root/Development/ray/src/util/rmatrix.h
Revision: 2.10
Committed: Wed Aug 14 18:20:02 2019 UTC (6 years, 2 months ago) by greg
Changes since 2.9: +3 -2 lines
1 /* RCSid $Id: rmatrix.h,v 2.9 2018/10/31 22:19:57 greg Exp $ */
2 /*
3 * Header file for general matrix routines.
4 */
5
6 #ifndef _RAD_RMATRIX_H_
7 #define _RAD_RMATRIX_H_
8
9 #include "cmatrix.h"
10
11 #ifdef __cplusplus
12 extern "C" {
13 #endif
14
15 /* General plane-ordered component matrix */
16 typedef struct {
17 int nrows, ncols, ncomp;
18 short dtype;
19 short swapin;
20 char *info;
21 double mtx[1]; /* extends struct */
22 } RMATRIX;
23
24 #define rmx_lval(rm,r,c,i) (rm)->mtx[(i)+(rm)->ncomp*((c)+(size_t)(rm)->ncols*(r))]
25
26 /* Allocate a nr x nc matrix with n components */
27 extern RMATRIX *rmx_alloc(int nr, int nc, int n);
28
29 /* Free a RMATRIX array */
30 extern void rmx_free(RMATRIX *rm);
31
32 /* Resolve data type based on two input types (returns 0 for mismatch) */
33 extern int rmx_newtype(int dtyp1, int dtyp2);
34
35 /* Load matrix from supported file type (NULL for stdin, '!' with command) */
36 extern RMATRIX *rmx_load(const char *inspec);
37
38 /* Append header information associated with matrix data */
39 extern int rmx_addinfo(RMATRIX *rm, const char *info);
40
41 /* Write matrix to file type indicated by dtype */
42 extern int rmx_write(const RMATRIX *rm, int dtype, FILE *fp);
43
44 /* Allocate and assign square identity matrix with n components */
45 extern RMATRIX *rmx_identity(int dim, int n);
46
47 /* Duplicate the given matrix */
48 extern RMATRIX *rmx_copy(const RMATRIX *rm);
49
50 /* Allocate and assign transposed matrix */
51 extern RMATRIX *rmx_transpose(const RMATRIX *rm);
52
53 /* Multiply (concatenate) two matrices and allocate the result */
54 extern RMATRIX *rmx_multiply(const RMATRIX *m1, const RMATRIX *m2);
55
56 /* Element-wise multiplication (or division) of m2 into m1 */
57 extern int rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide);
58
59 /* Sum second matrix into first, applying scale factor beforehand */
60 extern int rmx_sum(RMATRIX *msum, const RMATRIX *madd, const double sf[]);
61
62 /* Scale the given matrix by the indicated scalar component vector */
63 extern int rmx_scale(RMATRIX *rm, const double sf[]);
64
65 /* Allocate new matrix and apply component transformation */
66 extern RMATRIX *rmx_transform(const RMATRIX *msrc, int n, const double cmat[]);
67
68 /* Convert a color matrix to newly allocated RMATRIX buffer */
69 extern RMATRIX *rmx_from_cmatrix(const CMATRIX *cm);
70
71 /* Convert general matrix to newly allocated CMATRIX buffer */
72 extern CMATRIX *cm_from_rmatrix(const RMATRIX *rm);
73
74 #ifdef __cplusplus
75 }
76 #endif
77 #endif /* _RAD_RMATRIX_H_ */
