| 1 |
/* RCSid $Id: rmatrix.h,v 2.3 2014/08/01 23:37:24 greg Exp $ */
| 2 |
| 3 |
* Header file for general matrix routines.
| 4 |
| 5 |
| 6 |
#ifndef _RAD_RMATRIX_H_
| 7 |
#define _RAD_RMATRIX_H_
| 8 |
| 9 |
#include "cmatrix.h"
| 10 |
| 11 |
#ifdef __cplusplus
| 12 |
extern "C" {
| 13 |
#endif
| 14 |
| 15 |
/* General plane-ordered component matrix */
| 16 |
typedef struct {
| 17 |
int nrows, ncols, ncomp;
| 18 |
int dtype;
| 19 |
char *info;
| 20 |
double mtx[1]; /* extends struct */
| 21 |
} RMATRIX;
| 22 |
| 23 |
#define rmx_lval(rm,r,c,i) (rm)->mtx[((i)*(rm)->nrows+(r))*(rm)->ncols+(c)]
| 24 |
| 25 |
/* Allocate a nr x nc matrix with n components */
| 26 |
extern RMATRIX *rmx_alloc(int nr, int nc, int n);
| 27 |
| 28 |
/* Free a RMATRIX array */
| 29 |
extern void rmx_free(RMATRIX *rm);
| 30 |
| 31 |
/* Resolve data type based on two input types (returns 0 for mismatch) */
| 32 |
extern int rmx_newtype(int dtyp1, int dtyp2);
| 33 |
| 34 |
/* Load matrix from supported file type */
| 35 |
extern RMATRIX *rmx_load(const char *fname);
| 36 |
| 37 |
/* Append header information associated with matrix data */
| 38 |
extern int rmx_addinfo(RMATRIX *rm, const char *info);
| 39 |
| 40 |
/* Write matrix to file type indicated by dtype */
| 41 |
extern long rmx_write(const RMATRIX *rm, int dtype, FILE *fp);
| 42 |
| 43 |
/* Allocate and assign square identity matrix with n components */
| 44 |
extern RMATRIX *rmx_identity(int dim, int n);
| 45 |
| 46 |
/* Duplicate the given matrix */
| 47 |
extern RMATRIX *rmx_copy(const RMATRIX *rm);
| 48 |
| 49 |
/* Allocate and assign transposed matrix */
| 50 |
extern RMATRIX *rmx_transpose(const RMATRIX *rm);
| 51 |
| 52 |
/* Multiply (concatenate) two matrices and allocate the result */
| 53 |
extern RMATRIX *rmx_multiply(const RMATRIX *m1, const RMATRIX *m2);
| 54 |
| 55 |
/* Sum second matrix into first, applying scale factor beforehand */
| 56 |
extern int rmx_sum(RMATRIX *msum, const RMATRIX *madd, const double sf[]);
| 57 |
| 58 |
/* Scale the given matrix by the indicated scalar component vector */
| 59 |
extern int rmx_scale(RMATRIX *rm, const double sf[]);
| 60 |
| 61 |
/* Allocate new matrix and apply component transformation */
| 62 |
extern RMATRIX *rmx_transform(const RMATRIX *msrc, int n, const double cmat[]);
| 63 |
| 64 |
/* Convert a color matrix to newly allocated RMATRIX buffer */
| 65 |
extern RMATRIX *rmx_from_cmatrix(const CMATRIX *cm);
| 66 |
| 67 |
/* Convert general matrix to newly allocated CMATRIX buffer */
| 68 |
extern CMATRIX *cm_from_rmatrix(const RMATRIX *rm);
| 69 |
| 70 |
#ifdef __cplusplus
| 71 |
| 72 |
#endif
| 73 |
#endif /* _RAD_RMATRIX_H_ */
