--- ray/src/util/rmtxop.c 2021/01/21 17:47:07 2.19 +++ ray/src/util/rmtxop.c 2023/12/03 03:44:42 2.29 @@ -1,29 +1,29 @@ #ifndef lint -static const char RCSid[] = "$Id: rmtxop.c,v 2.19 2021/01/21 17:47:07 greg Exp $"; +static const char RCSid[] = "$Id: rmtxop.c,v 2.29 2023/12/03 03:44:42 greg Exp $"; #endif /* * General component matrix operations. */ -#include #include #include "rtio.h" #include "resolu.h" #include "rmatrix.h" #include "platform.h" -#define MAXCOMP 16 /* #components we support */ +#define MAXCOMP MAXCSAMP /* #components we support */ -/* unary matrix operation(s) */ +/* Unary matrix operation(s) */ typedef struct { - double sca[MAXCOMP]; /* scalar coefficients */ double cmat[MAXCOMP*MAXCOMP]; /* component transformation */ - short nsf; /* number of scalars */ + double sca[MAXCOMP]; /* scalar coefficients */ + const char *csym; /* symbolic coefs or file */ short clen; /* number of coefficients */ + short nsf; /* number of scalars */ short transpose; /* do transpose? */ } RUNARYOP; -/* matrix input source and requested operation(s) */ +/* Matrix input source and requested operation(s) */ typedef struct { const char *inspec; /* input specification */ RMPref rmp; /* matrix preference */ @@ -38,33 +38,274 @@ int verbose = 0; /* verbose reporting? */ static int loadmatrix(ROPMAT *rop) { - if (rop->mtx != NULL) + if (rop->mtx != NULL) /* already loaded? */ return(0); rop->mtx = rmx_load(rop->inspec, rop->rmp); - if (rop->mtx == NULL) { - fputs(rop->inspec, stderr); - fputs(": cannot load matrix\n", stderr); + + return(!rop->mtx ? -1 : 1); +} + +static int checksymbolic(ROPMAT *rop); + +/* Check/set transform based on a reference input file */ +static int +checkreffile(ROPMAT *rop) +{ + static const char *curRF = NULL; + static RMATRIX refm; + const int nc = rop->mtx->ncomp; + int i; + + if (!curRF || strcmp(rop->preop.csym, curRF)) { + FILE *fp = fopen(rop->preop.csym, "rb"); + if (!rmx_load_header(&refm, fp)) { + fprintf(stderr, "%s: cannot read info header\n", + rop->preop.csym); + curRF = NULL; + if (fp) fclose(fp); + return(-1); + } + fclose(fp); + curRF = rop->preop.csym; + } + if ((refm.ncomp == 3) & (refm.dtype != DTspec)) { + rop->preop.csym = (refm.dtype == DTxyze) ? "XYZ" : "RGB"; + return(checksymbolic(rop)); + } + if (refm.ncomp == 2) { + fprintf(stderr, "%s: cannot convert to 2 components\n", + curRF); return(-1); } - return(1); + if (refm.ncomp == 1) { + rop->preop.csym = "Y"; /* XXX big assumption */ + return(checksymbolic(rop)); + } + if (refm.ncomp == nc && + !memcmp(refm.wlpart, rop->mtx->wlpart, sizeof(refm.wlpart))) + return(0); /* nothing to do */ + + if ((nc <= 3) | (nc > MAXCSAMP) | (refm.ncomp > MAXCSAMP)) { + fprintf(stderr, "%s: cannot resample from %d to %d components\n", + curRF, nc, refm.ncomp); + return(-1); + } + rop->preop.clen = refm.ncomp * nc; /* compute spec to ref */ + + for (i = 0; i < nc; i++) { + SCOLOR scstim, scresp; + int j; + memset(scstim, 0, sizeof(COLORV)*nc); + scstim[i] = 1.f; + convertscolor(scresp, refm.ncomp, refm.wlpart[0], refm.wlpart[3], + scstim, nc, rop->mtx->wlpart[0], rop->mtx->wlpart[3]); + for (j = refm.ncomp; j-- > 0; ) + rop->preop.cmat[j*nc + i] = scresp[j]; + } + memcpy(rop->mtx->wlpart, refm.wlpart, sizeof(rop->mtx->wlpart)); + return(0); } +/* Compute conversion row from spectrum to one channel of RGB */ +static void +rgbrow(ROPMAT *rop, int r, int p) +{ + const int nc = rop->mtx->ncomp; + const float * wlp = rop->mtx->wlpart; + int i; + + for (i = nc; i--; ) { + int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc; + int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc; + COLOR crgb; + spec_rgb(crgb, nmStart, nmEnd); + rop->preop.cmat[r*nc+i] = crgb[p]; + } +} + +/* Compute conversion row from spectrum to one channel of XYZ */ +static void +xyzrow(ROPMAT *rop, int r, int p) +{ + const int nc = rop->mtx->ncomp; + const float * wlp = rop->mtx->wlpart; + int i; + + for (i = nc; i--; ) { + int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc; + int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc; + COLOR cxyz; + spec_cie(cxyz, nmStart, nmEnd); + rop->preop.cmat[r*nc+i] = cxyz[p]; + } +} + +/* Use the spectral sensitivity function to compute matrix coefficients */ +static void +sensrow(ROPMAT *rop, int r, double (*sf)(SCOLOR sc, int ncs, const float wlpt[4])) +{ + const int nc = rop->mtx->ncomp; + int i; + + for (i = nc; i--; ) { + SCOLOR sclr; + memset(sclr, 0, sizeof(COLORV)*nc); + sclr[i] = 1.f; + rop->preop.cmat[r*nc+i] = (*sf)(sclr, nc, rop->mtx->wlpart); + } +} + +/* Check/set symbolic transform */ +static int +checksymbolic(ROPMAT *rop) +{ + const int nc = rop->mtx->ncomp; + const int dt = rop->mtx->dtype; + int i, j; + /* check suffix => reference file */ + if (strchr(rop->preop.csym, '.') > rop->preop.csym) + return(checkreffile(rop)); + + if (nc < 3) { + fprintf(stderr, "%s: -c '%s' requires at least 3 components\n", + rop->inspec, rop->preop.csym); + return(-1); + } + rop->preop.clen = strlen(rop->preop.csym) * nc; + if (rop->preop.clen > MAXCOMP*MAXCOMP) { + fprintf(stderr, "%s: -c '%s' results in too many components\n", + rop->inspec, rop->preop.csym); + return(-1); + } + for (j = 0; rop->preop.csym[j]; j++) { + int comp = 0; + switch (rop->preop.csym[j]) { + case 'B': + ++comp; + /* fall through */ + case 'G': + ++comp; + /* fall through */ + case 'R': + if (dt == DTxyze) { + for (i = 3; i--; ) + rop->preop.cmat[j*nc+i] = 1./WHTEFFICACY * + xyz2rgbmat[comp][i]; + } else if (nc == 3) + rop->preop.cmat[j*nc+comp] = 1.; + else + rgbrow(rop, j, comp); + break; + case 'Z': + ++comp; + /* fall through */ + case 'Y': + ++comp; + /* fall through */ + case 'X': + if (dt == DTxyze) { + rop->preop.cmat[j*nc+comp] = 1.; + } else if (nc == 3) { + for (i = 3; i--; ) + rop->preop.cmat[j*nc+i] = + rgb2xyzmat[comp][i]; + } else if (comp == CIEY) + sensrow(rop, j, scolor2photopic); + else + xyzrow(rop, j, comp); + + for (i = nc*(dt != DTxyze); i--; ) + rop->preop.cmat[j*nc+i] *= WHTEFFICACY; + break; + case 'S': /* scotopic (il)luminance */ + sensrow(rop, j, scolor2scotopic); + for (i = nc; i--; ) + rop->preop.cmat[j*nc+i] *= WHTSCOTOPIC; + break; + case 'M': /* melanopic (il)luminance */ + sensrow(rop, j, scolor2melanopic); + for (i = nc; i--; ) + rop->preop.cmat[j*nc+i] *= WHTMELANOPIC; + break; + case 'A': /* average component */ + for (i = nc; i--; ) + rop->preop.cmat[j*nc+i] = 1./(double)nc; + break; + default: + fprintf(stderr, "%s: -c '%c' unsupported\n", + rop->inspec, rop->preop.csym[j]); + return(-1); + } + } + /* return recommended output type */ + if (!strcmp(rop->preop.csym, "XYZ")) { + if (dt <= DTspec) + return(DTxyze); + } else if (!strcmp(rop->preop.csym, "RGB")) { + if (dt <= DTspec) + return(DTrgbe); + } + if ((nc > 3) & (dt <= DTspec)) + return(DTfloat); /* probably not actual spectrum */ + return(0); +} + /* Get matrix and perform unary operations */ static RMATRIX * loadop(ROPMAT *rop) { + int outtype = 0; RMATRIX *mres; - int i; + int i, j; if (loadmatrix(rop) < 0) /* make sure we're loaded */ return(NULL); - if (rop->preop.nsf > 0) { /* apply scalar(s) */ - if (rop->preop.clen > 0) { - fputs("Options -s and -c are exclusive\n", stderr); + if (rop->preop.csym && /* symbolic transform? */ + (outtype = checksymbolic(rop)) < 0) + goto failure; + if (rop->preop.clen > 0) { /* apply component transform? */ + if (rop->preop.clen % rop->mtx->ncomp) { + fprintf(stderr, "%s: -c must have N x %d coefficients\n", + rop->inspec, rop->mtx->ncomp); goto failure; } + if (rop->preop.nsf > 0) { /* scale transform, first */ + if (rop->preop.nsf == 1) { + for (i = rop->preop.clen; i--; ) + rop->preop.cmat[i] *= rop->preop.sca[0]; + } else if (rop->preop.nsf*rop->mtx->ncomp != rop->preop.clen) { + fprintf(stderr, "%s: -s must have one or %d factors\n", + rop->inspec, + rop->preop.clen/rop->mtx->ncomp); + goto failure; + } else { + for (i = rop->preop.nsf; i--; ) + for (j = rop->mtx->ncomp; j--; ) + rop->preop.cmat[i*rop->mtx->ncomp+j] + *= rop->preop.sca[i]; + } + } + mres = rmx_transform(rop->mtx, rop->preop.clen/rop->mtx->ncomp, + rop->preop.cmat); + if (mres == NULL) { + fprintf(stderr, "%s: matrix transform failed\n", + rop->inspec); + goto failure; + } + if (verbose) + fprintf(stderr, "%s: applied %d x %d transform%s\n", + rop->inspec, mres->ncomp, + rop->mtx->ncomp, + rop->preop.nsf ? " (* scalar)" : ""); + rop->preop.nsf = 0; /* now folded in */ + if ((mres->ncomp > 3) & (mres->dtype <= DTspec)) + outtype = DTfloat; /* probably not actual spectrum */ + rmx_free(rop->mtx); + rop->mtx = mres; + } + if (rop->preop.nsf > 0) { /* apply scalar(s)? */ if (rop->preop.nsf == 1) { for (i = rop->mtx->ncomp; --i; ) rop->preop.sca[i] = rop->preop.sca[0]; @@ -86,27 +327,7 @@ loadop(ROPMAT *rop) fputs(" )\n", stderr); } } - if (rop->preop.clen > 0) { /* apply transform */ - if (rop->preop.clen % rop->mtx->ncomp) { - fprintf(stderr, "%s: -c must have N x %d coefficients\n", - rop->inspec, rop->mtx->ncomp); - goto failure; - } - mres = rmx_transform(rop->mtx, rop->preop.clen/rop->mtx->ncomp, - rop->preop.cmat); - if (mres == NULL) { - fprintf(stderr, "%s: matrix transform failed\n", - rop->inspec); - goto failure; - } - if (verbose) - fprintf(stderr, "%s: applied %d x %d transform\n", - rop->inspec, mres->ncomp, - rop->mtx->ncomp); - rmx_free(rop->mtx); - rop->mtx = mres; - } - if (rop->preop.transpose) { /* transpose matrix? */ + if (rop->preop.transpose) { /* transpose matrix? */ mres = rmx_transpose(rop->mtx); if (mres == NULL) { fputs(rop->inspec, stderr); @@ -122,6 +343,8 @@ loadop(ROPMAT *rop) } mres = rop->mtx; rop->mtx = NULL; + if (outtype) + mres->dtype = outtype; return(mres); failure: rmx_free(rop->mtx); @@ -239,7 +462,7 @@ op_right2left(ROPMAT *mop) while (rpos-- > 0) { if (mright == NULL) break; - mright = binaryop(mop[rpos].inspec, + mright = binaryop(mop[rpos+1].inspec, loadop(mop+rpos), mop[rpos].binop, mright); } return(mright); @@ -289,15 +512,18 @@ get_factors(double da[], int n, char *av[]) } static ROPMAT * -grow_moparray(ROPMAT *mop, int n2alloc) +resize_moparr(ROPMAT *mop, int n2alloc) { int nmats = 0; + int i; while (mop[nmats++].binop) ; + for (i = nmats; i > n2alloc; i--) + rmx_free(mop[i].mtx); mop = (ROPMAT *)realloc(mop, n2alloc*sizeof(ROPMAT)); if (mop == NULL) { - fputs("Out of memory in grow_moparray()\n", stderr); + fputs("Out of memory in resize_moparr()\n", stderr); exit(1); } if (n2alloc > nmats) @@ -309,13 +535,14 @@ grow_moparray(ROPMAT *mop, int n2alloc) int main(int argc, char *argv[]) { - int outfmt = DTfromHeader; - int nall = 2; - ROPMAT *mop = (ROPMAT *)calloc(nall, sizeof(ROPMAT)); - int nmats = 0; - RMATRIX *mres = NULL; - int stdin_used = 0; - int i; + int outfmt = DTfromHeader; + const char *defCsym = NULL; + int nall = 2; + ROPMAT *mop = (ROPMAT *)calloc(nall, sizeof(ROPMAT)); + int nmats = 0; + RMATRIX *mres = NULL; + int stdin_used = 0; + int i; /* get options and arguments */ for (i = 1; i < argc; i++) { if (argv[i][0] && !argv[i][1] && @@ -338,6 +565,8 @@ main(int argc, char *argv[]) mop[nmats].inspec = stdin_name; } else mop[nmats].inspec = argv[i]; + if (!mop[nmats].preop.csym) + mop[nmats].preop.csym = defCsym; if (nmats > 0 && !mop[nmats-1].binop) mop[nmats-1].binop = '.'; nmats++; @@ -373,12 +602,34 @@ main(int argc, char *argv[]) i += mop[nmats].preop.nsf = get_factors(mop[nmats].preop.sca, n, argv+i+1); + if (mop[nmats].preop.nsf <= 0) { + fprintf(stderr, "%s: -s missing arguments\n", + argv[0]); + goto userr; + } break; + case 'C': + if (!n || isflt(argv[i+1])) + goto userr; + defCsym = mop[nmats].preop.csym = argv[++i]; + mop[nmats].preop.clen = 0; + break; case 'c': + if (n && !isflt(argv[i+1])) { + mop[nmats].preop.csym = argv[++i]; + mop[nmats].preop.clen = 0; + break; + } if (n > MAXCOMP*MAXCOMP) n = MAXCOMP*MAXCOMP; i += mop[nmats].preop.clen = get_factors(mop[nmats].preop.cmat, n, argv+i+1); + if (mop[nmats].preop.clen <= 0) { + fprintf(stderr, "%s: -c missing arguments\n", + argv[0]); + goto userr; + } + mop[nmats].preop.csym = NULL; break; case 'r': if (argv[i][2] == 'f') @@ -395,7 +646,7 @@ main(int argc, char *argv[]) } } if (nmats >= nall) - mop = grow_moparray(mop, nall += 2); + mop = resize_moparr(mop, nall += 2); } if (mop[0].inspec == NULL) /* nothing to do? */ goto userr; @@ -415,22 +666,20 @@ main(int argc, char *argv[]) mres = loadop(mop+nmats); if (mres == NULL) return(1); - /* write result to stdout */ - if (outfmt == DTfromHeader) + if (outfmt == DTfromHeader) /* check data type */ outfmt = mres->dtype; - if (outfmt != DTascii) - SET_FILE_BINARY(stdout); - newheader("RADIANCE", stdout); - printargs(argc, argv, stdout); - if (!rmx_write(mres, outfmt, stdout)) { - fprintf(stderr, "%s: error writing result matrix\n", argv[0]); - return(1); + if (outfmt == DTrgbe) { + if (mres->ncomp > 3) + outfmt = DTspec; + else if (mres->dtype == DTxyze) + outfmt = DTxyze; } - /* rmx_free(mres); free(mop); */ - return(0); + newheader("RADIANCE", stdout); /* write result to stdout */ + printargs(argc, argv, stdout); + return(rmx_write(mres, outfmt, stdout) ? 0 : 1); userr: fprintf(stderr, - "Usage: %s [-v][-f[adfc][-t][-s sf .. | -c ce ..][-rf|-rb] m1 [.+*/] .. > mres\n", + "Usage: %s [-v][-f{adfc}][-t][-s sf .. | -c ce ..][-rf|-rb] m1 [.+*/] .. > mres\n", argv[0]); return(1); }
