root/radiance/ray/src/util/rmtxop.c
Revision: 2.23
Committed: Tue Nov 28 16:36:50 2023 UTC (4 months, 4 weeks ago) by greg
Changes since 2.22: +5 -13 lines
fix(rmtxop): Eliminated redundant error messages
2 static const char RCSid[] = "$Id: rmtxop.c,v 2.22 2023/11/27 22:04:45 greg Exp $";
5 * General component matrix operations.
6 */
7
8 #include <stdlib.h>
9 #include <errno.h>
10 #include <ctype.h>
11 #include "rtio.h"
12 #include "resolu.h"
13 #include "rmatrix.h"
14 #include "platform.h"
15
16 #define MAXCOMP MAXCSAMP /* #components we support */
17
18 /* Unary matrix operation(s) */
19 typedef struct {
20 double sca[MAXCOMP]; /* scalar coefficients */
21 double cmat[MAXCOMP*MAXCOMP]; /* component transformation */
22 short nsf; /* number of scalars */
23 short clen; /* number of coefficients */
24 char csym[11]; /* symbolic coefficients */
25 char transpose; /* do transpose? */
26 } RUNARYOP;
27
28 /* Matrix input source and requested operation(s) */
29 typedef struct {
30 const char *inspec; /* input specification */
31 RMPref rmp; /* matrix preference */
32 RUNARYOP preop; /* unary operation(s) */
33 RMATRIX *mtx; /* original matrix if loaded */
34 int binop; /* binary op with next (or 0) */
35 } ROPMAT;
36
37 int verbose = 0; /* verbose reporting? */
38
39 /* Load matrix */
40 static int
41 loadmatrix(ROPMAT *rop)
42 {
43 if (rop->mtx != NULL) /* already loaded? */
44 return(0);
45
46 rop->mtx = rmx_load(rop->inspec, rop->rmp);
47
48 return(!rop->mtx ? -1 : 1);
49 }
50
51 /* Compute conversion row from spectrum to one channel of RGB */
52 static void
53 rgbrow(ROPMAT *rop, int r, int p)
54 {
55 const int nc = rop->mtx->ncomp;
56 const float * wlp = rop->mtx->wlpart;
57 int i;
58
59 for (i = nc; i--; ) {
60 int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc;
61 int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc;
62 COLOR crgb;
63 spec_rgb(crgb, nmStart, nmEnd);
64 rop->preop.cmat[r*nc+i] = crgb[p];
65 }
66 }
67
68 /* Compute conversion row from spectrum to one channel of XYZ */
69 static void
70 xyzrow(ROPMAT *rop, int r, int p)
71 {
72 const int nc = rop->mtx->ncomp;
73 const float * wlp = rop->mtx->wlpart;
74 int i;
75
76 for (i = nc; i--; ) {
77 int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc;
78 int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc;
79 COLOR cxyz;
80 spec_cie(cxyz, nmStart, nmEnd);
81 rop->preop.cmat[r*nc+i] = cxyz[p];
82 }
83 }
84
85 /* Use the spectral sensitivity function to compute matrix coefficients */
86 static void
87 sensrow(ROPMAT *rop, int r, double (*sf)(SCOLOR sc, int ncs, const float wlpt[4]))
88 {
89 const int nc = rop->mtx->ncomp;
90 int i;
91
92 for (i = nc; i--; ) {
93 SCOLOR sclr;
94 scolorblack(sclr);
95 sclr[i] = 1;
96 rop->preop.cmat[r*nc+i] = (*sf)(sclr, nc, rop->mtx->wlpart);
97 }
98 }
99
100 /* Check/set symbolic transform */
101 static int
102 checksymbolic(ROPMAT *rop)
103 {
104 const int nc = rop->mtx->ncomp;
105 const int dt = rop->mtx->dtype;
106 int i, j;
107
108 if (nc < 3) {
109 fprintf(stderr, "%s: -c '%s' requires at least 3 components\n",
110 rop->inspec, rop->preop.csym);
111 return(-1);
112 }
113 rop->preop.clen = strlen(rop->preop.csym) * nc;
114 if (rop->preop.clen > MAXCOMP*MAXCOMP) {
115 fprintf(stderr, "%s: -c '%s' results in too many components\n",
116 rop->inspec, rop->preop.csym);
117 return(-1);
118 }
119 for (j = 0; rop->preop.csym[j]; j++) {
120 int comp = 0;
121 switch (rop->preop.csym[j]) {
122 case 'B':
123 ++comp;
124 /* fall through */
125 case 'G':
126 ++comp;
127 /* fall through */
128 case 'R':
129 if (dt == DTxyze) {
130 for (i = 3; i--; )
131 rop->preop.cmat[j*nc+i] = 1./WHTEFFICACY *
132 xyz2rgbmat[comp][i];
133 } else if (nc == 3)
134 rop->preop.cmat[j*nc+comp] = 1.;
135 else
136 rgbrow(rop, j, comp);
137 break;
138 case 'Z':
139 ++comp;
140 /* fall through */
141 case 'Y':
142 ++comp;
143 /* fall through */
144 case 'X':
145 if (dt == DTxyze) {
146 rop->preop.cmat[j*nc+comp] = 1.;
147 } else if (nc == 3) {
148 for (i = 3; i--; )
149 rop->preop.cmat[j*nc+i] =
150 rgb2xyzmat[comp][i];
151 } else if (comp == CIEY)
152 sensrow(rop, j, scolor2photopic);
153 else
154 xyzrow(rop, j, comp);
155
156 for (i = nc*(dt != DTxyze); i--; )
157 rop->preop.cmat[j*nc+i] *= WHTEFFICACY;
158 break;
159 case 'S':
160 sensrow(rop, j, scolor2scotopic);
161 for (i = nc; i--; )
162 rop->preop.cmat[j*nc+i] *= WHTSCOTOPIC;
163 break;
164 case 'M':
165 sensrow(rop, j, scolor2melanopic);
166 for (i = nc; i--; )
167 rop->preop.cmat[j*nc+i] *= WHTMELANOPIC;
168 break;
169 default:
170 fprintf(stderr, "%s: -c '%c' unsupported\n",
171 rop->inspec, rop->preop.csym[j]);
172 return(-1);
173 }
174 }
175 /* return recommended output type */
176 if (!strcmp(rop->preop.csym, "XYZ")) {
177 if (dt <= DTspec)
178 return(DTxyze);
179 } else if (!strcmp(rop->preop.csym, "RGB")) {
180 if (dt <= DTspec)
181 return(DTrgbe);
182 }
183 if ((nc > 3) & (dt <= DTspec))
184 return(DTfloat); /* probably not actual spectrum */
185 return(0);
186 }
187
188 /* Get matrix and perform unary operations */
189 static RMATRIX *
190 loadop(ROPMAT *rop)
191 {
192 int outtype = 0;
193 RMATRIX *mres;
194 int i, j;
195
196 if (loadmatrix(rop) < 0) /* make sure we're loaded */
197 return(NULL);
198
199 if (rop->preop.csym[0] && /* symbolic transform? */
200 (outtype = checksymbolic(rop)) < 0)
201 goto failure;
202 if (rop->preop.clen > 0) { /* apply component transform? */
203 if (rop->preop.clen % rop->mtx->ncomp) {
204 fprintf(stderr, "%s: -c must have N x %d coefficients\n",
205 rop->inspec, rop->mtx->ncomp);
206 goto failure;
207 }
208 if (rop->preop.nsf > 0) { /* scale transform, first */
209 if (rop->preop.nsf == 1) {
210 for (i = rop->preop.clen; i--; )
211 rop->preop.cmat[i] *= rop->preop.sca[0];
212 } else if (rop->preop.nsf != rop->mtx->ncomp) {
213 fprintf(stderr, "%s: -s must have one or %d factors\n",
214 rop->inspec, rop->mtx->ncomp);
215 goto failure;
216 } else {
217 for (j = rop->preop.clen/rop->preop.nsf; j--; )
218 for (i = rop->preop.nsf; i--; )
219 rop->preop.cmat[j*rop->preop.nsf+i] *=
220 rop->preop.sca[i];
221 }
222 }
223 mres = rmx_transform(rop->mtx, rop->preop.clen/rop->mtx->ncomp,
224 rop->preop.cmat);
225 if (mres == NULL) {
226 fprintf(stderr, "%s: matrix transform failed\n",
227 rop->inspec);
228 goto failure;
229 }
230 if (verbose)
231 fprintf(stderr, "%s: applied %d x %d transform%s\n",
232 rop->inspec, mres->ncomp,
233 rop->mtx->ncomp,
234 rop->preop.nsf ? " (* scalar)" : "");
235 rop->preop.nsf = 0;
236 if ((mres->ncomp > 3) & (mres->dtype <= DTspec))
237 outtype = DTfloat; /* probably not actual spectrum */
238 rmx_free(rop->mtx);
239 rop->mtx = mres;
240 }
241 if (rop->preop.nsf > 0) { /* apply scalar(s)? */
242 if (rop->preop.nsf == 1) {
243 for (i = rop->mtx->ncomp; --i; )
244 rop->preop.sca[i] = rop->preop.sca[0];
245 } else if (rop->preop.nsf != rop->mtx->ncomp) {
246 fprintf(stderr, "%s: -s must have one or %d factors\n",
247 rop->inspec, rop->mtx->ncomp);
248 goto failure;
249 }
250 if (!rmx_scale(rop->mtx, rop->preop.sca)) {
251 fputs(rop->inspec, stderr);
252 fputs(": scalar operation failed\n", stderr);
253 goto failure;
254 }
255 if (verbose) {
256 fputs(rop->inspec, stderr);
257 fputs(": applied scalar (", stderr);
258 for (i = 0; i < rop->preop.nsf; i++)
259 fprintf(stderr, " %f", rop->preop.sca[i]);
260 fputs(" )\n", stderr);
261 }
262 }
263 if (rop->preop.transpose) { /* transpose matrix? */
264 mres = rmx_transpose(rop->mtx);
265 if (mres == NULL) {
266 fputs(rop->inspec, stderr);
267 fputs(": transpose failed\n", stderr);
268 goto failure;
269 }
270 if (verbose) {
271 fputs(rop->inspec, stderr);
272 fputs(": transposed rows and columns\n", stderr);
273 }
274 rmx_free(rop->mtx);
275 rop->mtx = mres;
276 }
277 mres = rop->mtx;
278 rop->mtx = NULL;
279 if (outtype)
280 mres->dtype = outtype;
281 return(mres);
282 failure:
283 rmx_free(rop->mtx);
284 return(rop->mtx = NULL);
285 }
286
287 /* Execute binary operation, free matrix arguments and return new result */
288 static RMATRIX *
289 binaryop(const char *inspec, RMATRIX *mleft, int op, RMATRIX *mright)
290 {
291 RMATRIX *mres = NULL;
292 int i;
293
294 if ((mleft == NULL) | (mright == NULL))
295 return(NULL);
296 switch (op) {
297 case '.': /* concatenate */
298 if (mleft->ncomp != mright->ncomp) {
299 fputs(inspec, stderr);
300 fputs(": # components do not match\n", stderr);
301 } else if (mleft->ncols != mright->nrows) {
302 fputs(inspec, stderr);
303 fputs(": mismatched dimensions\n",
304 stderr);
305 } else
306 mres = rmx_multiply(mleft, mright);
307 rmx_free(mleft);
308 rmx_free(mright);
309 if (mres == NULL) {
310 fputs(inspec, stderr);
311 fputs(": concatenation failed\n", stderr);
312 return(NULL);
313 }
314 if (verbose) {
315 fputs(inspec, stderr);
316 fputs(": concatenated matrix\n", stderr);
317 }
318 break;
319 case '+':
320 if (!rmx_sum(mleft, mright, NULL)) {
321 fputs(inspec, stderr);
322 fputs(": matrix sum failed\n", stderr);
323 rmx_free(mleft);
324 rmx_free(mright);
325 return(NULL);
326 }
327 if (verbose) {
328 fputs(inspec, stderr);
329 fputs(": added in matrix\n", stderr);
330 }
331 rmx_free(mright);
332 mres = mleft;
333 break;
334 case '*':
335 case '/': {
336 const char * tnam = (op == '/') ?
337 "division" : "multiplication";
338 errno = 0;
339 if (!rmx_elemult(mleft, mright, (op == '/'))) {
340 fprintf(stderr, "%s: element-wise %s failed\n",
341 inspec, tnam);
342 rmx_free(mleft);
343 rmx_free(mright);
344 return(NULL);
345 }
346 if (errno)
347 fprintf(stderr,
348 "%s: warning - error during element-wise %s\n",
349 inspec, tnam);
350 else if (verbose)
351 fprintf(stderr, "%s: element-wise %s\n", inspec, tnam);
352 rmx_free(mright);
353 mres = mleft;
354 } break;
355 default:
356 fprintf(stderr, "%s: unknown operation '%c'\n", inspec, op);
357 rmx_free(mleft);
358 rmx_free(mright);
359 return(NULL);
360 }
361 return(mres);
362 }
363
364 /* Perform matrix operations from left to right */
365 static RMATRIX *
366 op_left2right(ROPMAT *mop)
367 {
368 RMATRIX *mleft = loadop(mop);
369
370 while (mop->binop) {
371 if (mleft == NULL)
372 break;
373 mleft = binaryop(mop[1].inspec,
374 mleft, mop->binop, loadop(mop+1));
375 mop++;
376 }
377 return(mleft);
378 }
379
380 /* Perform matrix operations from right to left */
381 static RMATRIX *
382 op_right2left(ROPMAT *mop)
383 {
384 RMATRIX *mright;
385 int rpos = 0;
386 /* find end of list */
387 while (mop[rpos].binop)
388 if (mop[rpos++].binop != '.') {
389 fputs(
390 "Right-to-left evaluation only for matrix multiplication!\n",
391 stderr);
392 return(NULL);
393 }
394 mright = loadop(mop+rpos);
395 while (rpos-- > 0) {
396 if (mright == NULL)
397 break;
398 mright = binaryop(mop[rpos+1].inspec,
399 loadop(mop+rpos), mop[rpos].binop, mright);
400 }
401 return(mright);
402 }
403
404 #define t_nrows(mop) ((mop)->preop.transpose ? (mop)->mtx->ncols \
405 : (mop)->mtx->nrows)
406 #define t_ncols(mop) ((mop)->preop.transpose ? (mop)->mtx->nrows \
407 : (mop)->mtx->ncols)
408
409 /* Should we prefer concatenating from rightmost matrix towards left? */
410 static int
411 prefer_right2left(ROPMAT *mop)
412 {
413 int mri = 0;
414
415 while (mop[mri].binop) /* find rightmost matrix */
416 if (mop[mri++].binop != '.')
417 return(0); /* pre-empt reversal for other ops */
418
419 if (mri <= 1)
420 return(0); /* won't matter */
421
422 if (loadmatrix(mop+mri) < 0) /* load rightmost cat */
423 return(1); /* fail will bail in a moment */
424
425 if (t_ncols(mop+mri) == 1)
426 return(1); /* definitely better R->L */
427
428 if (t_ncols(mop+mri) >= t_nrows(mop+mri))
429 return(0); /* ...probably worse */
430
431 if (loadmatrix(mop) < 0) /* load leftmost */
432 return(0); /* fail will bail in a moment */
433
434 return(t_ncols(mop+mri) < t_nrows(mop));
435 }
436
437 static int
438 get_factors(double da[], int n, char *av[])
439 {
440 int ac;
441
442 for (ac = 0; ac < n && isflt(av[ac]); ac++)
443 da[ac] = atof(av[ac]);
444 return(ac);
445 }
446
447 static ROPMAT *
448 grow_moparray(ROPMAT *mop, int n2alloc)
449 {
450 int nmats = 0;
451
452 while (mop[nmats++].binop)
453 ;
454 mop = (ROPMAT *)realloc(mop, n2alloc*sizeof(ROPMAT));
455 if (mop == NULL) {
456 fputs("Out of memory in grow_moparray()\n", stderr);
457 exit(1);
458 }
459 if (n2alloc > nmats)
460 memset(mop+nmats, 0, (n2alloc-nmats)*sizeof(ROPMAT));
461 return(mop);
462 }
463
464 /* Load one or more matrices and operate on them, sending results to stdout */
465 int
466 main(int argc, char *argv[])
467 {
468 int outfmt = DTfromHeader;
469 int nall = 2;
470 ROPMAT *mop = (ROPMAT *)calloc(nall, sizeof(ROPMAT));
471 int nmats = 0;
472 RMATRIX *mres = NULL;
473 int stdin_used = 0;
474 int i;
475 /* get options and arguments */
476 for (i = 1; i < argc; i++) {
477 if (argv[i][0] && !argv[i][1] &&
478 strchr(".+*/", argv[i][0]) != NULL) {
479 if (!nmats || mop[nmats-1].binop) {
480 fprintf(stderr,
481 "%s: missing matrix argument before '%c' operation\n",
482 argv[0], argv[i][0]);
483 return(1);
484 }
485 mop[nmats-1].binop = argv[i][0];
486 } else if (argv[i][0] != '-' || !argv[i][1]) {
487 if (argv[i][0] == '-') {
488 if (stdin_used++) {
489 fprintf(stderr,
490 "%s: standard input used for more than one matrix\n",
491 argv[0]);
492 return(1);
493 }
494 mop[nmats].inspec = stdin_name;
495 } else
496 mop[nmats].inspec = argv[i];
497 if (nmats > 0 && !mop[nmats-1].binop)
498 mop[nmats-1].binop = '.';
499 nmats++;
500 } else {
501 int n = argc-1 - i;
502 switch (argv[i][1]) { /* get option */
503 case 'v':
504 verbose++;
505 break;
506 case 'f':
507 switch (argv[i][2]) {
508 case 'd':
509 outfmt = DTdouble;
510 break;
511 case 'f':
512 outfmt = DTfloat;
513 break;
514 case 'a':
515 outfmt = DTascii;
516 break;
517 case 'c':
518 outfmt = DTrgbe;
519 break;
520 default:
521 goto userr;
522 }
523 break;
524 case 't':
525 mop[nmats].preop.transpose = 1;
526 break;
527 case 's':
528 if (n > MAXCOMP) n = MAXCOMP;
529 i += mop[nmats].preop.nsf =
530 get_factors(mop[nmats].preop.sca,
531 n, argv+i+1);
532 if (mop[nmats].preop.nsf <= 0) {
533 fprintf(stderr, "%s: -s missing arguments\n",
534 argv[0]);
535 goto userr;
536 }
537 break;
538 case 'c':
539 if (n && isupper(argv[i+1][0])) {
540 strlcpy(mop[nmats].preop.csym,
541 argv[++i],
542 sizeof(mop[0].preop.csym));
543 mop[nmats].preop.clen = 0;
544 break;
545 }
546 if (n > MAXCOMP*MAXCOMP) n = MAXCOMP*MAXCOMP;
547 i += mop[nmats].preop.clen =
548 get_factors(mop[nmats].preop.cmat,
549 n, argv+i+1);
550 if (mop[nmats].preop.clen <= 0) {
551 fprintf(stderr, "%s: -c missing arguments\n",
552 argv[0]);
553 goto userr;
554 }
555 mop[nmats].preop.csym[0] = '\0';
556 break;
557 case 'r':
558 if (argv[i][2] == 'f')
559 mop[nmats].rmp = RMPreflF;
560 else if (argv[i][2] == 'b')
561 mop[nmats].rmp = RMPreflB;
562 else
563 goto userr;
564 break;
565 default:
566 fprintf(stderr, "%s: unknown operation '%s'\n",
567 argv[0], argv[i]);
568 goto userr;
569 }
570 }
571 if (nmats >= nall)
572 mop = grow_moparray(mop, nall += 2);
573 }
574 if (mop[0].inspec == NULL) /* nothing to do? */
575 goto userr;
576 if (mop[nmats-1].binop) {
577 fprintf(stderr,
578 "%s: missing matrix argument after '%c' operation\n",
579 argv[0], mop[nmats-1].binop);
580 return(1);
581 }
582 /* favor quicker concatenation */
583 mop[nmats].mtx = prefer_right2left(mop) ? op_right2left(mop)
584 : op_left2right(mop);
585 if (mop[nmats].mtx == NULL)
586 return(1);
587 /* apply trailing unary operations */
588 mop[nmats].inspec = "trailing_ops";
589 mres = loadop(mop+nmats);
590 if (mres == NULL)
591 return(1);
592 if (outfmt == DTfromHeader) /* check data type */
593 outfmt = mres->dtype;
594 if (outfmt == DTrgbe) {
595 if (mres->ncomp > 3)
596 outfmt = DTspec;
597 else if (mres->dtype == DTxyze)
598 outfmt = DTxyze;
599 }
600 if (outfmt != DTascii) /* write result to stdout */
601 SET_FILE_BINARY(stdout);
602 newheader("RADIANCE", stdout);
603 printargs(argc, argv, stdout);
604
605 return(rmx_write(mres, outfmt, stdout) ? 0 : 1);
606 userr:
607 fprintf(stderr,
608 "Usage: %s [-v][-f[adfc][-t][-s sf .. | -c ce ..][-rf|-rb] m1 [.+*/] .. > mres\n",
609 argv[0]);
610 return(1);
611 }
