1 |
/* RCSid $Id: rmatrix.h,v 2.15 2022/03/05 01:45:21 greg Exp $ */ |
2 |
3 |
* Header file for general matrix routines. |
4 |
5 |
6 |
#ifndef _RAD_RMATRIX_H_ |
7 |
#define _RAD_RMATRIX_H_ |
8 |
9 |
#include "cmatrix.h" |
10 |
11 |
#ifdef __cplusplus |
12 |
extern "C" { |
13 |
#endif |
14 |
15 |
/* Preferred BSDF component: |
16 |
transmission, reflection front (normal side), reflection back */ |
17 |
typedef enum {RMPtrans=0, RMPreflF, RMPreflB} RMPref; |
18 |
19 |
/* General [row][col][cmp] component matrix */ |
20 |
typedef struct { |
21 |
char *info; |
22 |
void *mapped; |
23 |
double *mtx; |
24 |
COLOR cexp; |
25 |
float wlpart[4]; |
26 |
int nrows, ncols; |
27 |
short ncomp; |
28 |
uby8 dtype; |
29 |
uby8 swapin; |
30 |
} RMATRIX; |
31 |
32 |
#define rmx_lval(rm,r,c) ((rm)->mtx + (rm)->ncomp*((c)+(size_t)(rm)->ncols*(r))) |
33 |
34 |
/* Initialize a RMATRIX struct but don't allocate array space */ |
35 |
extern RMATRIX *rmx_new(int nr, int nc, int n); |
36 |
37 |
/* Prepare a RMATRIX for writing (allocate array if needed) */ |
38 |
extern int rmx_prepare(RMATRIX *rm); |
39 |
40 |
/* Call rmx_new() and rmx_prepare() */ |
41 |
extern RMATRIX *rmx_alloc(int nr, int nc, int n); |
42 |
43 |
/* Free a RMATRIX array */ |
44 |
extern void rmx_free(RMATRIX *rm); |
45 |
46 |
/* Resolve data type based on two input types (returns 0 for mismatch) */ |
47 |
extern int rmx_newtype(int dtyp1, int dtyp2); |
48 |
49 |
/* Load matrix from supported file type (NULL for stdin, '!' with command) */ |
50 |
extern RMATRIX *rmx_load(const char *inspec, RMPref rmp); |
51 |
52 |
/* Append header information associated with matrix data */ |
53 |
extern int rmx_addinfo(RMATRIX *rm, const char *info); |
54 |
55 |
/* Write matrix to file type indicated by dtype */ |
56 |
extern int rmx_write(const RMATRIX *rm, int dtype, FILE *fp); |
57 |
58 |
/* Allocate and assign square identity matrix with n components */ |
59 |
extern RMATRIX *rmx_identity(int dim, int n); |
60 |
61 |
/* Duplicate the given matrix */ |
62 |
extern RMATRIX *rmx_copy(const RMATRIX *rm); |
63 |
64 |
/* Allocate and assign transposed matrix */ |
65 |
extern RMATRIX *rmx_transpose(const RMATRIX *rm); |
66 |
67 |
/* Multiply (concatenate) two matrices and allocate the result */ |
68 |
extern RMATRIX *rmx_multiply(const RMATRIX *m1, const RMATRIX *m2); |
69 |
70 |
/* Element-wise multiplication (or division) of m2 into m1 */ |
71 |
extern int rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide); |
72 |
73 |
/* Sum second matrix into first, applying scale factor beforehand */ |
74 |
extern int rmx_sum(RMATRIX *msum, const RMATRIX *madd, const double sf[]); |
75 |
76 |
/* Scale the given matrix by the indicated scalar component vector */ |
77 |
extern int rmx_scale(RMATRIX *rm, const double sf[]); |
78 |
79 |
/* Allocate new matrix and apply component transformation */ |
80 |
extern RMATRIX *rmx_transform(const RMATRIX *msrc, int n, const double cmat[]); |
81 |
82 |
/* Convert a color matrix to newly allocated RMATRIX buffer */ |
83 |
extern RMATRIX *rmx_from_cmatrix(const CMATRIX *cm); |
84 |
85 |
/* Convert general matrix to newly allocated CMATRIX buffer */ |
86 |
extern CMATRIX *cm_from_rmatrix(const RMATRIX *rm); |
87 |
88 |
89 |
90 |
#endif |
91 |
#endif /* _RAD_RMATRIX_H_ */ |
