root/radiance/ray/src/util/rpiece.c
Revision: 2.1
Committed: Thu Aug 6 16:45:01 1992 UTC (31 years, 10 months ago) by greg
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Generate sections of a picture.
9 */
10
11 #include "standard.h"
12 #include <fcntl.h>
13 #include "color.h"
14 #include "view.h"
15 #include "resolu.h"
16
17 /* rpict command */
18 char *rpargv[128] = {"rpict", "-S", "1", "-x", "512", "-y", "512", };
19 int rpargc = 7;
20 int rpd[3];
21 FILE *torp, *fromrp;
22 COLR *scanline;
23 /* our view parameters */
24 VIEW ourview = STDVIEW;
25 double pixaspect = 0.0;
26 int hres = 512, vres = 512, hmult = 2, vmult = 2;
27 /* output file */
28 char *outfile = NULL;
29 int outfd;
30 long scanorig;
31
32 char *progname;
33 int verbose = 0;
34
35 extern long lseek(), ftell();
36
37
38 main(argc, argv)
39 int argc;
40 char *argv[];
41 {
42 register int i, rval;
43
44 progname = argv[0];
45 for (i = 1; i < argc; i++) {
46 if (argv[i][0] == '-')
47 switch (argv[i][1]) {
48 case 'v':
49 switch (argv[i][2]) {
50 case '\0': /* verbose option */
51 verbose = !verbose;
52 continue;
53 case 'f': /* view file */
54 if (viewfile(argv[++i], &ourview, NULL) <= 0) {
55 fprintf(stderr,
56 "%s: not a view file\n", argv[i]);
57 exit(1);
58 }
59 continue;
60 default: /* view option? */
61 rval = getviewopt(&ourview, argc-i, argv+i);
62 if (rval >= 0) {
63 i += rval;
64 continue;
65 }
66 break;
67 }
68 break;
69 case 'p': /* pixel aspect ratio? */
70 if (argv[i][2] == 'a' && !argv[i][3])
71 pixaspect = atof(argv[i+1]);
72 break;
73 case 'x': /* piece x resolution */
74 if (!argv[i][2])
75 hres = atoi(argv[i+1]);
76 break;
77 case 'y': /* piece y resolution */
78 if (!argv[i][2])
79 vres = atoi(argv[i+1]);
80 break;
81 case 'X': /* horizontal multiplier */
82 if (argv[i][2])
83 break;
84 hmult = atoi(argv[++i]);
85 continue;
86 case 'Y': /* vertical multiplier */
87 if (argv[i][2])
88 break;
89 vmult = atoi(argv[++i]);
90 continue;
91 case 'o': /* output file */
92 if (argv[i][2])
93 break;
94 outfile = argv[++i];
95 continue;
96 }
97 rpargv[rpargc++] = argv[i];
98 }
99 rpargv[rpargc] = NULL;
100 if (outfile == NULL) {
101 fprintf(stderr, "%s: missing output file\n", argv[0]);
102 exit(1);
103 }
104 init(argc, argv);
105 rpiece();
106 rval = cleanup();
107 exit(rval);
108 }
109
110
111 init(ac, av) /* set up output file and start rpict */
112 int ac;
113 char **av;
114 {
115 char *err;
116 FILE *fp;
117 int hr, vr;
118 /* set up view */
119 if ((err = setview(&ourview)) != NULL) {
120 fprintf(stderr, "%s: %s\n", progname, err);
121 exit(1);
122 }
123 normaspect(viewaspect(&ourview)*hmult/vmult, &pixaspect, &hres, &vres);
124 /* open output file */
125 if ((outfd = open(outfile, O_WRONLY|O_CREAT|O_EXCL, 0666)) >= 0) {
126 if ((fp = fdopen(dup(outfd), "w")) == NULL)
127 goto filerr;
128 printargs(ac, av, fp); /* write header */
129 fputs(VIEWSTR, fp);
130 fprintview(&ourview, fp);
131 putc('\n', fp);
132 if (pixaspect < .99 || pixaspect > 1.01)
133 fputaspect(pixaspect, fp);
134 fputformat(COLRFMT, fp);
135 putc('\n', fp);
136 fprtresolu(hres*hmult, vres*vmult, fp);
137 } else if ((outfd = open(outfile, O_RDWR)) >= 0) {
138 sleep(30); /* wait for header */
139 if ((fp = fdopen(dup(outfd), "r+")) == NULL)
140 goto filerr;
141 getheader(fp, NULL); /* skip header */
142 if (fscnresolu(&hr, &vr, fp) < 0 || /* check resolution */
143 hr != hres*hmult || vr != vres*vmult) {
144 fprintf(stderr, "%s: picture resolution mismatch\n",
145 outfile);
146 exit(1);
147 }
148 } else {
149 fprintf(stderr, "%s: cannot open\n", outfile);
150 exit(1);
151 }
152 scanorig = ftell(fp); /* record position of first scanline */
153 if (fclose(fp) == -1) /* done with stream i/o */
154 goto filerr;
155 /* start rpict process */
156 if (open_process(rpd, rpargv) <= 0) {
157 fprintf(stderr, "%s: cannot start\n", rpargv[0]);
158 exit(1);
159 }
160 if ((fromrp = fdopen(rpd[0], "r")) == NULL ||
161 (torp = fdopen(rpd[1], "w")) == NULL) {
162 fprintf(stderr, "%s: cannot open stream to %s\n",
163 progname, rpargv[0]);
164 exit(1);
165 }
166 if ((scanline = (COLR *)malloc(hres*sizeof(COLR))) == NULL) {
167 fprintf(stderr, "%s: out of memory\n", progname);
168 exit(1);
169 }
170 return;
171 filerr:
172 fprintf(stderr, "%s: file i/o error\n", outfile);
173 exit(1);
174 }
175
176
177 int
178 cleanup() /* close rpict process and clean up */
179 {
180 register int rpstat;
181
182 free((char *)scanline);
183 fclose(torp);
184 fclose(fromrp);
185 rpstat = close_process(rpd);
186 if (rpstat == -1)
187 rpstat = 0;
188 return(rpstat);
189 }
190
191
192 rpiece() /* render picture piece by piece */
193 {
194 extern char *gets(), *strcat();
195 VIEW pview;
196 char buf[48];
197 int xorg, yorg;
198
199 while (gets(buf) != NULL) {
200 if (sscanf(buf, "%d %d", &xorg, &yorg) != 2) {
201 fprintf(stderr, "%s: input format error\n", progname);
202 exit(1);
203 }
204 copystruct(&pview, &ourview); /* compute view for piece */
205 switch (ourview.type) {
206 case VT_PER:
207 pview.horiz = 2.*180./PI*atan(
208 tan(PI/180./2.*ourview.horiz)/hmult );
209 pview.vert = 2.*180./PI*atan(
210 tan(PI/180./2.*ourview.vert)/vmult );
211 break;
212 case VT_PAR:
213 case VT_ANG:
214 pview.horiz = ourview.horiz / hmult;
215 pview.vert = ourview.vert / vmult;
216 break;
217 case VT_HEM:
218 default:
219 fprintf(stderr, "%s: unknown view type '-vt%c'\n",
220 progname, ourview.type);
221 exit(1);
222 }
223 pview.hoff += xorg - 0.5*(hmult-1);
224 pview.voff += yorg - 0.5*(vmult-1);
225 fputs(VIEWSTR, torp);
226 fprintview(&pview, torp);
227 putc('\n', torp);
228 fflush(torp); /* assign piece to rpict */
229 putpiece(xorg, yorg); /* place piece in output */
230 if (verbose) { /* notify caller */
231 strcat(buf, " done\n");
232 writebuf(fileno(stdout), buf, strlen(buf));
233 }
234 }
235 }
236
237
238 putpiece(xpos, ypos) /* get next piece from rpict */
239 int xpos, ypos;
240 {
241 int hr, vr;
242 int y;
243
244 getheader(fromrp, NULL); /* discard header info. */
245 if (fscnresolu(&hr, &vr, fromrp) < 0 || /* check resolution */
246 hr != hres || vr != vres) {
247 fprintf(stderr, "%s: resolution mismatch from rpict\n",
248 progname);
249 exit(1);
250 }
251 for (y = 0; y < vr; y++) { /* transfer scanlines */
252 if (freadcolrs(scanline, hr, fromrp) < 0) {
253 fprintf(stderr, "%s: read error from rpict\n",
254 progname);
255 exit(1);
256 }
257 if ((y == 0 || hmult != 1) && lseek(outfd,
258 scanorig+((long)((vmult-1-ypos)*vres+y)*hmult*hres+xpos*hres)*sizeof(COLR),
259 0) == -1) {
260 fprintf(stderr, "%s: seek error\n", outfile);
261 exit(1);
262 }
263 if (writebuf(outfd, (char *)scanline, hr*sizeof(COLR)) !=
264 hr*sizeof(COLR)) {
265 fprintf(stderr, "%s: write error\n", outfile);
266 exit(1);
267 }
268 }
269 }
