--- ray/src/util/rmatrix.h 2015/05/04 20:53:21 2.7 +++ ray/src/util/rmatrix.h 2024/06/04 21:23:11 2.22 @@ -1,4 +1,4 @@ -/* RCSid $Id: rmatrix.h,v 2.7 2015/05/04 20:53:21 greg Exp $ */ +/* RCSid $Id: rmatrix.h,v 2.22 2024/06/04 21:23:11 greg Exp $ */ /* * Header file for general matrix routines. */ @@ -12,32 +12,77 @@ extern "C" { #endif -/* General plane-ordered component matrix */ +/* Preferred BSDF component: + none, transmission, reflection front (normal side), reflection back */ +typedef enum {RMPnone=-1, RMPtrans=0, RMPreflF, RMPreflB} RMPref; + +/* Private flags: + need to swap input, need to free/unmap memory */ +#define RMF_SWAPIN 1 +#define RMF_OURMEM 2 + +#define DTrmx_native DTdouble /* in-core data type */ + +/* General [row][col][cmp] component matrix */ typedef struct { - int nrows, ncols, ncomp; - int dtype; char *info; - double mtx[1]; /* extends struct */ + void *mapped; + double *mtx; + COLOR cexp; + float wlpart[4]; + int nrows, ncols; + short ncomp; + uby8 dtype; + uby8 pflags; } RMATRIX; -#define rmx_lval(rm,r,c,i) (rm)->mtx[(i)+(rm)->ncomp*((c)+(rm)->ncols*(r))] +#define rmx_lval(rm,r,c) ((rm)->mtx + (rm)->ncomp*((c)+(size_t)(rm)->ncols*(r))) +#define rmx_val rmx_lval -/* Allocate a nr x nc matrix with n components */ +#define rmx_array_size(rm) (sizeof(double)*(rm)->nrows*(rm)->ncols*(rm)->ncomp) +#define rmx_mapped_size(rm) ((char *)(rm)->mtx + rmx_array_size(rm) - (char *)(rm)->mapped) + +/* Initialize a RMATRIX struct but don't allocate array space */ +extern RMATRIX *rmx_new(int nr, int nc, int n); + +/* Prepare a RMATRIX for writing (allocate array if needed) */ +extern int rmx_prepare(RMATRIX *rm); + +/* Call rmx_new() and rmx_prepare() */ extern RMATRIX *rmx_alloc(int nr, int nc, int n); -/* Free a RMATRIX array */ +/* Clear state by freeing info and matrix data */ +extern void rmx_reset(RMATRIX *rm); + +/* Free an RMATRIX struct and data */ extern void rmx_free(RMATRIX *rm); /* Resolve data type based on two input types (returns 0 for mismatch) */ extern int rmx_newtype(int dtyp1, int dtyp2); +/* Read matrix header from input stream (cannot be XML) */ +extern int rmx_load_header(RMATRIX *rm, FILE *fp); + +/* Load next row as double (cannot be XML) */ +extern int rmx_load_row(double *drp, const RMATRIX *rm, FILE *fp); + +/* Allocate & load post-header data from stream given type set in rm->dtype */ +extern int rmx_load_data(RMATRIX *rm, FILE *fp); + /* Load matrix from supported file type (NULL for stdin, '!' with command) */ -extern RMATRIX *rmx_load(const char *inspec); +extern RMATRIX *rmx_load(const char *inspec, RMPref rmp); /* Append header information associated with matrix data */ extern int rmx_addinfo(RMATRIX *rm, const char *info); -/* Write matrix to file type indicated by dtype */ +/* Finish writing header data with resolution and format, returning type used */ +extern int rmx_write_header(const RMATRIX *rm, int dtype, FILE *fp); + +/* Write out matrix data (usually by row) */ +extern int rmx_write_data(const double *dp, int nc, int len, + int dtype, FILE *fp); + +/* Write matrix using file format indicated by dtype */ extern int rmx_write(const RMATRIX *rm, int dtype, FILE *fp); /* Allocate and assign square identity matrix with n components */ @@ -46,11 +91,17 @@ extern RMATRIX *rmx_identity(int dim, int n); /* Duplicate the given matrix */ extern RMATRIX *rmx_copy(const RMATRIX *rm); +/* Replace data in first matrix with data from second */ +extern int rmx_transfer_data(RMATRIX *rdst, RMATRIX *rsrc, int dometa); + /* Allocate and assign transposed matrix */ extern RMATRIX *rmx_transpose(const RMATRIX *rm); /* Multiply (concatenate) two matrices and allocate the result */ extern RMATRIX *rmx_multiply(const RMATRIX *m1, const RMATRIX *m2); + +/* Element-wise multiplication (or division) of m2 into m1 */ +extern int rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide); /* Sum second matrix into first, applying scale factor beforehand */ extern int rmx_sum(RMATRIX *msum, const RMATRIX *madd, const double sf[]);
