--- ray/src/util/rmatrix.h 2023/11/21 01:30:20 2.16 +++ ray/src/util/rmatrix.h 2025/04/04 18:06:48 2.26 @@ -1,4 +1,4 @@ -/* RCSid $Id: rmatrix.h,v 2.16 2023/11/21 01:30:20 greg Exp $ */ +/* RCSid $Id: rmatrix.h,v 2.26 2025/04/04 18:06:48 greg Exp $ */ /* * Header file for general matrix routines. */ @@ -13,24 +13,46 @@ extern "C" { #endif /* Preferred BSDF component: - transmission, reflection front (normal side), reflection back */ -typedef enum {RMPtrans=0, RMPreflF, RMPreflB} RMPref; + none, transmission, reflection front (normal side), reflection back */ +typedef enum {RMPnone=-1, RMPtrans=0, RMPreflF, RMPreflB} RMPref; +/* RMATRIX flags (usually private): + need to swap input, we should free memory */ +#define RMF_SWAPIN 1 +#define RMF_FREEMEM 2 + +#ifndef MAXCOMP +#define MAXCOMP MAXCSAMP /* #components we support */ +#endif + /* Set in-core data type */ +#if !defined(DTrmx_native) || DTrmx_native==DTfloat +#define DTrmx_native DTfloat +#define rmx_dtype float +#define rmx_scanfmt "%f" +#elif DTrmx_native==DTdouble +#define rmx_dtype double +#define rmx_scanfmt "%lf" +#endif + /* General [row][col][cmp] component matrix */ typedef struct { - char *info; - void *mapped; - double *mtx; - COLOR cexp; - float wlpart[4]; - int nrows, ncols; - short ncomp; - uby8 dtype; - uby8 swapin; + char *info; + void *mapped; + rmx_dtype *mtx; + COLOR cexp; + float wlpart[4]; + int nrows, ncols; + short ncomp; + uby8 dtype; + uby8 pflags; } RMATRIX; #define rmx_lval(rm,r,c) ((rm)->mtx + (rm)->ncomp*((c)+(size_t)(rm)->ncols*(r))) +#define rmx_val rmx_lval +#define rmx_array_size(rm) (sizeof(rmx_dtype)*(rm)->nrows*(rm)->ncols*(rm)->ncomp) +#define rmx_mapped_size(rm) ((char *)(rm)->mtx + rmx_array_size(rm) - (char *)(rm)->mapped) + /* Initialize a RMATRIX struct but don't allocate array space */ extern RMATRIX *rmx_new(int nr, int nc, int n); @@ -40,19 +62,38 @@ extern int rmx_prepare(RMATRIX *rm); /* Call rmx_new() and rmx_prepare() */ extern RMATRIX *rmx_alloc(int nr, int nc, int n); -/* Free a RMATRIX array */ +/* Clear state by freeing info and matrix data */ +extern void rmx_reset(RMATRIX *rm); + +/* Free an RMATRIX struct and data */ extern void rmx_free(RMATRIX *rm); /* Resolve data type based on two input types (returns 0 for mismatch) */ extern int rmx_newtype(int dtyp1, int dtyp2); +/* Read matrix header from input stream (cannot be XML) */ +extern int rmx_load_header(RMATRIX *rm, FILE *fp); + +/* Load next row as rmx_dtype (cannot be XML) */ +extern int rmx_load_row(rmx_dtype *drp, const RMATRIX *rm, FILE *fp); + +/* Allocate & load post-header data from stream given type set in rm->dtype */ +extern int rmx_load_data(RMATRIX *rm, FILE *fp); + /* Load matrix from supported file type (NULL for stdin, '!' with command) */ extern RMATRIX *rmx_load(const char *inspec, RMPref rmp); /* Append header information associated with matrix data */ extern int rmx_addinfo(RMATRIX *rm, const char *info); -/* Write matrix to file type indicated by dtype */ +/* Finish writing header data with resolution and format, returning type used */ +extern int rmx_write_header(const RMATRIX *rm, int dtype, FILE *fp); + +/* Write out matrix data (usually by row) */ +extern int rmx_write_data(const rmx_dtype *dp, int nc, int len, + int dtype, FILE *fp); + +/* Write matrix using file format indicated by dtype */ extern int rmx_write(const RMATRIX *rm, int dtype, FILE *fp); /* Allocate and assign square identity matrix with n components */ @@ -61,8 +102,11 @@ extern RMATRIX *rmx_identity(int dim, int n); /* Duplicate the given matrix */ extern RMATRIX *rmx_copy(const RMATRIX *rm); -/* Allocate and assign transposed matrix */ -extern RMATRIX *rmx_transpose(const RMATRIX *rm); +/* Replace data in first matrix with data from second */ +extern int rmx_transfer_data(RMATRIX *rdst, RMATRIX *rsrc, int dometa); + +/* Transpose the given matrix */ +extern int rmx_transpose(RMATRIX *rm); /* Multiply (concatenate) two matrices and allocate the result */ extern RMATRIX *rmx_multiply(const RMATRIX *m1, const RMATRIX *m2);
