root/Development/ray/src/util/rmatrix.h
Revision: 2.26
Committed: Fri Apr 4 18:06:48 2025 UTC (8 months, 4 weeks ago) by greg
Changes since 2.25: +12 -2 lines
1 /* RCSid $Id: rmatrix.h,v 2.25 2025/04/04 01:48:25 greg Exp $ */
2 /*
3 * Header file for general matrix routines.
4 */
5
6 #ifndef _RAD_RMATRIX_H_
7 #define _RAD_RMATRIX_H_
8
9 #include "cmatrix.h"
10
11 #ifdef __cplusplus
12 extern "C" {
13 #endif
14
15 /* Preferred BSDF component:
16 none, transmission, reflection front (normal side), reflection back */
17 typedef enum {RMPnone=-1, RMPtrans=0, RMPreflF, RMPreflB} RMPref;
18
19 /* RMATRIX flags (usually private):
20 need to swap input, we should free memory */
21 #define RMF_SWAPIN 1
22 #define RMF_FREEMEM 2
23
24 #ifndef MAXCOMP
25 #define MAXCOMP MAXCSAMP /* #components we support */
26 #endif
27 /* Set in-core data type */
28 #if !defined(DTrmx_native) || DTrmx_native==DTfloat
29 #define DTrmx_native DTfloat
30 #define rmx_dtype float
31 #define rmx_scanfmt "%f"
32 #elif DTrmx_native==DTdouble
33 #define rmx_dtype double
34 #define rmx_scanfmt "%lf"
35 #endif
36
37 /* General [row][col][cmp] component matrix */
38 typedef struct {
39 char *info;
40 void *mapped;
41 rmx_dtype *mtx;
42 COLOR cexp;
43 float wlpart[4];
44 int nrows, ncols;
45 short ncomp;
46 uby8 dtype;
47 uby8 pflags;
48 } RMATRIX;
49
50 #define rmx_lval(rm,r,c) ((rm)->mtx + (rm)->ncomp*((c)+(size_t)(rm)->ncols*(r)))
51 #define rmx_val rmx_lval
52
53 #define rmx_array_size(rm) (sizeof(rmx_dtype)*(rm)->nrows*(rm)->ncols*(rm)->ncomp)
54 #define rmx_mapped_size(rm) ((char *)(rm)->mtx + rmx_array_size(rm) - (char *)(rm)->mapped)
55
56 /* Initialize a RMATRIX struct but don't allocate array space */
57 extern RMATRIX *rmx_new(int nr, int nc, int n);
58
59 /* Prepare a RMATRIX for writing (allocate array if needed) */
60 extern int rmx_prepare(RMATRIX *rm);
61
62 /* Call rmx_new() and rmx_prepare() */
63 extern RMATRIX *rmx_alloc(int nr, int nc, int n);
64
65 /* Clear state by freeing info and matrix data */
66 extern void rmx_reset(RMATRIX *rm);
67
68 /* Free an RMATRIX struct and data */
69 extern void rmx_free(RMATRIX *rm);
70
71 /* Resolve data type based on two input types (returns 0 for mismatch) */
72 extern int rmx_newtype(int dtyp1, int dtyp2);
73
74 /* Read matrix header from input stream (cannot be XML) */
75 extern int rmx_load_header(RMATRIX *rm, FILE *fp);
76
77 /* Load next row as rmx_dtype (cannot be XML) */
78 extern int rmx_load_row(rmx_dtype *drp, const RMATRIX *rm, FILE *fp);
79
80 /* Allocate & load post-header data from stream given type set in rm->dtype */
81 extern int rmx_load_data(RMATRIX *rm, FILE *fp);
82
83 /* Load matrix from supported file type (NULL for stdin, '!' with command) */
84 extern RMATRIX *rmx_load(const char *inspec, RMPref rmp);
85
86 /* Append header information associated with matrix data */
87 extern int rmx_addinfo(RMATRIX *rm, const char *info);
88
89 /* Finish writing header data with resolution and format, returning type used */
90 extern int rmx_write_header(const RMATRIX *rm, int dtype, FILE *fp);
91
92 /* Write out matrix data (usually by row) */
93 extern int rmx_write_data(const rmx_dtype *dp, int nc, int len,
94 int dtype, FILE *fp);
95
96 /* Write matrix using file format indicated by dtype */
97 extern int rmx_write(const RMATRIX *rm, int dtype, FILE *fp);
98
99 /* Allocate and assign square identity matrix with n components */
100 extern RMATRIX *rmx_identity(int dim, int n);
101
102 /* Duplicate the given matrix */
103 extern RMATRIX *rmx_copy(const RMATRIX *rm);
104
105 /* Replace data in first matrix with data from second */
106 extern int rmx_transfer_data(RMATRIX *rdst, RMATRIX *rsrc, int dometa);
107
108 /* Transpose the given matrix */
109 extern int rmx_transpose(RMATRIX *rm);
110
111 /* Multiply (concatenate) two matrices and allocate the result */
112 extern RMATRIX *rmx_multiply(const RMATRIX *m1, const RMATRIX *m2);
113
114 /* Element-wise multiplication (or division) of m2 into m1 */
115 extern int rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide);
116
117 /* Sum second matrix into first, applying scale factor beforehand */
118 extern int rmx_sum(RMATRIX *msum, const RMATRIX *madd, const double sf[]);
119
120 /* Scale the given matrix by the indicated scalar component vector */
121 extern int rmx_scale(RMATRIX *rm, const double sf[]);
122
123 /* Allocate new matrix and apply component transformation */
124 extern RMATRIX *rmx_transform(const RMATRIX *msrc, int n, const double cmat[]);
125
126 /* Convert a color matrix to newly allocated RMATRIX buffer */
127 extern RMATRIX *rmx_from_cmatrix(const CMATRIX *cm);
128
129 /* Convert general matrix to newly allocated CMATRIX buffer */
130 extern CMATRIX *cm_from_rmatrix(const RMATRIX *rm);
131
132 #ifdef __cplusplus
133 }
134 #endif
135 #endif /* _RAD_RMATRIX_H_ */
