1 |
greg |
2.1 |
#ifndef lint |
2 |
greg |
2.7 |
static const char RCSid[] = "$Id: rmtxcomb.c,v 2.6 2023/12/11 15:13:39 greg Exp $"; |
3 |
greg |
2.1 |
#endif |
4 |
5 |
* General component matrix combiner, operating on a row at a time. |
6 |
7 |
8 |
#include <errno.h> |
9 |
#include <math.h> |
10 |
#include "platform.h" |
11 |
#include "rtio.h" |
12 |
#include "resolu.h" |
13 |
#include "rmatrix.h" |
14 |
#include "calcomp.h" |
15 |
#include "paths.h" |
16 |
17 |
#ifndef M_PI |
18 |
#define M_PI 3.14159265358979323846 |
19 |
#endif |
20 |
21 |
#define MAXCOMP MAXCSAMP /* #components we support */ |
22 |
23 |
/* Unary matrix operation(s) */ |
24 |
typedef struct { |
25 |
double cmat[MAXCOMP*MAXCOMP]; /* component transformation */ |
26 |
double sca[MAXCOMP]; /* scalar coefficients */ |
27 |
const char *csym; /* symbolic coefficients */ |
28 |
short clen; /* number of coefficients */ |
29 |
short nsf; /* number of scalars */ |
30 |
} RUNARYOP; |
31 |
32 |
/* Input matrix */ |
33 |
typedef struct { |
34 |
const char *inspec; /* input specification */ |
35 |
RUNARYOP preop; /* transform operation */ |
36 |
RMATRIX imx; /* input matrix header info */ |
37 |
RMATRIX *rmp; /* active single-row matrix */ |
38 |
FILE *infp; /* open input stream */ |
39 |
} ROPMAT; |
40 |
41 |
ROPMAT *mop = NULL; /* allocated input array */ |
42 |
int nall = 0; /* number allocated */ |
43 |
int nmats = 0; /* number of actual inputs */ |
44 |
45 |
RMATRIX *mcat = NULL; /* final concatenation */ |
46 |
int mcat_last = 0; /* goes after trailing ops? */ |
47 |
48 |
int in_nrows; /* input row count */ |
49 |
#define in_ncols (mop[0].rmp->ncols) /* input column count */ |
50 |
#define in_ncomp (mop[0].rmp->ncomp) /* input #components */ |
51 |
52 |
extern int nowarn; /* turn off warnings? */ |
53 |
54 |
int cur_row; /* current input/output row */ |
55 |
int cur_col; /* current input/output column */ |
56 |
int cur_chan; /* if we're looping channels */ |
57 |
58 |
static int checksymbolic(ROPMAT *rop); |
59 |
60 |
static int |
61 |
split_input(ROPMAT *rop) |
62 |
63 |
if (rop->rmp == &rop->imx && !(rop->rmp = rmx_copy(&rop->imx))) { |
64 |
fputs("Out of memory in split_input()\n", stderr); |
65 |
return(0); |
66 |
67 |
rmx_reset(rop->rmp); |
68 |
return(1); |
69 |
70 |
71 |
/* Check/set transform based on a reference input file */ |
72 |
static int |
73 |
checkreffile(ROPMAT *rop) |
74 |
75 |
static const char *curRF = NULL; |
76 |
static RMATRIX refm; |
77 |
const int nc = rop->imx.ncomp; |
78 |
int i; |
79 |
80 |
if (!curRF || strcmp(rop->preop.csym, curRF)) { |
81 |
FILE *fp = fopen(rop->preop.csym, "rb"); |
82 |
if (!rmx_load_header(&refm, fp)) { |
83 |
fprintf(stderr, "%s: cannot read info header\n", |
84 |
rop->preop.csym); |
85 |
curRF = NULL; |
86 |
if (fp) fclose(fp); |
87 |
return(0); |
88 |
89 |
fclose(fp); |
90 |
curRF = rop->preop.csym; |
91 |
92 |
greg |
2.5 |
if (refm.ncomp == 3) { |
93 |
greg |
2.1 |
rop->preop.csym = (refm.dtype == DTxyze) ? "XYZ" : "RGB"; |
94 |
return(checksymbolic(rop)); |
95 |
96 |
if (refm.ncomp == 2) { |
97 |
fprintf(stderr, "%s: cannot convert to 2 components\n", |
98 |
curRF); |
99 |
return(0); |
100 |
101 |
if (refm.ncomp == 1) { |
102 |
rop->preop.csym = "Y"; /* XXX big assumption */ |
103 |
104 |
105 |
if (refm.ncomp == nc && |
106 |
!memcmp(refm.wlpart, rop->imx.wlpart, sizeof(refm.wlpart))) |
107 |
return(1); /* nothing to do */ |
108 |
109 |
if ((nc <= 3) | (nc > MAXCSAMP) | (refm.ncomp > MAXCSAMP)) { |
110 |
fprintf(stderr, "%s: cannot resample from %d to %d components\n", |
111 |
curRF, nc, refm.ncomp); |
112 |
return(0); |
113 |
114 |
if (!split_input(rop)) /* get our own struct */ |
115 |
return(0); |
116 |
rop->preop.clen = refm.ncomp * nc; /* compute spec to ref */ |
117 |
118 |
for (i = 0; i < nc; i++) { |
119 |
SCOLOR scstim, scresp; |
120 |
int j; |
121 |
memset(scstim, 0, sizeof(COLORV)*nc); |
122 |
scstim[i] = 1.f; |
123 |
convertscolor(scresp, refm.ncomp, refm.wlpart[0], refm.wlpart[3], |
124 |
scstim, nc, rop->imx.wlpart[0], rop->imx.wlpart[3]); |
125 |
for (j = refm.ncomp; j-- > 0; ) |
126 |
rop->preop.cmat[j*nc + i] = scresp[j]; |
127 |
128 |
/* remember new spectral params */ |
129 |
memcpy(rop->rmp->wlpart, refm.wlpart, sizeof(rop->rmp->wlpart)); |
130 |
rop->rmp->ncomp = refm.ncomp; |
131 |
return(1); |
132 |
133 |
134 |
/* Compute conversion row from spectrum to one channel of RGB */ |
135 |
static void |
136 |
rgbrow(ROPMAT *rop, int r, int p) |
137 |
138 |
139 |
const float * wlp = rop->imx.wlpart; |
140 |
int i; |
141 |
142 |
for (i = nc; i--; ) { |
143 |
int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc; |
144 |
int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc; |
145 |
COLOR crgb; |
146 |
spec_rgb(crgb, nmStart, nmEnd); |
147 |
rop->preop.cmat[r*nc+i] = crgb[p]; |
148 |
149 |
150 |
151 |
/* Compute conversion row from spectrum to one channel of XYZ */ |
152 |
static void |
153 |
xyzrow(ROPMAT *rop, int r, int p) |
154 |
155 |
156 |
157 |
int i; |
158 |
159 |
160 |
161 |
162 |
COLOR cxyz; |
163 |
spec_cie(cxyz, nmStart, nmEnd); |
164 |
rop->preop.cmat[r*nc+i] = cxyz[p]; |
165 |
166 |
167 |
168 |
/* Use the spectral sensitivity function to compute matrix coefficients */ |
169 |
static void |
170 |
sensrow(ROPMAT *rop, int r, double (*sf)(SCOLOR sc, int ncs, const float wlpt[4])) |
171 |
172 |
173 |
int i; |
174 |
175 |
176 |
SCOLOR sclr; |
177 |
memset(sclr, 0, sizeof(COLORV)*nc); |
178 |
sclr[i] = 1.f; |
179 |
rop->preop.cmat[r*nc+i] = (*sf)(sclr, nc, rop->imx.wlpart); |
180 |
181 |
182 |
183 |
/* Check/set symbolic transform */ |
184 |
static int |
185 |
checksymbolic(ROPMAT *rop) |
186 |
187 |
188 |
const int dt = rop->imx.dtype; |
189 |
int i, j; |
190 |
/* check suffix => reference file */ |
191 |
if (strchr(rop->preop.csym, '.') > rop->preop.csym) |
192 |
return(checkreffile(rop)); |
193 |
194 |
if (nc < 3) { |
195 |
fprintf(stderr, "%s: -c '%s' requires at least 3 components\n", |
196 |
rop->inspec, rop->preop.csym); |
197 |
return(0); |
198 |
199 |
rop->preop.clen = strlen(rop->preop.csym) * nc; |
200 |
if (rop->preop.clen > MAXCOMP*MAXCOMP) { |
201 |
fprintf(stderr, "%s: -c '%s' results in too many components\n", |
202 |
203 |
return(0); |
204 |
205 |
for (j = 0; rop->preop.csym[j]; j++) { |
206 |
int comp = 0; |
207 |
switch (rop->preop.csym[j]) { |
208 |
case 'B': |
209 |
++comp; |
210 |
/* fall through */ |
211 |
case 'G': |
212 |
++comp; |
213 |
214 |
case 'R': |
215 |
if (dt == DTxyze) { |
216 |
for (i = 3; i--; ) |
217 |
rop->preop.cmat[j*nc+i] = 1./WHTEFFICACY * |
218 |
xyz2rgbmat[comp][i]; |
219 |
} else if (nc == 3) |
220 |
rop->preop.cmat[j*nc+comp] = 1.; |
221 |
else |
222 |
rgbrow(rop, j, comp); |
223 |
break; |
224 |
case 'Z': |
225 |
++comp; |
226 |
227 |
case 'Y': |
228 |
++comp; |
229 |
230 |
case 'X': |
231 |
232 |
233 |
} else if (nc == 3) { |
234 |
235 |
rop->preop.cmat[j*nc+i] = |
236 |
rgb2xyzmat[comp][i]; |
237 |
} else if (comp == CIEY) |
238 |
sensrow(rop, j, scolor2photopic); |
239 |
else |
240 |
xyzrow(rop, j, comp); |
241 |
242 |
for (i = nc*(dt != DTxyze); i--; ) |
243 |
rop->preop.cmat[j*nc+i] *= WHTEFFICACY; |
244 |
break; |
245 |
case 'S': /* scotopic (il)luminance */ |
246 |
sensrow(rop, j, scolor2scotopic); |
247 |
for (i = nc; i--; ) |
248 |
rop->preop.cmat[j*nc+i] *= WHTSCOTOPIC; |
249 |
break; |
250 |
case 'M': /* melanopic (il)luminance */ |
251 |
sensrow(rop, j, scolor2melanopic); |
252 |
253 |
rop->preop.cmat[j*nc+i] *= WHTMELANOPIC; |
254 |
break; |
255 |
case 'A': /* average component */ |
256 |
257 |
rop->preop.cmat[j*nc+i] = 1./(double)nc; |
258 |
break; |
259 |
default: |
260 |
fprintf(stderr, "%s: -c '%c' unsupported\n", |
261 |
rop->inspec, rop->preop.csym[j]); |
262 |
return(0); |
263 |
264 |
265 |
266 |
return(0); |
267 |
memcpy(rop->rmp->wlpart, WLPART, sizeof(rop->rmp->wlpart)); |
268 |
rop->rmp->ncomp = rop->preop.clen / nc; |
269 |
/* decide on output type */ |
270 |
if (!strcmp(rop->preop.csym, "XYZ")) { |
271 |
if (dt <= DTspec) |
272 |
rop->rmp->dtype = DTxyze; |
273 |
} else if (!strcmp(rop->preop.csym, "RGB")) { |
274 |
if (dt <= DTspec) |
275 |
rop->rmp->dtype = DTrgbe; |
276 |
greg |
2.2 |
} else if (rop->rmp->dtype == DTspec) |
277 |
greg |
2.1 |
rop->rmp->dtype = DTfloat; |
278 |
return(1); |
279 |
280 |
281 |
static int |
282 |
get_component_xfm(ROPMAT *rop) |
283 |
284 |
int i, j; |
285 |
286 |
if (rop->rmp != &rop->imx) { /* reset destination matrix */ |
287 |
rmx_free(rop->rmp); |
288 |
rop->rmp = &rop->imx; |
289 |
290 |
if (rop->preop.csym && /* symbolic transform? */ |
291 |
!checksymbolic(rop)) |
292 |
return(0); |
293 |
/* undo exposure? */ |
294 |
if (fabs(1. - bright(rop->rmp->cexp)) > .025) { |
295 |
if (rop->rmp->ncomp == 1) |
296 |
rop->rmp->cexp[RED] = rop->rmp->cexp[GRN] = |
297 |
rop->rmp->cexp[BLU] = bright(rop->rmp->cexp); |
298 |
if (rop->preop.nsf <= 0) { |
299 |
rop->preop.nsf = i = rop->rmp->ncomp; |
300 |
while (i--) |
301 |
rop->preop.sca[i] = 1.; |
302 |
303 |
greg |
2.2 |
if (rop->preop.nsf == 1) { |
304 |
if (rop->rmp->ncomp == 3) { |
305 |
rop->preop.sca[2] = rop->preop.sca[1] = |
306 |
rop->preop.sca[0]; |
307 |
rop->preop.nsf = 3; |
308 |
} else |
309 |
rop->preop.sca[0] /= bright(rop->rmp->cexp); |
310 |
311 |
if (rop->preop.nsf == 3) { |
312 |
greg |
2.1 |
opcolor(rop->preop.sca, /=, rop->rmp->cexp); |
313 |
greg |
2.2 |
} else if (rop->preop.nsf > 3) { /* punt */ |
314 |
greg |
2.1 |
double mult = 1./bright(rop->rmp->cexp); |
315 |
for (i = rop->preop.nsf; i--; ) |
316 |
rop->preop.sca[i] *= mult; |
317 |
318 |
setcolor(rop->rmp->cexp, 1., 1., 1.); |
319 |
320 |
if (rop->preop.clen > 0) { /* use component transform? */ |
321 |
if (rop->preop.clen % rop->imx.ncomp) { |
322 |
fprintf(stderr, "%s: -c must have N x %d coefficients\n", |
323 |
rop->inspec, rop->imx.ncomp); |
324 |
return(0); |
325 |
326 |
if (rop->preop.nsf > 0) { /* scale transform, instead */ |
327 |
328 |
for (i = rop->preop.clen; i--; ) |
329 |
rop->preop.cmat[i] *= rop->preop.sca[0]; |
330 |
} else if (rop->preop.nsf*rop->imx.ncomp != rop->preop.clen) { |
331 |
fprintf(stderr, "%s: -s must have one or %d factors\n", |
332 |
rop->inspec, |
333 |
rop->preop.clen/rop->imx.ncomp); |
334 |
return(0); |
335 |
} else { |
336 |
337 |
for (j = rop->imx.ncomp; j--; ) |
338 |
rop->preop.cmat[i*rop->imx.ncomp+j] |
339 |
*= rop->preop.sca[i]; |
340 |
341 |
342 |
rop->preop.nsf = 0; /* now folded in */ |
343 |
344 |
return(0); |
345 |
rop->rmp->ncomp = rop->preop.clen / rop->imx.ncomp; |
346 |
greg |
2.4 |
if ((rop->rmp->ncomp > 3) & (rop->rmp->dtype <= DTspec)) { |
347 |
greg |
2.1 |
rop->rmp->dtype = DTfloat; /* probably not actual spectrum */ |
348 |
greg |
2.4 |
349 |
350 |
greg |
2.1 |
} else if (rop->preop.nsf > 0) { /* else use scalar(s)? */ |
351 |
352 |
for (i = rop->rmp->ncomp; --i; ) |
353 |
rop->preop.sca[i] = rop->preop.sca[0]; |
354 |
rop->preop.nsf = rop->rmp->ncomp; |
355 |
} else if (rop->preop.nsf != rop->rmp->ncomp) { |
356 |
357 |
rop->inspec, rop->rmp->ncomp); |
358 |
return(0); |
359 |
360 |
361 |
return(1); |
362 |
363 |
364 |
static int |
365 |
apply_op(RMATRIX *dst, const RMATRIX *src, const RUNARYOP *ro) |
366 |
367 |
if (ro->clen > 0) { |
368 |
RMATRIX *res = rmx_transform(src, dst->ncomp, ro->cmat); |
369 |
if (!res) { |
370 |
fputs("Error in call to rmx_transform()\n", stderr); |
371 |
return(0); |
372 |
373 |
greg |
2.4 |
if (!rmx_transfer_data(dst, res, 0)) |
374 |
return(0); |
375 |
greg |
2.1 |
rmx_free(res); |
376 |
} else if (dst != src) |
377 |
memcpy(dst->mtx, src->mtx, |
378 |
sizeof(double)*dst->ncomp*dst->ncols*dst->nrows); |
379 |
if (ro->nsf == dst->ncomp) |
380 |
rmx_scale(dst, ro->sca); |
381 |
return(1); |
382 |
383 |
384 |
static int |
385 |
open_input(ROPMAT *rop) |
386 |
387 |
int outtype; |
388 |
389 |
if (!rop || !rop->inspec || !rop->inspec[0]) |
390 |
return(0); |
391 |
if (rop->inspec == stdin_name) |
392 |
rop->infp = stdin; |
393 |
else if (rop->inspec[0] == '!') |
394 |
rop->infp = popen(rop->inspec+1, "r"); |
395 |
else |
396 |
rop->infp = fopen(rop->inspec, "rb"); |
397 |
398 |
if (!rmx_load_header(&rop->imx, rop->infp)) { |
399 |
fprintf(stderr, "Bad header from: %s\n", rop->inspec); |
400 |
return(0); |
401 |
402 |
return(get_component_xfm(rop)); |
403 |
404 |
405 |
/* Return nominal wavelength associated with input component (return nm) */ |
406 |
static double |
407 |
l_wavelength(char *nam) |
408 |
409 |
double comp = argument(1); |
410 |
411 |
if ((comp < -.5) | (comp >= in_ncomp+.5)) { |
412 |
errno = EDOM; |
413 |
return(.0); |
414 |
415 |
if (comp < .5) /* asking for #components? */ |
416 |
return(in_ncomp); |
417 |
418 |
if (in_ncomp == 3) { /* special case for RGB */ |
419 |
const int w0 = (int)(comp - .5); |
420 |
return(mop[0].rmp->wlpart[w0] + |
421 |
(comp-.5)*(mop[0].rmp->wlpart[w0+1] - |
422 |
mop[0].rmp->wlpart[w0])); |
423 |
424 |
return(mop[0].rmp->wlpart[0] + /* general case, even div. */ |
425 |
(comp-.5)/(double)in_ncomp * |
426 |
(mop[0].rmp->wlpart[3] - mop[0].rmp->wlpart[0])); |
427 |
428 |
429 |
/* Return ith input with optional channel selector */ |
430 |
static double |
431 |
l_chanin(char *nam) |
432 |
433 |
double inp = argument(1); |
434 |
int mi, chan; |
435 |
436 |
if ((mi = (int)(inp-.5)) < 0 || mi >= nmats) { |
437 |
errno = EDOM; |
438 |
return(.0); |
439 |
440 |
greg |
2.2 |
if (inp < .5) /* asking for #inputs? */ |
441 |
greg |
2.1 |
return(nmats); |
442 |
443 |
if (nargum() >= 2) { |
444 |
double cval = argument(2); |
445 |
if (cval < .5 || (chan = (int)(cval-.5)) >= in_ncomp) { |
446 |
errno = EDOM; |
447 |
return(.0); |
448 |
449 |
} else |
450 |
chan = cur_chan; |
451 |
452 |
return(mop[mi].rmp->mtx[cur_col*in_ncomp + chan]); |
453 |
454 |
455 |
static int |
456 |
initialize(RMATRIX *imp) |
457 |
458 |
int i; |
459 |
/* XXX struct is zeroed coming in */ |
460 |
setcolor(imp->cexp, 1.f, 1.f, 1.f); |
461 |
for (i = 0; i < nmats; i++) { /* open each input */ |
462 |
int restype; |
463 |
if (!open_input(&mop[i])) |
464 |
return(0); |
465 |
restype = mop[i].rmp->dtype; |
466 |
if (!imp->dtype || (restype = rmx_newtype(restype, imp->dtype)) > 0) |
467 |
imp->dtype = restype; |
468 |
else |
469 |
fprintf(stderr, "%s: warning - data type mismatch\n", |
470 |
mop[i].inspec); |
471 |
if (!i) { |
472 |
imp->nrows = in_nrows = mop[0].rmp->nrows; |
473 |
imp->ncols = mop[0].rmp->ncols; |
474 |
imp->ncomp = mop[0].rmp->ncomp; |
475 |
memcpy(imp->wlpart, mop[0].rmp->wlpart, sizeof(imp->wlpart)); |
476 |
} else if ((mop[i].rmp->nrows != imp->nrows) | |
477 |
(mop[i].rmp->ncols != imp->ncols) | |
478 |
(mop[i].rmp->ncomp != imp->ncomp)) { |
479 |
fprintf(stderr, "%s: mismatch in size or #components\n", |
480 |
mop[i].inspec); |
481 |
return(0); |
482 |
} /* XXX should check wlpart? */ |
483 |
} /* set up .cal environment */ |
484 |
esupport |= E_VARIABLE|E_FUNCTION|E_RCONST; |
485 |
esupport &= ~(E_OUTCHAN|E_INCHAN); |
486 |
varset("PI", ':', M_PI); |
487 |
varset("nfiles", ':', nmats); |
488 |
varset("nrows", ':', in_nrows); |
489 |
varset("ncols", ':', in_ncols); |
490 |
varset("ncomp", ':', in_ncomp); |
491 |
varset("R", ':', 1.); |
492 |
varset("G", ':', 2.); |
493 |
varset("B", ':', 3.); |
494 |
funset("wl", 1, ':', l_wavelength); |
495 |
funset("ci", 1, '=', l_chanin); |
496 |
scompile("ri(i)=ci(i,R);gi(i)=ci(i,G);bi(i)=ci(i,B)", NULL, 0); |
497 |
return(1); |
498 |
499 |
500 |
static void |
501 |
output_headinfo(FILE *fp) |
502 |
503 |
int i; |
504 |
505 |
for (i = 0; i < nmats; i++) { |
506 |
const char *cp = mop[i].imx.info; |
507 |
fputs(mop[i].inspec, fp); |
508 |
fputs(":\n", fp); |
509 |
if (!cp) continue; |
510 |
while (*cp) { |
511 |
if (*cp == '\n') { |
512 |
cp++; /* avoid inadvertant terminus */ |
513 |
continue; |
514 |
515 |
fputc('\t', fp); /* indent this input's info */ |
516 |
do |
517 |
putc(*cp, fp); |
518 |
while (*cp++ != '\n'); |
519 |
520 |
521 |
522 |
523 |
static int |
524 |
combine_input(ROPMAT *res, FILE *fout) |
525 |
526 |
greg |
2.2 |
int set_r, set_c; |
527 |
greg |
2.1 |
RMATRIX *tmp = NULL; |
528 |
int co_set; |
529 |
int i; |
530 |
/* allocate input row buffers */ |
531 |
532 |
mop[i].imx.nrows = 1; /* we'll be doing a row at a time */ |
533 |
if (!rmx_prepare(&mop[i].imx)) |
534 |
goto memerror; |
535 |
if (mop[i].rmp != &mop[i].imx) { |
536 |
mop[i].rmp->nrows = 1; |
537 |
if (!rmx_prepare(mop[i].rmp)) |
538 |
goto memerror; |
539 |
540 |
541 |
/* prep output row buffers */ |
542 |
if (mcat || res->preop.clen > 0) { |
543 |
if (!split_input(res)) /* need separate buffer */ |
544 |
return(0); |
545 |
if (res->preop.clen > 0) |
546 |
res->rmp->ncomp = res->preop.clen / res->imx.ncomp; |
547 |
res->rmp->nrows = 1; |
548 |
if (!mcat | !mcat_last && !rmx_prepare(res->rmp)) |
549 |
goto memerror; |
550 |
551 |
if (mcat && mcat_last && |
552 |
greg |
2.3 |
!(tmp = rmx_alloc(1, res->imx.ncols, res->rmp->ncomp))) |
553 |
greg |
2.1 |
goto memerror; |
554 |
res->imx.nrows = 1; |
555 |
if (!rmx_prepare(&res->imx)) |
556 |
goto memerror; |
557 |
/* figure out what the user set */ |
558 |
co_set = fundefined("co"); |
559 |
if (!co_set) |
560 |
co_set = -vardefined("co"); |
561 |
if (!co_set & (in_ncomp == 3) && vardefined("ro") && |
562 |
vardefined("go") && vardefined("bo")) { |
563 |
scompile("co(p)=select(p,ro,go,bo)", NULL, 0); |
564 |
co_set = 1; |
565 |
566 |
greg |
2.6 |
if (co_set) { /* set if user wants, didn't set */ |
567 |
set_r = varlookup("r") != NULL && !vardefined("r"); |
568 |
set_c = varlookup("c") != NULL && !vardefined("c"); |
569 |
greg |
2.2 |
} else /* save a little time */ |
570 |
set_r = set_c = 0; |
571 |
greg |
2.1 |
/* read/process row-by-row */ |
572 |
for (cur_row = 0; cur_row < in_nrows; cur_row++) { |
573 |
RMATRIX *mres = NULL; |
574 |
575 |
greg |
2.2 |
if (!rmx_load_row(mop[i].imx.mtx, &mop[i].imx, mop[i].infp)) { |
576 |
fprintf(stderr, "%s: read error at row %d\n", |
577 |
mop[i].inspec, cur_row); |
578 |
greg |
2.1 |
return(0); |
579 |
greg |
2.2 |
580 |
greg |
2.1 |
if (!apply_op(mop[i].rmp, &mop[i].imx, &mop[i].preop)) |
581 |
return(0); |
582 |
583 |
greg |
2.2 |
if (set_r) varset("r", '=', cur_row); |
584 |
greg |
2.1 |
for (cur_col = 0; cur_col < in_ncols; cur_col++) { |
585 |
greg |
2.2 |
if (set_c) varset("c", '=', cur_col); |
586 |
greg |
2.1 |
for (cur_chan = 0; cur_chan < in_ncomp; cur_chan++) { |
587 |
const int ndx = cur_col*in_ncomp + cur_chan; |
588 |
eclock++; |
589 |
if (!co_set) { /* just summing elements? */ |
590 |
res->imx.mtx[ndx] = 0; |
591 |
for (i = nmats; i--; ) |
592 |
res->imx.mtx[ndx] += mop[i].rmp->mtx[ndx]; |
593 |
} else if (co_set > 0) { |
594 |
greg |
2.2 |
double dchan = cur_chan+1; |
595 |
greg |
2.1 |
res->imx.mtx[ndx] = funvalue("co", 1, &dchan); |
596 |
} else |
597 |
res->imx.mtx[ndx] = varvalue("co"); |
598 |
599 |
} /* final conversions */ |
600 |
if (!mcat) { |
601 |
if (!apply_op(res->rmp, &res->imx, &res->preop)) |
602 |
return(0); |
603 |
} else if (mcat_last) { |
604 |
if (!apply_op(tmp, &res->imx, &res->preop)) |
605 |
return(0); |
606 |
mres = rmx_multiply(tmp, mcat); |
607 |
if (!mres) |
608 |
goto multerror; |
609 |
greg |
2.4 |
if (!rmx_transfer_data(res->rmp, mres, 0)) |
610 |
return(0); |
611 |
greg |
2.1 |
} else /* mcat && !mcat_last */ { |
612 |
mres = rmx_multiply(&res->imx, mcat); |
613 |
if (!mres) |
614 |
goto multerror; |
615 |
if (!apply_op(res->rmp, mres, &res->preop)) |
616 |
return(0); |
617 |
618 |
rmx_free(mres); mres = NULL; |
619 |
if (!rmx_write_data(res->rmp->mtx, res->rmp->ncomp, |
620 |
res->rmp->ncols, res->rmp->dtype, fout)) |
621 |
return(0); |
622 |
623 |
greg |
2.2 |
#if 0 /* we're about to exit, so who cares? */ |
624 |
greg |
2.1 |
rmx_free(tmp); /* clean up */ |
625 |
greg |
2.2 |
rmx_reset(res->rmp); |
626 |
rmx_reset(&res->imx); |
627 |
628 |
rmx_reset(mop[i].rmp); |
629 |
rmx_reset(&mop[i].imx); |
630 |
if (mop[i].inspec[0] == '!') |
631 |
pclose(mop[i].infp); |
632 |
else if (mop[i].inspec != stdin_name) |
633 |
fclose(mop[i].infp); |
634 |
mop[i].infp = NULL; |
635 |
greg |
2.1 |
636 |
greg |
2.2 |
#endif |
637 |
return(fflush(fout) != EOF); |
638 |
greg |
2.1 |
memerror: |
639 |
fputs("Out of buffer space in combine_input()\n", stderr); |
640 |
return(0); |
641 |
multerror: |
642 |
fputs("Unexpected matrix multiply error in combine_input()\n", stderr); |
643 |
return(0); |
644 |
645 |
646 |
static int |
647 |
get_factors(double da[], int n, char *av[]) |
648 |
649 |
int ac; |
650 |
651 |
for (ac = 0; ac < n && isflt(av[ac]); ac++) |
652 |
da[ac] = atof(av[ac]); |
653 |
return(ac); |
654 |
655 |
656 |
static void |
657 |
resize_inparr(int n2alloc) |
658 |
659 |
int i; |
660 |
661 |
for (i = nmats; i > n2alloc; i--) { |
662 |
663 |
if (mop[i].rmp != &mop[i].imx) |
664 |
rmx_free(mop[i].rmp); |
665 |
666 |
mop = (ROPMAT *)realloc(mop, n2alloc*sizeof(ROPMAT)); |
667 |
if (mop == NULL) { |
668 |
fputs("Out of memory in resize_inparr()\n", stderr); |
669 |
exit(1); |
670 |
671 |
if (n2alloc > nmats) |
672 |
memset(mop+nmats, 0, (n2alloc-nmats)*sizeof(ROPMAT)); |
673 |
nall = n2alloc; |
674 |
675 |
676 |
/* Load one or more matrices and operate on them, sending results to stdout */ |
677 |
int |
678 |
main(int argc, char *argv[]) |
679 |
680 |
681 |
int outfmt = DTfromHeader; |
682 |
const char *defCsym = NULL; |
683 |
int echoheader = 1; |
684 |
int stdin_used = 0; |
685 |
const char *mcat_spec = NULL; |
686 |
int n2comp = 0; |
687 |
uby8 comp_ndx[128]; |
688 |
int i; |
689 |
/* get starting input array */ |
690 |
mop = (ROPMAT *)calloc(nall=2, sizeof(ROPMAT)); |
691 |
/* get options and arguments */ |
692 |
for (i = 1; i < argc; i++) |
693 |
if (argv[i][0] != '-' || !argv[i][1]) { |
694 |
if (argv[i][0] == '-') { |
695 |
if (stdin_used++) goto stdin_error; |
696 |
mop[nmats].inspec = stdin_name; |
697 |
} else |
698 |
mop[nmats].inspec = argv[i]; |
699 |
if (!mop[nmats].preop.csym) |
700 |
mop[nmats].preop.csym = defCsym; |
701 |
if (++nmats >= nall) |
702 |
resize_inparr(nmats + (nmats>>2) + 2); |
703 |
} else { |
704 |
int n = argc-1 - i; |
705 |
switch (argv[i][1]) { /* get option */ |
706 |
case 'w': |
707 |
nowarn = !nowarn; |
708 |
break; |
709 |
case 'h': |
710 |
echoheader = !echoheader; |
711 |
break; |
712 |
case 'e': |
713 |
if (!n) goto userr; |
714 |
comp_ndx[n2comp++] = i++; |
715 |
break; |
716 |
case 'f': |
717 |
switch (argv[i][2]) { |
718 |
case '\0': |
719 |
720 |
721 |
break; |
722 |
case 'd': |
723 |
outfmt = DTdouble; |
724 |
break; |
725 |
case 'f': |
726 |
outfmt = DTfloat; |
727 |
break; |
728 |
case 'a': |
729 |
outfmt = DTascii; |
730 |
break; |
731 |
case 'c': |
732 |
outfmt = DTrgbe; |
733 |
break; |
734 |
default: |
735 |
goto userr; |
736 |
737 |
break; |
738 |
case 's': |
739 |
if (n > MAXCOMP) n = MAXCOMP; |
740 |
i += mop[nmats].preop.nsf = |
741 |
get_factors(mop[nmats].preop.sca, |
742 |
n, argv+i+1); |
743 |
if (mop[nmats].preop.nsf <= 0) { |
744 |
fprintf(stderr, "%s: -s missing arguments\n", |
745 |
argv[0]); |
746 |
goto userr; |
747 |
748 |
break; |
749 |
case 'C': |
750 |
if (!n || isflt(argv[i+1])) |
751 |
goto userr; |
752 |
defCsym = mop[nmats].preop.csym = argv[++i]; |
753 |
mop[nmats].preop.clen = 0; |
754 |
mcat_last = 0; |
755 |
break; |
756 |
case 'c': |
757 |
if (n && !isflt(argv[i+1])) { |
758 |
759 |
760 |
break; |
761 |
762 |
if (n > MAXCOMP*MAXCOMP) n = MAXCOMP*MAXCOMP; |
763 |
i += mop[nmats].preop.clen = |
764 |
get_factors(mop[nmats].preop.cmat, |
765 |
n, argv+i+1); |
766 |
if (mop[nmats].preop.clen <= 0) { |
767 |
fprintf(stderr, "%s: -c missing arguments\n", |
768 |
argv[0]); |
769 |
goto userr; |
770 |
771 |
mop[nmats].preop.csym = NULL; |
772 |
mcat_last = 0; |
773 |
break; |
774 |
case 'm': |
775 |
776 |
if (argv[++i][0] == '-' && !argv[i][1]) { |
777 |
778 |
mcat_spec = stdin_name; |
779 |
} else |
780 |
mcat_spec = argv[i]; |
781 |
mcat_last = 1; |
782 |
break; |
783 |
default: |
784 |
fprintf(stderr, "%s: unknown option '%s'\n", |
785 |
argv[0], argv[i]); |
786 |
goto userr; |
787 |
788 |
789 |
if (!nmats) { |
790 |
fprintf(stderr, "%s: need at least one input matrix\n", argv[0]); |
791 |
goto userr; |
792 |
793 |
resize_inparr(nmats+1); /* extra matrix at end for result */ |
794 |
mop[nmats].inspec = "trailing_ops"; |
795 |
/* load final concatenation matrix */ |
796 |
if (mcat_spec && !(mcat = rmx_load(mcat_spec, RMPnone))) { |
797 |
greg |
2.3 |
fprintf(stderr, "%s: error loading concatenation matrix: %s\n", |
798 |
greg |
2.1 |
argv[0], mcat_spec); |
799 |
return(1); |
800 |
801 |
/* get/check inputs, set constants */ |
802 |
if (!initialize(&mop[nmats].imx)) |
803 |
return(1); |
804 |
805 |
for (i = 0; i < n2comp; i++) /* user .cal files and expressions */ |
806 |
if (argv[comp_ndx[i]][1] == 'f') { |
807 |
char *fpath = getpath(argv[comp_ndx[i]+1], |
808 |
getrlibpath(), 0); |
809 |
if (fpath == NULL) { |
810 |
fprintf(stderr, "%s: cannot find file '%s'\n", |
811 |
argv[0], argv[comp_ndx[i]+1]); |
812 |
return(1); |
813 |
814 |
fcompile(fpath); |
815 |
} else /* (argv[comp_ndx[i]][1] == 'e') */ |
816 |
scompile(argv[comp_ndx[i]+1], NULL, 0); |
817 |
818 |
/* get trailing color transform */ |
819 |
if (!get_component_xfm(&mop[nmats])) |
820 |
return(1); |
821 |
/* adjust output dimensions and #components */ |
822 |
if (mcat) { |
823 |
if (mop[nmats].imx.ncols != mcat->nrows) { |
824 |
fprintf(stderr, |
825 |
"%s: number of input columns does not match number of rows in '%s'\n", |
826 |
827 |
return(1); |
828 |
829 |
if (mcat->ncomp != (mcat_last ? mop[nmats].rmp->ncomp : mop[nmats].imx.ncomp)) { |
830 |
fprintf(stderr, |
831 |
"%s: number of components does not match those in '%s'\n", |
832 |
833 |
return(1); |
834 |
835 |
greg |
2.3 |
if (!split_input(&mop[nmats])) |
836 |
return(1); |
837 |
greg |
2.1 |
mop[nmats].rmp->ncols = mcat->ncols; |
838 |
839 |
greg |
2.2 |
newheader("RADIANCE", stdout); /* write output header */ |
840 |
greg |
2.1 |
if (echoheader) |
841 |
output_headinfo(stdout); |
842 |
printargs(argc, argv, stdout); |
843 |
fputnow(stdout); |
844 |
greg |
2.2 |
mop[nmats].rmp->dtype = rmx_write_header(mop[nmats].rmp, outfmt, stdout); |
845 |
if (!mop[nmats].rmp->dtype) { |
846 |
fprintf(stderr, "%s: unsupported output format\n", argv[0]); |
847 |
greg |
2.1 |
return(1); |
848 |
849 |
/* process & write rows */ |
850 |
return(combine_input(&mop[nmats], stdout) ? 0 : 1); |
851 |
stdin_error: |
852 |
fprintf(stderr, "%s: %s used for more than one input\n", |
853 |
argv[0], stdin_name); |
854 |
return(1); |
855 |
userr: |
856 |
fprintf(stderr, |
857 |
"Usage: %s [-h][-f{adfc}][-e expr][-f file][-s sf .. | -c ce ..] m1 .. -m mcat > mres\n", |
858 |
argv[0]); |
859 |
return(1); |
860 |
