root/Development/ray/src/util/rmatrix.h
Revision: 2.2
Committed: Sat May 31 19:21:21 2014 UTC (11 years, 7 months ago) by greg
CVS Tags: rad4R2
Changes since 2.1: +4 -6 lines
Bug fixes
1 /* RCSid $Id: rmatrix.h,v 2.1 2014/05/31 05:02:37 greg Exp $ */
2 /*
3 * Header file for general matrix routines.
4 */
5
6 #ifndef _RAD_RMATRIX_H_
7 #define _RAD_RMATRIX_H_
8
9 #include "cmatrix.h"
10
11 #ifdef __cplusplus
12 extern "C" {
13 #endif
14
15 /* General plane-ordered component matrix */
16 typedef struct {
17 int nrows, ncols, ncomp;
18 double mtx[1]; /* extends struct */
19 } RMATRIX;
20
21 #define rmx_lval(rm,r,c,i) (rm)->mtx[((i)*(rm)->nrows+(r))*(rm)->ncols+(c)]
22
23 #define rmx_free(rm) free(rm)
24
25 /* Allocate a nr x nc matrix with n components */
26 extern RMATRIX *rmx_alloc(int nr, int nc, int n);
27
28 /* Load matrix from supported file type */
29 extern RMATRIX *rmx_load(const char *fname);
30
31 /* Write matrix to file type indicated by dt */
32 extern long rmx_write(const RMATRIX *rm, int dtype, FILE *fp);
33
34 /* Allocate and assign square identity matrix with n components */
35 extern RMATRIX *rmx_identity(int dim, int n);
36
37 /* Duplicate the given matrix */
38 extern RMATRIX *rmx_copy(const RMATRIX *rm);
39
40 /* Allocate and assign transposed matrix */
41 extern RMATRIX *rmx_transpose(const RMATRIX *rm);
42
43 /* Multiply (concatenate) two matrices and allocate the result */
44 extern RMATRIX *rmx_multiply(const RMATRIX *m1, const RMATRIX *m2);
45
46 /* Sum second matrix into first, applying scale factor beforehand */
47 extern int rmx_sum(RMATRIX *msum, const RMATRIX *madd, const double sf[]);
48
49 /* Scale the given matrix by the indicated scalar component vector */
50 extern int rmx_scale(RMATRIX *rm, const double sf[]);
51
52 /* Allocate new matrix and apply component transformation */
53 extern RMATRIX *rmx_transform(const RMATRIX *msrc, int n, const double cmat[]);
54
55 /* Convert a color matrix to newly allocated RMATRIX buffer */
56 extern RMATRIX *rmx_from_cmatrix(const CMATRIX *cm);
57
58 /* Convert general matrix to newly allocated CMATRIX buffer */
59 extern CMATRIX *cm_from_rmatrix(const RMATRIX *rm);
60
61 #ifdef __cplusplus
62 }
63 #endif
64 #endif /* _RAD_RMATRIX_H_ */
