--- ray/src/util/rmatrix.h 2014/05/31 19:21:21 2.2 +++ ray/src/util/rmatrix.h 2023/12/06 17:57:34 2.20 @@ -1,4 +1,4 @@ -/* RCSid $Id: rmatrix.h,v 2.2 2014/05/31 19:21:21 greg Exp $ */ +/* RCSid $Id: rmatrix.h,v 2.20 2023/12/06 17:57:34 greg Exp $ */ /* * Header file for general matrix routines. */ @@ -12,36 +12,86 @@ extern "C" { #endif -/* General plane-ordered component matrix */ +/* Preferred BSDF component: + none, transmission, reflection front (normal side), reflection back */ +typedef enum {RMPnone=-1, RMPtrans=0, RMPreflF, RMPreflB} RMPref; + +/* General [row][col][cmp] component matrix */ typedef struct { - int nrows, ncols, ncomp; - double mtx[1]; /* extends struct */ + char *info; + void *mapped; + double *mtx; + COLOR cexp; + float wlpart[4]; + int nrows, ncols; + short ncomp; + uby8 dtype; + uby8 swapin; } RMATRIX; -#define rmx_lval(rm,r,c,i) (rm)->mtx[((i)*(rm)->nrows+(r))*(rm)->ncols+(c)] +#define rmx_lval(rm,r,c) ((rm)->mtx + (rm)->ncomp*((c)+(size_t)(rm)->ncols*(r))) +#define rmx_val rmx_lval -#define rmx_free(rm) free(rm) +/* Initialize a RMATRIX struct but don't allocate array space */ +extern RMATRIX *rmx_new(int nr, int nc, int n); -/* Allocate a nr x nc matrix with n components */ +/* Prepare a RMATRIX for writing (allocate array if needed) */ +extern int rmx_prepare(RMATRIX *rm); + +/* Call rmx_new() and rmx_prepare() */ extern RMATRIX *rmx_alloc(int nr, int nc, int n); -/* Load matrix from supported file type */ -extern RMATRIX *rmx_load(const char *fname); +/* Clear state by freeing info and matrix data */ +extern void rmx_reset(RMATRIX *rm); -/* Write matrix to file type indicated by dt */ -extern long rmx_write(const RMATRIX *rm, int dtype, FILE *fp); +/* Free an RMATRIX struct and data */ +extern void rmx_free(RMATRIX *rm); +/* Resolve data type based on two input types (returns 0 for mismatch) */ +extern int rmx_newtype(int dtyp1, int dtyp2); + +/* Read matrix header from input stream (cannot be XML) */ +extern int rmx_load_header(RMATRIX *rm, FILE *fp); + +/* Load next row as double (cannot be XML) */ +extern int rmx_load_row(double *drp, const RMATRIX *rm, FILE *fp); + +/* Allocate & load post-header data from stream given type set in rm->dtype */ +extern int rmx_load_data(RMATRIX *rm, FILE *fp); + +/* Load matrix from supported file type (NULL for stdin, '!' with command) */ +extern RMATRIX *rmx_load(const char *inspec, RMPref rmp); + +/* Append header information associated with matrix data */ +extern int rmx_addinfo(RMATRIX *rm, const char *info); + +/* Finish writing header data with resolution and format, returning type used */ +extern int rmx_write_header(const RMATRIX *rm, int dtype, FILE *fp); + +/* Write out matrix data (usually by row) */ +extern int rmx_write_data(const double *dp, int nc, int len, + int dtype, FILE *fp); + +/* Write matrix using file format indicated by dtype */ +extern int rmx_write(const RMATRIX *rm, int dtype, FILE *fp); + /* Allocate and assign square identity matrix with n components */ extern RMATRIX *rmx_identity(int dim, int n); /* Duplicate the given matrix */ extern RMATRIX *rmx_copy(const RMATRIX *rm); +/* Replace data in first matrix with data from second */ +extern int rmx_transfer_data(RMATRIX *rdst, RMATRIX *rsrc, int dometa); + /* Allocate and assign transposed matrix */ extern RMATRIX *rmx_transpose(const RMATRIX *rm); /* Multiply (concatenate) two matrices and allocate the result */ extern RMATRIX *rmx_multiply(const RMATRIX *m1, const RMATRIX *m2); + +/* Element-wise multiplication (or division) of m2 into m1 */ +extern int rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide); /* Sum second matrix into first, applying scale factor beforehand */ extern int rmx_sum(RMATRIX *msum, const RMATRIX *madd, const double sf[]);
