root/radiance/ray/src/util/rpiece.c
Revision: 2.15
Committed: Thu Jan 21 17:46:31 1993 UTC (31 years, 4 months ago) by greg
Changes since 2.14: +9 -6 lines
minor bug fixes and changes for -PP option
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Generate sections of a picture.
9 */
10
11 #include "standard.h"
12 #include <fcntl.h>
13 #include <signal.h>
14 #include "color.h"
15 #include "view.h"
16 #include "resolu.h"
17
18 #ifndef NFS
19 #define NFS 1
20 #endif
21 /* set the following to 0 to forgo forking */
22 #ifndef MAXFORK
23 #if NFS
24 #define MAXFORK 3 /* allotment of duped processes */
25 #else
26 #define MAXFORK 0
27 #endif
28 #endif
29
30 /* rpict command */
31 char *rpargv[128] = {"rpict", "-S", "1", "-x", "512", "-y", "512", "-pa", "1"};
32 int rpargc = 9;
33 int rpd[3];
34 FILE *torp, *fromrp;
35 COLR *pbuf;
36 /* our view parameters */
37 VIEW ourview = STDVIEW;
38 double pixaspect = 1.0;
39 int hres = 512, vres = 512, hmult = 2, vmult = 2;
40 /* output file */
41 char *outfile = NULL;
42 int outfd;
43 long scanorig;
44 int syncfd = -1; /* lock file descriptor */
45 int nforked = 0;
46
47 char *progname;
48 int verbose = 0;
49
50 extern long lseek(), ftell();
51
52 int gotalrm = 0;
53 int onalrm() { gotalrm++; }
54
55
56 main(argc, argv)
57 int argc;
58 char *argv[];
59 {
60 register int i, rval;
61
62 progname = argv[0];
63 for (i = 1; i < argc; i++) {
64 if (argv[i][0] == '-')
65 switch (argv[i][1]) {
66 case 'v':
67 switch (argv[i][2]) {
68 case '\0': /* verbose option */
69 verbose = !verbose;
70 continue;
71 case 'f': /* view file */
72 if (viewfile(argv[++i], &ourview, NULL) <= 0) {
73 fprintf(stderr,
74 "%s: not a view file\n", argv[i]);
75 exit(1);
76 }
77 continue;
78 default: /* view option? */
79 rval = getviewopt(&ourview, argc-i, argv+i);
80 if (rval >= 0) {
81 i += rval;
82 continue;
83 }
84 break;
85 }
86 break;
87 case 'p': /* pixel aspect ratio? */
88 if (argv[i][2] == 'a' && !argv[i][3])
89 pixaspect = atof(argv[i+1]);
90 break;
91 case 'x': /* piece x resolution */
92 if (!argv[i][2])
93 hres = atoi(argv[i+1]);
94 break;
95 case 'y': /* piece y resolution */
96 if (!argv[i][2])
97 vres = atoi(argv[i+1]);
98 break;
99 case 'X': /* horizontal multiplier */
100 if (argv[i][2])
101 break;
102 hmult = atoi(argv[++i]);
103 continue;
104 case 'Y': /* vertical multiplier */
105 if (argv[i][2])
106 break;
107 vmult = atoi(argv[++i]);
108 continue;
109 case 'F': /* syncronization file */
110 if (argv[i][2])
111 break;
112 if ((syncfd = open(argv[++i],
113 O_RDWR|O_CREAT, 0666)) < 0) {
114 fprintf(stderr, "%s: cannot open\n",
115 argv[i]);
116 exit(1);
117 }
118 continue;
119 case 'z': /* z-file ist verbotten */
120 fprintf(stderr, "%s: -z option not allowed\n",
121 argv[0]);
122 exit(1);
123 case 'o': /* output file */
124 if (argv[i][2])
125 break;
126 outfile = argv[++i];
127 continue;
128 }
129 rpargv[rpargc++] = argv[i];
130 }
131 rpargv[rpargc] = NULL;
132 if (outfile == NULL) {
133 fprintf(stderr, "%s: missing output file\n", argv[0]);
134 exit(1);
135 }
136 init(argc, argv);
137 rpiece();
138 exit(cleanup(0));
139 }
140
141
142 init(ac, av) /* set up output file and start rpict */
143 int ac;
144 char **av;
145 {
146 extern char VersionID[];
147 char *err;
148 FILE *fp;
149 int hr, vr;
150 /* set up view */
151 if ((err = setview(&ourview)) != NULL) {
152 fprintf(stderr, "%s: %s\n", progname, err);
153 exit(1);
154 }
155 if (syncfd != -1) {
156 char buf[32];
157 buf[read(syncfd, buf, sizeof(buf)-1)] = '\0';
158 sscanf(buf, "%d %d", &hmult, &vmult);
159 }
160 normaspect(viewaspect(&ourview)*hmult/vmult, &pixaspect, &hres, &vres);
161 /* open output file */
162 if ((outfd = open(outfile, O_WRONLY|O_CREAT|O_EXCL, 0666)) >= 0) {
163 if ((fp = fdopen(dup(outfd), "w")) == NULL)
164 goto filerr;
165 printargs(ac, av, fp); /* write header */
166 fprintf(fp, "SOFTWARE= %s\n", VersionID);
167 fputs(VIEWSTR, fp);
168 fprintview(&ourview, fp);
169 putc('\n', fp);
170 if (pixaspect < .99 || pixaspect > 1.01)
171 fputaspect(pixaspect, fp);
172 fputformat(COLRFMT, fp);
173 putc('\n', fp);
174 fprtresolu(hres*hmult, vres*vmult, fp);
175 } else if ((outfd = open(outfile, O_RDWR)) >= 0) {
176 if ((fp = fdopen(dup(outfd), "r+")) == NULL)
177 goto filerr;
178 getheader(fp, NULL, NULL); /* skip header */
179 if (!fscnresolu(&hr, &vr, fp) || /* check resolution */
180 hr != hres*hmult || vr != vres*vmult) {
181 fprintf(stderr, "%s: resolution mismatch on file \"%s\"\n",
182 progname, outfile);
183 exit(1);
184 }
185 } else {
186 fprintf(stderr, "%s: cannot open file \"%s\"\n",
187 progname, outfile);
188 exit(1);
189 }
190 scanorig = ftell(fp); /* record position of first scanline */
191 if (fclose(fp) == -1) /* done with stream i/o */
192 goto filerr;
193 #if NFS
194 sync(); /* flush NFS buffers */
195 #endif
196 /* start rpict process */
197 if (open_process(rpd, rpargv) <= 0) {
198 fprintf(stderr, "%s: cannot start %s\n", progname, rpargv[0]);
199 exit(1);
200 }
201 if ((fromrp = fdopen(rpd[0], "r")) == NULL ||
202 (torp = fdopen(rpd[1], "w")) == NULL) {
203 fprintf(stderr, "%s: cannot open stream to %s\n",
204 progname, rpargv[0]);
205 exit(1);
206 }
207 if ((pbuf = (COLR *)malloc(hres*vres*sizeof(COLR))) == NULL) {
208 fprintf(stderr, "%s: out of memory\n", progname);
209 exit(1);
210 }
211 signal(SIGALRM, onalrm);
212 return;
213 filerr:
214 fprintf(stderr, "%s: i/o error on file \"%s\"\n", progname, outfile);
215 exit(1);
216 }
217
218
219 int
220 nextpiece(xp, yp) /* get next piece assignment */
221 int *xp, *yp;
222 {
223 extern char *fgets();
224 struct flock fls;
225 char buf[64];
226
227 if (gotalrm) /* someone wants us to quit */
228 return(0);
229 if (syncfd != -1) { /* use sync file */
230 fls.l_type = F_WRLCK; /* gain exclusive access */
231 fls.l_whence = 0;
232 fls.l_start = 0L;
233 fls.l_len = 0L;
234 fcntl(syncfd, F_SETLKW, &fls);
235 lseek(syncfd, 0L, 0);
236 buf[read(syncfd, buf, sizeof(buf)-1)] = '\0';
237 if (sscanf(buf, "%*d %*d %d %d", xp, yp) < 2) {
238 *xp = hmult-1;
239 *yp = vmult;
240 }
241 if (--(*yp) < 0) { /* decrement position */
242 *yp = vmult-1;
243 if (--(*xp) < 0) { /* all done! */
244 close(syncfd);
245 return(0);
246 }
247 }
248 sprintf(buf, "%d %d\n%d %d\n", hmult, vmult, *xp, *yp);
249 lseek(syncfd, 0L, 0); /* write new position */
250 write(syncfd, buf, strlen(buf));
251 fls.l_type = F_UNLCK; /* release sync file */
252 fcntl(syncfd, F_SETLKW, &fls);
253 return(1);
254 }
255 if (fgets(buf, sizeof(buf), stdin) == NULL) /* use stdin */
256 return(0);
257 if (sscanf(buf, "%d %d", xp, yp) == 2)
258 return(1);
259 fprintf(stderr, "%s: input format error\n", progname);
260 exit(cleanup(1));
261 }
262
263
264 int
265 cleanup(rstat) /* close rpict process and clean up */
266 int rstat;
267 {
268 int status;
269
270 free((char *)pbuf);
271 fclose(torp);
272 fclose(fromrp);
273 while (wait(&status) != -1)
274 if (rstat == 0)
275 rstat = status>>8 & 0xff;
276 return(rstat);
277 }
278
279
280 rpiece() /* render picture piece by piece */
281 {
282 VIEW pview;
283 int xorg, yorg;
284 /* compute view parameters */
285 copystruct(&pview, &ourview);
286 switch (ourview.type) {
287 case VT_PER:
288 pview.horiz = 2.*180./PI*atan(
289 tan(PI/180./2.*ourview.horiz)/hmult );
290 pview.vert = 2.*180./PI*atan(
291 tan(PI/180./2.*ourview.vert)/vmult );
292 break;
293 case VT_PAR:
294 case VT_ANG:
295 pview.horiz = ourview.horiz / hmult;
296 pview.vert = ourview.vert / vmult;
297 break;
298 case VT_HEM:
299 pview.horiz = 2.*180./PI*asin(
300 sin(PI/180./2.*ourview.horiz)/hmult );
301 pview.vert = 2.*180./PI*asin(
302 sin(PI/180./2.*ourview.vert)/vmult );
303 break;
304 default:
305 fprintf(stderr, "%s: unknown view type '-vt%c'\n",
306 progname, ourview.type);
307 exit(cleanup(1));
308 }
309 /* render each piece */
310 while (nextpiece(&xorg, &yorg)) {
311 pview.hoff = ourview.hoff + xorg - 0.5*(hmult-1);
312 pview.voff = ourview.voff + yorg - 0.5*(vmult-1);
313 fputs(VIEWSTR, torp);
314 fprintview(&pview, torp);
315 putc('\n', torp);
316 fflush(torp); /* assigns piece to rpict */
317 putpiece(xorg, yorg); /* place piece in output */
318 if (verbose) { /* notify caller */
319 printf("%d %d done\n", xorg, yorg);
320 fflush(stdout);
321 }
322 }
323 }
324
325
326 int
327 putpiece(xpos, ypos) /* get next piece from rpict */
328 int xpos, ypos;
329 {
330 struct flock fls;
331 int pid, status;
332 int hr, vr;
333 register int y;
334 /* check bounds */
335 if (xpos < 0 | ypos < 0 | xpos >= hmult | ypos >= vmult) {
336 fprintf(stderr, "%s: requested piece (%d,%d) out of range\n",
337 progname, xpos, ypos);
338 exit(cleanup(1));
339 }
340 /* check header from rpict */
341 getheader(fromrp, NULL, NULL);
342 if (!fscnresolu(&hr, &vr, fromrp) || hr != hres | vr != vres) {
343 fprintf(stderr, "%s: resolution mismatch from %s\n",
344 progname, rpargv[0]);
345 exit(cleanup(1));
346 }
347 /* load new piece into buffer */
348 for (y = 0; y < vr; y++)
349 if (freadcolrs(pbuf+y*hr, hr, fromrp) < 0) {
350 fprintf(stderr, "%s: read error from %s\n",
351 progname, rpargv[0]);
352 exit(cleanup(1));
353 }
354 #if MAXFORK
355 /* fork so we don't slow rpict down */
356 if ((pid = fork()) > 0) {
357 if (++nforked >= MAXFORK) {
358 wait(&status); /* reap a child */
359 if (status)
360 exit(cleanup(status>>8 & 0xff));
361 nforked--;
362 }
363 return(pid);
364 }
365 #else
366 pid = -1; /* no forking */
367 #endif
368 fls.l_len = (long)vres*hmult*hres*sizeof(COLR);
369 fls.l_start = scanorig + (vmult-1-ypos)*fls.l_len;
370 #if NFS
371 /* lock file section so NFS doesn't mess up */
372 fls.l_whence = 0;
373 fls.l_type = F_WRLCK;
374 fcntl(outfd, F_SETLKW, &fls);
375 #endif
376 /* write new piece to file */
377 if (lseek(outfd, fls.l_start+(long)xpos*hres*sizeof(COLR), 0) == -1)
378 goto seekerr;
379 if (hmult == 1) {
380 if (writebuf(outfd, (char *)pbuf,
381 vr*hr*sizeof(COLR)) != vr*hr*sizeof(COLR))
382 goto writerr;
383 } else
384 for (y = 0; y < vr; y++) {
385 if (writebuf(outfd, (char *)(pbuf+y*hr),
386 hr*sizeof(COLR)) != hr*sizeof(COLR))
387 goto writerr;
388 if (y < vr-1 && lseek(outfd,
389 (long)(hmult-1)*hr*sizeof(COLR),
390 1) == -1)
391 goto seekerr;
392 }
393 if (pid == -1) { /* fork failed */
394 #if NFS
395 fls.l_type = F_UNLCK; /* release lock */
396 fcntl(outfd, F_SETLKW, &fls);
397 #endif
398 return(0);
399 }
400 _exit(0); /* else exit child process (releasing lock) */
401 seekerr:
402 fprintf(stderr, "%s: seek error on file \"%s\"\n", progname, outfile);
403 _exit(1);
404 writerr:
405 fprintf(stderr, "%s: write error on file \"%s\"\n", progname, outfile);
406 _exit(1);
407 }
