigns piece to rpict */ putpiece(xorg, yorg); /* place piece in output */ if (verbose) { /* notify caller */ printf("%d %d done\n", xorg, yorg); @@ -324,19 +359,24 @@ int xpos, ypos; exit(cleanup(1)); } /* check header from rpict */ - getheader(fromrp, NULL); - if (fscnresolu(&hr, &vr, fromrp) < 0 || hr != hres || vr != vres) { + guard_io(); + getheader(fromrp, NULL, NULL); + if (!fscnresolu(&hr, &vr, fromrp) || hr != hres | vr != vres) { fprintf(stderr, "%s: resolution mismatch from %s\n", progname, rpargv[0]); exit(cleanup(1)); } + unguard(); /* load new piece into buffer */ - for (y = 0; y < vr; y++) + for (y = 0; y < vr; y++) { + guard_io(); if (freadcolrs(pbuf+y*hr, hr, fromrp) < 0) { fprintf(stderr, "%s: read error from %s\n", progname, rpargv[0]); exit(cleanup(1)); } + unguard(); + } #if MAXFORK /* fork so we don't slow rpict down */ if ((pid = fork()) > 0) { @@ -351,12 +391,14 @@ int xpos, ypos; #else pid = -1; /* no forking */ #endif - /* lock file section so NFS doesn't mess up */ - fls.l_whence = 0; fls.l_len = (long)vres*hmult*hres*sizeof(COLR); fls.l_start = scanorig + (vmult-1-ypos)*fls.l_len; +#if NFS + /* lock file section so NFS doesn't mess up */ + fls.l_whence = 0; fls.l_type = F_WRLCK; fcntl(outfd, F_SETLKW, &fls); +#endif /* write new piece to file */ if (lseek(outfd, fls.l_start+(long)xpos*hres*sizeof(COLR), 0) == -1) goto seekerr; @@ -375,8 +417,10 @@ int xpos, ypos; goto seekerr; } if (pid == -1) { /* fork failed */ +#if NFS fls.l_type = F_UNLCK; /* release lock */ fcntl(outfd, F_SETLKW, &fls); +#endif return(0); } _exit(0); /* else exit child process (releasing lock) */ @@ -387,3 +431,5 @@ writerr: fprintf(stderr, "%s: write error on file \"%s\"\n", progname, outfile); _exit(1); } + +#endif
