--- ray/src/util/rmtxop.c 2023/11/28 16:36:50 2.23 +++ ray/src/util/rmtxop.c 2023/12/03 02:28:33 2.28 @@ -1,13 +1,11 @@ #ifndef lint -static const char RCSid[] = "$Id: rmtxop.c,v 2.23 2023/11/28 16:36:50 greg Exp $"; +static const char RCSid[] = "$Id: rmtxop.c,v 2.28 2023/12/03 02:28:33 greg Exp $"; #endif /* * General component matrix operations. */ -#include #include -#include #include "rtio.h" #include "resolu.h" #include "rmatrix.h" @@ -17,12 +15,12 @@ static const char RCSid[] = "$Id: rmtxop.c,v 2.23 2023 /* Unary matrix operation(s) */ typedef struct { - double sca[MAXCOMP]; /* scalar coefficients */ double cmat[MAXCOMP*MAXCOMP]; /* component transformation */ - short nsf; /* number of scalars */ + double sca[MAXCOMP]; /* scalar coefficients */ + const char *csym; /* symbolic coefs or file */ short clen; /* number of coefficients */ - char csym[11]; /* symbolic coefficients */ - char transpose; /* do transpose? */ + short nsf; /* number of scalars */ + short transpose; /* do transpose? */ } RUNARYOP; /* Matrix input source and requested operation(s) */ @@ -48,6 +46,66 @@ loadmatrix(ROPMAT *rop) return(!rop->mtx ? -1 : 1); } +static int checksymbolic(ROPMAT *rop); + +/* Check/set transform based on a reference input file */ +static int +checkreffile(ROPMAT *rop) +{ + static const char *curRF = NULL; + static RMATRIX refm; + const int nc = rop->mtx->ncomp; + int i; + + if (!curRF || strcmp(rop->preop.csym, curRF)) { + FILE *fp = fopen(rop->preop.csym, "rb"); + if (!rmx_load_header(&refm, fp)) { + fprintf(stderr, "%s: cannot read info header\n", + rop->preop.csym); + curRF = NULL; + if (fp) fclose(fp); + return(-1); + } + fclose(fp); + curRF = rop->preop.csym; + } + if ((refm.ncomp == 3) & (refm.dtype != DTspec)) { + rop->preop.csym = (refm.dtype == DTxyze) ? "XYZ" : "RGB"; + return(checksymbolic(rop)); + } + if (refm.ncomp == 2) { + fprintf(stderr, "%s: cannot convert to 2 components\n", + curRF); + return(-1); + } + if (refm.ncomp == 1) { + rop->preop.csym = "Y"; /* XXX big assumption */ + return(checksymbolic(rop)); + } + if (refm.ncomp == nc && + !memcmp(refm.wlpart, rop->mtx->wlpart, sizeof(refm.wlpart))) + return(0); /* nothing to do */ + + if ((nc <= 3) | (nc > MAXCSAMP) | (refm.ncomp > MAXCSAMP)) { + fprintf(stderr, "%s: cannot resample from %d to %d components\n", + curRF, nc, refm.ncomp); + return(-1); + } + rop->preop.clen = refm.ncomp * nc; /* compute spec to ref */ + + for (i = 0; i < nc; i++) { + SCOLOR scstim, scresp; + int j; + memset(scstim, 0, sizeof(COLORV)*nc); + scstim[i] = 1.f; + convertscolor(scresp, refm.ncomp, refm.wlpart[0], refm.wlpart[3], + scstim, nc, rop->mtx->wlpart[0], rop->mtx->wlpart[3]); + for (j = refm.ncomp; j-- > 0; ) + rop->preop.cmat[j*nc + i] = scresp[j]; + } + return(0); +} + /* Compute conversion row from spectrum to one channel of RGB */ static void rgbrow(ROPMAT *rop, int r, int p) @@ -91,8 +149,8 @@ sensrow(ROPMAT *rop, int r, double (*sf)(SCOLOR sc, in for (i = nc; i--; ) { SCOLOR sclr; - scolorblack(sclr); - sclr[i] = 1; + memset(sclr, 0, sizeof(COLORV)*nc); + sclr[i] = 1.f; rop->preop.cmat[r*nc+i] = (*sf)(sclr, nc, rop->mtx->wlpart); } } @@ -104,6 +162,9 @@ checksymbolic(ROPMAT *rop) const int nc = rop->mtx->ncomp; const int dt = rop->mtx->dtype; int i, j; + /* check suffix => reference file */ + if (strchr(rop->preop.csym, '.') > rop->preop.csym) + return(checkreffile(rop)); if (nc < 3) { fprintf(stderr, "%s: -c '%s' requires at least 3 components\n", @@ -156,16 +217,20 @@ checksymbolic(ROPMAT *rop) for (i = nc*(dt != DTxyze); i--; ) rop->preop.cmat[j*nc+i] *= WHTEFFICACY; break; - case 'S': + case 'S': /* scotopic (il)luminance */ sensrow(rop, j, scolor2scotopic); for (i = nc; i--; ) rop->preop.cmat[j*nc+i] *= WHTSCOTOPIC; break; - case 'M': + case 'M': /* melanopic (il)luminance */ sensrow(rop, j, scolor2melanopic); for (i = nc; i--; ) rop->preop.cmat[j*nc+i] *= WHTMELANOPIC; break; + case 'A': /* average component */ + for (i = nc; i--; ) + rop->preop.cmat[j*nc+i] = 1./(double)nc; + break; default: fprintf(stderr, "%s: -c '%c' unsupported\n", rop->inspec, rop->preop.csym[j]); @@ -196,7 +261,7 @@ loadop(ROPMAT *rop) if (loadmatrix(rop) < 0) /* make sure we're loaded */ return(NULL); - if (rop->preop.csym[0] && /* symbolic transform? */ + if (rop->preop.csym && /* symbolic transform? */ (outtype = checksymbolic(rop)) < 0) goto failure; if (rop->preop.clen > 0) { /* apply component transform? */ @@ -209,15 +274,16 @@ loadop(ROPMAT *rop) if (rop->preop.nsf == 1) { for (i = rop->preop.clen; i--; ) rop->preop.cmat[i] *= rop->preop.sca[0]; - } else if (rop->preop.nsf != rop->mtx->ncomp) { + } else if (rop->preop.nsf*rop->mtx->ncomp != rop->preop.clen) { fprintf(stderr, "%s: -s must have one or %d factors\n", - rop->inspec, rop->mtx->ncomp); + rop->inspec, + rop->preop.clen/rop->mtx->ncomp); goto failure; } else { - for (j = rop->preop.clen/rop->preop.nsf; j--; ) - for (i = rop->preop.nsf; i--; ) - rop->preop.cmat[j*rop->preop.nsf+i] *= - rop->preop.sca[i]; + for (i = rop->preop.nsf; i--; ) + for (j = rop->mtx->ncomp; j--; ) + rop->preop.cmat[i*rop->mtx->ncomp+j] + *= rop->preop.sca[i]; } } mres = rmx_transform(rop->mtx, rop->preop.clen/rop->mtx->ncomp, @@ -232,7 +298,7 @@ loadop(ROPMAT *rop) rop->inspec, mres->ncomp, rop->mtx->ncomp, rop->preop.nsf ? " (* scalar)" : ""); - rop->preop.nsf = 0; + rop->preop.nsf = 0; /* now folded in */ if ((mres->ncomp > 3) & (mres->dtype <= DTspec)) outtype = DTfloat; /* probably not actual spectrum */ rmx_free(rop->mtx); @@ -445,15 +511,18 @@ get_factors(double da[], int n, char *av[]) } static ROPMAT * -grow_moparray(ROPMAT *mop, int n2alloc) +resize_moparr(ROPMAT *mop, int n2alloc) { int nmats = 0; + int i; while (mop[nmats++].binop) ; + for (i = nmats; i > n2alloc; i--) + rmx_free(mop[i].mtx); mop = (ROPMAT *)realloc(mop, n2alloc*sizeof(ROPMAT)); if (mop == NULL) { - fputs("Out of memory in grow_moparray()\n", stderr); + fputs("Out of memory in resize_moparr()\n", stderr); exit(1); } if (n2alloc > nmats) @@ -465,13 +534,14 @@ grow_moparray(ROPMAT *mop, int n2alloc) int main(int argc, char *argv[]) { - int outfmt = DTfromHeader; - int nall = 2; - ROPMAT *mop = (ROPMAT *)calloc(nall, sizeof(ROPMAT)); - int nmats = 0; - RMATRIX *mres = NULL; - int stdin_used = 0; - int i; + int outfmt = DTfromHeader; + const char *defCsym = NULL; + int nall = 2; + ROPMAT *mop = (ROPMAT *)calloc(nall, sizeof(ROPMAT)); + int nmats = 0; + RMATRIX *mres = NULL; + int stdin_used = 0; + int i; /* get options and arguments */ for (i = 1; i < argc; i++) { if (argv[i][0] && !argv[i][1] && @@ -494,6 +564,8 @@ main(int argc, char *argv[]) mop[nmats].inspec = stdin_name; } else mop[nmats].inspec = argv[i]; + if (!mop[nmats].preop.csym) + mop[nmats].preop.csym = defCsym; if (nmats > 0 && !mop[nmats-1].binop) mop[nmats-1].binop = '.'; nmats++; @@ -535,11 +607,15 @@ main(int argc, char *argv[]) goto userr; } break; + case 'C': + if (!n || isflt(argv[i+1])) + goto userr; + defCsym = mop[nmats].preop.csym = argv[++i]; + mop[nmats].preop.clen = 0; + break; case 'c': - if (n && isupper(argv[i+1][0])) { - strlcpy(mop[nmats].preop.csym, - argv[++i], - sizeof(mop[0].preop.csym)); + if (n && !isflt(argv[i+1])) { + mop[nmats].preop.csym = argv[++i]; mop[nmats].preop.clen = 0; break; } @@ -552,7 +628,7 @@ main(int argc, char *argv[]) argv[0]); goto userr; } - mop[nmats].preop.csym[0] = '\0'; + mop[nmats].preop.csym = NULL; break; case 'r': if (argv[i][2] == 'f') @@ -569,7 +645,7 @@ main(int argc, char *argv[]) } } if (nmats >= nall) - mop = grow_moparray(mop, nall += 2); + mop = resize_moparr(mop, nall += 2); } if (mop[0].inspec == NULL) /* nothing to do? */ goto userr; @@ -597,15 +673,12 @@ main(int argc, char *argv[]) else if (mres->dtype == DTxyze) outfmt = DTxyze; } - if (outfmt != DTascii) /* write result to stdout */ - SET_FILE_BINARY(stdout); - newheader("RADIANCE", stdout); + newheader("RADIANCE", stdout); /* write result to stdout */ printargs(argc, argv, stdout); - return(rmx_write(mres, outfmt, stdout) ? 0 : 1); userr: fprintf(stderr, - "Usage: %s [-v][-f[adfc][-t][-s sf .. | -c ce ..][-rf|-rb] m1 [.+*/] .. > mres\n", + "Usage: %s [-v][-f{adfc}][-t][-s sf .. | -c ce ..][-rf|-rb] m1 [.+*/] .. > mres\n", argv[0]); return(1); }
