root/radiance/ray/src/util/rmatrix.h
Revision: 2.27
Committed: Fri Apr 18 23:59:03 2025 UTC (4 weeks, 2 days ago) by greg
Changes since 2.26: +2 -6 lines
# User Rev Content
1 greg 2.27 /* RCSid $Id: rmatrix.h,v 2.26 2025/04/04 18:06:48 greg Exp $ */
2 greg 2.1 /*
3     * Header file for general matrix routines.
4     */
5
6     #ifndef _RAD_RMATRIX_H_
7     #define _RAD_RMATRIX_H_
8
9     #include "cmatrix.h"
10
11     #ifdef __cplusplus
12     extern "C" {
13     #endif
14
15 greg 2.23 /* RMATRIX flags (usually private):
16     need to swap input, we should free memory */
17 greg 2.21 #define RMF_SWAPIN 1
18 greg 2.23 #define RMF_FREEMEM 2
19 greg 2.21
20 greg 2.26 #ifndef MAXCOMP
21     #define MAXCOMP MAXCSAMP /* #components we support */
22     #endif
23     /* Set in-core data type */
24     #if !defined(DTrmx_native) || DTrmx_native==DTfloat
25     #define DTrmx_native DTfloat
26     #define rmx_dtype float
27     #define rmx_scanfmt "%f"
28     #elif DTrmx_native==DTdouble
29 greg 2.24 #define rmx_dtype double
30 greg 2.26 #define rmx_scanfmt "%lf"
31     #endif
32 greg 2.22
33 greg 2.14 /* General [row][col][cmp] component matrix */
34 greg 2.1 typedef struct {
35 greg 2.24 char *info;
36     void *mapped;
37     rmx_dtype *mtx;
38     COLOR cexp;
39     float wlpart[4];
40     int nrows, ncols;
41     short ncomp;
42     uby8 dtype;
43     uby8 pflags;
44 greg 2.1 } RMATRIX;
45
46 greg 2.15 #define rmx_lval(rm,r,c) ((rm)->mtx + (rm)->ncomp*((c)+(size_t)(rm)->ncols*(r)))
47 greg 2.17 #define rmx_val rmx_lval
48 greg 2.1
49 greg 2.24 #define rmx_array_size(rm) (sizeof(rmx_dtype)*(rm)->nrows*(rm)->ncols*(rm)->ncomp)
50 greg 2.21 #define rmx_mapped_size(rm) ((char *)(rm)->mtx + rmx_array_size(rm) - (char *)(rm)->mapped)
51
52 greg 2.14 /* Initialize a RMATRIX struct but don't allocate array space */
53     extern RMATRIX *rmx_new(int nr, int nc, int n);
54
55     /* Prepare a RMATRIX for writing (allocate array if needed) */
56     extern int rmx_prepare(RMATRIX *rm);
57
58     /* Call rmx_new() and rmx_prepare() */
59 greg 2.1 extern RMATRIX *rmx_alloc(int nr, int nc, int n);
60
61 greg 2.19 /* Clear state by freeing info and matrix data */
62     extern void rmx_reset(RMATRIX *rm);
63
64     /* Free an RMATRIX struct and data */
65 greg 2.4 extern void rmx_free(RMATRIX *rm);
66
67     /* Resolve data type based on two input types (returns 0 for mismatch) */
68     extern int rmx_newtype(int dtyp1, int dtyp2);
69
70 greg 2.17 /* Read matrix header from input stream (cannot be XML) */
71     extern int rmx_load_header(RMATRIX *rm, FILE *fp);
72
73 greg 2.24 /* Load next row as rmx_dtype (cannot be XML) */
74     extern int rmx_load_row(rmx_dtype *drp, const RMATRIX *rm, FILE *fp);
75 greg 2.18
76 greg 2.17 /* Allocate & load post-header data from stream given type set in rm->dtype */
77     extern int rmx_load_data(RMATRIX *rm, FILE *fp);
78
79 greg 2.7 /* Load matrix from supported file type (NULL for stdin, '!' with command) */
80 greg 2.27 extern RMATRIX *rmx_load(const char *inspec);
81 greg 2.1
82 greg 2.3 /* Append header information associated with matrix data */
83     extern int rmx_addinfo(RMATRIX *rm, const char *info);
84
85 greg 2.19 /* Finish writing header data with resolution and format, returning type used */
86     extern int rmx_write_header(const RMATRIX *rm, int dtype, FILE *fp);
87
88     /* Write out matrix data (usually by row) */
89 greg 2.24 extern int rmx_write_data(const rmx_dtype *dp, int nc, int len,
90 greg 2.19 int dtype, FILE *fp);
91
92     /* Write matrix using file format indicated by dtype */
93 greg 2.6 extern int rmx_write(const RMATRIX *rm, int dtype, FILE *fp);
94 greg 2.1
95     /* Allocate and assign square identity matrix with n components */
96     extern RMATRIX *rmx_identity(int dim, int n);
97
98     /* Duplicate the given matrix */
99     extern RMATRIX *rmx_copy(const RMATRIX *rm);
100
101 greg 2.20 /* Replace data in first matrix with data from second */
102     extern int rmx_transfer_data(RMATRIX *rdst, RMATRIX *rsrc, int dometa);
103
104 greg 2.25 /* Transpose the given matrix */
105     extern int rmx_transpose(RMATRIX *rm);
106 greg 2.1
107     /* Multiply (concatenate) two matrices and allocate the result */
108     extern RMATRIX *rmx_multiply(const RMATRIX *m1, const RMATRIX *m2);
109
110 greg 2.8 /* Element-wise multiplication (or division) of m2 into m1 */
111     extern int rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide);
112
113 greg 2.1 /* Sum second matrix into first, applying scale factor beforehand */
114     extern int rmx_sum(RMATRIX *msum, const RMATRIX *madd, const double sf[]);
115
116     /* Scale the given matrix by the indicated scalar component vector */
117     extern int rmx_scale(RMATRIX *rm, const double sf[]);
118
119     /* Allocate new matrix and apply component transformation */
120     extern RMATRIX *rmx_transform(const RMATRIX *msrc, int n, const double cmat[]);
121
122     /* Convert a color matrix to newly allocated RMATRIX buffer */
123     extern RMATRIX *rmx_from_cmatrix(const CMATRIX *cm);
124
125     /* Convert general matrix to newly allocated CMATRIX buffer */
126     extern CMATRIX *cm_from_rmatrix(const RMATRIX *rm);
127
128     #ifdef __cplusplus
129     }
130     #endif
131     #endif /* _RAD_RMATRIX_H_ */
