| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rmtxop.c,v 2.42 2025/04/19 03:58:00 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* General component matrix operations.
| 6 |
| 7 |
| 8 |
#include <errno.h>
| 9 |
#include "rtio.h"
| 10 |
#include "rmatrix.h"
| 11 |
#include "platform.h"
| 12 |
| 13 |
/* Preferred BSDF component:
| 14 |
none, transmission, reflection front (normal side), reflection back */
| 15 |
typedef enum {RMPnone=-1, RMPtrans=0, RMPreflF, RMPreflB} RMPref;
| 16 |
| 17 |
/* Unary matrix operation(s) */
| 18 |
typedef struct {
| 19 |
double cmat[MAXCOMP*MAXCOMP]; /* component transformation */
| 20 |
double sca[MAXCOMP]; /* scalar coefficients */
| 21 |
const char *csym; /* symbolic coefs or file */
| 22 |
short clen; /* number of coefficients */
| 23 |
short nsf; /* number of scalars */
| 24 |
short transpose; /* do transpose? */
| 25 |
} RUNARYOP;
| 26 |
| 27 |
/* Matrix input source and requested operation(s) */
| 28 |
typedef struct {
| 29 |
const char *inspec; /* input specification */
| 30 |
RMPref rmp; /* matrix preference */
| 31 |
RUNARYOP preop; /* unary operation(s) */
| 32 |
RMATRIX *mtx; /* original matrix if loaded */
| 33 |
int binop; /* binary op with next (or 0) */
| 34 |
} ROPMAT;
| 35 |
| 36 |
int verbose = 0; /* verbose reporting? */
| 37 |
| 38 |
/* Load matrix */
| 39 |
int
| 40 |
loadmatrix(ROPMAT *rop)
| 41 |
| 42 |
if (rop->mtx) /* already loaded? */
| 43 |
return(0);
| 44 |
/* check for BSDF input */
| 45 |
if ((rop->inspec[0] != '!') & (rop->rmp != RMPnone)) {
| 46 |
const char *sp = strrchr(rop->inspec, '.');
| 47 |
if (sp > rop->inspec && !strcasecmp(sp+1, "XML")) {
| 48 |
CMATRIX *cm = rop->rmp==RMPtrans ? cm_loadBTDF(rop->inspec) :
| 49 |
cm_loadBRDF(rop->inspec, rop->rmp==RMPreflB) ;
| 50 |
if (!cm)
| 51 |
return(-1);
| 52 |
rop->mtx = rmx_from_cmatrix(cm);
| 53 |
cm_free(cm);
| 54 |
if (!rop->mtx)
| 55 |
return(-1);
| 56 |
rop->mtx->dtype = DTascii;
| 57 |
return(1); /* loaded BSDF XML file */
| 58 |
| 59 |
} /* else load regular matrix */
| 60 |
rop->mtx = rmx_load(rop->inspec);
| 61 |
| 62 |
return(rop->mtx ? 1 : -1);
| 63 |
| 64 |
| 65 |
extern int checksymbolic(ROPMAT *rop);
| 66 |
| 67 |
/* Check/set transform based on a reference input file */
| 68 |
int
| 69 |
checkreffile(ROPMAT *rop)
| 70 |
| 71 |
static const char *curRF = NULL;
| 72 |
static RMATRIX refm;
| 73 |
const int nc = rop->mtx->ncomp;
| 74 |
int i;
| 75 |
| 76 |
if (!curRF || strcmp(rop->preop.csym, curRF)) {
| 77 |
FILE *fp = fopen(rop->preop.csym, "rb");
| 78 |
if (!rmx_load_header(&refm, fp)) {
| 79 |
fprintf(stderr, "%s: cannot read info header\n",
| 80 |
rop->preop.csym);
| 81 |
curRF = NULL;
| 82 |
if (fp) fclose(fp);
| 83 |
return(-1);
| 84 |
| 85 |
fclose(fp);
| 86 |
curRF = rop->preop.csym;
| 87 |
| 88 |
if (refm.ncomp == 3) {
| 89 |
rop->preop.csym = (refm.dtype == DTxyze) ? "XYZ" : "RGB";
| 90 |
return(checksymbolic(rop));
| 91 |
| 92 |
if (refm.ncomp == 2) {
| 93 |
fprintf(stderr, "%s: cannot convert to 2 components\n",
| 94 |
curRF);
| 95 |
return(-1);
| 96 |
| 97 |
if (refm.ncomp == 1) {
| 98 |
rop->preop.csym = "Y"; /* XXX big assumption */
| 99 |
| 100 |
| 101 |
if (refm.ncomp == nc &&
| 102 |
!memcmp(refm.wlpart, rop->mtx->wlpart, sizeof(refm.wlpart)))
| 103 |
return(0); /* nothing to do */
| 104 |
| 105 |
if ((nc <= 3) | (nc > MAXCSAMP) | (refm.ncomp > MAXCSAMP)) {
| 106 |
fprintf(stderr, "%s: cannot resample from %d to %d components\n",
| 107 |
curRF, nc, refm.ncomp);
| 108 |
return(-1);
| 109 |
| 110 |
rop->preop.clen = refm.ncomp * nc; /* compute spec to ref */
| 111 |
| 112 |
for (i = 0; i < nc; i++) {
| 113 |
SCOLOR scstim, scresp;
| 114 |
int j;
| 115 |
memset(scstim, 0, sizeof(COLORV)*nc);
| 116 |
scstim[i] = 1.f;
| 117 |
convertscolor(scresp, refm.ncomp, refm.wlpart[0], refm.wlpart[3],
| 118 |
scstim, nc, rop->mtx->wlpart[0], rop->mtx->wlpart[3]);
| 119 |
for (j = refm.ncomp; j-- > 0; )
| 120 |
rop->preop.cmat[j*nc + i] = scresp[j];
| 121 |
| 122 |
memcpy(rop->mtx->wlpart, refm.wlpart, sizeof(rop->mtx->wlpart));
| 123 |
return(0);
| 124 |
| 125 |
| 126 |
/* Compute conversion row from spectrum to one channel of RGB */
| 127 |
void
| 128 |
rgbrow(ROPMAT *rop, int r, int p)
| 129 |
| 130 |
| 131 |
const float * wlp = rop->mtx->wlpart;
| 132 |
int i;
| 133 |
| 134 |
for (i = nc; i--; ) {
| 135 |
int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc;
| 136 |
int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc;
| 137 |
COLOR crgb;
| 138 |
spec_rgb(crgb, nmStart, nmEnd);
| 139 |
rop->preop.cmat[r*nc+i] = crgb[p];
| 140 |
| 141 |
| 142 |
| 143 |
/* Compute conversion row from spectrum to one channel of XYZ */
| 144 |
void
| 145 |
xyzrow(ROPMAT *rop, int r, int p)
| 146 |
| 147 |
| 148 |
| 149 |
int i;
| 150 |
| 151 |
| 152 |
| 153 |
| 154 |
COLOR cxyz;
| 155 |
spec_cie(cxyz, nmStart, nmEnd);
| 156 |
rop->preop.cmat[r*nc+i] = cxyz[p];
| 157 |
| 158 |
| 159 |
| 160 |
/* Use the spectral sensitivity function to compute matrix coefficients */
| 161 |
void
| 162 |
sensrow(ROPMAT *rop, int r, double (*sf)(const SCOLOR sc, int ncs, const float wlpt[4]))
| 163 |
| 164 |
| 165 |
int i;
| 166 |
| 167 |
| 168 |
SCOLOR sclr;
| 169 |
memset(sclr, 0, sizeof(COLORV)*nc);
| 170 |
sclr[i] = 1.f;
| 171 |
rop->preop.cmat[r*nc+i] = (*sf)(sclr, nc, rop->mtx->wlpart);
| 172 |
| 173 |
| 174 |
| 175 |
/* Check/set symbolic transform */
| 176 |
int
| 177 |
| 178 |
| 179 |
| 180 |
const int dt = rop->mtx->dtype;
| 181 |
double cf = 1;
| 182 |
int i, j;
| 183 |
/* check suffix => reference file */
| 184 |
if (strchr(rop->preop.csym, '.') != NULL)
| 185 |
return(checkreffile(rop));
| 186 |
| 187 |
if (nc < 3) {
| 188 |
fprintf(stderr, "%s: -c '%s' requires at least 3 components\n",
| 189 |
rop->inspec, rop->preop.csym);
| 190 |
return(-1);
| 191 |
| 192 |
rop->preop.clen = strlen(rop->preop.csym) * nc;
| 193 |
if (rop->preop.clen > MAXCOMP*MAXCOMP) {
| 194 |
fprintf(stderr, "%s: -c '%s' results in too many components\n",
| 195 |
| 196 |
return(-1);
| 197 |
| 198 |
for (j = 0; rop->preop.csym[j]; j++) {
| 199 |
int comp = 0;
| 200 |
switch (rop->preop.csym[j]) {
| 201 |
case 'B':
| 202 |
case 'b':
| 203 |
++comp;
| 204 |
/* fall through */
| 205 |
case 'G':
| 206 |
case 'g':
| 207 |
++comp;
| 208 |
/* fall through */
| 209 |
case 'R':
| 210 |
case 'r':
| 211 |
if (rop->preop.csym[j] <= 'Z')
| 212 |
cf = 1./WHTEFFICACY;
| 213 |
if (dt == DTxyze) {
| 214 |
for (i = 3; i--; )
| 215 |
rop->preop.cmat[j*nc+i] = cf*xyz2rgbmat[comp][i];
| 216 |
} else if (nc == 3)
| 217 |
rop->preop.cmat[j*nc+comp] = 1.;
| 218 |
else
| 219 |
rgbrow(rop, j, comp);
| 220 |
break;
| 221 |
case 'Z':
| 222 |
case 'z':
| 223 |
++comp;
| 224 |
/* fall through */
| 225 |
case 'Y':
| 226 |
case 'y':
| 227 |
++comp;
| 228 |
/* fall through */
| 229 |
case 'X':
| 230 |
case 'x':
| 231 |
if ((rop->preop.csym[j] <= 'Z') & (dt != DTxyze))
| 232 |
cf = WHTEFFICACY;
| 233 |
if (dt == DTxyze) {
| 234 |
| 235 |
} else if (nc == 3) {
| 236 |
for (i = 3; i--; )
| 237 |
| 238 |
rgb2xyzmat[comp][i];
| 239 |
} else if (comp == CIEY)
| 240 |
sensrow(rop, j, scolor2photopic);
| 241 |
else
| 242 |
xyzrow(rop, j, comp);
| 243 |
| 244 |
for (i = nc*(cf != 1); i--; )
| 245 |
rop->preop.cmat[j*nc+i] *= cf;
| 246 |
break;
| 247 |
case 'S': /* scotopic (il)luminance */
| 248 |
cf = WHTSCOTOPIC;
| 249 |
/* fall through */
| 250 |
case 's':
| 251 |
sensrow(rop, j, scolor2scotopic);
| 252 |
| 253 |
| 254 |
break;
| 255 |
case 'M': /* melanopic (il)luminance */
| 256 |
cf = WHTMELANOPIC;
| 257 |
/* fall through */
| 258 |
case 'm':
| 259 |
sensrow(rop, j, scolor2melanopic);
| 260 |
| 261 |
| 262 |
break;
| 263 |
case 'A': /* average component */
| 264 |
case 'a':
| 265 |
for (i = nc; i--; )
| 266 |
rop->preop.cmat[j*nc+i] = 1./(double)nc;
| 267 |
break;
| 268 |
default:
| 269 |
fprintf(stderr, "%s: -c '%c' unsupported\n",
| 270 |
rop->inspec, rop->preop.csym[j]);
| 271 |
return(-1);
| 272 |
| 273 |
| 274 |
/* return recommended output type */
| 275 |
if (!strcasecmp(rop->preop.csym, "XYZ")) {
| 276 |
if (dt <= DTspec)
| 277 |
return(DTxyze);
| 278 |
} else if (!strcasecmp(rop->preop.csym, "RGB")) {
| 279 |
if (dt <= DTspec)
| 280 |
return(DTrgbe);
| 281 |
} else if (dt == DTspec)
| 282 |
return(DTfloat); /* probably not actual spectrum */
| 283 |
return(0);
| 284 |
| 285 |
| 286 |
/* Get matrix and perform unary operations */
| 287 |
RMATRIX *
| 288 |
loadop(ROPMAT *rop)
| 289 |
| 290 |
int outtype = 0;
| 291 |
RMATRIX *mres;
| 292 |
int i, j;
| 293 |
| 294 |
if (loadmatrix(rop) < 0) /* make sure we're loaded */
| 295 |
return(NULL);
| 296 |
| 297 |
if (rop->preop.csym && /* symbolic transform? */
| 298 |
(outtype = checksymbolic(rop)) < 0)
| 299 |
goto failure;
| 300 |
if (rop->preop.clen > 0) { /* apply component transform? */
| 301 |
if (rop->preop.clen % rop->mtx->ncomp) {
| 302 |
fprintf(stderr, "%s: -c must have N x %d coefficients\n",
| 303 |
rop->inspec, rop->mtx->ncomp);
| 304 |
goto failure;
| 305 |
| 306 |
if (rop->preop.nsf > 0) { /* scale transform, first */
| 307 |
if (rop->preop.nsf == 1) {
| 308 |
for (i = rop->preop.clen; i--; )
| 309 |
rop->preop.cmat[i] *= rop->preop.sca[0];
| 310 |
} else if (rop->preop.nsf*rop->mtx->ncomp != rop->preop.clen) {
| 311 |
fprintf(stderr, "%s: -s must have one or %d factors\n",
| 312 |
rop->inspec,
| 313 |
rop->preop.clen/rop->mtx->ncomp);
| 314 |
goto failure;
| 315 |
} else {
| 316 |
for (i = rop->preop.nsf; i--; )
| 317 |
for (j = rop->mtx->ncomp; j--; )
| 318 |
rop->preop.cmat[i*rop->mtx->ncomp+j]
| 319 |
*= rop->preop.sca[i];
| 320 |
| 321 |
| 322 |
mres = rmx_transform(rop->mtx, rop->preop.clen/rop->mtx->ncomp,
| 323 |
rop->preop.cmat);
| 324 |
if (mres == NULL) {
| 325 |
fprintf(stderr, "%s: matrix transform failed\n",
| 326 |
rop->inspec);
| 327 |
goto failure;
| 328 |
| 329 |
if (verbose)
| 330 |
fprintf(stderr, "%s: applied %d x %d transform%s\n",
| 331 |
rop->inspec, mres->ncomp,
| 332 |
rop->mtx->ncomp,
| 333 |
rop->preop.nsf ? " (* scalar)" : "");
| 334 |
rop->preop.nsf = 0; /* now folded in */
| 335 |
if ((mres->ncomp > 3) & (mres->dtype <= DTspec))
| 336 |
outtype = DTfloat; /* probably not actual spectrum */
| 337 |
rmx_free(rop->mtx);
| 338 |
rop->mtx = mres;
| 339 |
| 340 |
if (rop->preop.nsf > 0) { /* apply scalar(s)? */
| 341 |
| 342 |
for (i = rop->mtx->ncomp; --i; )
| 343 |
rop->preop.sca[i] = rop->preop.sca[0];
| 344 |
} else if (rop->preop.nsf != rop->mtx->ncomp) {
| 345 |
| 346 |
| 347 |
goto failure;
| 348 |
| 349 |
if (!rmx_scale(rop->mtx, rop->preop.sca)) {
| 350 |
fputs(rop->inspec, stderr);
| 351 |
fputs(": scalar operation failed\n", stderr);
| 352 |
goto failure;
| 353 |
| 354 |
if (verbose) {
| 355 |
| 356 |
fputs(": applied scalar (", stderr);
| 357 |
for (i = 0; i < rop->preop.nsf; i++)
| 358 |
fprintf(stderr, " %f", rop->preop.sca[i]);
| 359 |
fputs(" )\n", stderr);
| 360 |
| 361 |
| 362 |
if (rop->preop.transpose) { /* transpose matrix? */
| 363 |
if (!rmx_transpose(rop->mtx)) {
| 364 |
| 365 |
fputs(": transpose failed\n", stderr);
| 366 |
goto failure;
| 367 |
| 368 |
if (verbose) {
| 369 |
| 370 |
fputs(": transposed rows and columns\n", stderr);
| 371 |
| 372 |
| 373 |
mres = rop->mtx;
| 374 |
rop->mtx = NULL;
| 375 |
if (outtype)
| 376 |
mres->dtype = outtype;
| 377 |
return(mres);
| 378 |
failure:
| 379 |
rmx_free(rop->mtx);
| 380 |
return(rop->mtx = NULL);
| 381 |
| 382 |
| 383 |
/* Execute binary operation, free matrix arguments and return new result */
| 384 |
RMATRIX *
| 385 |
binaryop(const char *inspec, RMATRIX *mleft, int op, RMATRIX *mright)
| 386 |
| 387 |
RMATRIX *mres = NULL;
| 388 |
int i;
| 389 |
| 390 |
if ((mleft == NULL) | (mright == NULL))
| 391 |
return(NULL);
| 392 |
switch (op) {
| 393 |
case '.': /* concatenate */
| 394 |
if (mleft->ncomp != mright->ncomp) {
| 395 |
fputs(inspec, stderr);
| 396 |
fputs(": # components do not match\n", stderr);
| 397 |
} else if (mleft->ncols != mright->nrows) {
| 398 |
| 399 |
fputs(": mismatched dimensions\n",
| 400 |
stderr);
| 401 |
} else
| 402 |
mres = rmx_multiply(mleft, mright);
| 403 |
rmx_free(mleft);
| 404 |
rmx_free(mright);
| 405 |
if (mres == NULL) {
| 406 |
| 407 |
fputs(": concatenation failed\n", stderr);
| 408 |
return(NULL);
| 409 |
| 410 |
if (verbose) {
| 411 |
| 412 |
fputs(": concatenated matrix\n", stderr);
| 413 |
| 414 |
break;
| 415 |
case '+':
| 416 |
if (!rmx_sum(mleft, mright, NULL)) {
| 417 |
| 418 |
fputs(": matrix sum failed\n", stderr);
| 419 |
rmx_free(mleft);
| 420 |
rmx_free(mright);
| 421 |
return(NULL);
| 422 |
| 423 |
if (verbose) {
| 424 |
| 425 |
fputs(": added in matrix\n", stderr);
| 426 |
| 427 |
rmx_free(mright);
| 428 |
mres = mleft;
| 429 |
break;
| 430 |
case '*':
| 431 |
case '/': {
| 432 |
const char * tnam = (op == '/') ?
| 433 |
"division" : "multiplication";
| 434 |
errno = 0;
| 435 |
if (!rmx_elemult(mleft, mright, (op == '/'))) {
| 436 |
fprintf(stderr, "%s: element-wise %s failed\n",
| 437 |
inspec, tnam);
| 438 |
rmx_free(mleft);
| 439 |
rmx_free(mright);
| 440 |
return(NULL);
| 441 |
| 442 |
if (errno)
| 443 |
fprintf(stderr,
| 444 |
"%s: warning - error during element-wise %s\n",
| 445 |
inspec, tnam);
| 446 |
else if (verbose)
| 447 |
fprintf(stderr, "%s: element-wise %s\n", inspec, tnam);
| 448 |
rmx_free(mright);
| 449 |
mres = mleft;
| 450 |
} break;
| 451 |
default:
| 452 |
fprintf(stderr, "%s: unknown operation '%c'\n", inspec, op);
| 453 |
rmx_free(mleft);
| 454 |
rmx_free(mright);
| 455 |
return(NULL);
| 456 |
| 457 |
return(mres);
| 458 |
| 459 |
| 460 |
/* Perform matrix operations from left to right */
| 461 |
RMATRIX *
| 462 |
op_left2right(ROPMAT *mop)
| 463 |
| 464 |
RMATRIX *mleft = loadop(mop);
| 465 |
| 466 |
while (mop->binop) {
| 467 |
if (mleft == NULL)
| 468 |
break;
| 469 |
mleft = binaryop(mop[1].inspec,
| 470 |
mleft, mop->binop, loadop(mop+1));
| 471 |
mop++;
| 472 |
| 473 |
return(mleft);
| 474 |
| 475 |
| 476 |
/* Perform matrix operations from right to left */
| 477 |
RMATRIX *
| 478 |
op_right2left(ROPMAT *mop)
| 479 |
| 480 |
RMATRIX *mright;
| 481 |
int rpos = 0;
| 482 |
/* find end of list */
| 483 |
while (mop[rpos].binop)
| 484 |
if (mop[rpos++].binop != '.') {
| 485 |
fputs(
| 486 |
"Right-to-left evaluation only for matrix multiplication!\n",
| 487 |
stderr);
| 488 |
return(NULL);
| 489 |
| 490 |
mright = loadop(mop+rpos);
| 491 |
while (rpos-- > 0) {
| 492 |
if (mright == NULL)
| 493 |
break;
| 494 |
mright = binaryop(mop[rpos+1].inspec,
| 495 |
loadop(mop+rpos), mop[rpos].binop, mright);
| 496 |
| 497 |
return(mright);
| 498 |
| 499 |
| 500 |
#define t_nrows(mop) ((mop)->preop.transpose ? (mop)->mtx->ncols \
| 501 |
: (mop)->mtx->nrows)
| 502 |
#define t_ncols(mop) ((mop)->preop.transpose ? (mop)->mtx->nrows \
| 503 |
: (mop)->mtx->ncols)
| 504 |
| 505 |
/* Should we prefer concatenating from rightmost matrix towards left? */
| 506 |
int
| 507 |
prefer_right2left(ROPMAT *mop)
| 508 |
| 509 |
int mri = 0;
| 510 |
| 511 |
while (mop[mri].binop) /* find rightmost matrix */
| 512 |
if (mop[mri++].binop != '.')
| 513 |
return(0); /* pre-empt reversal for other ops */
| 514 |
| 515 |
if (mri <= 1)
| 516 |
return(0); /* won't matter */
| 517 |
| 518 |
if (loadmatrix(mop+mri) < 0) /* load rightmost cat */
| 519 |
return(1); /* fail will bail in a moment */
| 520 |
| 521 |
if (t_ncols(mop+mri) == 1)
| 522 |
return(1); /* definitely better R->L */
| 523 |
| 524 |
if (t_ncols(mop+mri) >= t_nrows(mop+mri))
| 525 |
return(0); /* ...probably worse */
| 526 |
| 527 |
if (loadmatrix(mop) < 0) /* load leftmost */
| 528 |
return(0); /* fail will bail in a moment */
| 529 |
| 530 |
return(t_ncols(mop+mri) < t_nrows(mop));
| 531 |
| 532 |
| 533 |
int
| 534 |
get_factors(double da[], int n, char *av[])
| 535 |
| 536 |
int ac;
| 537 |
| 538 |
for (ac = 0; ac < n && isflt(av[ac]); ac++)
| 539 |
da[ac] = atof(av[ac]);
| 540 |
return(ac);
| 541 |
| 542 |
| 543 |
ROPMAT *
| 544 |
resize_moparr(ROPMAT *mop, int n2alloc)
| 545 |
| 546 |
int nmats = 0;
| 547 |
int i;
| 548 |
| 549 |
while (mop[nmats++].binop)
| 550 |
| 551 |
for (i = nmats; i >= n2alloc; i--)
| 552 |
rmx_free(mop[i].mtx);
| 553 |
mop = (ROPMAT *)realloc(mop, n2alloc*sizeof(ROPMAT));
| 554 |
if (mop == NULL) {
| 555 |
fputs("Out of memory in resize_moparr()\n", stderr);
| 556 |
exit(1);
| 557 |
| 558 |
if (n2alloc > nmats)
| 559 |
memset(mop+nmats, 0, (n2alloc-nmats)*sizeof(ROPMAT));
| 560 |
return(mop);
| 561 |
| 562 |
| 563 |
/* Load one or more matrices and operate on them, sending results to stdout */
| 564 |
int
| 565 |
main(int argc, char *argv[])
| 566 |
| 567 |
int outfmt = DTfromHeader;
| 568 |
const char *defCsym = NULL;
| 569 |
int nall = 2;
| 570 |
ROPMAT *mop = (ROPMAT *)calloc(nall, sizeof(ROPMAT));
| 571 |
int nmats = 0;
| 572 |
| 573 |
int stdin_used = 0;
| 574 |
int i;
| 575 |
/* get options and arguments */
| 576 |
for (i = 1; i < argc; i++) {
| 577 |
if (argv[i][0] && !argv[i][1] &&
| 578 |
strchr(".+*/", argv[i][0]) != NULL) {
| 579 |
if (!nmats || mop[nmats-1].binop) {
| 580 |
fprintf(stderr,
| 581 |
"%s: missing matrix argument before '%c' operation\n",
| 582 |
argv[0], argv[i][0]);
| 583 |
return(1);
| 584 |
| 585 |
mop[nmats-1].binop = argv[i][0];
| 586 |
} else if (argv[i][0] != '-' || !argv[i][1]) {
| 587 |
if (argv[i][0] == '-') {
| 588 |
if (stdin_used++) {
| 589 |
fprintf(stderr,
| 590 |
"%s: standard input used for more than one matrix\n",
| 591 |
argv[0]);
| 592 |
return(1);
| 593 |
| 594 |
mop[nmats].inspec = stdin_name;
| 595 |
} else
| 596 |
mop[nmats].inspec = argv[i];
| 597 |
if (!mop[nmats].preop.csym)
| 598 |
mop[nmats].preop.csym = defCsym;
| 599 |
if (nmats > 0 && !mop[nmats-1].binop)
| 600 |
mop[nmats-1].binop = '.';
| 601 |
nmats++;
| 602 |
} else {
| 603 |
int n = argc-1 - i;
| 604 |
switch (argv[i][1]) { /* get option */
| 605 |
case 'v':
| 606 |
verbose++;
| 607 |
break;
| 608 |
case 'f':
| 609 |
switch (argv[i][2]) {
| 610 |
case 'd':
| 611 |
outfmt = DTdouble;
| 612 |
break;
| 613 |
case 'f':
| 614 |
outfmt = DTfloat;
| 615 |
break;
| 616 |
case 'a':
| 617 |
outfmt = DTascii;
| 618 |
break;
| 619 |
case 'c':
| 620 |
outfmt = DTrgbe;
| 621 |
break;
| 622 |
default:
| 623 |
goto userr;
| 624 |
| 625 |
break;
| 626 |
case 't':
| 627 |
mop[nmats].preop.transpose = 1;
| 628 |
break;
| 629 |
case 's':
| 630 |
if (n > MAXCOMP) n = MAXCOMP;
| 631 |
i += mop[nmats].preop.nsf =
| 632 |
get_factors(mop[nmats].preop.sca,
| 633 |
n, argv+i+1);
| 634 |
if (mop[nmats].preop.nsf <= 0) {
| 635 |
fprintf(stderr, "%s: -s missing arguments\n",
| 636 |
argv[0]);
| 637 |
goto userr;
| 638 |
| 639 |
break;
| 640 |
case 'C':
| 641 |
if (!n || isflt(argv[i+1]))
| 642 |
goto userr;
| 643 |
defCsym = mop[nmats].preop.csym = argv[++i];
| 644 |
mop[nmats].preop.clen = 0;
| 645 |
break;
| 646 |
case 'c':
| 647 |
if (n && !isflt(argv[i+1])) {
| 648 |
| 649 |
| 650 |
break;
| 651 |
| 652 |
if (n > MAXCOMP*MAXCOMP) n = MAXCOMP*MAXCOMP;
| 653 |
i += mop[nmats].preop.clen =
| 654 |
get_factors(mop[nmats].preop.cmat,
| 655 |
n, argv+i+1);
| 656 |
if (mop[nmats].preop.clen <= 0) {
| 657 |
fprintf(stderr, "%s: -c missing arguments\n",
| 658 |
argv[0]);
| 659 |
goto userr;
| 660 |
| 661 |
mop[nmats].preop.csym = NULL;
| 662 |
break;
| 663 |
case 'r':
| 664 |
if (argv[i][2] == 'f')
| 665 |
mop[nmats].rmp = RMPreflF;
| 666 |
else if (argv[i][2] == 'b')
| 667 |
mop[nmats].rmp = RMPreflB;
| 668 |
else
| 669 |
goto userr;
| 670 |
break;
| 671 |
default:
| 672 |
fprintf(stderr, "%s: unknown operation '%s'\n",
| 673 |
argv[0], argv[i]);
| 674 |
goto userr;
| 675 |
| 676 |
| 677 |
if (nmats >= nall)
| 678 |
mop = resize_moparr(mop, nall += 2);
| 679 |
| 680 |
if (mop[0].inspec == NULL) /* nothing to do? */
| 681 |
goto userr;
| 682 |
if (mop[nmats-1].binop) {
| 683 |
fprintf(stderr,
| 684 |
"%s: missing matrix argument after '%c' operation\n",
| 685 |
argv[0], mop[nmats-1].binop);
| 686 |
return(1);
| 687 |
| 688 |
/* favor quicker concatenation */
| 689 |
mop[nmats].mtx = prefer_right2left(mop) ? op_right2left(mop)
| 690 |
: op_left2right(mop);
| 691 |
if (mop[nmats].mtx == NULL)
| 692 |
return(1);
| 693 |
/* apply trailing unary operations */
| 694 |
mop[nmats].inspec = "trailing_ops";
| 695 |
mres = loadop(mop+nmats);
| 696 |
if (mres == NULL)
| 697 |
return(1);
| 698 |
if ((outfmt == DTfromHeader) & (mres->dtype < DTspec))
| 699 |
outfmt = mres->dtype;
| 700 |
if (outfmt == DTrgbe) { /* check data type */
| 701 |
if (mres->ncomp > 3)
| 702 |
outfmt = DTspec;
| 703 |
else if (mres->dtype == DTxyze)
| 704 |
outfmt = DTxyze;
| 705 |
| 706 |
#if DTrmx_native==DTfloat
| 707 |
if (outfmt == DTdouble)
| 708 |
fprintf(stderr,
| 709 |
"%s: warning - writing float result as double\n",
| 710 |
argv[0]);
| 711 |
#endif
| 712 |
newheader("RADIANCE", stdout); /* write result to stdout */
| 713 |
printargs(argc, argv, stdout);
| 714 |
return(rmx_write(mres, outfmt, stdout) ? 0 : 1);
| 715 |
userr:
| 716 |
fprintf(stderr,
| 717 |
"Usage: %s [-v][-f{adfc}][-t][-s sf .. | -c ce ..][-rf|-rb] m1 [.+*/] .. > mres\n",
| 718 |
argv[0]);
| 719 |
return(1);
| 720 |
