root/radiance/ray/src/util/rmtxop.c
Revision: 2.28
Committed: Sun Dec 3 02:28:33 2023 UTC (20 months, 1 week ago) by greg
Changes since 2.27: +8 -7 lines
fix(rmtxop): Corrected scalar post-multiplying component transform
2 static const char RCSid[] = "$Id: rmtxop.c,v 2.27 2023/12/02 00:42:21 greg Exp $";
5 * General component matrix operations.
6 */
7
8 #include <errno.h>
9 #include "rtio.h"
10 #include "resolu.h"
11 #include "rmatrix.h"
12 #include "platform.h"
13
14 #define MAXCOMP MAXCSAMP /* #components we support */
15
16 /* Unary matrix operation(s) */
17 typedef struct {
18 double cmat[MAXCOMP*MAXCOMP]; /* component transformation */
19 double sca[MAXCOMP]; /* scalar coefficients */
20 const char *csym; /* symbolic coefs or file */
21 short clen; /* number of coefficients */
22 short nsf; /* number of scalars */
23 short transpose; /* do transpose? */
24 } RUNARYOP;
25
26 /* Matrix input source and requested operation(s) */
27 typedef struct {
28 const char *inspec; /* input specification */
29 RMPref rmp; /* matrix preference */
30 RUNARYOP preop; /* unary operation(s) */
31 RMATRIX *mtx; /* original matrix if loaded */
32 int binop; /* binary op with next (or 0) */
33 } ROPMAT;
34
35 int verbose = 0; /* verbose reporting? */
36
37 /* Load matrix */
38 static int
39 loadmatrix(ROPMAT *rop)
40 {
41 if (rop->mtx != NULL) /* already loaded? */
42 return(0);
43
44 rop->mtx = rmx_load(rop->inspec, rop->rmp);
45
46 return(!rop->mtx ? -1 : 1);
47 }
48
49 static int checksymbolic(ROPMAT *rop);
50
51 /* Check/set transform based on a reference input file */
52 static int
53 checkreffile(ROPMAT *rop)
54 {
55 static const char *curRF = NULL;
56 static RMATRIX refm;
57 const int nc = rop->mtx->ncomp;
58 int i;
59
60 if (!curRF || strcmp(rop->preop.csym, curRF)) {
61 FILE *fp = fopen(rop->preop.csym, "rb");
62 if (!rmx_load_header(&refm, fp)) {
63 fprintf(stderr, "%s: cannot read info header\n",
64 rop->preop.csym);
65 curRF = NULL;
66 if (fp) fclose(fp);
67 return(-1);
68 }
69 fclose(fp);
70 curRF = rop->preop.csym;
71 }
72 if ((refm.ncomp == 3) & (refm.dtype != DTspec)) {
73 rop->preop.csym = (refm.dtype == DTxyze) ? "XYZ" : "RGB";
74 return(checksymbolic(rop));
75 }
76 if (refm.ncomp == 2) {
77 fprintf(stderr, "%s: cannot convert to 2 components\n",
78 curRF);
79 return(-1);
80 }
81 if (refm.ncomp == 1) {
82 rop->preop.csym = "Y"; /* XXX big assumption */
83 return(checksymbolic(rop));
84 }
85 if (refm.ncomp == nc &&
86 !memcmp(refm.wlpart, rop->mtx->wlpart, sizeof(refm.wlpart)))
87 return(0); /* nothing to do */
88
89 if ((nc <= 3) | (nc > MAXCSAMP) | (refm.ncomp > MAXCSAMP)) {
90 fprintf(stderr, "%s: cannot resample from %d to %d components\n",
91 curRF, nc, refm.ncomp);
92 return(-1);
93 }
94 rop->preop.clen = refm.ncomp * nc; /* compute spec to ref */
95
96 for (i = 0; i < nc; i++) {
97 SCOLOR scstim, scresp;
98 int j;
99 memset(scstim, 0, sizeof(COLORV)*nc);
100 scstim[i] = 1.f;
101 convertscolor(scresp, refm.ncomp, refm.wlpart[0], refm.wlpart[3],
102 scstim, nc, rop->mtx->wlpart[0], rop->mtx->wlpart[3]);
103 for (j = refm.ncomp; j-- > 0; )
104 rop->preop.cmat[j*nc + i] = scresp[j];
105 }
106 return(0);
107 }
108
109 /* Compute conversion row from spectrum to one channel of RGB */
110 static void
111 rgbrow(ROPMAT *rop, int r, int p)
112 {
113 const int nc = rop->mtx->ncomp;
114 const float * wlp = rop->mtx->wlpart;
115 int i;
116
117 for (i = nc; i--; ) {
118 int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc;
119 int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc;
120 COLOR crgb;
121 spec_rgb(crgb, nmStart, nmEnd);
122 rop->preop.cmat[r*nc+i] = crgb[p];
123 }
124 }
125
126 /* Compute conversion row from spectrum to one channel of XYZ */
127 static void
128 xyzrow(ROPMAT *rop, int r, int p)
129 {
130 const int nc = rop->mtx->ncomp;
131 const float * wlp = rop->mtx->wlpart;
132 int i;
133
134 for (i = nc; i--; ) {
135 int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc;
136 int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc;
137 COLOR cxyz;
138 spec_cie(cxyz, nmStart, nmEnd);
139 rop->preop.cmat[r*nc+i] = cxyz[p];
140 }
141 }
142
143 /* Use the spectral sensitivity function to compute matrix coefficients */
144 static void
145 sensrow(ROPMAT *rop, int r, double (*sf)(SCOLOR sc, int ncs, const float wlpt[4]))
146 {
147 const int nc = rop->mtx->ncomp;
148 int i;
149
150 for (i = nc; i--; ) {
151 SCOLOR sclr;
152 memset(sclr, 0, sizeof(COLORV)*nc);
153 sclr[i] = 1.f;
154 rop->preop.cmat[r*nc+i] = (*sf)(sclr, nc, rop->mtx->wlpart);
155 }
156 }
157
158 /* Check/set symbolic transform */
159 static int
160 checksymbolic(ROPMAT *rop)
161 {
162 const int nc = rop->mtx->ncomp;
163 const int dt = rop->mtx->dtype;
164 int i, j;
165 /* check suffix => reference file */
166 if (strchr(rop->preop.csym, '.') > rop->preop.csym)
167 return(checkreffile(rop));
168
169 if (nc < 3) {
170 fprintf(stderr, "%s: -c '%s' requires at least 3 components\n",
171 rop->inspec, rop->preop.csym);
172 return(-1);
173 }
174 rop->preop.clen = strlen(rop->preop.csym) * nc;
175 if (rop->preop.clen > MAXCOMP*MAXCOMP) {
176 fprintf(stderr, "%s: -c '%s' results in too many components\n",
177 rop->inspec, rop->preop.csym);
178 return(-1);
179 }
180 for (j = 0; rop->preop.csym[j]; j++) {
181 int comp = 0;
182 switch (rop->preop.csym[j]) {
183 case 'B':
184 ++comp;
185 /* fall through */
186 case 'G':
187 ++comp;
188 /* fall through */
189 case 'R':
190 if (dt == DTxyze) {
191 for (i = 3; i--; )
192 rop->preop.cmat[j*nc+i] = 1./WHTEFFICACY *
193 xyz2rgbmat[comp][i];
194 } else if (nc == 3)
195 rop->preop.cmat[j*nc+comp] = 1.;
196 else
197 rgbrow(rop, j, comp);
198 break;
199 case 'Z':
200 ++comp;
201 /* fall through */
202 case 'Y':
203 ++comp;
204 /* fall through */
205 case 'X':
206 if (dt == DTxyze) {
207 rop->preop.cmat[j*nc+comp] = 1.;
208 } else if (nc == 3) {
209 for (i = 3; i--; )
210 rop->preop.cmat[j*nc+i] =
211 rgb2xyzmat[comp][i];
212 } else if (comp == CIEY)
213 sensrow(rop, j, scolor2photopic);
214 else
215 xyzrow(rop, j, comp);
216
217 for (i = nc*(dt != DTxyze); i--; )
218 rop->preop.cmat[j*nc+i] *= WHTEFFICACY;
219 break;
220 case 'S': /* scotopic (il)luminance */
221 sensrow(rop, j, scolor2scotopic);
222 for (i = nc; i--; )
223 rop->preop.cmat[j*nc+i] *= WHTSCOTOPIC;
224 break;
225 case 'M': /* melanopic (il)luminance */
226 sensrow(rop, j, scolor2melanopic);
227 for (i = nc; i--; )
228 rop->preop.cmat[j*nc+i] *= WHTMELANOPIC;
229 break;
230 case 'A': /* average component */
231 for (i = nc; i--; )
232 rop->preop.cmat[j*nc+i] = 1./(double)nc;
233 break;
234 default:
235 fprintf(stderr, "%s: -c '%c' unsupported\n",
236 rop->inspec, rop->preop.csym[j]);
237 return(-1);
238 }
239 }
240 /* return recommended output type */
241 if (!strcmp(rop->preop.csym, "XYZ")) {
242 if (dt <= DTspec)
243 return(DTxyze);
244 } else if (!strcmp(rop->preop.csym, "RGB")) {
245 if (dt <= DTspec)
246 return(DTrgbe);
247 }
248 if ((nc > 3) & (dt <= DTspec))
249 return(DTfloat); /* probably not actual spectrum */
250 return(0);
251 }
252
253 /* Get matrix and perform unary operations */
254 static RMATRIX *
255 loadop(ROPMAT *rop)
256 {
257 int outtype = 0;
258 RMATRIX *mres;
259 int i, j;
260
261 if (loadmatrix(rop) < 0) /* make sure we're loaded */
262 return(NULL);
263
264 if (rop->preop.csym && /* symbolic transform? */
265 (outtype = checksymbolic(rop)) < 0)
266 goto failure;
267 if (rop->preop.clen > 0) { /* apply component transform? */
268 if (rop->preop.clen % rop->mtx->ncomp) {
269 fprintf(stderr, "%s: -c must have N x %d coefficients\n",
270 rop->inspec, rop->mtx->ncomp);
271 goto failure;
272 }
273 if (rop->preop.nsf > 0) { /* scale transform, first */
274 if (rop->preop.nsf == 1) {
275 for (i = rop->preop.clen; i--; )
276 rop->preop.cmat[i] *= rop->preop.sca[0];
277 } else if (rop->preop.nsf*rop->mtx->ncomp != rop->preop.clen) {
278 fprintf(stderr, "%s: -s must have one or %d factors\n",
279 rop->inspec,
280 rop->preop.clen/rop->mtx->ncomp);
281 goto failure;
282 } else {
283 for (i = rop->preop.nsf; i--; )
284 for (j = rop->mtx->ncomp; j--; )
285 rop->preop.cmat[i*rop->mtx->ncomp+j]
286 *= rop->preop.sca[i];
287 }
288 }
289 mres = rmx_transform(rop->mtx, rop->preop.clen/rop->mtx->ncomp,
290 rop->preop.cmat);
291 if (mres == NULL) {
292 fprintf(stderr, "%s: matrix transform failed\n",
293 rop->inspec);
294 goto failure;
295 }
296 if (verbose)
297 fprintf(stderr, "%s: applied %d x %d transform%s\n",
298 rop->inspec, mres->ncomp,
299 rop->mtx->ncomp,
300 rop->preop.nsf ? " (* scalar)" : "");
301 rop->preop.nsf = 0; /* now folded in */
302 if ((mres->ncomp > 3) & (mres->dtype <= DTspec))
303 outtype = DTfloat; /* probably not actual spectrum */
304 rmx_free(rop->mtx);
305 rop->mtx = mres;
306 }
307 if (rop->preop.nsf > 0) { /* apply scalar(s)? */
308 if (rop->preop.nsf == 1) {
309 for (i = rop->mtx->ncomp; --i; )
310 rop->preop.sca[i] = rop->preop.sca[0];
311 } else if (rop->preop.nsf != rop->mtx->ncomp) {
312 fprintf(stderr, "%s: -s must have one or %d factors\n",
313 rop->inspec, rop->mtx->ncomp);
314 goto failure;
315 }
316 if (!rmx_scale(rop->mtx, rop->preop.sca)) {
317 fputs(rop->inspec, stderr);
318 fputs(": scalar operation failed\n", stderr);
319 goto failure;
320 }
321 if (verbose) {
322 fputs(rop->inspec, stderr);
323 fputs(": applied scalar (", stderr);
324 for (i = 0; i < rop->preop.nsf; i++)
325 fprintf(stderr, " %f", rop->preop.sca[i]);
326 fputs(" )\n", stderr);
327 }
328 }
329 if (rop->preop.transpose) { /* transpose matrix? */
330 mres = rmx_transpose(rop->mtx);
331 if (mres == NULL) {
332 fputs(rop->inspec, stderr);
333 fputs(": transpose failed\n", stderr);
334 goto failure;
335 }
336 if (verbose) {
337 fputs(rop->inspec, stderr);
338 fputs(": transposed rows and columns\n", stderr);
339 }
340 rmx_free(rop->mtx);
341 rop->mtx = mres;
342 }
343 mres = rop->mtx;
344 rop->mtx = NULL;
345 if (outtype)
346 mres->dtype = outtype;
347 return(mres);
348 failure:
349 rmx_free(rop->mtx);
350 return(rop->mtx = NULL);
351 }
352
353 /* Execute binary operation, free matrix arguments and return new result */
354 static RMATRIX *
355 binaryop(const char *inspec, RMATRIX *mleft, int op, RMATRIX *mright)
356 {
357 RMATRIX *mres = NULL;
358 int i;
359
360 if ((mleft == NULL) | (mright == NULL))
361 return(NULL);
362 switch (op) {
363 case '.': /* concatenate */
364 if (mleft->ncomp != mright->ncomp) {
365 fputs(inspec, stderr);
366 fputs(": # components do not match\n", stderr);
367 } else if (mleft->ncols != mright->nrows) {
368 fputs(inspec, stderr);
369 fputs(": mismatched dimensions\n",
370 stderr);
371 } else
372 mres = rmx_multiply(mleft, mright);
373 rmx_free(mleft);
374 rmx_free(mright);
375 if (mres == NULL) {
376 fputs(inspec, stderr);
377 fputs(": concatenation failed\n", stderr);
378 return(NULL);
379 }
380 if (verbose) {
381 fputs(inspec, stderr);
382 fputs(": concatenated matrix\n", stderr);
383 }
384 break;
385 case '+':
386 if (!rmx_sum(mleft, mright, NULL)) {
387 fputs(inspec, stderr);
388 fputs(": matrix sum failed\n", stderr);
389 rmx_free(mleft);
390 rmx_free(mright);
391 return(NULL);
392 }
393 if (verbose) {
394 fputs(inspec, stderr);
395 fputs(": added in matrix\n", stderr);
396 }
397 rmx_free(mright);
398 mres = mleft;
399 break;
400 case '*':
401 case '/': {
402 const char * tnam = (op == '/') ?
403 "division" : "multiplication";
404 errno = 0;
405 if (!rmx_elemult(mleft, mright, (op == '/'))) {
406 fprintf(stderr, "%s: element-wise %s failed\n",
407 inspec, tnam);
408 rmx_free(mleft);
409 rmx_free(mright);
410 return(NULL);
411 }
412 if (errno)
413 fprintf(stderr,
414 "%s: warning - error during element-wise %s\n",
415 inspec, tnam);
416 else if (verbose)
417 fprintf(stderr, "%s: element-wise %s\n", inspec, tnam);
418 rmx_free(mright);
419 mres = mleft;
420 } break;
421 default:
422 fprintf(stderr, "%s: unknown operation '%c'\n", inspec, op);
423 rmx_free(mleft);
424 rmx_free(mright);
425 return(NULL);
426 }
427 return(mres);
428 }
429
430 /* Perform matrix operations from left to right */
431 static RMATRIX *
432 op_left2right(ROPMAT *mop)
433 {
434 RMATRIX *mleft = loadop(mop);
435
436 while (mop->binop) {
437 if (mleft == NULL)
438 break;
439 mleft = binaryop(mop[1].inspec,
440 mleft, mop->binop, loadop(mop+1));
441 mop++;
442 }
443 return(mleft);
444 }
445
446 /* Perform matrix operations from right to left */
447 static RMATRIX *
448 op_right2left(ROPMAT *mop)
449 {
450 RMATRIX *mright;
451 int rpos = 0;
452 /* find end of list */
453 while (mop[rpos].binop)
454 if (mop[rpos++].binop != '.') {
455 fputs(
456 "Right-to-left evaluation only for matrix multiplication!\n",
457 stderr);
458 return(NULL);
459 }
460 mright = loadop(mop+rpos);
461 while (rpos-- > 0) {
462 if (mright == NULL)
463 break;
464 mright = binaryop(mop[rpos+1].inspec,
465 loadop(mop+rpos), mop[rpos].binop, mright);
466 }
467 return(mright);
468 }
469
470 #define t_nrows(mop) ((mop)->preop.transpose ? (mop)->mtx->ncols \
471 : (mop)->mtx->nrows)
472 #define t_ncols(mop) ((mop)->preop.transpose ? (mop)->mtx->nrows \
473 : (mop)->mtx->ncols)
474
475 /* Should we prefer concatenating from rightmost matrix towards left? */
476 static int
477 prefer_right2left(ROPMAT *mop)
478 {
479 int mri = 0;
480
481 while (mop[mri].binop) /* find rightmost matrix */
482 if (mop[mri++].binop != '.')
483 return(0); /* pre-empt reversal for other ops */
484
485 if (mri <= 1)
486 return(0); /* won't matter */
487
488 if (loadmatrix(mop+mri) < 0) /* load rightmost cat */
489 return(1); /* fail will bail in a moment */
490
491 if (t_ncols(mop+mri) == 1)
492 return(1); /* definitely better R->L */
493
494 if (t_ncols(mop+mri) >= t_nrows(mop+mri))
495 return(0); /* ...probably worse */
496
497 if (loadmatrix(mop) < 0) /* load leftmost */
498 return(0); /* fail will bail in a moment */
499
500 return(t_ncols(mop+mri) < t_nrows(mop));
501 }
502
503 static int
504 get_factors(double da[], int n, char *av[])
505 {
506 int ac;
507
508 for (ac = 0; ac < n && isflt(av[ac]); ac++)
509 da[ac] = atof(av[ac]);
510 return(ac);
511 }
512
513 static ROPMAT *
514 resize_moparr(ROPMAT *mop, int n2alloc)
515 {
516 int nmats = 0;
517 int i;
518
519 while (mop[nmats++].binop)
520 ;
521 for (i = nmats; i > n2alloc; i--)
522 rmx_free(mop[i].mtx);
523 mop = (ROPMAT *)realloc(mop, n2alloc*sizeof(ROPMAT));
524 if (mop == NULL) {
525 fputs("Out of memory in resize_moparr()\n", stderr);
526 exit(1);
527 }
528 if (n2alloc > nmats)
529 memset(mop+nmats, 0, (n2alloc-nmats)*sizeof(ROPMAT));
530 return(mop);
531 }
532
533 /* Load one or more matrices and operate on them, sending results to stdout */
534 int
535 main(int argc, char *argv[])
536 {
537 int outfmt = DTfromHeader;
538 const char *defCsym = NULL;
539 int nall = 2;
540 ROPMAT *mop = (ROPMAT *)calloc(nall, sizeof(ROPMAT));
541 int nmats = 0;
542 RMATRIX *mres = NULL;
543 int stdin_used = 0;
544 int i;
545 /* get options and arguments */
546 for (i = 1; i < argc; i++) {
547 if (argv[i][0] && !argv[i][1] &&
548 strchr(".+*/", argv[i][0]) != NULL) {
549 if (!nmats || mop[nmats-1].binop) {
550 fprintf(stderr,
551 "%s: missing matrix argument before '%c' operation\n",
552 argv[0], argv[i][0]);
553 return(1);
554 }
555 mop[nmats-1].binop = argv[i][0];
556 } else if (argv[i][0] != '-' || !argv[i][1]) {
557 if (argv[i][0] == '-') {
558 if (stdin_used++) {
559 fprintf(stderr,
560 "%s: standard input used for more than one matrix\n",
561 argv[0]);
562 return(1);
563 }
564 mop[nmats].inspec = stdin_name;
565 } else
566 mop[nmats].inspec = argv[i];
567 if (!mop[nmats].preop.csym)
568 mop[nmats].preop.csym = defCsym;
569 if (nmats > 0 && !mop[nmats-1].binop)
570 mop[nmats-1].binop = '.';
571 nmats++;
572 } else {
573 int n = argc-1 - i;
574 switch (argv[i][1]) { /* get option */
575 case 'v':
576 verbose++;
577 break;
578 case 'f':
579 switch (argv[i][2]) {
580 case 'd':
581 outfmt = DTdouble;
582 break;
583 case 'f':
584 outfmt = DTfloat;
585 break;
586 case 'a':
587 outfmt = DTascii;
588 break;
589 case 'c':
590 outfmt = DTrgbe;
591 break;
592 default:
593 goto userr;
594 }
595 break;
596 case 't':
597 mop[nmats].preop.transpose = 1;
598 break;
599 case 's':
600 if (n > MAXCOMP) n = MAXCOMP;
601 i += mop[nmats].preop.nsf =
602 get_factors(mop[nmats].preop.sca,
603 n, argv+i+1);
604 if (mop[nmats].preop.nsf <= 0) {
605 fprintf(stderr, "%s: -s missing arguments\n",
606 argv[0]);
607 goto userr;
608 }
609 break;
610 case 'C':
611 if (!n || isflt(argv[i+1]))
612 goto userr;
613 defCsym = mop[nmats].preop.csym = argv[++i];
614 mop[nmats].preop.clen = 0;
615 break;
616 case 'c':
617 if (n && !isflt(argv[i+1])) {
618 mop[nmats].preop.csym = argv[++i];
619 mop[nmats].preop.clen = 0;
620 break;
621 }
622 if (n > MAXCOMP*MAXCOMP) n = MAXCOMP*MAXCOMP;
623 i += mop[nmats].preop.clen =
624 get_factors(mop[nmats].preop.cmat,
625 n, argv+i+1);
626 if (mop[nmats].preop.clen <= 0) {
627 fprintf(stderr, "%s: -c missing arguments\n",
628 argv[0]);
629 goto userr;
630 }
631 mop[nmats].preop.csym = NULL;
632 break;
633 case 'r':
634 if (argv[i][2] == 'f')
635 mop[nmats].rmp = RMPreflF;
636 else if (argv[i][2] == 'b')
637 mop[nmats].rmp = RMPreflB;
638 else
639 goto userr;
640 break;
641 default:
642 fprintf(stderr, "%s: unknown operation '%s'\n",
643 argv[0], argv[i]);
644 goto userr;
645 }
646 }
647 if (nmats >= nall)
648 mop = resize_moparr(mop, nall += 2);
649 }
650 if (mop[0].inspec == NULL) /* nothing to do? */
651 goto userr;
652 if (mop[nmats-1].binop) {
653 fprintf(stderr,
654 "%s: missing matrix argument after '%c' operation\n",
655 argv[0], mop[nmats-1].binop);
656 return(1);
657 }
658 /* favor quicker concatenation */
659 mop[nmats].mtx = prefer_right2left(mop) ? op_right2left(mop)
660 : op_left2right(mop);
661 if (mop[nmats].mtx == NULL)
662 return(1);
663 /* apply trailing unary operations */
664 mop[nmats].inspec = "trailing_ops";
665 mres = loadop(mop+nmats);
666 if (mres == NULL)
667 return(1);
668 if (outfmt == DTfromHeader) /* check data type */
669 outfmt = mres->dtype;
670 if (outfmt == DTrgbe) {
671 if (mres->ncomp > 3)
672 outfmt = DTspec;
673 else if (mres->dtype == DTxyze)
674 outfmt = DTxyze;
675 }
676 newheader("RADIANCE", stdout); /* write result to stdout */
677 printargs(argc, argv, stdout);
678 return(rmx_write(mres, outfmt, stdout) ? 0 : 1);
679 userr:
680 fprintf(stderr,
681 "Usage: %s [-v][-f{adfc}][-t][-s sf .. | -c ce ..][-rf|-rb] m1 [.+*/] .. > mres\n",
682 argv[0]);
683 return(1);
684 }
