--- ray/src/util/rmtxop.c 2019/08/12 02:26:46 2.14 +++ ray/src/util/rmtxop.c 2023/11/29 18:56:28 2.24 @@ -1,34 +1,34 @@ #ifndef lint -static const char RCSid[] = "$Id: rmtxop.c,v 2.14 2019/08/12 02:26:46 greg Exp $"; +static const char RCSid[] = "$Id: rmtxop.c,v 2.24 2023/11/29 18:56:28 greg Exp $"; #endif /* * General component matrix operations. */ -#include #include #include +#include #include "rtio.h" #include "resolu.h" #include "rmatrix.h" #include "platform.h" -#define MAXCOMP 16 /* #components we support */ +#define MAXCOMP MAXCSAMP /* #components we support */ -static const char stdin_name[] = ""; - -/* unary matrix operation(s) */ +/* Unary matrix operation(s) */ typedef struct { double sca[MAXCOMP]; /* scalar coefficients */ double cmat[MAXCOMP*MAXCOMP]; /* component transformation */ short nsf; /* number of scalars */ short clen; /* number of coefficients */ - short transpose; /* do transpose? */ + char csym[11]; /* symbolic coefficients */ + char transpose; /* do transpose? */ } RUNARYOP; -/* matrix input source and requested operation(s) */ +/* Matrix input source and requested operation(s) */ typedef struct { const char *inspec; /* input specification */ + RMPref rmp; /* matrix preference */ RUNARYOP preop; /* unary operation(s) */ RMATRIX *mtx; /* original matrix if loaded */ int binop; /* binary op with next (or 0) */ @@ -40,34 +40,209 @@ int verbose = 0; /* verbose reporting? */ static int loadmatrix(ROPMAT *rop) { - if (rop->mtx != NULL) + if (rop->mtx != NULL) /* already loaded? */ return(0); - rop->mtx = rmx_load(rop->inspec == stdin_name ? - (const char *)NULL : rop->inspec); - if (rop->mtx == NULL) { - fputs(rop->inspec, stderr); - fputs(": cannot load matrix\n", stderr); + rop->mtx = rmx_load(rop->inspec, rop->rmp); + + return(!rop->mtx ? -1 : 1); +} + +/* Compute conversion row from spectrum to one channel of RGB */ +static void +rgbrow(ROPMAT *rop, int r, int p) +{ + const int nc = rop->mtx->ncomp; + const float * wlp = rop->mtx->wlpart; + int i; + + for (i = nc; i--; ) { + int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc; + int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc; + COLOR crgb; + spec_rgb(crgb, nmStart, nmEnd); + rop->preop.cmat[r*nc+i] = crgb[p]; + } +} + +/* Compute conversion row from spectrum to one channel of XYZ */ +static void +xyzrow(ROPMAT *rop, int r, int p) +{ + const int nc = rop->mtx->ncomp; + const float * wlp = rop->mtx->wlpart; + int i; + + for (i = nc; i--; ) { + int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc; + int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc; + COLOR cxyz; + spec_cie(cxyz, nmStart, nmEnd); + rop->preop.cmat[r*nc+i] = cxyz[p]; + } +} + +/* Use the spectral sensitivity function to compute matrix coefficients */ +static void +sensrow(ROPMAT *rop, int r, double (*sf)(SCOLOR sc, int ncs, const float wlpt[4])) +{ + const int nc = rop->mtx->ncomp; + int i; + + for (i = nc; i--; ) { + SCOLOR sclr; + scolorblack(sclr); + sclr[i] = 1.f; + rop->preop.cmat[r*nc+i] = (*sf)(sclr, nc, rop->mtx->wlpart); + } +} + +/* Check/set symbolic transform */ +static int +checksymbolic(ROPMAT *rop) +{ + const int nc = rop->mtx->ncomp; + const int dt = rop->mtx->dtype; + int i, j; + + if (nc < 3) { + fprintf(stderr, "%s: -c '%s' requires at least 3 components\n", + rop->inspec, rop->preop.csym); return(-1); } - return(1); + rop->preop.clen = strlen(rop->preop.csym) * nc; + if (rop->preop.clen > MAXCOMP*MAXCOMP) { + fprintf(stderr, "%s: -c '%s' results in too many components\n", + rop->inspec, rop->preop.csym); + return(-1); + } + for (j = 0; rop->preop.csym[j]; j++) { + int comp = 0; + switch (rop->preop.csym[j]) { + case 'B': + ++comp; + /* fall through */ + case 'G': + ++comp; + /* fall through */ + case 'R': + if (dt == DTxyze) { + for (i = 3; i--; ) + rop->preop.cmat[j*nc+i] = 1./WHTEFFICACY * + xyz2rgbmat[comp][i]; + } else if (nc == 3) + rop->preop.cmat[j*nc+comp] = 1.; + else + rgbrow(rop, j, comp); + break; + case 'Z': + ++comp; + /* fall through */ + case 'Y': + ++comp; + /* fall through */ + case 'X': + if (dt == DTxyze) { + rop->preop.cmat[j*nc+comp] = 1.; + } else if (nc == 3) { + for (i = 3; i--; ) + rop->preop.cmat[j*nc+i] = + rgb2xyzmat[comp][i]; + } else if (comp == CIEY) + sensrow(rop, j, scolor2photopic); + else + xyzrow(rop, j, comp); + + for (i = nc*(dt != DTxyze); i--; ) + rop->preop.cmat[j*nc+i] *= WHTEFFICACY; + break; + case 'S': /* scotopic (il)luminance */ + sensrow(rop, j, scolor2scotopic); + for (i = nc; i--; ) + rop->preop.cmat[j*nc+i] *= WHTSCOTOPIC; + break; + case 'M': /* melanopic (il)luminance */ + sensrow(rop, j, scolor2melanopic); + for (i = nc; i--; ) + rop->preop.cmat[j*nc+i] *= WHTMELANOPIC; + break; + case 'A': /* average component */ + for (i = nc; i--; ) + rop->preop->cmat[j*nc+i] = 1./(double)nc; + break; + default: + fprintf(stderr, "%s: -c '%c' unsupported\n", + rop->inspec, rop->preop.csym[j]); + return(-1); + } + } + /* return recommended output type */ + if (!strcmp(rop->preop.csym, "XYZ")) { + if (dt <= DTspec) + return(DTxyze); + } else if (!strcmp(rop->preop.csym, "RGB")) { + if (dt <= DTspec) + return(DTrgbe); + } + if ((nc > 3) & (dt <= DTspec)) + return(DTfloat); /* probably not actual spectrum */ + return(0); } /* Get matrix and perform unary operations */ static RMATRIX * loadop(ROPMAT *rop) { + int outtype = 0; RMATRIX *mres; - int i; + int i, j; if (loadmatrix(rop) < 0) /* make sure we're loaded */ return(NULL); - if (rop->preop.nsf > 0) { /* apply scalar(s) */ - if (rop->preop.clen > 0) { - fputs("Options -s and -c are exclusive\n", stderr); + if (rop->preop.csym[0] && /* symbolic transform? */ + (outtype = checksymbolic(rop)) < 0) + goto failure; + if (rop->preop.clen > 0) { /* apply component transform? */ + if (rop->preop.clen % rop->mtx->ncomp) { + fprintf(stderr, "%s: -c must have N x %d coefficients\n", + rop->inspec, rop->mtx->ncomp); goto failure; } + if (rop->preop.nsf > 0) { /* scale transform, first */ + if (rop->preop.nsf == 1) { + for (i = rop->preop.clen; i--; ) + rop->preop.cmat[i] *= rop->preop.sca[0]; + } else if (rop->preop.nsf != rop->mtx->ncomp) { + fprintf(stderr, "%s: -s must have one or %d factors\n", + rop->inspec, rop->mtx->ncomp); + goto failure; + } else { + for (j = rop->preop.clen/rop->preop.nsf; j--; ) + for (i = rop->preop.nsf; i--; ) + rop->preop.cmat[j*rop->preop.nsf+i] *= + rop->preop.sca[i]; + } + } + mres = rmx_transform(rop->mtx, rop->preop.clen/rop->mtx->ncomp, + rop->preop.cmat); + if (mres == NULL) { + fprintf(stderr, "%s: matrix transform failed\n", + rop->inspec); + goto failure; + } + if (verbose) + fprintf(stderr, "%s: applied %d x %d transform%s\n", + rop->inspec, mres->ncomp, + rop->mtx->ncomp, + rop->preop.nsf ? " (* scalar)" : ""); + rop->preop.nsf = 0; + if ((mres->ncomp > 3) & (mres->dtype <= DTspec)) + outtype = DTfloat; /* probably not actual spectrum */ + rmx_free(rop->mtx); + rop->mtx = mres; + } + if (rop->preop.nsf > 0) { /* apply scalar(s)? */ if (rop->preop.nsf == 1) { for (i = rop->mtx->ncomp; --i; ) rop->preop.sca[i] = rop->preop.sca[0]; @@ -89,27 +264,7 @@ loadop(ROPMAT *rop) fputs(" )\n", stderr); } } - if (rop->preop.clen > 0) { /* apply transform */ - if (rop->preop.clen % rop->mtx->ncomp) { - fprintf(stderr, "%s: -c must have N x %d coefficients\n", - rop->inspec, rop->mtx->ncomp); - goto failure; - } - mres = rmx_transform(rop->mtx, rop->preop.clen/rop->mtx->ncomp, - rop->preop.cmat); - if (mres == NULL) { - fprintf(stderr, "%s: matrix transform failed\n", - rop->inspec); - goto failure; - } - if (verbose) - fprintf(stderr, "%s: applied %d x %d transform\n", - rop->inspec, mres->ncomp, - rop->mtx->ncomp); - rmx_free(rop->mtx); - rop->mtx = mres; - } - if (rop->preop.transpose) { /* transpose matrix? */ + if (rop->preop.transpose) { /* transpose matrix? */ mres = rmx_transpose(rop->mtx); if (mres == NULL) { fputs(rop->inspec, stderr); @@ -125,6 +280,8 @@ loadop(ROPMAT *rop) } mres = rop->mtx; rop->mtx = NULL; + if (outtype) + mres->dtype = outtype; return(mres); failure: rmx_free(rop->mtx); @@ -140,19 +297,22 @@ binaryop(const char *inspec, RMATRIX *mleft, int op, R if ((mleft == NULL) | (mright == NULL)) return(NULL); - switch (op) { case '.': /* concatenate */ - mres = rmx_multiply(mleft, mright); + if (mleft->ncomp != mright->ncomp) { + fputs(inspec, stderr); + fputs(": # components do not match\n", stderr); + } else if (mleft->ncols != mright->nrows) { + fputs(inspec, stderr); + fputs(": mismatched dimensions\n", + stderr); + } else + mres = rmx_multiply(mleft, mright); rmx_free(mleft); rmx_free(mright); if (mres == NULL) { fputs(inspec, stderr); - if (mleft->ncols != mright->nrows) - fputs(": mismatched dimensions for multiply\n", - stderr); - else - fputs(": concatenation failed\n", stderr); + fputs(": concatenation failed\n", stderr); return(NULL); } if (verbose) { @@ -239,7 +399,7 @@ op_right2left(ROPMAT *mop) while (rpos-- > 0) { if (mright == NULL) break; - mright = binaryop(mop[rpos].inspec, + mright = binaryop(mop[rpos+1].inspec, loadop(mop+rpos), mop[rpos].binop, mright); } return(mright); @@ -320,13 +480,13 @@ main(int argc, char *argv[]) for (i = 1; i < argc; i++) { if (argv[i][0] && !argv[i][1] && strchr(".+*/", argv[i][0]) != NULL) { - if (mop[nmats].inspec == NULL || mop[nmats].binop) { + if (!nmats || mop[nmats-1].binop) { fprintf(stderr, - "%s: missing matrix argument for '%c' operation\n", + "%s: missing matrix argument before '%c' operation\n", argv[0], argv[i][0]); return(1); } - mop[nmats++].binop = argv[i][0]; + mop[nmats-1].binop = argv[i][0]; } else if (argv[i][0] != '-' || !argv[i][1]) { if (argv[i][0] == '-') { if (stdin_used++) { @@ -373,13 +533,39 @@ main(int argc, char *argv[]) i += mop[nmats].preop.nsf = get_factors(mop[nmats].preop.sca, n, argv+i+1); + if (mop[nmats].preop.nsf <= 0) { + fprintf(stderr, "%s: -s missing arguments\n", + argv[0]); + goto userr; + } break; case 'c': + if (n && isupper(argv[i+1][0])) { + strlcpy(mop[nmats].preop.csym, + argv[++i], + sizeof(mop[0].preop.csym)); + mop[nmats].preop.clen = 0; + break; + } if (n > MAXCOMP*MAXCOMP) n = MAXCOMP*MAXCOMP; i += mop[nmats].preop.clen = get_factors(mop[nmats].preop.cmat, n, argv+i+1); + if (mop[nmats].preop.clen <= 0) { + fprintf(stderr, "%s: -c missing arguments\n", + argv[0]); + goto userr; + } + mop[nmats].preop.csym[0] = '\0'; break; + case 'r': + if (argv[i][2] == 'f') + mop[nmats].rmp = RMPreflF; + else if (argv[i][2] == 'b') + mop[nmats].rmp = RMPreflB; + else + goto userr; + break; default: fprintf(stderr, "%s: unknown operation '%s'\n", argv[0], argv[i]); @@ -391,6 +577,12 @@ main(int argc, char *argv[]) } if (mop[0].inspec == NULL) /* nothing to do? */ goto userr; + if (mop[nmats-1].binop) { + fprintf(stderr, + "%s: missing matrix argument after '%c' operation\n", + argv[0], mop[nmats-1].binop); + return(1); + } /* favor quicker concatenation */ mop[nmats].mtx = prefer_right2left(mop) ? op_right2left(mop) : op_left2right(mop); @@ -401,22 +593,23 @@ main(int argc, char *argv[]) mres = loadop(mop+nmats); if (mres == NULL) return(1); - /* write result to stdout */ - if (outfmt == DTfromHeader) + if (outfmt == DTfromHeader) /* check data type */ outfmt = mres->dtype; - if (outfmt != DTascii) + if (outfmt == DTrgbe) { + if (mres->ncomp > 3) + outfmt = DTspec; + else if (mres->dtype == DTxyze) + outfmt = DTxyze; + } + if (outfmt != DTascii) /* write result to stdout */ SET_FILE_BINARY(stdout); newheader("RADIANCE", stdout); printargs(argc, argv, stdout); - if (!rmx_write(mres, outfmt, stdout)) { - fprintf(stderr, "%s: error writing result matrix\n", argv[0]); - return(1); - } - /* rmx_free(mres); free(mop); */ - return(0); + + return(rmx_write(mres, outfmt, stdout) ? 0 : 1); userr: fprintf(stderr, - "Usage: %s [-v][-f[adfc][-t][-s sf .. | -c ce ..] m1 [.+*/] .. > mres\n", + "Usage: %s [-v][-f[adfc][-t][-s sf .. | -c ce ..][-rf|-rb] m1 [.+*/] .. > mres\n", argv[0]); return(1); }
