root/radiance/ray/src/util/rmtxop.c
Revision: 2.42
Committed: Sat Apr 19 03:58:00 2025 UTC (7 weeks ago) by greg
Changes since 2.41: +3 -1 lines
fix(rmtxop): Missed error test in last change
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.42 static const char RCSid[] = "$Id: rmtxop.c,v 2.41 2025/04/18 23:59:03 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * General component matrix operations.
6     */
7
8 greg 2.11 #include <errno.h>
9 greg 2.1 #include "rtio.h"
10     #include "rmatrix.h"
11 greg 2.10 #include "platform.h"
12 greg 2.1
13 greg 2.41 /* Preferred BSDF component:
14     none, transmission, reflection front (normal side), reflection back */
15     typedef enum {RMPnone=-1, RMPtrans=0, RMPreflF, RMPreflB} RMPref;
16
17 greg 2.22 /* Unary matrix operation(s) */
18 greg 2.1 typedef struct {
19 greg 2.27 double cmat[MAXCOMP*MAXCOMP]; /* component transformation */
20 greg 2.1 double sca[MAXCOMP]; /* scalar coefficients */
21 greg 2.27 const char *csym; /* symbolic coefs or file */
22     short clen; /* number of coefficients */
23 greg 2.13 short nsf; /* number of scalars */
24 greg 2.27 short transpose; /* do transpose? */
25 greg 2.13 } RUNARYOP;
26
27 greg 2.22 /* Matrix input source and requested operation(s) */
28 greg 2.13 typedef struct {
29     const char *inspec; /* input specification */
30 greg 2.18 RMPref rmp; /* matrix preference */
31 greg 2.13 RUNARYOP preop; /* unary operation(s) */
32     RMATRIX *mtx; /* original matrix if loaded */
33     int binop; /* binary op with next (or 0) */
34     } ROPMAT;
35 greg 2.1
36     int verbose = 0; /* verbose reporting? */
37
38 greg 2.13 /* Load matrix */
39 greg 2.35 int
40 greg 2.13 loadmatrix(ROPMAT *rop)
41 greg 2.1 {
42 greg 2.41 if (rop->mtx) /* already loaded? */
43 greg 2.13 return(0);
44 greg 2.41 /* check for BSDF input */
45     if ((rop->inspec[0] != '!') & (rop->rmp != RMPnone)) {
46     const char *sp = strrchr(rop->inspec, '.');
47     if (sp > rop->inspec && !strcasecmp(sp+1, "XML")) {
48     CMATRIX *cm = rop->rmp==RMPtrans ? cm_loadBTDF(rop->inspec) :
49     cm_loadBRDF(rop->inspec, rop->rmp==RMPreflB) ;
50     if (!cm)
51     return(-1);
52     rop->mtx = rmx_from_cmatrix(cm);
53     cm_free(cm);
54 greg 2.42 if (!rop->mtx)
55     return(-1);
56 greg 2.41 rop->mtx->dtype = DTascii;
57     return(1); /* loaded BSDF XML file */
58     }
59     } /* else load regular matrix */
60     rop->mtx = rmx_load(rop->inspec);
61 greg 2.13
62 greg 2.41 return(rop->mtx ? 1 : -1);
63 greg 2.1 }
64
65 greg 2.35 extern int checksymbolic(ROPMAT *rop);
66 greg 2.27
67     /* Check/set transform based on a reference input file */
68 greg 2.35 int
69 greg 2.27 checkreffile(ROPMAT *rop)
70     {
71     static const char *curRF = NULL;
72     static RMATRIX refm;
73     const int nc = rop->mtx->ncomp;
74     int i;
75
76     if (!curRF || strcmp(rop->preop.csym, curRF)) {
77     FILE *fp = fopen(rop->preop.csym, "rb");
78     if (!rmx_load_header(&refm, fp)) {
79     fprintf(stderr, "%s: cannot read info header\n",
80     rop->preop.csym);
81     curRF = NULL;
82     if (fp) fclose(fp);
83     return(-1);
84     }
85     fclose(fp);
86     curRF = rop->preop.csym;
87     }
88 greg 2.30 if (refm.ncomp == 3) {
89 greg 2.27 rop->preop.csym = (refm.dtype == DTxyze) ? "XYZ" : "RGB";
90     return(checksymbolic(rop));
91     }
92     if (refm.ncomp == 2) {
93     fprintf(stderr, "%s: cannot convert to 2 components\n",
94     curRF);
95     return(-1);
96     }
97     if (refm.ncomp == 1) {
98     rop->preop.csym = "Y"; /* XXX big assumption */
99     return(checksymbolic(rop));
100     }
101     if (refm.ncomp == nc &&
102     !memcmp(refm.wlpart, rop->mtx->wlpart, sizeof(refm.wlpart)))
103     return(0); /* nothing to do */
104
105     if ((nc <= 3) | (nc > MAXCSAMP) | (refm.ncomp > MAXCSAMP)) {
106     fprintf(stderr, "%s: cannot resample from %d to %d components\n",
107     curRF, nc, refm.ncomp);
108     return(-1);
109     }
110     rop->preop.clen = refm.ncomp * nc; /* compute spec to ref */
111
112     for (i = 0; i < nc; i++) {
113     SCOLOR scstim, scresp;
114     int j;
115     memset(scstim, 0, sizeof(COLORV)*nc);
116     scstim[i] = 1.f;
117     convertscolor(scresp, refm.ncomp, refm.wlpart[0], refm.wlpart[3],
118     scstim, nc, rop->mtx->wlpart[0], rop->mtx->wlpart[3]);
119     for (j = refm.ncomp; j-- > 0; )
120     rop->preop.cmat[j*nc + i] = scresp[j];
121     }
122 greg 2.29 memcpy(rop->mtx->wlpart, refm.wlpart, sizeof(rop->mtx->wlpart));
123 greg 2.27 return(0);
124     }
125
126 greg 2.22 /* Compute conversion row from spectrum to one channel of RGB */
127 greg 2.35 void
128 greg 2.22 rgbrow(ROPMAT *rop, int r, int p)
129     {
130     const int nc = rop->mtx->ncomp;
131     const float * wlp = rop->mtx->wlpart;
132     int i;
133
134     for (i = nc; i--; ) {
135     int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc;
136     int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc;
137     COLOR crgb;
138     spec_rgb(crgb, nmStart, nmEnd);
139     rop->preop.cmat[r*nc+i] = crgb[p];
140     }
141     }
142
143     /* Compute conversion row from spectrum to one channel of XYZ */
144 greg 2.35 void
145 greg 2.22 xyzrow(ROPMAT *rop, int r, int p)
146     {
147     const int nc = rop->mtx->ncomp;
148     const float * wlp = rop->mtx->wlpart;
149     int i;
150
151     for (i = nc; i--; ) {
152     int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc;
153     int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc;
154     COLOR cxyz;
155     spec_cie(cxyz, nmStart, nmEnd);
156     rop->preop.cmat[r*nc+i] = cxyz[p];
157     }
158     }
159
160     /* Use the spectral sensitivity function to compute matrix coefficients */
161 greg 2.35 void
162 greg 2.34 sensrow(ROPMAT *rop, int r, double (*sf)(const SCOLOR sc, int ncs, const float wlpt[4]))
163 greg 2.22 {
164     const int nc = rop->mtx->ncomp;
165     int i;
166
167     for (i = nc; i--; ) {
168     SCOLOR sclr;
169 greg 2.27 memset(sclr, 0, sizeof(COLORV)*nc);
170 greg 2.24 sclr[i] = 1.f;
171 greg 2.22 rop->preop.cmat[r*nc+i] = (*sf)(sclr, nc, rop->mtx->wlpart);
172     }
173     }
174
175     /* Check/set symbolic transform */
176 greg 2.35 int
177 greg 2.22 checksymbolic(ROPMAT *rop)
178     {
179     const int nc = rop->mtx->ncomp;
180     const int dt = rop->mtx->dtype;
181 greg 2.31 double cf = 1;
182 greg 2.22 int i, j;
183 greg 2.27 /* check suffix => reference file */
184     if (strchr(rop->preop.csym, '.') > rop->preop.csym)
185     return(checkreffile(rop));
186 greg 2.22
187     if (nc < 3) {
188     fprintf(stderr, "%s: -c '%s' requires at least 3 components\n",
189     rop->inspec, rop->preop.csym);
190     return(-1);
191     }
192     rop->preop.clen = strlen(rop->preop.csym) * nc;
193     if (rop->preop.clen > MAXCOMP*MAXCOMP) {
194     fprintf(stderr, "%s: -c '%s' results in too many components\n",
195     rop->inspec, rop->preop.csym);
196     return(-1);
197     }
198     for (j = 0; rop->preop.csym[j]; j++) {
199     int comp = 0;
200     switch (rop->preop.csym[j]) {
201     case 'B':
202 greg 2.31 case 'b':
203 greg 2.22 ++comp;
204     /* fall through */
205     case 'G':
206 greg 2.31 case 'g':
207 greg 2.22 ++comp;
208     /* fall through */
209     case 'R':
210 greg 2.31 case 'r':
211     if (rop->preop.csym[j] <= 'Z')
212     cf = 1./WHTEFFICACY;
213 greg 2.22 if (dt == DTxyze) {
214     for (i = 3; i--; )
215 greg 2.31 rop->preop.cmat[j*nc+i] = cf*xyz2rgbmat[comp][i];
216 greg 2.22 } else if (nc == 3)
217     rop->preop.cmat[j*nc+comp] = 1.;
218     else
219     rgbrow(rop, j, comp);
220     break;
221     case 'Z':
222 greg 2.31 case 'z':
223 greg 2.22 ++comp;
224     /* fall through */
225     case 'Y':
226 greg 2.31 case 'y':
227 greg 2.22 ++comp;
228     /* fall through */
229     case 'X':
230 greg 2.31 case 'x':
231     if ((rop->preop.csym[j] <= 'Z') & (dt != DTxyze))
232     cf = WHTEFFICACY;
233 greg 2.22 if (dt == DTxyze) {
234     rop->preop.cmat[j*nc+comp] = 1.;
235     } else if (nc == 3) {
236     for (i = 3; i--; )
237     rop->preop.cmat[j*nc+i] =
238     rgb2xyzmat[comp][i];
239     } else if (comp == CIEY)
240     sensrow(rop, j, scolor2photopic);
241     else
242     xyzrow(rop, j, comp);
243
244 greg 2.31 for (i = nc*(cf != 1); i--; )
245     rop->preop.cmat[j*nc+i] *= cf;
246 greg 2.22 break;
247 greg 2.24 case 'S': /* scotopic (il)luminance */
248 greg 2.31 cf = WHTSCOTOPIC;
249     /* fall through */
250     case 's':
251 greg 2.22 sensrow(rop, j, scolor2scotopic);
252 greg 2.31 for (i = nc*(cf != 1); i--; )
253     rop->preop.cmat[j*nc+i] *= cf;
254 greg 2.22 break;
255 greg 2.24 case 'M': /* melanopic (il)luminance */
256 greg 2.31 cf = WHTMELANOPIC;
257     /* fall through */
258     case 'm':
259 greg 2.22 sensrow(rop, j, scolor2melanopic);
260 greg 2.31 for (i = nc*(cf != 1); i--; )
261     rop->preop.cmat[j*nc+i] *= cf;
262 greg 2.22 break;
263 greg 2.24 case 'A': /* average component */
264 greg 2.31 case 'a':
265 greg 2.24 for (i = nc; i--; )
266 greg 2.25 rop->preop.cmat[j*nc+i] = 1./(double)nc;
267 greg 2.24 break;
268 greg 2.22 default:
269     fprintf(stderr, "%s: -c '%c' unsupported\n",
270     rop->inspec, rop->preop.csym[j]);
271     return(-1);
272     }
273     }
274     /* return recommended output type */
275 greg 2.32 if (!strcasecmp(rop->preop.csym, "XYZ")) {
276 greg 2.22 if (dt <= DTspec)
277     return(DTxyze);
278 greg 2.32 } else if (!strcasecmp(rop->preop.csym, "RGB")) {
279 greg 2.22 if (dt <= DTspec)
280     return(DTrgbe);
281 greg 2.30 } else if (dt == DTspec)
282 greg 2.22 return(DTfloat); /* probably not actual spectrum */
283     return(0);
284     }
285
286 greg 2.13 /* Get matrix and perform unary operations */
287 greg 2.35 RMATRIX *
288 greg 2.13 loadop(ROPMAT *rop)
289 greg 2.1 {
290 greg 2.22 int outtype = 0;
291 greg 2.13 RMATRIX *mres;
292 greg 2.22 int i, j;
293 greg 2.1
294 greg 2.13 if (loadmatrix(rop) < 0) /* make sure we're loaded */
295 greg 2.1 return(NULL);
296 greg 2.13
297 greg 2.27 if (rop->preop.csym && /* symbolic transform? */
298 greg 2.22 (outtype = checksymbolic(rop)) < 0)
299     goto failure;
300     if (rop->preop.clen > 0) { /* apply component transform? */
301     if (rop->preop.clen % rop->mtx->ncomp) {
302     fprintf(stderr, "%s: -c must have N x %d coefficients\n",
303     rop->inspec, rop->mtx->ncomp);
304     goto failure;
305     }
306     if (rop->preop.nsf > 0) { /* scale transform, first */
307     if (rop->preop.nsf == 1) {
308     for (i = rop->preop.clen; i--; )
309     rop->preop.cmat[i] *= rop->preop.sca[0];
310 greg 2.28 } else if (rop->preop.nsf*rop->mtx->ncomp != rop->preop.clen) {
311 greg 2.22 fprintf(stderr, "%s: -s must have one or %d factors\n",
312 greg 2.28 rop->inspec,
313     rop->preop.clen/rop->mtx->ncomp);
314 greg 2.22 goto failure;
315     } else {
316 greg 2.28 for (i = rop->preop.nsf; i--; )
317     for (j = rop->mtx->ncomp; j--; )
318     rop->preop.cmat[i*rop->mtx->ncomp+j]
319     *= rop->preop.sca[i];
320 greg 2.22 }
321     }
322     mres = rmx_transform(rop->mtx, rop->preop.clen/rop->mtx->ncomp,
323     rop->preop.cmat);
324     if (mres == NULL) {
325     fprintf(stderr, "%s: matrix transform failed\n",
326     rop->inspec);
327 greg 2.13 goto failure;
328 greg 2.1 }
329 greg 2.22 if (verbose)
330     fprintf(stderr, "%s: applied %d x %d transform%s\n",
331     rop->inspec, mres->ncomp,
332     rop->mtx->ncomp,
333     rop->preop.nsf ? " (* scalar)" : "");
334 greg 2.26 rop->preop.nsf = 0; /* now folded in */
335 greg 2.22 if ((mres->ncomp > 3) & (mres->dtype <= DTspec))
336     outtype = DTfloat; /* probably not actual spectrum */
337     rmx_free(rop->mtx);
338     rop->mtx = mres;
339     }
340     if (rop->preop.nsf > 0) { /* apply scalar(s)? */
341 greg 2.13 if (rop->preop.nsf == 1) {
342     for (i = rop->mtx->ncomp; --i; )
343     rop->preop.sca[i] = rop->preop.sca[0];
344     } else if (rop->preop.nsf != rop->mtx->ncomp) {
345 greg 2.1 fprintf(stderr, "%s: -s must have one or %d factors\n",
346 greg 2.13 rop->inspec, rop->mtx->ncomp);
347     goto failure;
348 greg 2.1 }
349 greg 2.13 if (!rmx_scale(rop->mtx, rop->preop.sca)) {
350     fputs(rop->inspec, stderr);
351 greg 2.1 fputs(": scalar operation failed\n", stderr);
352 greg 2.13 goto failure;
353 greg 2.1 }
354     if (verbose) {
355 greg 2.13 fputs(rop->inspec, stderr);
356 greg 2.1 fputs(": applied scalar (", stderr);
357 greg 2.13 for (i = 0; i < rop->preop.nsf; i++)
358     fprintf(stderr, " %f", rop->preop.sca[i]);
359 greg 2.1 fputs(" )\n", stderr);
360     }
361     }
362 greg 2.22 if (rop->preop.transpose) { /* transpose matrix? */
363 greg 2.37 if (!rmx_transpose(rop->mtx)) {
364 greg 2.13 fputs(rop->inspec, stderr);
365 greg 2.12 fputs(": transpose failed\n", stderr);
366 greg 2.13 goto failure;
367 greg 2.12 }
368     if (verbose) {
369 greg 2.13 fputs(rop->inspec, stderr);
370 greg 2.12 fputs(": transposed rows and columns\n", stderr);
371     }
372 greg 2.13 }
373     mres = rop->mtx;
374     rop->mtx = NULL;
375 greg 2.22 if (outtype)
376     mres->dtype = outtype;
377 greg 2.13 return(mres);
378     failure:
379     rmx_free(rop->mtx);
380     return(rop->mtx = NULL);
381     }
382
383     /* Execute binary operation, free matrix arguments and return new result */
384 greg 2.35 RMATRIX *
385 greg 2.13 binaryop(const char *inspec, RMATRIX *mleft, int op, RMATRIX *mright)
386     {
387     RMATRIX *mres = NULL;
388     int i;
389
390     if ((mleft == NULL) | (mright == NULL))
391     return(NULL);
392     switch (op) {
393     case '.': /* concatenate */
394 greg 2.16 if (mleft->ncomp != mright->ncomp) {
395     fputs(inspec, stderr);
396     fputs(": # components do not match\n", stderr);
397     } else if (mleft->ncols != mright->nrows) {
398     fputs(inspec, stderr);
399     fputs(": mismatched dimensions\n",
400     stderr);
401     } else
402     mres = rmx_multiply(mleft, mright);
403 greg 2.13 rmx_free(mleft);
404 greg 2.12 rmx_free(mright);
405 greg 2.1 if (mres == NULL) {
406 greg 2.13 fputs(inspec, stderr);
407 greg 2.16 fputs(": concatenation failed\n", stderr);
408 greg 2.1 return(NULL);
409     }
410     if (verbose) {
411 greg 2.13 fputs(inspec, stderr);
412 greg 2.1 fputs(": concatenated matrix\n", stderr);
413     }
414 greg 2.13 break;
415     case '+':
416     if (!rmx_sum(mleft, mright, NULL)) {
417     fputs(inspec, stderr);
418 greg 2.1 fputs(": matrix sum failed\n", stderr);
419 greg 2.13 rmx_free(mleft);
420 greg 2.1 rmx_free(mright);
421     return(NULL);
422     }
423     if (verbose) {
424 greg 2.13 fputs(inspec, stderr);
425 greg 2.1 fputs(": added in matrix\n", stderr);
426     }
427     rmx_free(mright);
428 greg 2.13 mres = mleft;
429     break;
430     case '*':
431     case '/': {
432     const char * tnam = (op == '/') ?
433 greg 2.11 "division" : "multiplication";
434     errno = 0;
435 greg 2.13 if (!rmx_elemult(mleft, mright, (op == '/'))) {
436 greg 2.11 fprintf(stderr, "%s: element-wise %s failed\n",
437 greg 2.13 inspec, tnam);
438     rmx_free(mleft);
439 greg 2.11 rmx_free(mright);
440     return(NULL);
441     }
442     if (errno)
443     fprintf(stderr,
444     "%s: warning - error during element-wise %s\n",
445 greg 2.13 inspec, tnam);
446 greg 2.11 else if (verbose)
447 greg 2.13 fprintf(stderr, "%s: element-wise %s\n", inspec, tnam);
448 greg 2.11 rmx_free(mright);
449 greg 2.13 mres = mleft;
450     } break;
451     default:
452     fprintf(stderr, "%s: unknown operation '%c'\n", inspec, op);
453     rmx_free(mleft);
454 greg 2.1 rmx_free(mright);
455     return(NULL);
456     }
457 greg 2.13 return(mres);
458     }
459
460     /* Perform matrix operations from left to right */
461 greg 2.35 RMATRIX *
462 greg 2.13 op_left2right(ROPMAT *mop)
463     {
464     RMATRIX *mleft = loadop(mop);
465
466     while (mop->binop) {
467     if (mleft == NULL)
468     break;
469     mleft = binaryop(mop[1].inspec,
470     mleft, mop->binop, loadop(mop+1));
471     mop++;
472     }
473 greg 2.1 return(mleft);
474     }
475
476 greg 2.13 /* Perform matrix operations from right to left */
477 greg 2.35 RMATRIX *
478 greg 2.13 op_right2left(ROPMAT *mop)
479     {
480     RMATRIX *mright;
481     int rpos = 0;
482     /* find end of list */
483     while (mop[rpos].binop)
484 greg 2.14 if (mop[rpos++].binop != '.') {
485     fputs(
486     "Right-to-left evaluation only for matrix multiplication!\n",
487     stderr);
488     return(NULL);
489     }
490 greg 2.13 mright = loadop(mop+rpos);
491     while (rpos-- > 0) {
492     if (mright == NULL)
493     break;
494 greg 2.20 mright = binaryop(mop[rpos+1].inspec,
495 greg 2.13 loadop(mop+rpos), mop[rpos].binop, mright);
496     }
497     return(mright);
498     }
499
500     #define t_nrows(mop) ((mop)->preop.transpose ? (mop)->mtx->ncols \
501     : (mop)->mtx->nrows)
502     #define t_ncols(mop) ((mop)->preop.transpose ? (mop)->mtx->nrows \
503     : (mop)->mtx->ncols)
504
505     /* Should we prefer concatenating from rightmost matrix towards left? */
506 greg 2.35 int
507 greg 2.13 prefer_right2left(ROPMAT *mop)
508     {
509     int mri = 0;
510
511     while (mop[mri].binop) /* find rightmost matrix */
512     if (mop[mri++].binop != '.')
513     return(0); /* pre-empt reversal for other ops */
514
515     if (mri <= 1)
516     return(0); /* won't matter */
517
518     if (loadmatrix(mop+mri) < 0) /* load rightmost cat */
519     return(1); /* fail will bail in a moment */
520
521     if (t_ncols(mop+mri) == 1)
522     return(1); /* definitely better R->L */
523
524     if (t_ncols(mop+mri) >= t_nrows(mop+mri))
525     return(0); /* ...probably worse */
526
527     if (loadmatrix(mop) < 0) /* load leftmost */
528     return(0); /* fail will bail in a moment */
529
530     return(t_ncols(mop+mri) < t_nrows(mop));
531     }
532
533 greg 2.35 int
534 greg 2.1 get_factors(double da[], int n, char *av[])
535     {
536     int ac;
537
538     for (ac = 0; ac < n && isflt(av[ac]); ac++)
539     da[ac] = atof(av[ac]);
540     return(ac);
541     }
542
543 greg 2.35 ROPMAT *
544 greg 2.26 resize_moparr(ROPMAT *mop, int n2alloc)
545 greg 2.13 {
546     int nmats = 0;
547 greg 2.26 int i;
548 greg 2.13
549     while (mop[nmats++].binop)
550     ;
551 greg 2.35 for (i = nmats; i >= n2alloc; i--)
552 greg 2.26 rmx_free(mop[i].mtx);
553 greg 2.13 mop = (ROPMAT *)realloc(mop, n2alloc*sizeof(ROPMAT));
554     if (mop == NULL) {
555 greg 2.26 fputs("Out of memory in resize_moparr()\n", stderr);
556 greg 2.13 exit(1);
557     }
558     if (n2alloc > nmats)
559     memset(mop+nmats, 0, (n2alloc-nmats)*sizeof(ROPMAT));
560     return(mop);
561     }
562
563 greg 2.1 /* Load one or more matrices and operate on them, sending results to stdout */
564     int
565     main(int argc, char *argv[])
566     {
567 greg 2.27 int outfmt = DTfromHeader;
568     const char *defCsym = NULL;
569     int nall = 2;
570     ROPMAT *mop = (ROPMAT *)calloc(nall, sizeof(ROPMAT));
571     int nmats = 0;
572     RMATRIX *mres = NULL;
573     int stdin_used = 0;
574     int i;
575 greg 2.1 /* get options and arguments */
576 greg 2.13 for (i = 1; i < argc; i++) {
577 greg 2.11 if (argv[i][0] && !argv[i][1] &&
578 greg 2.13 strchr(".+*/", argv[i][0]) != NULL) {
579 greg 2.15 if (!nmats || mop[nmats-1].binop) {
580 greg 2.14 fprintf(stderr,
581 greg 2.15 "%s: missing matrix argument before '%c' operation\n",
582 greg 2.14 argv[0], argv[i][0]);
583 greg 2.13 return(1);
584     }
585 greg 2.15 mop[nmats-1].binop = argv[i][0];
586 greg 2.1 } else if (argv[i][0] != '-' || !argv[i][1]) {
587 greg 2.13 if (argv[i][0] == '-') {
588     if (stdin_used++) {
589     fprintf(stderr,
590     "%s: standard input used for more than one matrix\n",
591     argv[0]);
592     return(1);
593     }
594     mop[nmats].inspec = stdin_name;
595     } else
596     mop[nmats].inspec = argv[i];
597 greg 2.27 if (!mop[nmats].preop.csym)
598     mop[nmats].preop.csym = defCsym;
599 greg 2.13 if (nmats > 0 && !mop[nmats-1].binop)
600     mop[nmats-1].binop = '.';
601     nmats++;
602 greg 2.1 } else {
603     int n = argc-1 - i;
604     switch (argv[i][1]) { /* get option */
605     case 'v':
606 greg 2.14 verbose++;
607 greg 2.1 break;
608     case 'f':
609     switch (argv[i][2]) {
610     case 'd':
611     outfmt = DTdouble;
612     break;
613     case 'f':
614     outfmt = DTfloat;
615     break;
616     case 'a':
617     outfmt = DTascii;
618     break;
619     case 'c':
620     outfmt = DTrgbe;
621     break;
622     default:
623     goto userr;
624     }
625     break;
626     case 't':
627 greg 2.13 mop[nmats].preop.transpose = 1;
628 greg 2.1 break;
629     case 's':
630     if (n > MAXCOMP) n = MAXCOMP;
631 greg 2.13 i += mop[nmats].preop.nsf =
632     get_factors(mop[nmats].preop.sca,
633     n, argv+i+1);
634 greg 2.22 if (mop[nmats].preop.nsf <= 0) {
635     fprintf(stderr, "%s: -s missing arguments\n",
636     argv[0]);
637     goto userr;
638     }
639 greg 2.1 break;
640 greg 2.27 case 'C':
641     if (!n || isflt(argv[i+1]))
642     goto userr;
643     defCsym = mop[nmats].preop.csym = argv[++i];
644     mop[nmats].preop.clen = 0;
645     break;
646 greg 2.1 case 'c':
647 greg 2.27 if (n && !isflt(argv[i+1])) {
648     mop[nmats].preop.csym = argv[++i];
649 greg 2.22 mop[nmats].preop.clen = 0;
650     break;
651     }
652 greg 2.1 if (n > MAXCOMP*MAXCOMP) n = MAXCOMP*MAXCOMP;
653 greg 2.13 i += mop[nmats].preop.clen =
654     get_factors(mop[nmats].preop.cmat,
655     n, argv+i+1);
656 greg 2.22 if (mop[nmats].preop.clen <= 0) {
657     fprintf(stderr, "%s: -c missing arguments\n",
658     argv[0]);
659     goto userr;
660     }
661 greg 2.27 mop[nmats].preop.csym = NULL;
662 greg 2.1 break;
663 greg 2.18 case 'r':
664     if (argv[i][2] == 'f')
665     mop[nmats].rmp = RMPreflF;
666     else if (argv[i][2] == 'b')
667     mop[nmats].rmp = RMPreflB;
668     else
669     goto userr;
670     break;
671 greg 2.1 default:
672     fprintf(stderr, "%s: unknown operation '%s'\n",
673     argv[0], argv[i]);
674     goto userr;
675     }
676     }
677 greg 2.14 if (nmats >= nall)
678 greg 2.26 mop = resize_moparr(mop, nall += 2);
679 greg 2.13 }
680     if (mop[0].inspec == NULL) /* nothing to do? */
681 greg 2.1 goto userr;
682 greg 2.15 if (mop[nmats-1].binop) {
683     fprintf(stderr,
684     "%s: missing matrix argument after '%c' operation\n",
685     argv[0], mop[nmats-1].binop);
686     return(1);
687     }
688 greg 2.13 /* favor quicker concatenation */
689 greg 2.14 mop[nmats].mtx = prefer_right2left(mop) ? op_right2left(mop)
690     : op_left2right(mop);
691     if (mop[nmats].mtx == NULL)
692     return(1);
693     /* apply trailing unary operations */
694     mop[nmats].inspec = "trailing_ops";
695     mres = loadop(mop+nmats);
696     if (mres == NULL)
697 greg 2.13 return(1);
698 greg 2.40 if ((outfmt == DTfromHeader) & (mres->dtype < DTspec))
699 greg 2.6 outfmt = mres->dtype;
700 greg 2.40 if (outfmt == DTrgbe) { /* check data type */
701 greg 2.22 if (mres->ncomp > 3)
702     outfmt = DTspec;
703     else if (mres->dtype == DTxyze)
704     outfmt = DTxyze;
705     }
706 greg 2.39 #if DTrmx_native==DTfloat
707     if (outfmt == DTdouble)
708     fprintf(stderr,
709     "%s: warning - writing float result as double\n",
710     argv[0]);
711     #endif
712 greg 2.26 newheader("RADIANCE", stdout); /* write result to stdout */
713 greg 2.1 printargs(argc, argv, stdout);
714 greg 2.23 return(rmx_write(mres, outfmt, stdout) ? 0 : 1);
715 greg 2.1 userr:
716     fprintf(stderr,
717 greg 2.26 "Usage: %s [-v][-f{adfc}][-t][-s sf .. | -c ce ..][-rf|-rb] m1 [.+*/] .. > mres\n",
718 greg 2.1 argv[0]);
719     return(1);
720     }
