root/radiance/ray/src/util/rmatrix.h
Revision: 2.16
Committed: Tue Nov 21 01:30:20 2023 UTC (5 months ago) by greg
Changes since 2.15: +2 -1 lines
1 /* RCSid $Id: rmatrix.h,v 2.15 2022/03/05 01:45:21 greg Exp $ */
2 /*
3 * Header file for general matrix routines.
4 */
5
6 #ifndef _RAD_RMATRIX_H_
7 #define _RAD_RMATRIX_H_
8
9 #include "cmatrix.h"
10
11 #ifdef __cplusplus
12 extern "C" {
13 #endif
14
15 /* Preferred BSDF component:
16 transmission, reflection front (normal side), reflection back */
17 typedef enum {RMPtrans=0, RMPreflF, RMPreflB} RMPref;
18
19 /* General [row][col][cmp] component matrix */
20 typedef struct {
21 char *info;
22 void *mapped;
23 double *mtx;
24 COLOR cexp;
25 float wlpart[4];
26 int nrows, ncols;
27 short ncomp;
28 uby8 dtype;
29 uby8 swapin;
30 } RMATRIX;
31
32 #define rmx_lval(rm,r,c) ((rm)->mtx + (rm)->ncomp*((c)+(size_t)(rm)->ncols*(r)))
33
34 /* Initialize a RMATRIX struct but don't allocate array space */
35 extern RMATRIX *rmx_new(int nr, int nc, int n);
36
37 /* Prepare a RMATRIX for writing (allocate array if needed) */
38 extern int rmx_prepare(RMATRIX *rm);
39
40 /* Call rmx_new() and rmx_prepare() */
41 extern RMATRIX *rmx_alloc(int nr, int nc, int n);
42
43 /* Free a RMATRIX array */
44 extern void rmx_free(RMATRIX *rm);
45
46 /* Resolve data type based on two input types (returns 0 for mismatch) */
47 extern int rmx_newtype(int dtyp1, int dtyp2);
48
49 /* Load matrix from supported file type (NULL for stdin, '!' with command) */
50 extern RMATRIX *rmx_load(const char *inspec, RMPref rmp);
51
52 /* Append header information associated with matrix data */
53 extern int rmx_addinfo(RMATRIX *rm, const char *info);
54
55 /* Write matrix to file type indicated by dtype */
56 extern int rmx_write(const RMATRIX *rm, int dtype, FILE *fp);
57
58 /* Allocate and assign square identity matrix with n components */
59 extern RMATRIX *rmx_identity(int dim, int n);
60
61 /* Duplicate the given matrix */
62 extern RMATRIX *rmx_copy(const RMATRIX *rm);
63
64 /* Allocate and assign transposed matrix */
65 extern RMATRIX *rmx_transpose(const RMATRIX *rm);
66
67 /* Multiply (concatenate) two matrices and allocate the result */
68 extern RMATRIX *rmx_multiply(const RMATRIX *m1, const RMATRIX *m2);
69
70 /* Element-wise multiplication (or division) of m2 into m1 */
71 extern int rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide);
72
73 /* Sum second matrix into first, applying scale factor beforehand */
74 extern int rmx_sum(RMATRIX *msum, const RMATRIX *madd, const double sf[]);
75
76 /* Scale the given matrix by the indicated scalar component vector */
77 extern int rmx_scale(RMATRIX *rm, const double sf[]);
78
79 /* Allocate new matrix and apply component transformation */
80 extern RMATRIX *rmx_transform(const RMATRIX *msrc, int n, const double cmat[]);
81
82 /* Convert a color matrix to newly allocated RMATRIX buffer */
83 extern RMATRIX *rmx_from_cmatrix(const CMATRIX *cm);
84
85 /* Convert general matrix to newly allocated CMATRIX buffer */
86 extern CMATRIX *cm_from_rmatrix(const RMATRIX *rm);
87
88 #ifdef __cplusplus
89 }
90 #endif
91 #endif /* _RAD_RMATRIX_H_ */
