--- ray/src/util/rmtxop.c 2015/07/22 04:47:51 2.8 +++ ray/src/util/rmtxop.c 2023/11/28 16:36:50 2.23 @@ -1,156 +1,440 @@ #ifndef lint -static const char RCSid[] = "$Id: rmtxop.c,v 2.8 2015/07/22 04:47:51 greg Exp $"; +static const char RCSid[] = "$Id: rmtxop.c,v 2.23 2023/11/28 16:36:50 greg Exp $"; #endif /* * General component matrix operations. */ -#include #include +#include +#include #include "rtio.h" #include "resolu.h" #include "rmatrix.h" +#include "platform.h" -#define MAXCOMP 50 /* #components we support */ +#define MAXCOMP MAXCSAMP /* #components we support */ +/* Unary matrix operation(s) */ typedef struct { double sca[MAXCOMP]; /* scalar coefficients */ - int nsf; /* number of scalars */ double cmat[MAXCOMP*MAXCOMP]; /* component transformation */ - int clen; /* number of coefficients */ - int transpose; /* do transpose? */ - int op; /* '*' or '+' */ -} ROPERAT; /* matrix operation */ + short nsf; /* number of scalars */ + short clen; /* number of coefficients */ + char csym[11]; /* symbolic coefficients */ + char transpose; /* do transpose? */ +} RUNARYOP; +/* Matrix input source and requested operation(s) */ +typedef struct { + const char *inspec; /* input specification */ + RMPref rmp; /* matrix preference */ + RUNARYOP preop; /* unary operation(s) */ + RMATRIX *mtx; /* original matrix if loaded */ + int binop; /* binary op with next (or 0) */ +} ROPMAT; + int verbose = 0; /* verbose reporting? */ +/* Load matrix */ +static int +loadmatrix(ROPMAT *rop) +{ + if (rop->mtx != NULL) /* already loaded? */ + return(0); + + rop->mtx = rmx_load(rop->inspec, rop->rmp); + + return(!rop->mtx ? -1 : 1); +} + +/* Compute conversion row from spectrum to one channel of RGB */ static void -op_default(ROPERAT *op) +rgbrow(ROPMAT *rop, int r, int p) { - memset(op, 0, sizeof(ROPERAT)); - op->op = '*'; + const int nc = rop->mtx->ncomp; + const float * wlp = rop->mtx->wlpart; + int i; + + for (i = nc; i--; ) { + int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc; + int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc; + COLOR crgb; + spec_rgb(crgb, nmStart, nmEnd); + rop->preop.cmat[r*nc+i] = crgb[p]; + } } +/* Compute conversion row from spectrum to one channel of XYZ */ +static void +xyzrow(ROPMAT *rop, int r, int p) +{ + const int nc = rop->mtx->ncomp; + const float * wlp = rop->mtx->wlpart; + int i; + + for (i = nc; i--; ) { + int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc; + int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc; + COLOR cxyz; + spec_cie(cxyz, nmStart, nmEnd); + rop->preop.cmat[r*nc+i] = cxyz[p]; + } +} + +/* Use the spectral sensitivity function to compute matrix coefficients */ +static void +sensrow(ROPMAT *rop, int r, double (*sf)(SCOLOR sc, int ncs, const float wlpt[4])) +{ + const int nc = rop->mtx->ncomp; + int i; + + for (i = nc; i--; ) { + SCOLOR sclr; + scolorblack(sclr); + sclr[i] = 1; + rop->preop.cmat[r*nc+i] = (*sf)(sclr, nc, rop->mtx->wlpart); + } +} + +/* Check/set symbolic transform */ +static int +checksymbolic(ROPMAT *rop) +{ + const int nc = rop->mtx->ncomp; + const int dt = rop->mtx->dtype; + int i, j; + + if (nc < 3) { + fprintf(stderr, "%s: -c '%s' requires at least 3 components\n", + rop->inspec, rop->preop.csym); + return(-1); + } + rop->preop.clen = strlen(rop->preop.csym) * nc; + if (rop->preop.clen > MAXCOMP*MAXCOMP) { + fprintf(stderr, "%s: -c '%s' results in too many components\n", + rop->inspec, rop->preop.csym); + return(-1); + } + for (j = 0; rop->preop.csym[j]; j++) { + int comp = 0; + switch (rop->preop.csym[j]) { + case 'B': + ++comp; + /* fall through */ + case 'G': + ++comp; + /* fall through */ + case 'R': + if (dt == DTxyze) { + for (i = 3; i--; ) + rop->preop.cmat[j*nc+i] = 1./WHTEFFICACY * + xyz2rgbmat[comp][i]; + } else if (nc == 3) + rop->preop.cmat[j*nc+comp] = 1.; + else + rgbrow(rop, j, comp); + break; + case 'Z': + ++comp; + /* fall through */ + case 'Y': + ++comp; + /* fall through */ + case 'X': + if (dt == DTxyze) { + rop->preop.cmat[j*nc+comp] = 1.; + } else if (nc == 3) { + for (i = 3; i--; ) + rop->preop.cmat[j*nc+i] = + rgb2xyzmat[comp][i]; + } else if (comp == CIEY) + sensrow(rop, j, scolor2photopic); + else + xyzrow(rop, j, comp); + + for (i = nc*(dt != DTxyze); i--; ) + rop->preop.cmat[j*nc+i] *= WHTEFFICACY; + break; + case 'S': + sensrow(rop, j, scolor2scotopic); + for (i = nc; i--; ) + rop->preop.cmat[j*nc+i] *= WHTSCOTOPIC; + break; + case 'M': + sensrow(rop, j, scolor2melanopic); + for (i = nc; i--; ) + rop->preop.cmat[j*nc+i] *= WHTMELANOPIC; + break; + default: + fprintf(stderr, "%s: -c '%c' unsupported\n", + rop->inspec, rop->preop.csym[j]); + return(-1); + } + } + /* return recommended output type */ + if (!strcmp(rop->preop.csym, "XYZ")) { + if (dt <= DTspec) + return(DTxyze); + } else if (!strcmp(rop->preop.csym, "RGB")) { + if (dt <= DTspec) + return(DTrgbe); + } + if ((nc > 3) & (dt <= DTspec)) + return(DTfloat); /* probably not actual spectrum */ + return(0); +} + +/* Get matrix and perform unary operations */ static RMATRIX * -operate(RMATRIX *mleft, ROPERAT *op, const char *fname) +loadop(ROPMAT *rop) { - RMATRIX *mright = rmx_load(fname); - RMATRIX *mtmp; - int i; + int outtype = 0; + RMATRIX *mres; + int i, j; - if (fname == NULL) - fname = ""; - if (mright == NULL) { - fputs(fname, stderr); - fputs(": cannot load matrix\n", stderr); + if (loadmatrix(rop) < 0) /* make sure we're loaded */ return(NULL); - } - if (op->transpose) { /* transpose matrix? */ - mtmp = rmx_transpose(mright); - if (mtmp == NULL) { - fputs(fname, stderr); - fputs(": transpose failed\n", stderr); - rmx_free(mright); - return(NULL); + + if (rop->preop.csym[0] && /* symbolic transform? */ + (outtype = checksymbolic(rop)) < 0) + goto failure; + if (rop->preop.clen > 0) { /* apply component transform? */ + if (rop->preop.clen % rop->mtx->ncomp) { + fprintf(stderr, "%s: -c must have N x %d coefficients\n", + rop->inspec, rop->mtx->ncomp); + goto failure; } - if (verbose) { - fputs(fname, stderr); - fputs(": transposed rows and columns\n", stderr); + if (rop->preop.nsf > 0) { /* scale transform, first */ + if (rop->preop.nsf == 1) { + for (i = rop->preop.clen; i--; ) + rop->preop.cmat[i] *= rop->preop.sca[0]; + } else if (rop->preop.nsf != rop->mtx->ncomp) { + fprintf(stderr, "%s: -s must have one or %d factors\n", + rop->inspec, rop->mtx->ncomp); + goto failure; + } else { + for (j = rop->preop.clen/rop->preop.nsf; j--; ) + for (i = rop->preop.nsf; i--; ) + rop->preop.cmat[j*rop->preop.nsf+i] *= + rop->preop.sca[i]; + } } - rmx_free(mright); - mright = mtmp; - } - if (op->nsf > 0) { /* apply scalar(s) */ - if (op->clen > 0) { - fputs("Options -s and -c are exclusive\n", stderr); - rmx_free(mright); - return(NULL); + mres = rmx_transform(rop->mtx, rop->preop.clen/rop->mtx->ncomp, + rop->preop.cmat); + if (mres == NULL) { + fprintf(stderr, "%s: matrix transform failed\n", + rop->inspec); + goto failure; } - if (op->nsf == 1) { - for (i = mright->ncomp; --i; ) - op->sca[i] = op->sca[0]; - } else if (op->nsf != mright->ncomp) { + if (verbose) + fprintf(stderr, "%s: applied %d x %d transform%s\n", + rop->inspec, mres->ncomp, + rop->mtx->ncomp, + rop->preop.nsf ? " (* scalar)" : ""); + rop->preop.nsf = 0; + if ((mres->ncomp > 3) & (mres->dtype <= DTspec)) + outtype = DTfloat; /* probably not actual spectrum */ + rmx_free(rop->mtx); + rop->mtx = mres; + } + if (rop->preop.nsf > 0) { /* apply scalar(s)? */ + if (rop->preop.nsf == 1) { + for (i = rop->mtx->ncomp; --i; ) + rop->preop.sca[i] = rop->preop.sca[0]; + } else if (rop->preop.nsf != rop->mtx->ncomp) { fprintf(stderr, "%s: -s must have one or %d factors\n", - fname, mright->ncomp); - rmx_free(mright); - return(NULL); + rop->inspec, rop->mtx->ncomp); + goto failure; } - if ((mleft == NULL) | (op->op != '+') && - !rmx_scale(mright, op->sca)) { - fputs(fname, stderr); + if (!rmx_scale(rop->mtx, rop->preop.sca)) { + fputs(rop->inspec, stderr); fputs(": scalar operation failed\n", stderr); - rmx_free(mright); - return(NULL); + goto failure; } if (verbose) { - fputs(fname, stderr); + fputs(rop->inspec, stderr); fputs(": applied scalar (", stderr); - for (i = 0; i < op->nsf; i++) - fprintf(stderr, " %f", op->sca[i]); + for (i = 0; i < rop->preop.nsf; i++) + fprintf(stderr, " %f", rop->preop.sca[i]); fputs(" )\n", stderr); } } - if (op->clen > 0) { /* apply transform */ - if (op->clen % mright->ncomp) { - fprintf(stderr, "%s: -c must have N x %d coefficients\n", - fname, mright->ncomp); - rmx_free(mright); - return(NULL); + if (rop->preop.transpose) { /* transpose matrix? */ + mres = rmx_transpose(rop->mtx); + if (mres == NULL) { + fputs(rop->inspec, stderr); + fputs(": transpose failed\n", stderr); + goto failure; } - mtmp = rmx_transform(mright, op->clen/mright->ncomp, op->cmat); - if (mtmp == NULL) { - fprintf(stderr, "%s: matrix transform failed\n", fname); - rmx_free(mright); - return(NULL); + if (verbose) { + fputs(rop->inspec, stderr); + fputs(": transposed rows and columns\n", stderr); } - if (verbose) - fprintf(stderr, "%s: applied %d x %d transform\n", - fname, mtmp->ncomp, mright->ncomp); - rmx_free(mright); - mright = mtmp; + rmx_free(rop->mtx); + rop->mtx = mres; } - if (mleft == NULL) /* just one matrix */ - return(mright); - if (op->op == '*') { /* concatenate */ - RMATRIX *mres = rmx_multiply(mleft, mright); + mres = rop->mtx; + rop->mtx = NULL; + if (outtype) + mres->dtype = outtype; + return(mres); +failure: + rmx_free(rop->mtx); + return(rop->mtx = NULL); +} + +/* Execute binary operation, free matrix arguments and return new result */ +static RMATRIX * +binaryop(const char *inspec, RMATRIX *mleft, int op, RMATRIX *mright) +{ + RMATRIX *mres = NULL; + int i; + + if ((mleft == NULL) | (mright == NULL)) + return(NULL); + switch (op) { + case '.': /* concatenate */ + if (mleft->ncomp != mright->ncomp) { + fputs(inspec, stderr); + fputs(": # components do not match\n", stderr); + } else if (mleft->ncols != mright->nrows) { + fputs(inspec, stderr); + fputs(": mismatched dimensions\n", + stderr); + } else + mres = rmx_multiply(mleft, mright); + rmx_free(mleft); + rmx_free(mright); if (mres == NULL) { - fputs(fname, stderr); - if (mleft->ncols != mright->nrows) - fputs(": mismatched dimensions for multiply\n", - stderr); - else - fputs(": concatenation failed\n", stderr); - rmx_free(mright); + fputs(inspec, stderr); + fputs(": concatenation failed\n", stderr); return(NULL); } if (verbose) { - fputs(fname, stderr); + fputs(inspec, stderr); fputs(": concatenated matrix\n", stderr); } - rmx_free(mright); - rmx_free(mleft); - mleft = mres; - } else if (op->op == '+') { - if (!rmx_sum(mleft, mright, op->nsf ? op->sca : (double *)NULL)) { - fputs(fname, stderr); + break; + case '+': + if (!rmx_sum(mleft, mright, NULL)) { + fputs(inspec, stderr); fputs(": matrix sum failed\n", stderr); + rmx_free(mleft); rmx_free(mright); return(NULL); } if (verbose) { - fputs(fname, stderr); + fputs(inspec, stderr); fputs(": added in matrix\n", stderr); } rmx_free(mright); - } else { - fprintf(stderr, "%s: unknown operation '%c'\n", fname, op->op); + mres = mleft; + break; + case '*': + case '/': { + const char * tnam = (op == '/') ? + "division" : "multiplication"; + errno = 0; + if (!rmx_elemult(mleft, mright, (op == '/'))) { + fprintf(stderr, "%s: element-wise %s failed\n", + inspec, tnam); + rmx_free(mleft); + rmx_free(mright); + return(NULL); + } + if (errno) + fprintf(stderr, + "%s: warning - error during element-wise %s\n", + inspec, tnam); + else if (verbose) + fprintf(stderr, "%s: element-wise %s\n", inspec, tnam); rmx_free(mright); + mres = mleft; + } break; + default: + fprintf(stderr, "%s: unknown operation '%c'\n", inspec, op); + rmx_free(mleft); + rmx_free(mright); return(NULL); } + return(mres); +} + +/* Perform matrix operations from left to right */ +static RMATRIX * +op_left2right(ROPMAT *mop) +{ + RMATRIX *mleft = loadop(mop); + + while (mop->binop) { + if (mleft == NULL) + break; + mleft = binaryop(mop[1].inspec, + mleft, mop->binop, loadop(mop+1)); + mop++; + } return(mleft); } +/* Perform matrix operations from right to left */ +static RMATRIX * +op_right2left(ROPMAT *mop) +{ + RMATRIX *mright; + int rpos = 0; + /* find end of list */ + while (mop[rpos].binop) + if (mop[rpos++].binop != '.') { + fputs( + "Right-to-left evaluation only for matrix multiplication!\n", + stderr); + return(NULL); + } + mright = loadop(mop+rpos); + while (rpos-- > 0) { + if (mright == NULL) + break; + mright = binaryop(mop[rpos+1].inspec, + loadop(mop+rpos), mop[rpos].binop, mright); + } + return(mright); +} + +#define t_nrows(mop) ((mop)->preop.transpose ? (mop)->mtx->ncols \ + : (mop)->mtx->nrows) +#define t_ncols(mop) ((mop)->preop.transpose ? (mop)->mtx->nrows \ + : (mop)->mtx->ncols) + +/* Should we prefer concatenating from rightmost matrix towards left? */ static int +prefer_right2left(ROPMAT *mop) +{ + int mri = 0; + + while (mop[mri].binop) /* find rightmost matrix */ + if (mop[mri++].binop != '.') + return(0); /* pre-empt reversal for other ops */ + + if (mri <= 1) + return(0); /* won't matter */ + + if (loadmatrix(mop+mri) < 0) /* load rightmost cat */ + return(1); /* fail will bail in a moment */ + + if (t_ncols(mop+mri) == 1) + return(1); /* definitely better R->L */ + + if (t_ncols(mop+mri) >= t_nrows(mop+mri)) + return(0); /* ...probably worse */ + + if (loadmatrix(mop) < 0) /* load leftmost */ + return(0); /* fail will bail in a moment */ + + return(t_ncols(mop+mri) < t_nrows(mop)); +} + +static int get_factors(double da[], int n, char *av[]) { int ac; @@ -160,36 +444,64 @@ get_factors(double da[], int n, char *av[]) return(ac); } +static ROPMAT * +grow_moparray(ROPMAT *mop, int n2alloc) +{ + int nmats = 0; + + while (mop[nmats++].binop) + ; + mop = (ROPMAT *)realloc(mop, n2alloc*sizeof(ROPMAT)); + if (mop == NULL) { + fputs("Out of memory in grow_moparray()\n", stderr); + exit(1); + } + if (n2alloc > nmats) + memset(mop+nmats, 0, (n2alloc-nmats)*sizeof(ROPMAT)); + return(mop); +} + /* Load one or more matrices and operate on them, sending results to stdout */ int main(int argc, char *argv[]) { int outfmt = DTfromHeader; + int nall = 2; + ROPMAT *mop = (ROPMAT *)calloc(nall, sizeof(ROPMAT)); + int nmats = 0; RMATRIX *mres = NULL; - ROPERAT op; + int stdin_used = 0; int i; - /* initialize */ - op_default(&op); /* get options and arguments */ - for (i = 1; i < argc; i++) - if (argv[i][0] == '+' && !argv[i][1]) { - op.op = '+'; - } else if (argv[i][0] != '-' || !argv[i][1]) { - char *fname = NULL; /* load matrix */ - if (argv[i][0] != '-') - fname = argv[i]; - mres = operate(mres, &op, fname); - if (mres == NULL) { - fprintf(stderr, "%s: operation failed on '%s'\n", - argv[0], argv[i]); - return(0); + for (i = 1; i < argc; i++) { + if (argv[i][0] && !argv[i][1] && + strchr(".+*/", argv[i][0]) != NULL) { + if (!nmats || mop[nmats-1].binop) { + fprintf(stderr, + "%s: missing matrix argument before '%c' operation\n", + argv[0], argv[i][0]); + return(1); } - op_default(&op); /* reset operator */ + mop[nmats-1].binop = argv[i][0]; + } else if (argv[i][0] != '-' || !argv[i][1]) { + if (argv[i][0] == '-') { + if (stdin_used++) { + fprintf(stderr, + "%s: standard input used for more than one matrix\n", + argv[0]); + return(1); + } + mop[nmats].inspec = stdin_name; + } else + mop[nmats].inspec = argv[i]; + if (nmats > 0 && !mop[nmats-1].binop) + mop[nmats-1].binop = '.'; + nmats++; } else { int n = argc-1 - i; switch (argv[i][1]) { /* get option */ case 'v': - verbose = !verbose; + verbose++; break; case 'f': switch (argv[i][2]) { @@ -210,44 +522,90 @@ main(int argc, char *argv[]) } break; case 't': - op.transpose = 1; + mop[nmats].preop.transpose = 1; break; case 's': if (n > MAXCOMP) n = MAXCOMP; - op.nsf = get_factors(op.sca, n, argv+i+1); - i += op.nsf; + i += mop[nmats].preop.nsf = + get_factors(mop[nmats].preop.sca, + n, argv+i+1); + if (mop[nmats].preop.nsf <= 0) { + fprintf(stderr, "%s: -s missing arguments\n", + argv[0]); + goto userr; + } break; case 'c': + if (n && isupper(argv[i+1][0])) { + strlcpy(mop[nmats].preop.csym, + argv[++i], + sizeof(mop[0].preop.csym)); + mop[nmats].preop.clen = 0; + break; + } if (n > MAXCOMP*MAXCOMP) n = MAXCOMP*MAXCOMP; - op.clen = get_factors(op.cmat, n, argv+i+1); - i += op.clen; + i += mop[nmats].preop.clen = + get_factors(mop[nmats].preop.cmat, + n, argv+i+1); + if (mop[nmats].preop.clen <= 0) { + fprintf(stderr, "%s: -c missing arguments\n", + argv[0]); + goto userr; + } + mop[nmats].preop.csym[0] = '\0'; break; + case 'r': + if (argv[i][2] == 'f') + mop[nmats].rmp = RMPreflF; + else if (argv[i][2] == 'b') + mop[nmats].rmp = RMPreflB; + else + goto userr; + break; default: fprintf(stderr, "%s: unknown operation '%s'\n", argv[0], argv[i]); goto userr; } } - if (mres == NULL) /* check that we got something */ + if (nmats >= nall) + mop = grow_moparray(mop, nall += 2); + } + if (mop[0].inspec == NULL) /* nothing to do? */ goto userr; - /* write result to stdout */ - if (outfmt == DTfromHeader) + if (mop[nmats-1].binop) { + fprintf(stderr, + "%s: missing matrix argument after '%c' operation\n", + argv[0], mop[nmats-1].binop); + return(1); + } + /* favor quicker concatenation */ + mop[nmats].mtx = prefer_right2left(mop) ? op_right2left(mop) + : op_left2right(mop); + if (mop[nmats].mtx == NULL) + return(1); + /* apply trailing unary operations */ + mop[nmats].inspec = "trailing_ops"; + mres = loadop(mop+nmats); + if (mres == NULL) + return(1); + if (outfmt == DTfromHeader) /* check data type */ outfmt = mres->dtype; -#ifdef _WIN32 - if (outfmt != DTascii) - _setmode(fileno(stdout), _O_BINARY); -#endif + if (outfmt == DTrgbe) { + if (mres->ncomp > 3) + outfmt = DTspec; + else if (mres->dtype == DTxyze) + outfmt = DTxyze; + } + if (outfmt != DTascii) /* write result to stdout */ + SET_FILE_BINARY(stdout); newheader("RADIANCE", stdout); printargs(argc, argv, stdout); - if (!rmx_write(mres, outfmt, stdout)) { - fprintf(stderr, "%s: error writing result matrix\n", argv[0]); - return(1); - } - /* rmx_free(mres); mres = NULL; */ - return(0); + + return(rmx_write(mres, outfmt, stdout) ? 0 : 1); userr: fprintf(stderr, - "Usage: %s [-v][-f[adfc][-t][-s sf .. | -c ce ..] m1 [+] .. > mres\n", + "Usage: %s [-v][-f[adfc][-t][-s sf .. | -c ce ..][-rf|-rb] m1 [.+*/] .. > mres\n", argv[0]); return(1); }
