root/radiance/ray/src/util/rpiece.c
Revision: 2.6
Committed: Fri Aug 7 11:34:27 1992 UTC (31 years, 10 months ago) by greg
Changes since 2.5: +9 -2 lines
added SIGALRM handling for graceful bowing out
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Generate sections of a picture.
9 */
10
11 #include "standard.h"
12 #include <fcntl.h>
13 #include <signal.h>
14 #include "color.h"
15 #include "view.h"
16 #include "resolu.h"
17
18 /* rpict command */
19 char *rpargv[128] = {"rpict", "-S", "1", "-x", "512", "-y", "512", "-pa", "1"};
20 int rpargc = 9;
21 int rpd[3];
22 FILE *torp, *fromrp;
23 COLR *scanline;
24 /* our view parameters */
25 VIEW ourview = STDVIEW;
26 double pixaspect = 1.0;
27 int hres = 512, vres = 512, hmult = 2, vmult = 2;
28 /* output file */
29 char *outfile = NULL;
30 int outfd;
31 long scanorig;
32 int syncfd = -1; /* lock file descriptor */
33
34 char *progname;
35 int verbose = 0;
36
37 extern long lseek(), ftell();
38
39 int gotalrm = 0;
40 int onalrm() { gotalrm++; }
41
42
43 main(argc, argv)
44 int argc;
45 char *argv[];
46 {
47 register int i, rval;
48
49 progname = argv[0];
50 for (i = 1; i < argc; i++) {
51 if (argv[i][0] == '-')
52 switch (argv[i][1]) {
53 case 'v':
54 switch (argv[i][2]) {
55 case '\0': /* verbose option */
56 verbose = !verbose;
57 continue;
58 case 'f': /* view file */
59 if (viewfile(argv[++i], &ourview, NULL) <= 0) {
60 fprintf(stderr,
61 "%s: not a view file\n", argv[i]);
62 exit(1);
63 }
64 continue;
65 default: /* view option? */
66 rval = getviewopt(&ourview, argc-i, argv+i);
67 if (rval >= 0) {
68 i += rval;
69 continue;
70 }
71 break;
72 }
73 break;
74 case 'p': /* pixel aspect ratio? */
75 if (argv[i][2] == 'a' && !argv[i][3])
76 pixaspect = atof(argv[i+1]);
77 break;
78 case 'x': /* piece x resolution */
79 if (!argv[i][2])
80 hres = atoi(argv[i+1]);
81 break;
82 case 'y': /* piece y resolution */
83 if (!argv[i][2])
84 vres = atoi(argv[i+1]);
85 break;
86 case 'X': /* horizontal multiplier */
87 if (argv[i][2])
88 break;
89 hmult = atoi(argv[++i]);
90 continue;
91 case 'Y': /* vertical multiplier */
92 if (argv[i][2])
93 break;
94 vmult = atoi(argv[++i]);
95 continue;
96 case 'F': /* syncronization file */
97 if (argv[i][2])
98 break;
99 if ((syncfd = open(argv[++i], O_RDWR)) < 0) {
100 fprintf(stderr, "%s: cannot open\n",
101 argv[i]);
102 exit(1);
103 }
104 continue;
105 case 'o': /* output file */
106 if (argv[i][2])
107 break;
108 outfile = argv[++i];
109 continue;
110 }
111 rpargv[rpargc++] = argv[i];
112 }
113 rpargv[rpargc] = NULL;
114 if (outfile == NULL) {
115 fprintf(stderr, "%s: missing output file\n", argv[0]);
116 exit(1);
117 }
118 init(argc, argv);
119 rpiece();
120 rval = cleanup();
121 exit(rval);
122 }
123
124
125 init(ac, av) /* set up output file and start rpict */
126 int ac;
127 char **av;
128 {
129 extern char VersionID[];
130 char *err;
131 FILE *fp;
132 int hr, vr;
133 /* set up view */
134 if ((err = setview(&ourview)) != NULL) {
135 fprintf(stderr, "%s: %s\n", progname, err);
136 exit(1);
137 }
138 if (syncfd != -1) {
139 char buf[32];
140 buf[read(syncfd, buf, sizeof(buf)-1)] = '\0';
141 sscanf(buf, "%d %d", &hmult, &vmult);
142 }
143 normaspect(viewaspect(&ourview)*hmult/vmult, &pixaspect, &hres, &vres);
144 /* open output file */
145 if ((outfd = open(outfile, O_WRONLY|O_CREAT|O_EXCL, 0666)) >= 0) {
146 if ((fp = fdopen(dup(outfd), "w")) == NULL)
147 goto filerr;
148 printargs(ac, av, fp); /* write header */
149 fprintf(fp, "SOFTWARE= %s\n", VersionID);
150 fputs(VIEWSTR, fp);
151 fprintview(&ourview, fp);
152 putc('\n', fp);
153 if (pixaspect < .99 || pixaspect > 1.01)
154 fputaspect(pixaspect, fp);
155 fputformat(COLRFMT, fp);
156 putc('\n', fp);
157 fprtresolu(hres*hmult, vres*vmult, fp);
158 } else if ((outfd = open(outfile, O_RDWR)) >= 0) {
159 if ((fp = fdopen(dup(outfd), "r+")) == NULL)
160 goto filerr;
161 getheader(fp, NULL); /* skip header */
162 if (fscnresolu(&hr, &vr, fp) < 0 || /* check resolution */
163 hr != hres*hmult || vr != vres*vmult) {
164 fprintf(stderr, "%s: picture resolution mismatch\n",
165 outfile);
166 exit(1);
167 }
168 } else {
169 fprintf(stderr, "%s: cannot open\n", outfile);
170 exit(1);
171 }
172 scanorig = ftell(fp); /* record position of first scanline */
173 if (fclose(fp) == -1) /* done with stream i/o */
174 goto filerr;
175 sync(); /* avoid NFS buffering */
176 /* start rpict process */
177 if (open_process(rpd, rpargv) <= 0) {
178 fprintf(stderr, "%s: cannot start %s\n", progname, rpargv[0]);
179 exit(1);
180 }
181 if ((fromrp = fdopen(rpd[0], "r")) == NULL ||
182 (torp = fdopen(rpd[1], "w")) == NULL) {
183 fprintf(stderr, "%s: cannot open stream to %s\n",
184 progname, rpargv[0]);
185 exit(1);
186 }
187 if ((scanline = (COLR *)malloc(hres*sizeof(COLR))) == NULL) {
188 fprintf(stderr, "%s: out of memory\n", progname);
189 exit(1);
190 }
191 signal(SIGALRM, onalrm);
192 return;
193 filerr:
194 fprintf(stderr, "%s: file i/o error\n", outfile);
195 exit(1);
196 }
197
198
199 int
200 nextpiece(xp, yp) /* get next piece assignment */
201 int *xp, *yp;
202 {
203 extern char *fgets();
204 struct flock fls;
205 char buf[64];
206
207 if (gotalrm) /* someone wants us to quit */
208 return(0);
209 if (syncfd != -1) { /* use sync file */
210 fls.l_type = F_WRLCK; /* gain exclusive access */
211 fls.l_whence = 0;
212 fls.l_start = 0L;
213 fls.l_len = 0L;
214 fcntl(syncfd, F_SETLKW, &fls);
215 lseek(syncfd, 0L, 0);
216 buf[read(syncfd, buf, sizeof(buf)-1)] = '\0';
217 if (sscanf(buf, "%*d %*d %d %d", xp, yp) < 2) {
218 *xp = hmult;
219 *yp = vmult-1;
220 }
221 if (--(*xp) < 0) { /* decrement position */
222 *xp = hmult-1;
223 if (--(*yp) < 0) { /* all done! */
224 close(syncfd);
225 return(0);
226 }
227 }
228 sprintf(buf, "%d %d\n%d %d\n", hmult, vmult, *xp, *yp);
229 lseek(syncfd, 0L, 0); /* write new position */
230 write(syncfd, buf, strlen(buf));
231 fls.l_type = F_UNLCK; /* release sync file */
232 fcntl(syncfd, F_SETLKW, &fls);
233 return(1);
234 }
235 if (fgets(buf, sizeof(buf), stdin) == NULL) /* use stdin */
236 return(0);
237 if (sscanf(buf, "%d %d", xp, yp) == 2)
238 return(1);
239 fprintf(stderr, "%s: input format error\n", progname);
240 exit(1);
241 }
242
243
244 int
245 cleanup() /* close rpict process and clean up */
246 {
247 register int rpstat;
248
249 free((char *)scanline);
250 fclose(torp);
251 fclose(fromrp);
252 rpstat = close_process(rpd);
253 if (rpstat == -1)
254 rpstat = 0;
255 return(rpstat);
256 }
257
258
259 rpiece() /* render picture piece by piece */
260 {
261 VIEW pview;
262 int xorg, yorg;
263
264 while (nextpiece(&xorg, &yorg)) {
265 copystruct(&pview, &ourview); /* compute view for piece */
266 switch (ourview.type) {
267 case VT_PER:
268 pview.horiz = 2.*180./PI*atan(
269 tan(PI/180./2.*ourview.horiz)/hmult );
270 pview.vert = 2.*180./PI*atan(
271 tan(PI/180./2.*ourview.vert)/vmult );
272 break;
273 case VT_PAR:
274 case VT_ANG:
275 pview.horiz = ourview.horiz / hmult;
276 pview.vert = ourview.vert / vmult;
277 break;
278 case VT_HEM:
279 pview.horiz = 2.*180./PI*asin(
280 sin(PI/180./2.*ourview.horiz)/hmult );
281 pview.vert = 2.*180./PI*asin(
282 sin(PI/180./2.*ourview.vert)/vmult );
283 break;
284 default:
285 fprintf(stderr, "%s: unknown view type '-vt%c'\n",
286 progname, ourview.type);
287 exit(1);
288 }
289 pview.hoff += xorg - 0.5*(hmult-1);
290 pview.voff += yorg - 0.5*(vmult-1);
291 fputs(VIEWSTR, torp);
292 fprintview(&pview, torp);
293 putc('\n', torp);
294 fflush(torp); /* assign piece to rpict */
295 putpiece(xorg, yorg); /* place piece in output */
296 if (verbose) { /* notify caller */
297 printf("%d %d done\n", xorg, yorg);
298 fflush(stdout);
299 }
300 }
301 }
302
303
304 putpiece(xpos, ypos) /* get next piece from rpict */
305 int xpos, ypos;
306 {
307 int hr, vr;
308 int y;
309
310 if (xpos < 0 | ypos < 0 | xpos >= hmult | ypos >= vmult) {
311 fprintf(stderr, "%s: requested piece (%d,%d) out of range\n",
312 progname, xpos, ypos);
313 exit(1);
314 }
315 getheader(fromrp, NULL); /* discard header info. */
316 if (fscnresolu(&hr, &vr, fromrp) < 0 || /* check resolution */
317 hr != hres || vr != vres) {
318 fprintf(stderr, "%s: resolution mismatch from %s\n",
319 progname, rpargv[0]);
320 exit(1);
321 }
322 for (y = 0; y < vr; y++) { /* transfer scanlines */
323 if (freadcolrs(scanline, hr, fromrp) < 0) {
324 fprintf(stderr, "%s: read error from %s\n",
325 progname, rpargv[0]);
326 exit(1);
327 }
328 if ((y == 0 || hmult != 1) && lseek(outfd,
329 scanorig+((long)((vmult-1-ypos)*vres+y)*hmult*hres+xpos*hres)*sizeof(COLR),
330 0) == -1) {
331 fprintf(stderr, "%s: seek error\n", outfile);
332 exit(1);
333 }
334 if (writebuf(outfd, (char *)scanline, hr*sizeof(COLR)) !=
335 hr*sizeof(COLR)) {
336 fprintf(stderr, "%s: write error\n", outfile);
337 exit(1);
338 }
339 }
340 }
