1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: rmtxop.c,v 2.23 2023/11/28 16:36:50 greg Exp $"; |
3 |
#endif |
4 |
5 |
* General component matrix operations. |
6 |
7 |
8 |
#include <stdlib.h> |
9 |
#include <errno.h> |
10 |
#include <ctype.h> |
11 |
#include "rtio.h" |
12 |
#include "resolu.h" |
13 |
#include "rmatrix.h" |
14 |
#include "platform.h" |
15 |
16 |
#define MAXCOMP MAXCSAMP /* #components we support */ |
17 |
18 |
/* Unary matrix operation(s) */ |
19 |
typedef struct { |
20 |
double sca[MAXCOMP]; /* scalar coefficients */ |
21 |
double cmat[MAXCOMP*MAXCOMP]; /* component transformation */ |
22 |
short nsf; /* number of scalars */ |
23 |
short clen; /* number of coefficients */ |
24 |
char csym[11]; /* symbolic coefficients */ |
25 |
char transpose; /* do transpose? */ |
26 |
} RUNARYOP; |
27 |
28 |
/* Matrix input source and requested operation(s) */ |
29 |
typedef struct { |
30 |
const char *inspec; /* input specification */ |
31 |
RMPref rmp; /* matrix preference */ |
32 |
RUNARYOP preop; /* unary operation(s) */ |
33 |
RMATRIX *mtx; /* original matrix if loaded */ |
34 |
int binop; /* binary op with next (or 0) */ |
35 |
} ROPMAT; |
36 |
37 |
int verbose = 0; /* verbose reporting? */ |
38 |
39 |
/* Load matrix */ |
40 |
static int |
41 |
loadmatrix(ROPMAT *rop) |
42 |
43 |
if (rop->mtx != NULL) /* already loaded? */ |
44 |
return(0); |
45 |
46 |
rop->mtx = rmx_load(rop->inspec, rop->rmp); |
47 |
48 |
return(!rop->mtx ? -1 : 1); |
49 |
50 |
51 |
/* Compute conversion row from spectrum to one channel of RGB */ |
52 |
static void |
53 |
rgbrow(ROPMAT *rop, int r, int p) |
54 |
55 |
const int nc = rop->mtx->ncomp; |
56 |
const float * wlp = rop->mtx->wlpart; |
57 |
int i; |
58 |
59 |
for (i = nc; i--; ) { |
60 |
int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc; |
61 |
int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc; |
62 |
COLOR crgb; |
63 |
spec_rgb(crgb, nmStart, nmEnd); |
64 |
rop->preop.cmat[r*nc+i] = crgb[p]; |
65 |
66 |
67 |
68 |
/* Compute conversion row from spectrum to one channel of XYZ */ |
69 |
static void |
70 |
xyzrow(ROPMAT *rop, int r, int p) |
71 |
72 |
73 |
74 |
int i; |
75 |
76 |
77 |
78 |
79 |
COLOR cxyz; |
80 |
spec_cie(cxyz, nmStart, nmEnd); |
81 |
rop->preop.cmat[r*nc+i] = cxyz[p]; |
82 |
83 |
84 |
85 |
/* Use the spectral sensitivity function to compute matrix coefficients */ |
86 |
static void |
87 |
sensrow(ROPMAT *rop, int r, double (*sf)(SCOLOR sc, int ncs, const float wlpt[4])) |
88 |
89 |
90 |
int i; |
91 |
92 |
93 |
SCOLOR sclr; |
94 |
scolorblack(sclr); |
95 |
sclr[i] = 1.f; |
96 |
rop->preop.cmat[r*nc+i] = (*sf)(sclr, nc, rop->mtx->wlpart); |
97 |
98 |
99 |
100 |
/* Check/set symbolic transform */ |
101 |
static int |
102 |
checksymbolic(ROPMAT *rop) |
103 |
104 |
105 |
const int dt = rop->mtx->dtype; |
106 |
int i, j; |
107 |
108 |
if (nc < 3) { |
109 |
fprintf(stderr, "%s: -c '%s' requires at least 3 components\n", |
110 |
rop->inspec, rop->preop.csym); |
111 |
return(-1); |
112 |
113 |
rop->preop.clen = strlen(rop->preop.csym) * nc; |
114 |
if (rop->preop.clen > MAXCOMP*MAXCOMP) { |
115 |
fprintf(stderr, "%s: -c '%s' results in too many components\n", |
116 |
117 |
return(-1); |
118 |
119 |
for (j = 0; rop->preop.csym[j]; j++) { |
120 |
int comp = 0; |
121 |
switch (rop->preop.csym[j]) { |
122 |
case 'B': |
123 |
++comp; |
124 |
/* fall through */ |
125 |
case 'G': |
126 |
++comp; |
127 |
128 |
case 'R': |
129 |
if (dt == DTxyze) { |
130 |
for (i = 3; i--; ) |
131 |
rop->preop.cmat[j*nc+i] = 1./WHTEFFICACY * |
132 |
xyz2rgbmat[comp][i]; |
133 |
} else if (nc == 3) |
134 |
rop->preop.cmat[j*nc+comp] = 1.; |
135 |
else |
136 |
rgbrow(rop, j, comp); |
137 |
break; |
138 |
case 'Z': |
139 |
++comp; |
140 |
141 |
case 'Y': |
142 |
++comp; |
143 |
144 |
case 'X': |
145 |
146 |
147 |
} else if (nc == 3) { |
148 |
149 |
rop->preop.cmat[j*nc+i] = |
150 |
rgb2xyzmat[comp][i]; |
151 |
} else if (comp == CIEY) |
152 |
sensrow(rop, j, scolor2photopic); |
153 |
else |
154 |
xyzrow(rop, j, comp); |
155 |
156 |
for (i = nc*(dt != DTxyze); i--; ) |
157 |
rop->preop.cmat[j*nc+i] *= WHTEFFICACY; |
158 |
break; |
159 |
case 'S': /* scotopic (il)luminance */ |
160 |
sensrow(rop, j, scolor2scotopic); |
161 |
for (i = nc; i--; ) |
162 |
rop->preop.cmat[j*nc+i] *= WHTSCOTOPIC; |
163 |
break; |
164 |
case 'M': /* melanopic (il)luminance */ |
165 |
sensrow(rop, j, scolor2melanopic); |
166 |
167 |
rop->preop.cmat[j*nc+i] *= WHTMELANOPIC; |
168 |
break; |
169 |
case 'A': /* average component */ |
170 |
171 |
rop->preop->cmat[j*nc+i] = 1./(double)nc; |
172 |
break; |
173 |
default: |
174 |
fprintf(stderr, "%s: -c '%c' unsupported\n", |
175 |
rop->inspec, rop->preop.csym[j]); |
176 |
return(-1); |
177 |
178 |
179 |
/* return recommended output type */ |
180 |
if (!strcmp(rop->preop.csym, "XYZ")) { |
181 |
if (dt <= DTspec) |
182 |
return(DTxyze); |
183 |
} else if (!strcmp(rop->preop.csym, "RGB")) { |
184 |
if (dt <= DTspec) |
185 |
return(DTrgbe); |
186 |
187 |
if ((nc > 3) & (dt <= DTspec)) |
188 |
return(DTfloat); /* probably not actual spectrum */ |
189 |
return(0); |
190 |
191 |
192 |
/* Get matrix and perform unary operations */ |
193 |
static RMATRIX * |
194 |
loadop(ROPMAT *rop) |
195 |
196 |
int outtype = 0; |
197 |
RMATRIX *mres; |
198 |
int i, j; |
199 |
200 |
if (loadmatrix(rop) < 0) /* make sure we're loaded */ |
201 |
return(NULL); |
202 |
203 |
if (rop->preop.csym[0] && /* symbolic transform? */ |
204 |
(outtype = checksymbolic(rop)) < 0) |
205 |
goto failure; |
206 |
if (rop->preop.clen > 0) { /* apply component transform? */ |
207 |
if (rop->preop.clen % rop->mtx->ncomp) { |
208 |
fprintf(stderr, "%s: -c must have N x %d coefficients\n", |
209 |
rop->inspec, rop->mtx->ncomp); |
210 |
goto failure; |
211 |
212 |
if (rop->preop.nsf > 0) { /* scale transform, first */ |
213 |
if (rop->preop.nsf == 1) { |
214 |
for (i = rop->preop.clen; i--; ) |
215 |
rop->preop.cmat[i] *= rop->preop.sca[0]; |
216 |
} else if (rop->preop.nsf != rop->mtx->ncomp) { |
217 |
fprintf(stderr, "%s: -s must have one or %d factors\n", |
218 |
219 |
goto failure; |
220 |
} else { |
221 |
for (j = rop->preop.clen/rop->preop.nsf; j--; ) |
222 |
for (i = rop->preop.nsf; i--; ) |
223 |
rop->preop.cmat[j*rop->preop.nsf+i] *= |
224 |
rop->preop.sca[i]; |
225 |
226 |
227 |
mres = rmx_transform(rop->mtx, rop->preop.clen/rop->mtx->ncomp, |
228 |
rop->preop.cmat); |
229 |
if (mres == NULL) { |
230 |
fprintf(stderr, "%s: matrix transform failed\n", |
231 |
rop->inspec); |
232 |
goto failure; |
233 |
234 |
if (verbose) |
235 |
fprintf(stderr, "%s: applied %d x %d transform%s\n", |
236 |
rop->inspec, mres->ncomp, |
237 |
rop->mtx->ncomp, |
238 |
rop->preop.nsf ? " (* scalar)" : ""); |
239 |
rop->preop.nsf = 0; |
240 |
if ((mres->ncomp > 3) & (mres->dtype <= DTspec)) |
241 |
outtype = DTfloat; /* probably not actual spectrum */ |
242 |
rmx_free(rop->mtx); |
243 |
rop->mtx = mres; |
244 |
245 |
if (rop->preop.nsf > 0) { /* apply scalar(s)? */ |
246 |
247 |
for (i = rop->mtx->ncomp; --i; ) |
248 |
rop->preop.sca[i] = rop->preop.sca[0]; |
249 |
250 |
251 |
252 |
goto failure; |
253 |
254 |
if (!rmx_scale(rop->mtx, rop->preop.sca)) { |
255 |
fputs(rop->inspec, stderr); |
256 |
fputs(": scalar operation failed\n", stderr); |
257 |
goto failure; |
258 |
259 |
if (verbose) { |
260 |
261 |
fputs(": applied scalar (", stderr); |
262 |
for (i = 0; i < rop->preop.nsf; i++) |
263 |
fprintf(stderr, " %f", rop->preop.sca[i]); |
264 |
fputs(" )\n", stderr); |
265 |
266 |
267 |
if (rop->preop.transpose) { /* transpose matrix? */ |
268 |
mres = rmx_transpose(rop->mtx); |
269 |
270 |
271 |
fputs(": transpose failed\n", stderr); |
272 |
goto failure; |
273 |
274 |
if (verbose) { |
275 |
276 |
fputs(": transposed rows and columns\n", stderr); |
277 |
278 |
279 |
rop->mtx = mres; |
280 |
281 |
mres = rop->mtx; |
282 |
rop->mtx = NULL; |
283 |
if (outtype) |
284 |
mres->dtype = outtype; |
285 |
return(mres); |
286 |
failure: |
287 |
288 |
return(rop->mtx = NULL); |
289 |
290 |
291 |
/* Execute binary operation, free matrix arguments and return new result */ |
292 |
static RMATRIX * |
293 |
binaryop(const char *inspec, RMATRIX *mleft, int op, RMATRIX *mright) |
294 |
295 |
RMATRIX *mres = NULL; |
296 |
int i; |
297 |
298 |
if ((mleft == NULL) | (mright == NULL)) |
299 |
return(NULL); |
300 |
switch (op) { |
301 |
case '.': /* concatenate */ |
302 |
if (mleft->ncomp != mright->ncomp) { |
303 |
fputs(inspec, stderr); |
304 |
fputs(": # components do not match\n", stderr); |
305 |
} else if (mleft->ncols != mright->nrows) { |
306 |
307 |
fputs(": mismatched dimensions\n", |
308 |
stderr); |
309 |
} else |
310 |
mres = rmx_multiply(mleft, mright); |
311 |
rmx_free(mleft); |
312 |
rmx_free(mright); |
313 |
314 |
315 |
fputs(": concatenation failed\n", stderr); |
316 |
return(NULL); |
317 |
318 |
if (verbose) { |
319 |
320 |
fputs(": concatenated matrix\n", stderr); |
321 |
322 |
break; |
323 |
case '+': |
324 |
if (!rmx_sum(mleft, mright, NULL)) { |
325 |
326 |
fputs(": matrix sum failed\n", stderr); |
327 |
rmx_free(mleft); |
328 |
rmx_free(mright); |
329 |
return(NULL); |
330 |
331 |
if (verbose) { |
332 |
333 |
fputs(": added in matrix\n", stderr); |
334 |
335 |
rmx_free(mright); |
336 |
mres = mleft; |
337 |
break; |
338 |
case '*': |
339 |
case '/': { |
340 |
const char * tnam = (op == '/') ? |
341 |
"division" : "multiplication"; |
342 |
errno = 0; |
343 |
if (!rmx_elemult(mleft, mright, (op == '/'))) { |
344 |
fprintf(stderr, "%s: element-wise %s failed\n", |
345 |
inspec, tnam); |
346 |
rmx_free(mleft); |
347 |
rmx_free(mright); |
348 |
return(NULL); |
349 |
350 |
if (errno) |
351 |
fprintf(stderr, |
352 |
"%s: warning - error during element-wise %s\n", |
353 |
inspec, tnam); |
354 |
else if (verbose) |
355 |
fprintf(stderr, "%s: element-wise %s\n", inspec, tnam); |
356 |
rmx_free(mright); |
357 |
mres = mleft; |
358 |
} break; |
359 |
default: |
360 |
fprintf(stderr, "%s: unknown operation '%c'\n", inspec, op); |
361 |
rmx_free(mleft); |
362 |
rmx_free(mright); |
363 |
return(NULL); |
364 |
365 |
return(mres); |
366 |
367 |
368 |
/* Perform matrix operations from left to right */ |
369 |
static RMATRIX * |
370 |
op_left2right(ROPMAT *mop) |
371 |
372 |
RMATRIX *mleft = loadop(mop); |
373 |
374 |
while (mop->binop) { |
375 |
if (mleft == NULL) |
376 |
break; |
377 |
mleft = binaryop(mop[1].inspec, |
378 |
mleft, mop->binop, loadop(mop+1)); |
379 |
mop++; |
380 |
381 |
return(mleft); |
382 |
383 |
384 |
/* Perform matrix operations from right to left */ |
385 |
static RMATRIX * |
386 |
op_right2left(ROPMAT *mop) |
387 |
388 |
RMATRIX *mright; |
389 |
int rpos = 0; |
390 |
/* find end of list */ |
391 |
while (mop[rpos].binop) |
392 |
if (mop[rpos++].binop != '.') { |
393 |
fputs( |
394 |
"Right-to-left evaluation only for matrix multiplication!\n", |
395 |
stderr); |
396 |
return(NULL); |
397 |
398 |
mright = loadop(mop+rpos); |
399 |
while (rpos-- > 0) { |
400 |
if (mright == NULL) |
401 |
break; |
402 |
mright = binaryop(mop[rpos+1].inspec, |
403 |
loadop(mop+rpos), mop[rpos].binop, mright); |
404 |
405 |
return(mright); |
406 |
407 |
408 |
#define t_nrows(mop) ((mop)->preop.transpose ? (mop)->mtx->ncols \ |
409 |
: (mop)->mtx->nrows) |
410 |
#define t_ncols(mop) ((mop)->preop.transpose ? (mop)->mtx->nrows \ |
411 |
: (mop)->mtx->ncols) |
412 |
413 |
/* Should we prefer concatenating from rightmost matrix towards left? */ |
414 |
static int |
415 |
prefer_right2left(ROPMAT *mop) |
416 |
417 |
int mri = 0; |
418 |
419 |
while (mop[mri].binop) /* find rightmost matrix */ |
420 |
if (mop[mri++].binop != '.') |
421 |
return(0); /* pre-empt reversal for other ops */ |
422 |
423 |
if (mri <= 1) |
424 |
return(0); /* won't matter */ |
425 |
426 |
if (loadmatrix(mop+mri) < 0) /* load rightmost cat */ |
427 |
return(1); /* fail will bail in a moment */ |
428 |
429 |
if (t_ncols(mop+mri) == 1) |
430 |
return(1); /* definitely better R->L */ |
431 |
432 |
if (t_ncols(mop+mri) >= t_nrows(mop+mri)) |
433 |
return(0); /* ...probably worse */ |
434 |
435 |
if (loadmatrix(mop) < 0) /* load leftmost */ |
436 |
return(0); /* fail will bail in a moment */ |
437 |
438 |
return(t_ncols(mop+mri) < t_nrows(mop)); |
439 |
440 |
441 |
static int |
442 |
get_factors(double da[], int n, char *av[]) |
443 |
444 |
int ac; |
445 |
446 |
for (ac = 0; ac < n && isflt(av[ac]); ac++) |
447 |
da[ac] = atof(av[ac]); |
448 |
return(ac); |
449 |
450 |
451 |
static ROPMAT * |
452 |
grow_moparray(ROPMAT *mop, int n2alloc) |
453 |
454 |
int nmats = 0; |
455 |
456 |
while (mop[nmats++].binop) |
457 |
458 |
mop = (ROPMAT *)realloc(mop, n2alloc*sizeof(ROPMAT)); |
459 |
if (mop == NULL) { |
460 |
fputs("Out of memory in grow_moparray()\n", stderr); |
461 |
exit(1); |
462 |
463 |
if (n2alloc > nmats) |
464 |
memset(mop+nmats, 0, (n2alloc-nmats)*sizeof(ROPMAT)); |
465 |
return(mop); |
466 |
467 |
468 |
/* Load one or more matrices and operate on them, sending results to stdout */ |
469 |
int |
470 |
main(int argc, char *argv[]) |
471 |
472 |
int outfmt = DTfromHeader; |
473 |
int nall = 2; |
474 |
ROPMAT *mop = (ROPMAT *)calloc(nall, sizeof(ROPMAT)); |
475 |
int nmats = 0; |
476 |
477 |
int stdin_used = 0; |
478 |
int i; |
479 |
/* get options and arguments */ |
480 |
for (i = 1; i < argc; i++) { |
481 |
if (argv[i][0] && !argv[i][1] && |
482 |
strchr(".+*/", argv[i][0]) != NULL) { |
483 |
if (!nmats || mop[nmats-1].binop) { |
484 |
fprintf(stderr, |
485 |
"%s: missing matrix argument before '%c' operation\n", |
486 |
argv[0], argv[i][0]); |
487 |
return(1); |
488 |
489 |
mop[nmats-1].binop = argv[i][0]; |
490 |
} else if (argv[i][0] != '-' || !argv[i][1]) { |
491 |
if (argv[i][0] == '-') { |
492 |
if (stdin_used++) { |
493 |
fprintf(stderr, |
494 |
"%s: standard input used for more than one matrix\n", |
495 |
argv[0]); |
496 |
return(1); |
497 |
498 |
mop[nmats].inspec = stdin_name; |
499 |
} else |
500 |
mop[nmats].inspec = argv[i]; |
501 |
if (nmats > 0 && !mop[nmats-1].binop) |
502 |
mop[nmats-1].binop = '.'; |
503 |
nmats++; |
504 |
} else { |
505 |
int n = argc-1 - i; |
506 |
switch (argv[i][1]) { /* get option */ |
507 |
case 'v': |
508 |
verbose++; |
509 |
break; |
510 |
case 'f': |
511 |
switch (argv[i][2]) { |
512 |
case 'd': |
513 |
outfmt = DTdouble; |
514 |
break; |
515 |
case 'f': |
516 |
outfmt = DTfloat; |
517 |
break; |
518 |
case 'a': |
519 |
outfmt = DTascii; |
520 |
break; |
521 |
case 'c': |
522 |
outfmt = DTrgbe; |
523 |
break; |
524 |
default: |
525 |
goto userr; |
526 |
527 |
break; |
528 |
case 't': |
529 |
mop[nmats].preop.transpose = 1; |
530 |
break; |
531 |
case 's': |
532 |
if (n > MAXCOMP) n = MAXCOMP; |
533 |
i += mop[nmats].preop.nsf = |
534 |
get_factors(mop[nmats].preop.sca, |
535 |
n, argv+i+1); |
536 |
if (mop[nmats].preop.nsf <= 0) { |
537 |
fprintf(stderr, "%s: -s missing arguments\n", |
538 |
argv[0]); |
539 |
goto userr; |
540 |
541 |
break; |
542 |
case 'c': |
543 |
if (n && isupper(argv[i+1][0])) { |
544 |
strlcpy(mop[nmats].preop.csym, |
545 |
argv[++i], |
546 |
sizeof(mop[0].preop.csym)); |
547 |
mop[nmats].preop.clen = 0; |
548 |
break; |
549 |
550 |
if (n > MAXCOMP*MAXCOMP) n = MAXCOMP*MAXCOMP; |
551 |
i += mop[nmats].preop.clen = |
552 |
get_factors(mop[nmats].preop.cmat, |
553 |
n, argv+i+1); |
554 |
if (mop[nmats].preop.clen <= 0) { |
555 |
fprintf(stderr, "%s: -c missing arguments\n", |
556 |
argv[0]); |
557 |
goto userr; |
558 |
559 |
mop[nmats].preop.csym[0] = '\0'; |
560 |
break; |
561 |
case 'r': |
562 |
if (argv[i][2] == 'f') |
563 |
mop[nmats].rmp = RMPreflF; |
564 |
else if (argv[i][2] == 'b') |
565 |
mop[nmats].rmp = RMPreflB; |
566 |
else |
567 |
goto userr; |
568 |
break; |
569 |
default: |
570 |
fprintf(stderr, "%s: unknown operation '%s'\n", |
571 |
argv[0], argv[i]); |
572 |
goto userr; |
573 |
574 |
575 |
if (nmats >= nall) |
576 |
mop = grow_moparray(mop, nall += 2); |
577 |
578 |
if (mop[0].inspec == NULL) /* nothing to do? */ |
579 |
goto userr; |
580 |
if (mop[nmats-1].binop) { |
581 |
fprintf(stderr, |
582 |
"%s: missing matrix argument after '%c' operation\n", |
583 |
argv[0], mop[nmats-1].binop); |
584 |
return(1); |
585 |
586 |
/* favor quicker concatenation */ |
587 |
mop[nmats].mtx = prefer_right2left(mop) ? op_right2left(mop) |
588 |
: op_left2right(mop); |
589 |
if (mop[nmats].mtx == NULL) |
590 |
return(1); |
591 |
/* apply trailing unary operations */ |
592 |
mop[nmats].inspec = "trailing_ops"; |
593 |
mres = loadop(mop+nmats); |
594 |
if (mres == NULL) |
595 |
return(1); |
596 |
if (outfmt == DTfromHeader) /* check data type */ |
597 |
outfmt = mres->dtype; |
598 |
if (outfmt == DTrgbe) { |
599 |
if (mres->ncomp > 3) |
600 |
outfmt = DTspec; |
601 |
else if (mres->dtype == DTxyze) |
602 |
outfmt = DTxyze; |
603 |
604 |
if (outfmt != DTascii) /* write result to stdout */ |
605 |
SET_FILE_BINARY(stdout); |
606 |
newheader("RADIANCE", stdout); |
607 |
printargs(argc, argv, stdout); |
608 |
609 |
return(rmx_write(mres, outfmt, stdout) ? 0 : 1); |
610 |
userr: |
611 |
fprintf(stderr, |
612 |
"Usage: %s [-v][-f[adfc][-t][-s sf .. | -c ce ..][-rf|-rb] m1 [.+*/] .. > mres\n", |
613 |
argv[0]); |
614 |
return(1); |
615 |
