--- ray/src/util/rpiece.c 2012/06/01 22:55:14 2.54 +++ ray/src/util/rpiece.c 2023/07/11 02:22:30 2.60 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rpiece.c,v 2.54 2012/06/01 22:55:14 greg Exp $"; +static const char RCSid[] = "$Id: rpiece.c,v 2.60 2023/07/11 02:22:30 greg Exp $"; #endif /* * Generate sections of a picture. @@ -37,7 +37,11 @@ main( #ifndef NFS #define NFS 1 #endif - /* set the following to 0 to forgo forking */ + +#ifndef RHAS_FORK_EXEC +#undef MAXFORK +#define MAXFORK 0 +#endif #ifndef MAXFORK #if NFS #define MAXFORK 3 /* allotment of duped processes */ @@ -101,7 +105,7 @@ main( char *argv[] ) { - register int i, rval; + int i, rval; progname = argv[0]; for (i = 1; i < argc; i++) { @@ -275,7 +279,7 @@ init( /* set up output file and start rpict */ normaspect(viewaspect(&ourview)*hmult/vmult, &pixaspect, &hres, &vres); if (!nowarn && (hr != hres*hmult) | (vr != vres*vmult)) fprintf(stderr, - "%s: warning - resolution changed from %dx%d to %dx%d\n", + "%s: warning - changed resolution from %dx%d to %dx%d\n", progname, hr, vr, hres*hmult, vres*vmult); sprintf(hrbuf, "%d", hres); rpargv[rpargc++] = "-x"; rpargv[rpargc++] = hrbuf; @@ -294,12 +298,13 @@ init( /* set up output file and start rpict */ fprintf(fp, "SOFTWARE= %s\n", VersionID); fputs(VIEWSTR, fp); fprintview(&ourview, fp); - putc('\n', fp); + fputc('\n', fp); fputnow(fp); if (pixaspect < .99 || pixaspect > 1.01) fputaspect(pixaspect, fp); + fputprims(stdprims, fp); fputformat(COLRFMT, fp); - putc('\n', fp); + fputc('\n', fp); fprtresolu(hres*hmult, vres*vmult, fp); } else if ((outfd = open(outfile, O_RDWR)) >= 0) { dolock(outfd, F_RDLCK); @@ -322,6 +327,7 @@ init( /* set up output file and start rpict */ goto filerr; dolock(outfd, F_UNLCK); /* start rpict process */ + rpd = sp_inactive; if (open_process(&rpd, rpargv) <= 0) { fprintf(stderr, "%s: cannot start %s\n", progname, rpargv[0]); exit(1); @@ -392,13 +398,13 @@ nextpiece( /* get next piece assignment */ static int rvrpiece( /* check for recoverable pieces */ - register int *xp, - register int *yp + int *xp, + int *yp ) { static char *pdone = NULL; /* which pieces are done */ static long readpos = -1; /* how far we've read */ - register int i; + int px, py, i; /* * This routine is called by nextpiece() with an * exclusive lock on syncfp and the file pointer at the @@ -407,15 +413,15 @@ rvrpiece( /* check for recoverable pieces */ if (rvrlim < 0) return(0); /* only check if asked */ if (pdone == NULL) /* first call */ - pdone = calloc(hmult*vmult, sizeof(char)); + pdone = (char *)calloc(hmult*vmult, sizeof(char)); if (pdone == NULL) { fprintf(stderr, "%s: out of memory\n", progname); exit(1); } if (readpos != -1) /* mark what's been done */ fseek(syncfp, readpos, 0); - while (fscanf(syncfp, "%d %d", xp, yp) == 2) - pdone[*xp*vmult+*yp] = 1; + while (fscanf(syncfp, "%d %d", &px, &py) == 2) + pdone[px*vmult+py] = 1; if (!feof(syncfp)) { fprintf(stderr, "%s: format error in sync file\n", progname); exit(1); @@ -456,57 +462,21 @@ cleanup( /* close rpict process and clean up */ static void rpiece(void) /* render picture piece by piece */ { + char *err; VIEW pview; int xorg, yorg; - /* compute view parameters */ - pview = ourview; - switch (ourview.type) { - case VT_PER: - pview.horiz = (2.*180./PI)*atan( - tan((PI/180./2.)*ourview.horiz)/hmult ); - pview.vert = (2.*180./PI)*atan( - tan((PI/180./2.)*ourview.vert)/vmult ); - break; - case VT_PAR: - case VT_ANG: - pview.horiz = ourview.horiz / hmult; - pview.vert = ourview.vert / vmult; - break; - case VT_CYL: - pview.horiz = ourview.horiz / hmult; - pview.vert = (2.*180./PI)*atan( - tan((PI/180./2.)*ourview.vert)/vmult ); - break; - case VT_HEM: - pview.horiz = (2.*180./PI)*asin( - sin((PI/180./2.)*ourview.horiz)/hmult ); - pview.vert = (2.*180./PI)*asin( - sin((PI/180./2.)*ourview.vert)/vmult ); - break; - case VT_PLS: - pview.horiz = sin((PI/180./2.)*ourview.horiz) / - (1.0 + cos((PI/180./2.)*ourview.horiz)) / hmult; - pview.horiz *= pview.horiz; - pview.horiz = (2.*180./PI)*acos((1. - pview.horiz) / - (1. + pview.horiz)); - pview.vert = sin((PI/180./2.)*ourview.vert) / - (1.0 + cos((PI/180./2.)*ourview.vert)) / vmult; - pview.vert *= pview.vert; - pview.vert = (2.*180./PI)*acos((1. - pview.vert) / - (1. + pview.vert)); - break; - default: - fprintf(stderr, "%s: unknown view type '-vt%c'\n", - progname, ourview.type); - exit(cleanup(1)); - } /* render each piece */ while (nextpiece(&xorg, &yorg)) { - pview.hoff = ourview.hoff*hmult + xorg - 0.5*(hmult-1); - pview.voff = ourview.voff*vmult + yorg - 0.5*(vmult-1); + pview = ourview; + err = cropview(&pview, (double)xorg/hmult, (double)yorg/vmult, + (xorg+1.)/hmult, (yorg+1.)/vmult); + if (err != NULL) { + fprintf(stderr, "%s: %s\n", progname, err); + exit(cleanup(1)); + } fputs(VIEWSTR, torp); fprintview(&pview, torp); - putc('\n', torp); + fputc('\n', torp); fflush(torp); /* assigns piece to rpict */ putpiece(xorg, yorg); /* place piece in output */ } @@ -522,7 +492,7 @@ int ypos struct flock fls; int pid, status; int hr, vr; - register int y; + int y; /* check bounds */ if ((xpos < 0) | (ypos < 0) | (xpos >= hmult) | (ypos >= vmult)) { fprintf(stderr, "%s: requested piece (%d,%d) out of range\n",
