root/radiance/ray/src/util/rpiece.c
Revision: 2.18
Committed: Fri Apr 16 12:03:59 1993 UTC (31 years, 1 month ago) by greg
Changes since 2.17: +15 -2 lines
added signal blocking for SYSV during freadcolrs() call
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Generate sections of a picture.
9 */
10
11 #include "standard.h"
12 #include <fcntl.h>
13
14 #ifndef F_SETLKW
15
16 main(argc, argv)
17 int argc;
18 char *argv[];
19 {
20 fprintf(stderr, "%s: no NFS lock manager on this machine\n", argv[0]);
21 exit(1);
22 }
23
24 #else
25
26 #include <signal.h>
27 #include "color.h"
28 #include "view.h"
29 #include "resolu.h"
30
31 #ifndef NFS
32 #define NFS 1
33 #endif
34 /* set the following to 0 to forgo forking */
35 #ifndef MAXFORK
36 #if NFS
37 #define MAXFORK 3 /* allotment of duped processes */
38 #else
39 #define MAXFORK 0
40 #endif
41 #endif
42 /* protection from SYSV signals(!) */
43 #if defined(sgi) || defined(hpux)
44 #define guard_io() sighold(SIGALRM)
45 #define unguard() sigrelse(SIGALRM)
46 #endif
47 #ifndef guard_io
48 #define guard_io() 0
49 #define unguard() 0
50 #endif
51 /* rpict command */
52 char *rpargv[128] = {"rpict", "-S", "1", "-x", "512", "-y", "512", "-pa", "1"};
53 int rpargc = 9;
54 int rpd[3];
55 FILE *torp, *fromrp;
56 COLR *pbuf;
57 /* our view parameters */
58 VIEW ourview = STDVIEW;
59 double pixaspect = 1.0;
60 int hres = 512, vres = 512, hmult = 2, vmult = 2;
61 /* output file */
62 char *outfile = NULL;
63 int outfd;
64 long scanorig;
65 int syncfd = -1; /* lock file descriptor */
66 int nforked = 0;
67
68 char *progname;
69 int verbose = 0;
70
71 extern long lseek(), ftell();
72
73 int gotalrm = 0;
74 int onalrm() { gotalrm++; }
75
76
77 main(argc, argv)
78 int argc;
79 char *argv[];
80 {
81 register int i, rval;
82
83 progname = argv[0];
84 for (i = 1; i < argc; i++) {
85 if (argv[i][0] == '-')
86 switch (argv[i][1]) {
87 case 'v':
88 switch (argv[i][2]) {
89 case '\0': /* verbose option */
90 verbose = !verbose;
91 continue;
92 case 'f': /* view file */
93 if (viewfile(argv[++i], &ourview, NULL) <= 0) {
94 fprintf(stderr,
95 "%s: not a view file\n", argv[i]);
96 exit(1);
97 }
98 continue;
99 default: /* view option? */
100 rval = getviewopt(&ourview, argc-i, argv+i);
101 if (rval >= 0) {
102 i += rval;
103 continue;
104 }
105 break;
106 }
107 break;
108 case 'p': /* pixel aspect ratio? */
109 if (argv[i][2] == 'a' && !argv[i][3])
110 pixaspect = atof(argv[i+1]);
111 break;
112 case 'x': /* piece x resolution */
113 if (!argv[i][2])
114 hres = atoi(argv[i+1]);
115 break;
116 case 'y': /* piece y resolution */
117 if (!argv[i][2])
118 vres = atoi(argv[i+1]);
119 break;
120 case 'X': /* horizontal multiplier */
121 if (argv[i][2])
122 break;
123 hmult = atoi(argv[++i]);
124 continue;
125 case 'Y': /* vertical multiplier */
126 if (argv[i][2])
127 break;
128 vmult = atoi(argv[++i]);
129 continue;
130 case 'F': /* syncronization file */
131 if (argv[i][2])
132 break;
133 if ((syncfd = open(argv[++i],
134 O_RDWR|O_CREAT, 0666)) < 0) {
135 fprintf(stderr, "%s: cannot open\n",
136 argv[i]);
137 exit(1);
138 }
139 continue;
140 case 'z': /* z-file ist verbotten */
141 fprintf(stderr, "%s: -z option not allowed\n",
142 argv[0]);
143 exit(1);
144 case 'o': /* output file */
145 if (argv[i][2])
146 break;
147 outfile = argv[++i];
148 continue;
149 }
150 rpargv[rpargc++] = argv[i];
151 }
152 rpargv[rpargc] = NULL;
153 if (outfile == NULL) {
154 fprintf(stderr, "%s: missing output file\n", argv[0]);
155 exit(1);
156 }
157 init(argc, argv);
158 rpiece();
159 exit(cleanup(0));
160 }
161
162
163 init(ac, av) /* set up output file and start rpict */
164 int ac;
165 char **av;
166 {
167 extern char VersionID[];
168 char *err;
169 FILE *fp;
170 int hr, vr;
171 /* set up view */
172 if ((err = setview(&ourview)) != NULL) {
173 fprintf(stderr, "%s: %s\n", progname, err);
174 exit(1);
175 }
176 if (syncfd != -1) {
177 char buf[32];
178 buf[read(syncfd, buf, sizeof(buf)-1)] = '\0';
179 sscanf(buf, "%d %d", &hmult, &vmult);
180 }
181 normaspect(viewaspect(&ourview)*hmult/vmult, &pixaspect, &hres, &vres);
182 /* open output file */
183 if ((outfd = open(outfile, O_WRONLY|O_CREAT|O_EXCL, 0666)) >= 0) {
184 if ((fp = fdopen(dup(outfd), "w")) == NULL)
185 goto filerr;
186 printargs(ac, av, fp); /* write header */
187 fprintf(fp, "SOFTWARE= %s\n", VersionID);
188 fputs(VIEWSTR, fp);
189 fprintview(&ourview, fp);
190 putc('\n', fp);
191 if (pixaspect < .99 || pixaspect > 1.01)
192 fputaspect(pixaspect, fp);
193 fputformat(COLRFMT, fp);
194 putc('\n', fp);
195 fprtresolu(hres*hmult, vres*vmult, fp);
196 } else if ((outfd = open(outfile, O_RDWR)) >= 0) {
197 if ((fp = fdopen(dup(outfd), "r+")) == NULL)
198 goto filerr;
199 getheader(fp, NULL, NULL); /* skip header */
200 if (!fscnresolu(&hr, &vr, fp) || /* check resolution */
201 hr != hres*hmult || vr != vres*vmult) {
202 fprintf(stderr, "%s: resolution mismatch on file \"%s\"\n",
203 progname, outfile);
204 exit(1);
205 }
206 } else {
207 fprintf(stderr, "%s: cannot open file \"%s\"\n",
208 progname, outfile);
209 exit(1);
210 }
211 scanorig = ftell(fp); /* record position of first scanline */
212 if (fclose(fp) == -1) /* done with stream i/o */
213 goto filerr;
214 #if NFS
215 sync(); /* flush NFS buffers */
216 #endif
217 /* start rpict process */
218 if (open_process(rpd, rpargv) <= 0) {
219 fprintf(stderr, "%s: cannot start %s\n", progname, rpargv[0]);
220 exit(1);
221 }
222 if ((fromrp = fdopen(rpd[0], "r")) == NULL ||
223 (torp = fdopen(rpd[1], "w")) == NULL) {
224 fprintf(stderr, "%s: cannot open stream to %s\n",
225 progname, rpargv[0]);
226 exit(1);
227 }
228 if ((pbuf = (COLR *)malloc(hres*vres*sizeof(COLR))) == NULL) {
229 fprintf(stderr, "%s: out of memory\n", progname);
230 exit(1);
231 }
232 signal(SIGALRM, onalrm);
233 return;
234 filerr:
235 fprintf(stderr, "%s: i/o error on file \"%s\"\n", progname, outfile);
236 exit(1);
237 }
238
239
240 int
241 nextpiece(xp, yp) /* get next piece assignment */
242 int *xp, *yp;
243 {
244 extern char *fgets();
245 struct flock fls;
246 char buf[64];
247
248 if (gotalrm) /* someone wants us to quit */
249 return(0);
250 if (syncfd != -1) { /* use sync file */
251 fls.l_type = F_WRLCK; /* gain exclusive access */
252 fls.l_whence = 0;
253 fls.l_start = 0L;
254 fls.l_len = 0L;
255 fcntl(syncfd, F_SETLKW, &fls);
256 lseek(syncfd, 0L, 0);
257 buf[read(syncfd, buf, sizeof(buf)-1)] = '\0';
258 if (sscanf(buf, "%*d %*d %d %d", xp, yp) < 2) {
259 *xp = hmult-1;
260 *yp = vmult;
261 }
262 if (--(*yp) < 0) { /* decrement position */
263 *yp = vmult-1;
264 if (--(*xp) < 0) { /* all done! */
265 close(syncfd);
266 return(0);
267 }
268 }
269 sprintf(buf, "%4d %4d\n%4d %4d\n", hmult, vmult, *xp, *yp);
270 lseek(syncfd, 0L, 0); /* write new position */
271 write(syncfd, buf, strlen(buf));
272 fls.l_type = F_UNLCK; /* release sync file */
273 fcntl(syncfd, F_SETLKW, &fls);
274 return(1);
275 }
276 if (fgets(buf, sizeof(buf), stdin) == NULL) /* use stdin */
277 return(0);
278 if (sscanf(buf, "%d %d", xp, yp) == 2)
279 return(1);
280 fprintf(stderr, "%s: input format error\n", progname);
281 exit(cleanup(1));
282 }
283
284
285 int
286 cleanup(rstat) /* close rpict process and clean up */
287 int rstat;
288 {
289 int status;
290
291 free((char *)pbuf);
292 fclose(torp);
293 fclose(fromrp);
294 while (wait(&status) != -1)
295 if (rstat == 0)
296 rstat = status>>8 & 0xff;
297 return(rstat);
298 }
299
300
301 rpiece() /* render picture piece by piece */
302 {
303 VIEW pview;
304 int xorg, yorg;
305 /* compute view parameters */
306 copystruct(&pview, &ourview);
307 switch (ourview.type) {
308 case VT_PER:
309 pview.horiz = 2.*180./PI*atan(
310 tan(PI/180./2.*ourview.horiz)/hmult );
311 pview.vert = 2.*180./PI*atan(
312 tan(PI/180./2.*ourview.vert)/vmult );
313 break;
314 case VT_PAR:
315 case VT_ANG:
316 pview.horiz = ourview.horiz / hmult;
317 pview.vert = ourview.vert / vmult;
318 break;
319 case VT_HEM:
320 pview.horiz = 2.*180./PI*asin(
321 sin(PI/180./2.*ourview.horiz)/hmult );
322 pview.vert = 2.*180./PI*asin(
323 sin(PI/180./2.*ourview.vert)/vmult );
324 break;
325 default:
326 fprintf(stderr, "%s: unknown view type '-vt%c'\n",
327 progname, ourview.type);
328 exit(cleanup(1));
329 }
330 /* render each piece */
331 while (nextpiece(&xorg, &yorg)) {
332 pview.hoff = ourview.hoff + xorg - 0.5*(hmult-1);
333 pview.voff = ourview.voff + yorg - 0.5*(vmult-1);
334 fputs(VIEWSTR, torp);
335 fprintview(&pview, torp);
336 putc('\n', torp);
337 fflush(torp); /* assigns piece to rpict */
338 putpiece(xorg, yorg); /* place piece in output */
339 if (verbose) { /* notify caller */
340 printf("%d %d done\n", xorg, yorg);
341 fflush(stdout);
342 }
343 }
344 }
345
346
347 int
348 putpiece(xpos, ypos) /* get next piece from rpict */
349 int xpos, ypos;
350 {
351 struct flock fls;
352 int pid, status;
353 int hr, vr;
354 register int y;
355 /* check bounds */
356 if (xpos < 0 | ypos < 0 | xpos >= hmult | ypos >= vmult) {
357 fprintf(stderr, "%s: requested piece (%d,%d) out of range\n",
358 progname, xpos, ypos);
359 exit(cleanup(1));
360 }
361 /* check header from rpict */
362 guard_io();
363 getheader(fromrp, NULL, NULL);
364 if (!fscnresolu(&hr, &vr, fromrp) || hr != hres | vr != vres) {
365 fprintf(stderr, "%s: resolution mismatch from %s\n",
366 progname, rpargv[0]);
367 exit(cleanup(1));
368 }
369 unguard();
370 /* load new piece into buffer */
371 for (y = 0; y < vr; y++) {
372 guard_io();
373 if (freadcolrs(pbuf+y*hr, hr, fromrp) < 0) {
374 fprintf(stderr, "%s: read error from %s\n",
375 progname, rpargv[0]);
376 exit(cleanup(1));
377 }
378 unguard();
379 }
380 #if MAXFORK
381 /* fork so we don't slow rpict down */
382 if ((pid = fork()) > 0) {
383 if (++nforked >= MAXFORK) {
384 wait(&status); /* reap a child */
385 if (status)
386 exit(cleanup(status>>8 & 0xff));
387 nforked--;
388 }
389 return(pid);
390 }
391 #else
392 pid = -1; /* no forking */
393 #endif
394 fls.l_len = (long)vres*hmult*hres*sizeof(COLR);
395 fls.l_start = scanorig + (vmult-1-ypos)*fls.l_len;
396 #if NFS
397 /* lock file section so NFS doesn't mess up */
398 fls.l_whence = 0;
399 fls.l_type = F_WRLCK;
400 fcntl(outfd, F_SETLKW, &fls);
401 #endif
402 /* write new piece to file */
403 if (lseek(outfd, fls.l_start+(long)xpos*hres*sizeof(COLR), 0) == -1)
404 goto seekerr;
405 if (hmult == 1) {
406 if (writebuf(outfd, (char *)pbuf,
407 vr*hr*sizeof(COLR)) != vr*hr*sizeof(COLR))
408 goto writerr;
409 } else
410 for (y = 0; y < vr; y++) {
411 if (writebuf(outfd, (char *)(pbuf+y*hr),
412 hr*sizeof(COLR)) != hr*sizeof(COLR))
413 goto writerr;
414 if (y < vr-1 && lseek(outfd,
415 (long)(hmult-1)*hr*sizeof(COLR),
416 1) == -1)
417 goto seekerr;
418 }
419 if (pid == -1) { /* fork failed */
420 #if NFS
421 fls.l_type = F_UNLCK; /* release lock */
422 fcntl(outfd, F_SETLKW, &fls);
423 #endif
424 return(0);
425 }
426 _exit(0); /* else exit child process (releasing lock) */
427 seekerr:
428 fprintf(stderr, "%s: seek error on file \"%s\"\n", progname, outfile);
429 _exit(1);
430 writerr:
431 fprintf(stderr, "%s: write error on file \"%s\"\n", progname, outfile);
432 _exit(1);
433 }
434
435 #endif
