root/radiance/ray/src/util/rmtxop.c
Revision: 2.32
Committed: Tue Dec 19 16:09:20 2023 UTC (4 months, 2 weeks ago) by greg
Error occurred while calculating annotation data.
fix(rmtxop,rcomb): Added checks for "xyz" and "rgb" format output
2 static const char RCSid[] = "$Id: rmtxop.c,v 2.31 2023/12/19 00:39:03 greg Exp $";
5 * General component matrix operations.
6 */
7
8 #include <errno.h>
9 #include "rtio.h"
10 #include "resolu.h"
11 #include "rmatrix.h"
12 #include "platform.h"
13
14 #define MAXCOMP MAXCSAMP /* #components we support */
15
16 /* Unary matrix operation(s) */
17 typedef struct {
18 double cmat[MAXCOMP*MAXCOMP]; /* component transformation */
19 double sca[MAXCOMP]; /* scalar coefficients */
20 const char *csym; /* symbolic coefs or file */
21 short clen; /* number of coefficients */
22 short nsf; /* number of scalars */
23 short transpose; /* do transpose? */
24 } RUNARYOP;
25
26 /* Matrix input source and requested operation(s) */
27 typedef struct {
28 const char *inspec; /* input specification */
29 RMPref rmp; /* matrix preference */
30 RUNARYOP preop; /* unary operation(s) */
31 RMATRIX *mtx; /* original matrix if loaded */
32 int binop; /* binary op with next (or 0) */
33 } ROPMAT;
34
35 int verbose = 0; /* verbose reporting? */
36
37 /* Load matrix */
38 static int
39 loadmatrix(ROPMAT *rop)
40 {
41 if (rop->mtx != NULL) /* already loaded? */
42 return(0);
43
44 rop->mtx = rmx_load(rop->inspec, rop->rmp);
45
46 return(!rop->mtx ? -1 : 1);
47 }
48
49 static int checksymbolic(ROPMAT *rop);
50
51 /* Check/set transform based on a reference input file */
52 static int
53 checkreffile(ROPMAT *rop)
54 {
55 static const char *curRF = NULL;
56 static RMATRIX refm;
57 const int nc = rop->mtx->ncomp;
58 int i;
59
60 if (!curRF || strcmp(rop->preop.csym, curRF)) {
61 FILE *fp = fopen(rop->preop.csym, "rb");
62 if (!rmx_load_header(&refm, fp)) {
63 fprintf(stderr, "%s: cannot read info header\n",
64 rop->preop.csym);
65 curRF = NULL;
66 if (fp) fclose(fp);
67 return(-1);
68 }
69 fclose(fp);
70 curRF = rop->preop.csym;
71 }
72 if (refm.ncomp == 3) {
73 rop->preop.csym = (refm.dtype == DTxyze) ? "XYZ" : "RGB";
74 return(checksymbolic(rop));
75 }
76 if (refm.ncomp == 2) {
77 fprintf(stderr, "%s: cannot convert to 2 components\n",
78 curRF);
79 return(-1);
80 }
81 if (refm.ncomp == 1) {
82 rop->preop.csym = "Y"; /* XXX big assumption */
83 return(checksymbolic(rop));
84 }
85 if (refm.ncomp == nc &&
86 !memcmp(refm.wlpart, rop->mtx->wlpart, sizeof(refm.wlpart)))
87 return(0); /* nothing to do */
88
89 if ((nc <= 3) | (nc > MAXCSAMP) | (refm.ncomp > MAXCSAMP)) {
90 fprintf(stderr, "%s: cannot resample from %d to %d components\n",
91 curRF, nc, refm.ncomp);
92 return(-1);
93 }
94 rop->preop.clen = refm.ncomp * nc; /* compute spec to ref */
95
96 for (i = 0; i < nc; i++) {
97 SCOLOR scstim, scresp;
98 int j;
99 memset(scstim, 0, sizeof(COLORV)*nc);
100 scstim[i] = 1.f;
101 convertscolor(scresp, refm.ncomp, refm.wlpart[0], refm.wlpart[3],
102 scstim, nc, rop->mtx->wlpart[0], rop->mtx->wlpart[3]);
103 for (j = refm.ncomp; j-- > 0; )
104 rop->preop.cmat[j*nc + i] = scresp[j];
105 }
106 memcpy(rop->mtx->wlpart, refm.wlpart, sizeof(rop->mtx->wlpart));
107 return(0);
108 }
109
110 /* Compute conversion row from spectrum to one channel of RGB */
111 static void
112 rgbrow(ROPMAT *rop, int r, int p)
113 {
114 const int nc = rop->mtx->ncomp;
115 const float * wlp = rop->mtx->wlpart;
116 int i;
117
118 for (i = nc; i--; ) {
119 int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc;
120 int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc;
121 COLOR crgb;
122 spec_rgb(crgb, nmStart, nmEnd);
123 rop->preop.cmat[r*nc+i] = crgb[p];
124 }
125 }
126
127 /* Compute conversion row from spectrum to one channel of XYZ */
128 static void
129 xyzrow(ROPMAT *rop, int r, int p)
130 {
131 const int nc = rop->mtx->ncomp;
132 const float * wlp = rop->mtx->wlpart;
133 int i;
134
135 for (i = nc; i--; ) {
136 int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc;
137 int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc;
138 COLOR cxyz;
139 spec_cie(cxyz, nmStart, nmEnd);
140 rop->preop.cmat[r*nc+i] = cxyz[p];
141 }
142 }
143
144 /* Use the spectral sensitivity function to compute matrix coefficients */
145 static void
146 sensrow(ROPMAT *rop, int r, double (*sf)(SCOLOR sc, int ncs, const float wlpt[4]))
147 {
148 const int nc = rop->mtx->ncomp;
149 int i;
150
151 for (i = nc; i--; ) {
152 SCOLOR sclr;
153 memset(sclr, 0, sizeof(COLORV)*nc);
154 sclr[i] = 1.f;
155 rop->preop.cmat[r*nc+i] = (*sf)(sclr, nc, rop->mtx->wlpart);
156 }
157 }
158
159 /* Check/set symbolic transform */
160 static int
161 checksymbolic(ROPMAT *rop)
162 {
163 const int nc = rop->mtx->ncomp;
164 const int dt = rop->mtx->dtype;
165 double cf = 1;
166 int i, j;
167 /* check suffix => reference file */
168 if (strchr(rop->preop.csym, '.') > rop->preop.csym)
169 return(checkreffile(rop));
170
171 if (nc < 3) {
172 fprintf(stderr, "%s: -c '%s' requires at least 3 components\n",
173 rop->inspec, rop->preop.csym);
174 return(-1);
175 }
176 rop->preop.clen = strlen(rop->preop.csym) * nc;
177 if (rop->preop.clen > MAXCOMP*MAXCOMP) {
178 fprintf(stderr, "%s: -c '%s' results in too many components\n",
179 rop->inspec, rop->preop.csym);
180 return(-1);
181 }
182 for (j = 0; rop->preop.csym[j]; j++) {
183 int comp = 0;
184 switch (rop->preop.csym[j]) {
185 case 'B':
186 case 'b':
187 ++comp;
188 /* fall through */
189 case 'G':
190 case 'g':
191 ++comp;
192 /* fall through */
193 case 'R':
194 case 'r':
195 if (rop->preop.csym[j] <= 'Z')
196 cf = 1./WHTEFFICACY;
197 if (dt == DTxyze) {
198 for (i = 3; i--; )
199 rop->preop.cmat[j*nc+i] = cf*xyz2rgbmat[comp][i];
200 } else if (nc == 3)
201 rop->preop.cmat[j*nc+comp] = 1.;
202 else
203 rgbrow(rop, j, comp);
204 break;
205 case 'Z':
206 case 'z':
207 ++comp;
208 /* fall through */
209 case 'Y':
210 case 'y':
211 ++comp;
212 /* fall through */
213 case 'X':
214 case 'x':
215 if ((rop->preop.csym[j] <= 'Z') & (dt != DTxyze))
216 cf = WHTEFFICACY;
217 if (dt == DTxyze) {
218 rop->preop.cmat[j*nc+comp] = 1.;
219 } else if (nc == 3) {
220 for (i = 3; i--; )
221 rop->preop.cmat[j*nc+i] =
222 rgb2xyzmat[comp][i];
223 } else if (comp == CIEY)
224 sensrow(rop, j, scolor2photopic);
225 else
226 xyzrow(rop, j, comp);
227
228 for (i = nc*(cf != 1); i--; )
229 rop->preop.cmat[j*nc+i] *= cf;
230 break;
231 case 'S': /* scotopic (il)luminance */
232 cf = WHTSCOTOPIC;
233 /* fall through */
234 case 's':
235 sensrow(rop, j, scolor2scotopic);
236 for (i = nc*(cf != 1); i--; )
237 rop->preop.cmat[j*nc+i] *= cf;
238 break;
239 case 'M': /* melanopic (il)luminance */
240 cf = WHTMELANOPIC;
241 /* fall through */
242 case 'm':
243 sensrow(rop, j, scolor2melanopic);
244 for (i = nc*(cf != 1); i--; )
245 rop->preop.cmat[j*nc+i] *= cf;
246 break;
247 case 'A': /* average component */
248 case 'a':
249 for (i = nc; i--; )
250 rop->preop.cmat[j*nc+i] = 1./(double)nc;
251 break;
252 default:
253 fprintf(stderr, "%s: -c '%c' unsupported\n",
254 rop->inspec, rop->preop.csym[j]);
255 return(-1);
256 }
257 }
258 /* return recommended output type */
259 if (!strcasecmp(rop->preop.csym, "XYZ")) {
260 if (dt <= DTspec)
261 return(DTxyze);
262 } else if (!strcasecmp(rop->preop.csym, "RGB")) {
263 if (dt <= DTspec)
264 return(DTrgbe);
265 } else if (dt == DTspec)
266 return(DTfloat); /* probably not actual spectrum */
267 return(0);
268 }
269
270 /* Get matrix and perform unary operations */
271 static RMATRIX *
272 loadop(ROPMAT *rop)
273 {
274 int outtype = 0;
275 RMATRIX *mres;
276 int i, j;
277
278 if (loadmatrix(rop) < 0) /* make sure we're loaded */
279 return(NULL);
280
281 if (rop->preop.csym && /* symbolic transform? */
282 (outtype = checksymbolic(rop)) < 0)
283 goto failure;
284 if (rop->preop.clen > 0) { /* apply component transform? */
285 if (rop->preop.clen % rop->mtx->ncomp) {
286 fprintf(stderr, "%s: -c must have N x %d coefficients\n",
287 rop->inspec, rop->mtx->ncomp);
288 goto failure;
289 }
290 if (rop->preop.nsf > 0) { /* scale transform, first */
291 if (rop->preop.nsf == 1) {
292 for (i = rop->preop.clen; i--; )
293 rop->preop.cmat[i] *= rop->preop.sca[0];
294 } else if (rop->preop.nsf*rop->mtx->ncomp != rop->preop.clen) {
295 fprintf(stderr, "%s: -s must have one or %d factors\n",
296 rop->inspec,
297 rop->preop.clen/rop->mtx->ncomp);
298 goto failure;
299 } else {
300 for (i = rop->preop.nsf; i--; )
301 for (j = rop->mtx->ncomp; j--; )
302 rop->preop.cmat[i*rop->mtx->ncomp+j]
303 *= rop->preop.sca[i];
304 }
305 }
306 mres = rmx_transform(rop->mtx, rop->preop.clen/rop->mtx->ncomp,
307 rop->preop.cmat);
308 if (mres == NULL) {
309 fprintf(stderr, "%s: matrix transform failed\n",
310 rop->inspec);
311 goto failure;
312 }
313 if (verbose)
314 fprintf(stderr, "%s: applied %d x %d transform%s\n",
315 rop->inspec, mres->ncomp,
316 rop->mtx->ncomp,
317 rop->preop.nsf ? " (* scalar)" : "");
318 rop->preop.nsf = 0; /* now folded in */
319 if ((mres->ncomp > 3) & (mres->dtype <= DTspec))
320 outtype = DTfloat; /* probably not actual spectrum */
321 rmx_free(rop->mtx);
322 rop->mtx = mres;
323 }
324 if (rop->preop.nsf > 0) { /* apply scalar(s)? */
325 if (rop->preop.nsf == 1) {
326 for (i = rop->mtx->ncomp; --i; )
327 rop->preop.sca[i] = rop->preop.sca[0];
328 } else if (rop->preop.nsf != rop->mtx->ncomp) {
329 fprintf(stderr, "%s: -s must have one or %d factors\n",
330 rop->inspec, rop->mtx->ncomp);
331 goto failure;
332 }
333 if (!rmx_scale(rop->mtx, rop->preop.sca)) {
334 fputs(rop->inspec, stderr);
335 fputs(": scalar operation failed\n", stderr);
336 goto failure;
337 }
338 if (verbose) {
339 fputs(rop->inspec, stderr);
340 fputs(": applied scalar (", stderr);
341 for (i = 0; i < rop->preop.nsf; i++)
342 fprintf(stderr, " %f", rop->preop.sca[i]);
343 fputs(" )\n", stderr);
344 }
345 }
346 if (rop->preop.transpose) { /* transpose matrix? */
347 mres = rmx_transpose(rop->mtx);
348 if (mres == NULL) {
349 fputs(rop->inspec, stderr);
350 fputs(": transpose failed\n", stderr);
351 goto failure;
352 }
353 if (verbose) {
354 fputs(rop->inspec, stderr);
355 fputs(": transposed rows and columns\n", stderr);
356 }
357 rmx_free(rop->mtx);
358 rop->mtx = mres;
359 }
360 mres = rop->mtx;
361 rop->mtx = NULL;
362 if (outtype)
363 mres->dtype = outtype;
364 return(mres);
365 failure:
366 rmx_free(rop->mtx);
367 return(rop->mtx = NULL);
368 }
369
370 /* Execute binary operation, free matrix arguments and return new result */
371 static RMATRIX *
372 binaryop(const char *inspec, RMATRIX *mleft, int op, RMATRIX *mright)
373 {
374 RMATRIX *mres = NULL;
375 int i;
376
377 if ((mleft == NULL) | (mright == NULL))
378 return(NULL);
379 switch (op) {
380 case '.': /* concatenate */
381 if (mleft->ncomp != mright->ncomp) {
382 fputs(inspec, stderr);
383 fputs(": # components do not match\n", stderr);
384 } else if (mleft->ncols != mright->nrows) {
385 fputs(inspec, stderr);
386 fputs(": mismatched dimensions\n",
387 stderr);
388 } else
389 mres = rmx_multiply(mleft, mright);
390 rmx_free(mleft);
391 rmx_free(mright);
392 if (mres == NULL) {
393 fputs(inspec, stderr);
394 fputs(": concatenation failed\n", stderr);
395 return(NULL);
396 }
397 if (verbose) {
398 fputs(inspec, stderr);
399 fputs(": concatenated matrix\n", stderr);
400 }
401 break;
402 case '+':
403 if (!rmx_sum(mleft, mright, NULL)) {
404 fputs(inspec, stderr);
405 fputs(": matrix sum failed\n", stderr);
406 rmx_free(mleft);
407 rmx_free(mright);
408 return(NULL);
409 }
410 if (verbose) {
411 fputs(inspec, stderr);
412 fputs(": added in matrix\n", stderr);
413 }
414 rmx_free(mright);
415 mres = mleft;
416 break;
417 case '*':
418 case '/': {
419 const char * tnam = (op == '/') ?
420 "division" : "multiplication";
421 errno = 0;
422 if (!rmx_elemult(mleft, mright, (op == '/'))) {
423 fprintf(stderr, "%s: element-wise %s failed\n",
424 inspec, tnam);
425 rmx_free(mleft);
426 rmx_free(mright);
427 return(NULL);
428 }
429 if (errno)
430 fprintf(stderr,
431 "%s: warning - error during element-wise %s\n",
432 inspec, tnam);
433 else if (verbose)
434 fprintf(stderr, "%s: element-wise %s\n", inspec, tnam);
435 rmx_free(mright);
436 mres = mleft;
437 } break;
438 default:
439 fprintf(stderr, "%s: unknown operation '%c'\n", inspec, op);
440 rmx_free(mleft);
441 rmx_free(mright);
442 return(NULL);
443 }
444 return(mres);
445 }
446
447 /* Perform matrix operations from left to right */
448 static RMATRIX *
449 op_left2right(ROPMAT *mop)
450 {
451 RMATRIX *mleft = loadop(mop);
452
453 while (mop->binop) {
454 if (mleft == NULL)
455 break;
456 mleft = binaryop(mop[1].inspec,
457 mleft, mop->binop, loadop(mop+1));
458 mop++;
459 }
460 return(mleft);
461 }
462
463 /* Perform matrix operations from right to left */
464 static RMATRIX *
465 op_right2left(ROPMAT *mop)
466 {
467 RMATRIX *mright;
468 int rpos = 0;
469 /* find end of list */
470 while (mop[rpos].binop)
471 if (mop[rpos++].binop != '.') {
472 fputs(
473 "Right-to-left evaluation only for matrix multiplication!\n",
474 stderr);
475 return(NULL);
476 }
477 mright = loadop(mop+rpos);
478 while (rpos-- > 0) {
479 if (mright == NULL)
480 break;
481 mright = binaryop(mop[rpos+1].inspec,
482 loadop(mop+rpos), mop[rpos].binop, mright);
483 }
484 return(mright);
485 }
486
487 #define t_nrows(mop) ((mop)->preop.transpose ? (mop)->mtx->ncols \
488 : (mop)->mtx->nrows)
489 #define t_ncols(mop) ((mop)->preop.transpose ? (mop)->mtx->nrows \
490 : (mop)->mtx->ncols)
491
492 /* Should we prefer concatenating from rightmost matrix towards left? */
493 static int
494 prefer_right2left(ROPMAT *mop)
495 {
496 int mri = 0;
497
498 while (mop[mri].binop) /* find rightmost matrix */
499 if (mop[mri++].binop != '.')
500 return(0); /* pre-empt reversal for other ops */
501
502 if (mri <= 1)
503 return(0); /* won't matter */
504
505 if (loadmatrix(mop+mri) < 0) /* load rightmost cat */
506 return(1); /* fail will bail in a moment */
507
508 if (t_ncols(mop+mri) == 1)
509 return(1); /* definitely better R->L */
510
511 if (t_ncols(mop+mri) >= t_nrows(mop+mri))
512 return(0); /* ...probably worse */
513
514 if (loadmatrix(mop) < 0) /* load leftmost */
515 return(0); /* fail will bail in a moment */
516
517 return(t_ncols(mop+mri) < t_nrows(mop));
518 }
519
520 static int
521 get_factors(double da[], int n, char *av[])
522 {
523 int ac;
524
525 for (ac = 0; ac < n && isflt(av[ac]); ac++)
526 da[ac] = atof(av[ac]);
527 return(ac);
528 }
529
530 static ROPMAT *
531 resize_moparr(ROPMAT *mop, int n2alloc)
532 {
533 int nmats = 0;
534 int i;
535
536 while (mop[nmats++].binop)
537 ;
538 for (i = nmats; i > n2alloc; i--)
539 rmx_free(mop[i].mtx);
540 mop = (ROPMAT *)realloc(mop, n2alloc*sizeof(ROPMAT));
541 if (mop == NULL) {
542 fputs("Out of memory in resize_moparr()\n", stderr);
543 exit(1);
544 }
545 if (n2alloc > nmats)
546 memset(mop+nmats, 0, (n2alloc-nmats)*sizeof(ROPMAT));
547 return(mop);
548 }
549
550 /* Load one or more matrices and operate on them, sending results to stdout */
551 int
552 main(int argc, char *argv[])
553 {
554 int outfmt = DTfromHeader;
555 const char *defCsym = NULL;
556 int nall = 2;
557 ROPMAT *mop = (ROPMAT *)calloc(nall, sizeof(ROPMAT));
558 int nmats = 0;
559 RMATRIX *mres = NULL;
560 int stdin_used = 0;
561 int i;
562 /* get options and arguments */
563 for (i = 1; i < argc; i++) {
564 if (argv[i][0] && !argv[i][1] &&
565 strchr(".+*/", argv[i][0]) != NULL) {
566 if (!nmats || mop[nmats-1].binop) {
567 fprintf(stderr,
568 "%s: missing matrix argument before '%c' operation\n",
569 argv[0], argv[i][0]);
570 return(1);
571 }
572 mop[nmats-1].binop = argv[i][0];
573 } else if (argv[i][0] != '-' || !argv[i][1]) {
574 if (argv[i][0] == '-') {
575 if (stdin_used++) {
576 fprintf(stderr,
577 "%s: standard input used for more than one matrix\n",
578 argv[0]);
579 return(1);
580 }
581 mop[nmats].inspec = stdin_name;
582 } else
583 mop[nmats].inspec = argv[i];
584 if (!mop[nmats].preop.csym)
585 mop[nmats].preop.csym = defCsym;
586 if (nmats > 0 && !mop[nmats-1].binop)
587 mop[nmats-1].binop = '.';
588 nmats++;
589 } else {
590 int n = argc-1 - i;
591 switch (argv[i][1]) { /* get option */
592 case 'v':
593 verbose++;
594 break;
595 case 'f':
596 switch (argv[i][2]) {
597 case 'd':
598 outfmt = DTdouble;
599 break;
600 case 'f':
601 outfmt = DTfloat;
602 break;
603 case 'a':
604 outfmt = DTascii;
605 break;
606 case 'c':
607 outfmt = DTrgbe;
608 break;
609 default:
610 goto userr;
611 }
612 break;
613 case 't':
614 mop[nmats].preop.transpose = 1;
615 break;
616 case 's':
617 if (n > MAXCOMP) n = MAXCOMP;
618 i += mop[nmats].preop.nsf =
619 get_factors(mop[nmats].preop.sca,
620 n, argv+i+1);
621 if (mop[nmats].preop.nsf <= 0) {
622 fprintf(stderr, "%s: -s missing arguments\n",
623 argv[0]);
624 goto userr;
625 }
626 break;
627 case 'C':
628 if (!n || isflt(argv[i+1]))
629 goto userr;
630 defCsym = mop[nmats].preop.csym = argv[++i];
631 mop[nmats].preop.clen = 0;
632 break;
633 case 'c':
634 if (n && !isflt(argv[i+1])) {
635 mop[nmats].preop.csym = argv[++i];
636 mop[nmats].preop.clen = 0;
637 break;
638 }
639 if (n > MAXCOMP*MAXCOMP) n = MAXCOMP*MAXCOMP;
640 i += mop[nmats].preop.clen =
641 get_factors(mop[nmats].preop.cmat,
642 n, argv+i+1);
643 if (mop[nmats].preop.clen <= 0) {
644 fprintf(stderr, "%s: -c missing arguments\n",
645 argv[0]);
646 goto userr;
647 }
648 mop[nmats].preop.csym = NULL;
649 break;
650 case 'r':
651 if (argv[i][2] == 'f')
652 mop[nmats].rmp = RMPreflF;
653 else if (argv[i][2] == 'b')
654 mop[nmats].rmp = RMPreflB;
655 else
656 goto userr;
657 break;
658 default:
659 fprintf(stderr, "%s: unknown operation '%s'\n",
660 argv[0], argv[i]);
661 goto userr;
662 }
663 }
664 if (nmats >= nall)
665 mop = resize_moparr(mop, nall += 2);
666 }
667 if (mop[0].inspec == NULL) /* nothing to do? */
668 goto userr;
669 if (mop[nmats-1].binop) {
670 fprintf(stderr,
671 "%s: missing matrix argument after '%c' operation\n",
672 argv[0], mop[nmats-1].binop);
673 return(1);
674 }
675 /* favor quicker concatenation */
676 mop[nmats].mtx = prefer_right2left(mop) ? op_right2left(mop)
677 : op_left2right(mop);
678 if (mop[nmats].mtx == NULL)
679 return(1);
680 /* apply trailing unary operations */
681 mop[nmats].inspec = "trailing_ops";
682 mres = loadop(mop+nmats);
683 if (mres == NULL)
684 return(1);
685 if (outfmt == DTfromHeader) /* check data type */
686 outfmt = mres->dtype;
687 if (outfmt == DTrgbe) {
688 if (mres->ncomp > 3)
689 outfmt = DTspec;
690 else if (mres->dtype == DTxyze)
691 outfmt = DTxyze;
692 }
693 newheader("RADIANCE", stdout); /* write result to stdout */
694 printargs(argc, argv, stdout);
695 return(rmx_write(mres, outfmt, stdout) ? 0 : 1);
696 userr:
697 fprintf(stderr,
698 "Usage: %s [-v][-f{adfc}][-t][-s sf .. | -c ce ..][-rf|-rb] m1 [.+*/] .. > mres\n",
699 argv[0]);
700 return(1);
701 }
