root/radiance/ray/src/util/rpiece.c
Revision: 2.44
Committed: Tue Jun 8 19:48:31 2004 UTC (21 years ago) by greg
Changes since 2.43: +2 -3 lines
2 static const char RCSid[] = "$Id: rpiece.c,v 2.43 2004/03/26 21:36:20 schorsch Exp $";
5 * Generate sections of a picture.
6 */
7
8
9 #include <stdio.h>
10 #include <signal.h>
11 #include <sys/types.h>
12 #include <sys/wait.h>
13
14 #include "platform.h"
15 #include "standard.h"
16 #include "color.h"
17 #include "view.h"
18 #include "rtprocess.h"
19
20 #ifndef F_SETLKW
21
22 int
23 main(
24 int argc,
25 char *argv[]
26 )
27 {
28 fprintf(stderr, "%s: no NFS lock manager on this machine\n", argv[0]);
29 exit(1);
30 }
31
32 #else
33
34 #ifndef NFS
35 #define NFS 1
36 #endif
37 /* set the following to 0 to forgo forking */
38 #ifndef MAXFORK
39 #if NFS
40 #define MAXFORK 3 /* allotment of duped processes */
41 #else
42 #define MAXFORK 0
43 #endif
44 #endif
45 /* protection from SYSV signals(!) */
46 #if defined(sgi)
47 #define guard_io() sighold(SIGALRM)
48 #define unguard() sigrelse(SIGALRM)
49 #endif
50 #ifndef guard_io
51 #define guard_io()
52 #define unguard()
53 #endif
54
55 extern char *strerror();
56
57 /* rpict command */
58 char *rpargv[128] = {"rpict", "-S", "1"};
59 int rpargc = 3;
60 FILE *torp, *fromrp;
61 COLR *pbuf;
62 /* our view parameters */
63 VIEW ourview = STDVIEW;
64 double pixaspect = 1.0;
65 int hres = 1024, vres = 1024, hmult = 4, vmult = 4;
66 /* output file */
67 char *outfile = NULL;
68 int outfd;
69 long scanorig;
70 FILE *syncfp = NULL; /* synchronization file pointer */
71 int synclst = F_UNLCK; /* synchronization file lock status */
72 int nforked = 0;
73
74 #define sflock(t) if ((t)!=synclst) dolock(fileno(syncfp),synclst=t)
75
76 char *progname;
77 int verbose = 0;
78 unsigned timelim = 0;
79 int rvrlim = -1;
80
81 int gotalrm = 0;
82 void onalrm(int i) { gotalrm++; }
83
84 static void dolock(int fd, int ltyp);
85 static void init(int ac, char **av);
86 static int nextpiece(int *xp, int *yp);
87 static int rvrpiece(int *xp, int *yp);
88 static int cleanup(int rstat);
89 static void rpiece(void);
90 static int putpiece(int xpos, int ypos);
91 static void filerr(char *t);
92
93
94 int
95 main(
96 int argc,
97 char *argv[]
98 )
99 {
100 register int i, rval;
101
102 progname = argv[0];
103 for (i = 1; i < argc; i++) {
104 /* expand arguments */
105 while ((rval = expandarg(&argc, &argv, i)) > 0)
106 ;
107 if (rval < 0) {
108 fprintf(stderr, "%s: cannot expand '%s'",
109 argv[0], argv[i]);
110 exit(1);
111 }
112 if (argv[i][0] == '-')
113 switch (argv[i][1]) {
114 case 'v':
115 switch (argv[i][2]) {
116 case '\0': /* verbose option */
117 verbose = !verbose;
118 continue;
119 case 'f': /* view file */
120 if (viewfile(argv[++i], &ourview, NULL) <= 0) {
121 fprintf(stderr,
122 "%s: not a view file\n", argv[i]);
123 exit(1);
124 }
125 continue;
126 default: /* view option? */
127 rval = getviewopt(&ourview, argc-i, argv+i);
128 if (rval >= 0) {
129 i += rval;
130 continue;
131 }
132 break;
133 }
134 break;
135 case 'p': /* pixel aspect ratio? */
136 if (argv[i][2] != 'a' || argv[i][3])
137 break;
138 pixaspect = atof(argv[++i]);
139 continue;
140 case 'T': /* time limit (hours) */
141 if (argv[i][2])
142 break;
143 timelim = atof(argv[++i])*3600. + .5;
144 break;
145 case 'x': /* overall x resolution */
146 if (argv[i][2])
147 break;
148 hres = atoi(argv[++i]);
149 continue;
150 case 'y': /* overall y resolution */
151 if (argv[i][2])
152 break;
153 vres = atoi(argv[++i]);
154 continue;
155 case 'X': /* horizontal multiplier */
156 if (argv[i][2])
157 break;
158 hmult = atoi(argv[++i]);
159 continue;
160 case 'Y': /* vertical multiplier */
161 if (argv[i][2])
162 break;
163 vmult = atoi(argv[++i]);
164 continue;
165 case 'R': /* recover */
166 if (argv[i][2])
167 break;
168 rvrlim = 0;
169 /* fall through */
170 case 'F': /* syncronization file */
171 if (argv[i][2])
172 break;
173 if ((syncfp =
174 fdopen(open(argv[++i],O_RDWR|O_CREAT,0666),"r+")) == NULL) {
175 fprintf(stderr, "%s: cannot open\n",
176 argv[i]);
177 exit(1);
178 }
179 continue;
180 case 'z': /* z-file ist verbotten */
181 fprintf(stderr, "%s: -z option not allowed\n",
182 argv[0]);
183 exit(1);
184 case 'o': /* output file */
185 if (argv[i][2])
186 break;
187 outfile = argv[++i];
188 continue;
189 } else if (i >= argc-1)
190 break;
191 rpargv[rpargc++] = argv[i];
192 }
193 if (i >= argc) {
194 fprintf(stderr, "%s: missing octree argument\n", argv[0]);
195 exit(1);
196 }
197 if (outfile == NULL) {
198 fprintf(stderr, "%s: missing output file\n", argv[0]);
199 exit(1);
200 }
201 init(argc, argv);
202 rpiece();
203 exit(cleanup(0));
204 }
205
206
207 static void
208 dolock( /* lock or unlock a file */
209 int fd,
210 int ltyp
211 )
212 {
213 static struct flock fls; /* static so initialized to zeroes */
214
215 fls.l_type = ltyp;
216 if (fcntl(fd, F_SETLKW, &fls) < 0) {
217 fprintf(stderr, "%s: cannot lock/unlock file: %s\n",
218 progname, strerror(errno));
219 exit(1);
220 }
221 }
222
223
224 static void
225 init( /* set up output file and start rpict */
226 int ac,
227 char **av
228 )
229 {
230 static char hrbuf[16], vrbuf[16];
231 extern char VersionID[];
232 char *err;
233 FILE *fp;
234 int hr, vr;
235 SUBPROC rpd; /* since we don't close_process(), this can be local */
236 /* set up view */
237 if ((err = setview(&ourview)) != NULL) {
238 fprintf(stderr, "%s: %s\n", progname, err);
239 exit(1);
240 }
241 if (syncfp != NULL) {
242 sflock(F_RDLCK);
243 fscanf(syncfp, "%d %d", &hmult, &vmult);
244 sflock(F_UNLCK);
245 }
246 /* compute piece size */
247 hres /= hmult;
248 vres /= vmult;
249 normaspect(viewaspect(&ourview)*hmult/vmult, &pixaspect, &hres, &vres);
250 sprintf(hrbuf, "%d", hres);
251 rpargv[rpargc++] = "-x"; rpargv[rpargc++] = hrbuf;
252 sprintf(vrbuf, "%d", vres);
253 rpargv[rpargc++] = "-y"; rpargv[rpargc++] = vrbuf;
254 rpargv[rpargc++] = "-pa"; rpargv[rpargc++] = "0";
255 rpargv[rpargc++] = av[ac-1];
256 rpargv[rpargc] = NULL;
257 /* open output file */
258 if ((outfd = open(outfile, O_WRONLY|O_CREAT|O_EXCL, 0666)) >= 0) {
259 dolock(outfd, F_WRLCK);
260 if ((fp = fdopen(dup(outfd), "w")) == NULL)
261 goto filerr;
262 newheader("RADIANCE", fp); /* create header */
263 printargs(ac, av, fp);
264 fprintf(fp, "SOFTWARE= %s\n", VersionID);
265 fputs(VIEWSTR, fp);
266 fprintview(&ourview, fp);
267 putc('\n', fp);
268 if (pixaspect < .99 || pixaspect > 1.01)
269 fputaspect(pixaspect, fp);
270 fputformat(COLRFMT, fp);
271 putc('\n', fp);
272 fprtresolu(hres*hmult, vres*vmult, fp);
273 } else if ((outfd = open(outfile, O_RDWR)) >= 0) {
274 dolock(outfd, F_RDLCK);
275 if ((fp = fdopen(dup(outfd), "r+")) == NULL)
276 goto filerr;
277 getheader(fp, NULL, NULL); /* skip header */
278 if (!fscnresolu(&hr, &vr, fp) || /* check resolution */
279 hr != hres*hmult || vr != vres*vmult) {
280 fprintf(stderr, "%s: resolution mismatch on file \"%s\"\n",
281 progname, outfile);
282 exit(1);
283 }
284 } else {
285 fprintf(stderr, "%s: cannot open file \"%s\"\n",
286 progname, outfile);
287 exit(1);
288 }
289 scanorig = ftell(fp); /* record position of first scanline */
290 if (fclose(fp) == -1) /* done with stream i/o */
291 goto filerr;
292 dolock(outfd, F_UNLCK);
293 /* start rpict process */
294 if (open_process(&rpd, rpargv) <= 0) {
295 fprintf(stderr, "%s: cannot start %s\n", progname, rpargv[0]);
296 exit(1);
297 }
298 if ((fromrp = fdopen(rpd.r, "r")) == NULL ||
299 (torp = fdopen(rpd.w, "w")) == NULL) {
300 fprintf(stderr, "%s: cannot open stream to %s\n",
301 progname, rpargv[0]);
302 exit(1);
303 }
304 if ((pbuf = (COLR *)bmalloc(hres*vres*sizeof(COLR))) == NULL) {
305 fprintf(stderr, "%s: out of memory\n", progname);
306 exit(1);
307 }
308 signal(SIGALRM, onalrm);
309 if (timelim)
310 alarm(timelim);
311 return;
312 filerr:
313 fprintf(stderr, "%s: i/o error on file \"%s\"\n", progname, outfile);
314 exit(1);
315 }
316
317
318 static int
319 nextpiece( /* get next piece assignment */
320 int *xp,
321 int *yp
322 )
323 {
324 if (gotalrm) /* someone wants us to quit */
325 return(0);
326 if (syncfp != NULL) { /* use sync file */
327 /*
328 * So we don't necessarily have to lock and unlock the file
329 * multiple times (very slow), we establish an exclusive
330 * lock at the beginning on our synchronization file and
331 * maintain it in the subroutine rvrpiece().
332 */
333 sflock(F_WRLCK);
334 fseek(syncfp, 0L, 0); /* read position */
335 if (fscanf(syncfp, "%*d %*d %d %d", xp, yp) < 2) {
336 *xp = hmult-1;
337 *yp = vmult;
338 }
339 if (rvrlim == 0) /* initialize recovery limit */
340 rvrlim = *xp*vmult + *yp;
341 if (rvrpiece(xp, yp)) { /* do stragglers first */
342 sflock(F_UNLCK);
343 return(1);
344 }
345 if (--(*yp) < 0) { /* decrement position */
346 *yp = vmult-1;
347 if (--(*xp) < 0) { /* all done */
348 sflock(F_UNLCK);
349 return(0);
350 }
351 }
352 fseek(syncfp, 0L, 0); /* write new position */
353 fprintf(syncfp, "%4d %4d\n%4d %4d\n\n", hmult, vmult, *xp, *yp);
354 fflush(syncfp);
355 sflock(F_UNLCK); /* release sync file */
356 return(1);
357 }
358 return(scanf("%d %d", xp, yp) == 2); /* use stdin */
359 }
360
361
362 static int
363 rvrpiece( /* check for recoverable pieces */
364 register int *xp,
365 register int *yp
366 )
367 {
368 static char *pdone = NULL; /* which pieces are done */
369 static long readpos = -1; /* how far we've read */
370 register int i;
371 /*
372 * This routine is called by nextpiece() with an
373 * exclusive lock on syncfp and the file pointer at the
374 * appropriate position to read in the finished pieces.
375 */
376 if (rvrlim < 0)
377 return(0); /* only check if asked */
378 if (pdone == NULL) /* first call */
379 pdone = calloc(hmult*vmult, sizeof(char));
380 if (pdone == NULL) {
381 fprintf(stderr, "%s: out of memory\n", progname);
382 exit(1);
383 }
384 if (readpos != -1) /* mark what's been done */
385 fseek(syncfp, readpos, 0);
386 while (fscanf(syncfp, "%d %d", xp, yp) == 2)
387 pdone[*xp*vmult+*yp] = 1;
388 if (!feof(syncfp)) {
389 fprintf(stderr, "%s: format error in sync file\n", progname);
390 exit(1);
391 }
392 readpos = ftell(syncfp);
393 i = hmult*vmult; /* find an unaccounted for piece */
394 while (i-- > rvrlim)
395 if (!pdone[i]) {
396 *xp = i / vmult;
397 *yp = i % vmult;
398 pdone[i] = 1; /* consider it done */
399 return(1);
400 }
401 rvrlim = -1; /* nothing left to recover */
402 free(pdone);
403 pdone = NULL;
404 return(0);
405 }
406
407
408 static int
409 cleanup( /* close rpict process and clean up */
410 int rstat
411 )
412 {
413 int status;
414
415 bfree((char *)pbuf, hres*vres*sizeof(COLR));
416 fclose(torp);
417 fclose(fromrp);
418 while (wait(&status) != -1)
419 if (rstat == 0)
420 rstat = status>>8 & 0xff;
421 return(rstat);
422 }
423
424
425 static void
426 rpiece(void) /* render picture piece by piece */
427 {
428 VIEW pview;
429 int xorg, yorg;
430 /* compute view parameters */
431 pview = ourview;
432 switch (ourview.type) {
433 case VT_PER:
434 pview.horiz = 2.*180./PI*atan(
435 tan(PI/180./2.*ourview.horiz)/hmult );
436 pview.vert = 2.*180./PI*atan(
437 tan(PI/180./2.*ourview.vert)/vmult );
438 break;
439 case VT_PAR:
440 case VT_ANG:
441 pview.horiz = ourview.horiz / hmult;
442 pview.vert = ourview.vert / vmult;
443 break;
444 case VT_CYL:
445 pview.horiz = ourview.horiz / hmult;
446 pview.vert = 2.*180./PI*atan(
447 tan(PI/180./2.*ourview.vert)/vmult );
448 break;
449 case VT_HEM:
450 pview.horiz = 2.*180./PI*asin(
451 sin(PI/180./2.*ourview.horiz)/hmult );
452 pview.vert = 2.*180./PI*asin(
453 sin(PI/180./2.*ourview.vert)/vmult );
454 break;
455 default:
456 fprintf(stderr, "%s: unknown view type '-vt%c'\n",
457 progname, ourview.type);
458 exit(cleanup(1));
459 }
460 /* render each piece */
461 while (nextpiece(&xorg, &yorg)) {
462 pview.hoff = ourview.hoff*hmult + xorg - 0.5*(hmult-1);
463 pview.voff = ourview.voff*vmult + yorg - 0.5*(vmult-1);
464 fputs(VIEWSTR, torp);
465 fprintview(&pview, torp);
466 putc('\n', torp);
467 fflush(torp); /* assigns piece to rpict */
468 putpiece(xorg, yorg); /* place piece in output */
469 }
470 }
471
472
473 static int
474 putpiece( /* get next piece from rpict */
475 int xpos,
476 int ypos
477 )
478 {
479 struct flock fls;
480 int pid, status;
481 int hr, vr;
482 register int y;
483 /* check bounds */
484 if ((xpos < 0) | (ypos < 0) | (xpos >= hmult) | (ypos >= vmult)) {
485 fprintf(stderr, "%s: requested piece (%d,%d) out of range\n",
486 progname, xpos, ypos);
487 exit(cleanup(1));
488 }
489 /* check header from rpict */
490 guard_io();
491 getheader(fromrp, NULL, NULL);
492 if (!fscnresolu(&hr, &vr, fromrp) || (hr != hres) | (vr != vres)) {
493 fprintf(stderr, "%s: resolution mismatch from %s\n",
494 progname, rpargv[0]);
495 exit(cleanup(1));
496 }
497 if (verbose) { /* notify caller */
498 printf("%d %d begun\n", xpos, ypos);
499 fflush(stdout);
500 }
501 unguard();
502 /* load new piece into buffer */
503 for (y = 0; y < vr; y++) {
504 guard_io();
505 if (freadcolrs(pbuf+y*hr, hr, fromrp) < 0) {
506 fprintf(stderr, "%s: read error from %s\n",
507 progname, rpargv[0]);
508 exit(cleanup(1));
509 }
510 unguard();
511 }
512 #if MAXFORK
513 /* fork so we don't slow rpict down */
514 if ((pid = fork()) > 0) {
515 if (++nforked >= MAXFORK) {
516 wait(&status); /* reap a child */
517 if (status)
518 exit(cleanup(status>>8 & 0xff));
519 nforked--;
520 }
521 return(pid);
522 }
523 #else
524 pid = -1; /* no forking */
525 #endif
526 fls.l_start = scanorig +
527 ((long)(vmult-1-ypos)*vres*hmult+xpos)*hres*sizeof(COLR);
528 #if NFS
529 fls.l_len = ((long)(vres-1)*hmult+1)*hres*sizeof(COLR);
530 /* lock file section so NFS doesn't mess up */
531 fls.l_whence = 0;
532 fls.l_type = F_WRLCK;
533 if (fcntl(outfd, F_SETLKW, &fls) < 0)
534 filerr("lock");
535 #endif
536 /* write new piece to file */
537 if (lseek(outfd, (off_t)fls.l_start, SEEK_SET) < 0)
538 filerr("seek");
539 if (hmult == 1) {
540 if (writebuf(outfd, (char *)pbuf,
541 vr*hr*sizeof(COLR)) != vr*hr*sizeof(COLR))
542 filerr("write");
543 } else
544 for (y = 0; y < vr; y++) {
545 if (writebuf(outfd, (char *)(pbuf+y*hr),
546 hr*sizeof(COLR)) != hr*sizeof(COLR))
547 filerr("write");
548 if (y < vr-1 && lseek(outfd,
549 (off_t)(hmult-1)*hr*sizeof(COLR),
550 SEEK_CUR) < 0)
551 filerr("seek");
552 }
553 #if NFS
554 fls.l_type = F_UNLCK; /* release lock */
555 if (fcntl(outfd, F_SETLKW, &fls) < 0)
556 filerr("lock");
557 #endif
558 if (verbose) { /* notify caller */
559 printf("%d %d done\n", xpos, ypos);
560 fflush(stdout);
561 }
562 if (syncfp != NULL) { /* record what's been done */
563 sflock(F_WRLCK);
564 fseek(syncfp, 0L, 2); /* append index */
565 fprintf(syncfp, "%4d %4d\n", xpos, ypos);
566 fflush(syncfp);
567 /*** Unlock not necessary, since
568 sflock(F_UNLCK); _exit() or nextpiece() is next ***/
569 }
570 if (pid == -1) /* didn't fork or fork failed */
571 return(0);
572 _exit(0); /* else exit child process (releasing locks) */
573 }
574
575
576 static void
577 filerr( /* report file error and exit */
578 char *t
579 )
580 {
581 fprintf(stderr, "%s: %s error on file \"%s\": %s\n",
582 progname, t, outfile, strerror(errno));
583 _exit(1);
584 }
585
586 #endif
