--- ray/src/util/rpiece.c 1998/06/18 09:23:49 2.36 +++ ray/src/util/rpiece.c 2003/07/27 22:12:04 2.41 @@ -1,9 +1,6 @@ -/* Copyright (c) 1995 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: rpiece.c,v 2.41 2003/07/27 22:12:04 schorsch Exp $"; #endif - /* * Generate sections of a picture. */ @@ -23,9 +20,10 @@ char *argv[]; #else #include + #include "color.h" #include "view.h" -#include "resolu.h" +#include "rtprocess.h" #ifndef NFS #define NFS 1 @@ -48,14 +46,11 @@ char *argv[]; #define unguard() 0 #endif -#ifndef linux -extern char *sys_errlist[]; -#endif +extern char *strerror(); /* rpict command */ char *rpargv[128] = {"rpict", "-S", "1"}; int rpargc = 3; -int rpd[3]; FILE *torp, *fromrp; COLR *pbuf; /* our view parameters */ @@ -78,7 +73,7 @@ unsigned timelim = 0; int rvrlim = -1; int gotalrm = 0; -int onalrm() { gotalrm++; } +void onalrm(int i) { gotalrm++; } main(argc, argv) @@ -90,12 +85,13 @@ char *argv[]; progname = argv[0]; for (i = 1; i < argc; i++) { /* expand arguments */ - while (rval = expandarg(&argc, &argv, i)) - if (rval < 0) { - fprintf(stderr, "%s: cannot expand '%s'", - argv[0], argv[i]); - exit(1); - } + while ((rval = expandarg(&argc, &argv, i)) > 0) + ; + if (rval < 0) { + fprintf(stderr, "%s: cannot expand '%s'", + argv[0], argv[i]); + exit(1); + } if (argv[i][0] == '-') switch (argv[i][1]) { case 'v': @@ -200,7 +196,7 @@ int ltyp; fls.l_type = ltyp; if (fcntl(fd, F_SETLKW, &fls) < 0) { fprintf(stderr, "%s: cannot lock/unlock file: %s\n", - progname, sys_errlist[errno]); + progname, strerror(errno)); exit(1); } } @@ -215,6 +211,7 @@ char **av; char *err; FILE *fp; int hr, vr; + SUBPROC rpd; /* since we don't close_process(), this can be local */ /* set up view */ if ((err = setview(&ourview)) != NULL) { fprintf(stderr, "%s: %s\n", progname, err); @@ -273,12 +270,12 @@ char **av; goto filerr; dolock(outfd, F_UNLCK); /* start rpict process */ - if (open_process(rpd, rpargv) <= 0) { + if (open_process(&rpd, rpargv) <= 0) { fprintf(stderr, "%s: cannot start %s\n", progname, rpargv[0]); exit(1); } - if ((fromrp = fdopen(rpd[0], "r")) == NULL || - (torp = fdopen(rpd[1], "w")) == NULL) { + if ((fromrp = fdopen(rpd.r, "r")) == NULL || + (torp = fdopen(rpd.w, "w")) == NULL) { fprintf(stderr, "%s: cannot open stream to %s\n", progname, rpargv[0]); exit(1); @@ -404,7 +401,7 @@ rpiece() /* render picture piece by piece */ VIEW pview; int xorg, yorg; /* compute view parameters */ - copystruct(&pview, &ourview); + pview = ourview; switch (ourview.type) { case VT_PER: pview.horiz = 2.*180./PI*atan( @@ -455,7 +452,7 @@ int xpos, ypos; int hr, vr; register int y; /* check bounds */ - if (xpos < 0 | ypos < 0 | xpos >= hmult | ypos >= vmult) { + if ((xpos < 0) | (ypos < 0) | (xpos >= hmult) | (ypos >= vmult)) { fprintf(stderr, "%s: requested piece (%d,%d) out of range\n", progname, xpos, ypos); exit(cleanup(1)); @@ -463,7 +460,7 @@ int xpos, ypos; /* check header from rpict */ guard_io(); getheader(fromrp, NULL, NULL); - if (!fscnresolu(&hr, &vr, fromrp) || hr != hres | vr != vres) { + if (!fscnresolu(&hr, &vr, fromrp) || (hr != hres) | (vr != vres)) { fprintf(stderr, "%s: resolution mismatch from %s\n", progname, rpargv[0]); exit(cleanup(1)); @@ -508,7 +505,7 @@ int xpos, ypos; filerr("lock"); #endif /* write new piece to file */ - if (lseek(outfd, fls.l_start, 0) < 0) + if (lseek(outfd, (off_t)fls.l_start, 0) < 0) filerr("seek"); if (hmult == 1) { if (writebuf(outfd, (char *)pbuf, @@ -520,7 +517,7 @@ int xpos, ypos; hr*sizeof(COLR)) != hr*sizeof(COLR)) filerr("write"); if (y < vr-1 && lseek(outfd, - (long)(hmult-1)*hr*sizeof(COLR), + (off_t)(hmult-1)*hr*sizeof(COLR), 1) < 0) filerr("seek"); } @@ -551,7 +548,7 @@ filerr(t) /* report file error and exit */ char *t; { fprintf(stderr, "%s: %s error on file \"%s\": %s\n", - progname, t, outfile, sys_errlist[errno]); + progname, t, outfile, strerror(errno)); _exit(1); }
