--- ray/src/util/rmatrix.h 2014/05/31 05:02:37 2.1 +++ ray/src/util/rmatrix.h 2023/11/21 01:30:20 2.16 @@ -1,4 +1,4 @@ -/* RCSid $Id: rmatrix.h,v 2.1 2014/05/31 05:02:37 greg Exp $ */ +/* RCSid $Id: rmatrix.h,v 2.16 2023/11/21 01:30:20 greg Exp $ */ /* * Header file for general matrix routines. */ @@ -12,38 +12,63 @@ extern "C" { #endif -/* General plane-ordered component matrix */ +/* Preferred BSDF component: + transmission, reflection front (normal side), reflection back */ +typedef enum {RMPtrans=0, RMPreflF, RMPreflB} RMPref; + +/* General [row][col][cmp] component matrix */ typedef struct { - int nrows, ncols, ncomp; - double mtx[1]; /* extends struct */ + char *info; + void *mapped; + double *mtx; + COLOR cexp; + float wlpart[4]; + int nrows, ncols; + short ncomp; + uby8 dtype; + uby8 swapin; } RMATRIX; -#define rmx_indx(rm,r,c,i) (((i)*(rm)->nrows+(r))*(rm)->ncols+(c)) +#define rmx_lval(rm,r,c) ((rm)->mtx + (rm)->ncomp*((c)+(size_t)(rm)->ncols*(r))) -#define rmx_lval(rm,r,c,i) (rm)->mtx[rmx_indx(rm,r,c,i)] +/* Initialize a RMATRIX struct but don't allocate array space */ +extern RMATRIX *rmx_new(int nr, int nc, int n); -#define rmx_free(rm) free(rm) +/* Prepare a RMATRIX for writing (allocate array if needed) */ +extern int rmx_prepare(RMATRIX *rm); -/* Allocate a nr x nc matrix with n components */ +/* Call rmx_new() and rmx_prepare() */ extern RMATRIX *rmx_alloc(int nr, int nc, int n); -/* Load matrix from supported file type */ -extern RMATRIX *rmx_load(const char *fname); +/* Free a RMATRIX array */ +extern void rmx_free(RMATRIX *rm); -/* Write matrix to file type indicated by dt */ -extern long rmx_write(const RMATRIX *rm, int dtype, FILE *fp); +/* Resolve data type based on two input types (returns 0 for mismatch) */ +extern int rmx_newtype(int dtyp1, int dtyp2); +/* Load matrix from supported file type (NULL for stdin, '!' with command) */ +extern RMATRIX *rmx_load(const char *inspec, RMPref rmp); + +/* Append header information associated with matrix data */ +extern int rmx_addinfo(RMATRIX *rm, const char *info); + +/* Write matrix to file type indicated by dtype */ +extern int rmx_write(const RMATRIX *rm, int dtype, FILE *fp); + /* Allocate and assign square identity matrix with n components */ extern RMATRIX *rmx_identity(int dim, int n); /* Duplicate the given matrix */ extern RMATRIX *rmx_copy(const RMATRIX *rm); -/* Swap rows and columns in the given matrix in situ */ -extern int rmx_transpose(RMATRIX *rm); +/* Allocate and assign transposed matrix */ +extern RMATRIX *rmx_transpose(const RMATRIX *rm); /* Multiply (concatenate) two matrices and allocate the result */ extern RMATRIX *rmx_multiply(const RMATRIX *m1, const RMATRIX *m2); + +/* Element-wise multiplication (or division) of m2 into m1 */ +extern int rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide); /* Sum second matrix into first, applying scale factor beforehand */ extern int rmx_sum(RMATRIX *msum, const RMATRIX *madd, const double sf[]);
