root/radiance/ray/src/util/rmtxop.c
Sat Dec 28 18:05:14 2019 UTC (4 years, 5 months ago) by greg
Changes since 2.16: +1 -2 lines
Diff to previous 2.16
Revision 2.16 - (view) (download) (annotate) - [selected]
Mon Aug 12 20:38:19 2019 UTC (4 years, 9 months ago) by greg
Changes since 2.15: +11 -8 lines
Diff to previous 2.15
Added warning about divide-by-zero to matrix information header
Mon Aug 12 16:55:24 2019 UTC (4 years, 9 months ago) by greg
Changes since 2.14: +10 -4 lines
Diff to previous 2.14 , to selected 2.16
Fixed argument parsing issue and added further explanations to man page
Mon Aug 12 02:26:46 2019 UTC (4 years, 9 months ago) by greg
Changes since 2.13: +21 -9 lines
Diff to previous 2.13 , to selected 2.16
Mon Aug 12 01:20:26 2019 UTC (4 years, 9 months ago) by greg
Changes since 2.12: +246 -107 lines
Diff to previous 2.12 , to selected 2.16
Mon Aug 27 23:03:05 2018 UTC (5 years, 9 months ago) by greg
Changes since 2.11: +16 -16 lines
Diff to previous 2.11 , to selected 2.16
Moved transpose operation later to save memory with -c (transform) reduction
Mon Aug 28 15:59:46 2017 UTC (6 years, 9 months ago) by greg
Changes since 2.10: +25 -6 lines
Diff to previous 2.10 , to selected 2.16
Thu Aug 18 17:57:57 2016 UTC (7 years, 9 months ago) by greg
Changes since 2.9: +3 -4 lines
Diff to previous 2.9 , to selected 2.16
Diff to previous 2.8 , to selected 2.16
Wed Jul 22 04:47:51 2015 UTC (8 years, 10 months ago) by greg
Changes since 2.7: +1 -4 lines
Diff to previous 2.7 , to selected 2.16
Moved some file settings around to improve logic
Fri Jan 23 01:03:17 2015 UTC (9 years, 4 months ago) by greg
Diff to previous 2.6 , to selected 2.16
Minor fix
Tue Dec 16 20:21:46 2014 UTC (9 years, 5 months ago) by greg
Diff to previous 2.5 , to selected 2.16
Fixed output format for ASCII from ASCII inputs
Thu Sep 18 23:20:12 2014 UTC (9 years, 8 months ago) by greg
CVS Tags: rad4R2P2
Changes since 2.4: +3 -7 lines
Diff to previous 2.4 , to selected 2.16
Took out unreliable call to ftell()
Tue Aug 5 21:45:05 2014 UTC (9 years, 9 months ago) by greg
CVS Tags: rad4R2P1
Changes since 2.3: +8 -1 lines
Diff to previous 2.3 , to selected 2.16
Added missing _O_BINARY setting for Windows
Sat Aug 2 17:10:43 2014 UTC (9 years, 10 months ago) by greg
Diff to previous 2.2 , to selected 2.16
Sat May 31 19:21:21 2014 UTC (10 years ago) by greg
CVS Tags: rad4R2
Changes since 2.1: +10 -22 lines
Diff to previous 2.1 , to selected 2.16
Bug fixes
Sat May 31 05:02:37 2014 UTC (10 years ago) by greg
Diff to selected 2.16
