root/radiance/ray/src/util/rpiece.c
Revision: 2.16
Committed: Fri Jan 29 11:56:09 1993 UTC (32 years, 3 months ago) by greg
Changes since 2.15: +15 -0 lines
put in conditional compilation for systems without NFS lock manager
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Generate sections of a picture.
9 */
10
11 #include "standard.h"
12 #include <fcntl.h>
13
14 #ifndef F_SETLKW
15
16 main(argc, argv)
17 int argc;
18 char *argv[];
19 {
20 fprintf(stderr, "%s: no NFS lock manager on this machine\n", argv[0]);
21 exit(1);
22 }
23
24 #else
25
26 #include <signal.h>
27 #include "color.h"
28 #include "view.h"
29 #include "resolu.h"
30
31 #ifndef NFS
32 #define NFS 1
33 #endif
34 /* set the following to 0 to forgo forking */
35 #ifndef MAXFORK
36 #if NFS
37 #define MAXFORK 3 /* allotment of duped processes */
38 #else
39 #define MAXFORK 0
40 #endif
41 #endif
42
43 /* rpict command */
44 char *rpargv[128] = {"rpict", "-S", "1", "-x", "512", "-y", "512", "-pa", "1"};
45 int rpargc = 9;
46 int rpd[3];
47 FILE *torp, *fromrp;
48 COLR *pbuf;
49 /* our view parameters */
50 VIEW ourview = STDVIEW;
51 double pixaspect = 1.0;
52 int hres = 512, vres = 512, hmult = 2, vmult = 2;
53 /* output file */
54 char *outfile = NULL;
55 int outfd;
56 long scanorig;
57 int syncfd = -1; /* lock file descriptor */
58 int nforked = 0;
59
60 char *progname;
61 int verbose = 0;
62
63 extern long lseek(), ftell();
64
65 int gotalrm = 0;
66 int onalrm() { gotalrm++; }
67
68
69 main(argc, argv)
70 int argc;
71 char *argv[];
72 {
73 register int i, rval;
74
75 progname = argv[0];
76 for (i = 1; i < argc; i++) {
77 if (argv[i][0] == '-')
78 switch (argv[i][1]) {
79 case 'v':
80 switch (argv[i][2]) {
81 case '\0': /* verbose option */
82 verbose = !verbose;
83 continue;
84 case 'f': /* view file */
85 if (viewfile(argv[++i], &ourview, NULL) <= 0) {
86 fprintf(stderr,
87 "%s: not a view file\n", argv[i]);
88 exit(1);
89 }
90 continue;
91 default: /* view option? */
92 rval = getviewopt(&ourview, argc-i, argv+i);
93 if (rval >= 0) {
94 i += rval;
95 continue;
96 }
97 break;
98 }
99 break;
100 case 'p': /* pixel aspect ratio? */
101 if (argv[i][2] == 'a' && !argv[i][3])
102 pixaspect = atof(argv[i+1]);
103 break;
104 case 'x': /* piece x resolution */
105 if (!argv[i][2])
106 hres = atoi(argv[i+1]);
107 break;
108 case 'y': /* piece y resolution */
109 if (!argv[i][2])
110 vres = atoi(argv[i+1]);
111 break;
112 case 'X': /* horizontal multiplier */
113 if (argv[i][2])
114 break;
115 hmult = atoi(argv[++i]);
116 continue;
117 case 'Y': /* vertical multiplier */
118 if (argv[i][2])
119 break;
120 vmult = atoi(argv[++i]);
121 continue;
122 case 'F': /* syncronization file */
123 if (argv[i][2])
124 break;
125 if ((syncfd = open(argv[++i],
126 O_RDWR|O_CREAT, 0666)) < 0) {
127 fprintf(stderr, "%s: cannot open\n",
128 argv[i]);
129 exit(1);
130 }
131 continue;
132 case 'z': /* z-file ist verbotten */
133 fprintf(stderr, "%s: -z option not allowed\n",
134 argv[0]);
135 exit(1);
136 case 'o': /* output file */
137 if (argv[i][2])
138 break;
139 outfile = argv[++i];
140 continue;
141 }
142 rpargv[rpargc++] = argv[i];
143 }
144 rpargv[rpargc] = NULL;
145 if (outfile == NULL) {
146 fprintf(stderr, "%s: missing output file\n", argv[0]);
147 exit(1);
148 }
149 init(argc, argv);
150 rpiece();
151 exit(cleanup(0));
152 }
153
154
155 init(ac, av) /* set up output file and start rpict */
156 int ac;
157 char **av;
158 {
159 extern char VersionID[];
160 char *err;
161 FILE *fp;
162 int hr, vr;
163 /* set up view */
164 if ((err = setview(&ourview)) != NULL) {
165 fprintf(stderr, "%s: %s\n", progname, err);
166 exit(1);
167 }
168 if (syncfd != -1) {
169 char buf[32];
170 buf[read(syncfd, buf, sizeof(buf)-1)] = '\0';
171 sscanf(buf, "%d %d", &hmult, &vmult);
172 }
173 normaspect(viewaspect(&ourview)*hmult/vmult, &pixaspect, &hres, &vres);
174 /* open output file */
175 if ((outfd = open(outfile, O_WRONLY|O_CREAT|O_EXCL, 0666)) >= 0) {
176 if ((fp = fdopen(dup(outfd), "w")) == NULL)
177 goto filerr;
178 printargs(ac, av, fp); /* write header */
179 fprintf(fp, "SOFTWARE= %s\n", VersionID);
180 fputs(VIEWSTR, fp);
181 fprintview(&ourview, fp);
182 putc('\n', fp);
183 if (pixaspect < .99 || pixaspect > 1.01)
184 fputaspect(pixaspect, fp);
185 fputformat(COLRFMT, fp);
186 putc('\n', fp);
187 fprtresolu(hres*hmult, vres*vmult, fp);
188 } else if ((outfd = open(outfile, O_RDWR)) >= 0) {
189 if ((fp = fdopen(dup(outfd), "r+")) == NULL)
190 goto filerr;
191 getheader(fp, NULL, NULL); /* skip header */
192 if (!fscnresolu(&hr, &vr, fp) || /* check resolution */
193 hr != hres*hmult || vr != vres*vmult) {
194 fprintf(stderr, "%s: resolution mismatch on file \"%s\"\n",
195 progname, outfile);
196 exit(1);
197 }
198 } else {
199 fprintf(stderr, "%s: cannot open file \"%s\"\n",
200 progname, outfile);
201 exit(1);
202 }
203 scanorig = ftell(fp); /* record position of first scanline */
204 if (fclose(fp) == -1) /* done with stream i/o */
205 goto filerr;
206 #if NFS
207 sync(); /* flush NFS buffers */
208 #endif
209 /* start rpict process */
210 if (open_process(rpd, rpargv) <= 0) {
211 fprintf(stderr, "%s: cannot start %s\n", progname, rpargv[0]);
212 exit(1);
213 }
214 if ((fromrp = fdopen(rpd[0], "r")) == NULL ||
215 (torp = fdopen(rpd[1], "w")) == NULL) {
216 fprintf(stderr, "%s: cannot open stream to %s\n",
217 progname, rpargv[0]);
218 exit(1);
219 }
220 if ((pbuf = (COLR *)malloc(hres*vres*sizeof(COLR))) == NULL) {
221 fprintf(stderr, "%s: out of memory\n", progname);
222 exit(1);
223 }
224 signal(SIGALRM, onalrm);
225 return;
226 filerr:
227 fprintf(stderr, "%s: i/o error on file \"%s\"\n", progname, outfile);
228 exit(1);
229 }
230
231
232 int
233 nextpiece(xp, yp) /* get next piece assignment */
234 int *xp, *yp;
235 {
236 extern char *fgets();
237 struct flock fls;
238 char buf[64];
239
240 if (gotalrm) /* someone wants us to quit */
241 return(0);
242 if (syncfd != -1) { /* use sync file */
243 fls.l_type = F_WRLCK; /* gain exclusive access */
244 fls.l_whence = 0;
245 fls.l_start = 0L;
246 fls.l_len = 0L;
247 fcntl(syncfd, F_SETLKW, &fls);
248 lseek(syncfd, 0L, 0);
249 buf[read(syncfd, buf, sizeof(buf)-1)] = '\0';
250 if (sscanf(buf, "%*d %*d %d %d", xp, yp) < 2) {
251 *xp = hmult-1;
252 *yp = vmult;
253 }
254 if (--(*yp) < 0) { /* decrement position */
255 *yp = vmult-1;
256 if (--(*xp) < 0) { /* all done! */
257 close(syncfd);
258 return(0);
259 }
260 }
261 sprintf(buf, "%d %d\n%d %d\n", hmult, vmult, *xp, *yp);
262 lseek(syncfd, 0L, 0); /* write new position */
263 write(syncfd, buf, strlen(buf));
264 fls.l_type = F_UNLCK; /* release sync file */
265 fcntl(syncfd, F_SETLKW, &fls);
266 return(1);
267 }
268 if (fgets(buf, sizeof(buf), stdin) == NULL) /* use stdin */
269 return(0);
270 if (sscanf(buf, "%d %d", xp, yp) == 2)
271 return(1);
272 fprintf(stderr, "%s: input format error\n", progname);
273 exit(cleanup(1));
274 }
275
276
277 int
278 cleanup(rstat) /* close rpict process and clean up */
279 int rstat;
280 {
281 int status;
282
283 free((char *)pbuf);
284 fclose(torp);
285 fclose(fromrp);
286 while (wait(&status) != -1)
287 if (rstat == 0)
288 rstat = status>>8 & 0xff;
289 return(rstat);
290 }
291
292
293 rpiece() /* render picture piece by piece */
294 {
295 VIEW pview;
296 int xorg, yorg;
297 /* compute view parameters */
298 copystruct(&pview, &ourview);
299 switch (ourview.type) {
300 case VT_PER:
301 pview.horiz = 2.*180./PI*atan(
302 tan(PI/180./2.*ourview.horiz)/hmult );
303 pview.vert = 2.*180./PI*atan(
304 tan(PI/180./2.*ourview.vert)/vmult );
305 break;
306 case VT_PAR:
307 case VT_ANG:
308 pview.horiz = ourview.horiz / hmult;
309 pview.vert = ourview.vert / vmult;
310 break;
311 case VT_HEM:
312 pview.horiz = 2.*180./PI*asin(
313 sin(PI/180./2.*ourview.horiz)/hmult );
314 pview.vert = 2.*180./PI*asin(
315 sin(PI/180./2.*ourview.vert)/vmult );
316 break;
317 default:
318 fprintf(stderr, "%s: unknown view type '-vt%c'\n",
319 progname, ourview.type);
320 exit(cleanup(1));
321 }
322 /* render each piece */
323 while (nextpiece(&xorg, &yorg)) {
324 pview.hoff = ourview.hoff + xorg - 0.5*(hmult-1);
325 pview.voff = ourview.voff + yorg - 0.5*(vmult-1);
326 fputs(VIEWSTR, torp);
327 fprintview(&pview, torp);
328 putc('\n', torp);
329 fflush(torp); /* assigns piece to rpict */
330 putpiece(xorg, yorg); /* place piece in output */
331 if (verbose) { /* notify caller */
332 printf("%d %d done\n", xorg, yorg);
333 fflush(stdout);
334 }
335 }
336 }
337
338
339 int
340 putpiece(xpos, ypos) /* get next piece from rpict */
341 int xpos, ypos;
342 {
343 struct flock fls;
344 int pid, status;
345 int hr, vr;
346 register int y;
347 /* check bounds */
348 if (xpos < 0 | ypos < 0 | xpos >= hmult | ypos >= vmult) {
349 fprintf(stderr, "%s: requested piece (%d,%d) out of range\n",
350 progname, xpos, ypos);
351 exit(cleanup(1));
352 }
353 /* check header from rpict */
354 getheader(fromrp, NULL, NULL);
355 if (!fscnresolu(&hr, &vr, fromrp) || hr != hres | vr != vres) {
356 fprintf(stderr, "%s: resolution mismatch from %s\n",
357 progname, rpargv[0]);
358 exit(cleanup(1));
359 }
360 /* load new piece into buffer */
361 for (y = 0; y < vr; y++)
362 if (freadcolrs(pbuf+y*hr, hr, fromrp) < 0) {
363 fprintf(stderr, "%s: read error from %s\n",
364 progname, rpargv[0]);
365 exit(cleanup(1));
366 }
367 #if MAXFORK
368 /* fork so we don't slow rpict down */
369 if ((pid = fork()) > 0) {
370 if (++nforked >= MAXFORK) {
371 wait(&status); /* reap a child */
372 if (status)
373 exit(cleanup(status>>8 & 0xff));
374 nforked--;
375 }
376 return(pid);
377 }
378 #else
379 pid = -1; /* no forking */
380 #endif
381 fls.l_len = (long)vres*hmult*hres*sizeof(COLR);
382 fls.l_start = scanorig + (vmult-1-ypos)*fls.l_len;
383 #if NFS
384 /* lock file section so NFS doesn't mess up */
385 fls.l_whence = 0;
386 fls.l_type = F_WRLCK;
387 fcntl(outfd, F_SETLKW, &fls);
388 #endif
389 /* write new piece to file */
390 if (lseek(outfd, fls.l_start+(long)xpos*hres*sizeof(COLR), 0) == -1)
391 goto seekerr;
392 if (hmult == 1) {
393 if (writebuf(outfd, (char *)pbuf,
394 vr*hr*sizeof(COLR)) != vr*hr*sizeof(COLR))
395 goto writerr;
396 } else
397 for (y = 0; y < vr; y++) {
398 if (writebuf(outfd, (char *)(pbuf+y*hr),
399 hr*sizeof(COLR)) != hr*sizeof(COLR))
400 goto writerr;
401 if (y < vr-1 && lseek(outfd,
402 (long)(hmult-1)*hr*sizeof(COLR),
403 1) == -1)
404 goto seekerr;
405 }
406 if (pid == -1) { /* fork failed */
407 #if NFS
408 fls.l_type = F_UNLCK; /* release lock */
409 fcntl(outfd, F_SETLKW, &fls);
410 #endif
411 return(0);
412 }
413 _exit(0); /* else exit child process (releasing lock) */
414 seekerr:
415 fprintf(stderr, "%s: seek error on file \"%s\"\n", progname, outfile);
416 _exit(1);
417 writerr:
418 fprintf(stderr, "%s: write error on file \"%s\"\n", progname, outfile);
419 _exit(1);
420 }
421
422 #endif
