root/radiance/ray/src/util/rmatrix.h
Revision: 2.27
Committed: Fri Apr 18 23:59:03 2025 UTC (3 months, 3 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.26: +2 -6 lines
1 /* RCSid $Id: rmatrix.h,v 2.26 2025/04/04 18:06:48 greg Exp $ */
2 /*
3 * Header file for general matrix routines.
4 */
5
6 #ifndef _RAD_RMATRIX_H_
7 #define _RAD_RMATRIX_H_
8
9 #include "cmatrix.h"
10
11 #ifdef __cplusplus
12 extern "C" {
13 #endif
14
15 /* RMATRIX flags (usually private):
16 need to swap input, we should free memory */
17 #define RMF_SWAPIN 1
18 #define RMF_FREEMEM 2
19
20 #ifndef MAXCOMP
21 #define MAXCOMP MAXCSAMP /* #components we support */
22 #endif
23 /* Set in-core data type */
24 #if !defined(DTrmx_native) || DTrmx_native==DTfloat
25 #define DTrmx_native DTfloat
26 #define rmx_dtype float
27 #define rmx_scanfmt "%f"
28 #elif DTrmx_native==DTdouble
29 #define rmx_dtype double
30 #define rmx_scanfmt "%lf"
31 #endif
32
33 /* General [row][col][cmp] component matrix */
34 typedef struct {
35 char *info;
36 void *mapped;
37 rmx_dtype *mtx;
38 COLOR cexp;
39 float wlpart[4];
40 int nrows, ncols;
41 short ncomp;
42 uby8 dtype;
43 uby8 pflags;
44 } RMATRIX;
45
46 #define rmx_lval(rm,r,c) ((rm)->mtx + (rm)->ncomp*((c)+(size_t)(rm)->ncols*(r)))
47 #define rmx_val rmx_lval
48
49 #define rmx_array_size(rm) (sizeof(rmx_dtype)*(rm)->nrows*(rm)->ncols*(rm)->ncomp)
50 #define rmx_mapped_size(rm) ((char *)(rm)->mtx + rmx_array_size(rm) - (char *)(rm)->mapped)
51
52 /* Initialize a RMATRIX struct but don't allocate array space */
53 extern RMATRIX *rmx_new(int nr, int nc, int n);
54
55 /* Prepare a RMATRIX for writing (allocate array if needed) */
56 extern int rmx_prepare(RMATRIX *rm);
57
58 /* Call rmx_new() and rmx_prepare() */
59 extern RMATRIX *rmx_alloc(int nr, int nc, int n);
60
61 /* Clear state by freeing info and matrix data */
62 extern void rmx_reset(RMATRIX *rm);
63
64 /* Free an RMATRIX struct and data */
65 extern void rmx_free(RMATRIX *rm);
66
67 /* Resolve data type based on two input types (returns 0 for mismatch) */
68 extern int rmx_newtype(int dtyp1, int dtyp2);
69
70 /* Read matrix header from input stream (cannot be XML) */
71 extern int rmx_load_header(RMATRIX *rm, FILE *fp);
72
73 /* Load next row as rmx_dtype (cannot be XML) */
74 extern int rmx_load_row(rmx_dtype *drp, const RMATRIX *rm, FILE *fp);
75
76 /* Allocate & load post-header data from stream given type set in rm->dtype */
77 extern int rmx_load_data(RMATRIX *rm, FILE *fp);
78
79 /* Load matrix from supported file type (NULL for stdin, '!' with command) */
80 extern RMATRIX *rmx_load(const char *inspec);
81
82 /* Append header information associated with matrix data */
83 extern int rmx_addinfo(RMATRIX *rm, const char *info);
84
85 /* Finish writing header data with resolution and format, returning type used */
86 extern int rmx_write_header(const RMATRIX *rm, int dtype, FILE *fp);
87
88 /* Write out matrix data (usually by row) */
89 extern int rmx_write_data(const rmx_dtype *dp, int nc, int len,
90 int dtype, FILE *fp);
91
92 /* Write matrix using file format indicated by dtype */
93 extern int rmx_write(const RMATRIX *rm, int dtype, FILE *fp);
94
95 /* Allocate and assign square identity matrix with n components */
96 extern RMATRIX *rmx_identity(int dim, int n);
97
98 /* Duplicate the given matrix */
99 extern RMATRIX *rmx_copy(const RMATRIX *rm);
100
101 /* Replace data in first matrix with data from second */
102 extern int rmx_transfer_data(RMATRIX *rdst, RMATRIX *rsrc, int dometa);
103
104 /* Transpose the given matrix */
105 extern int rmx_transpose(RMATRIX *rm);
106
107 /* Multiply (concatenate) two matrices and allocate the result */
108 extern RMATRIX *rmx_multiply(const RMATRIX *m1, const RMATRIX *m2);
109
110 /* Element-wise multiplication (or division) of m2 into m1 */
111 extern int rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide);
112
113 /* Sum second matrix into first, applying scale factor beforehand */
114 extern int rmx_sum(RMATRIX *msum, const RMATRIX *madd, const double sf[]);
115
116 /* Scale the given matrix by the indicated scalar component vector */
117 extern int rmx_scale(RMATRIX *rm, const double sf[]);
118
119 /* Allocate new matrix and apply component transformation */
120 extern RMATRIX *rmx_transform(const RMATRIX *msrc, int n, const double cmat[]);
121
122 /* Convert a color matrix to newly allocated RMATRIX buffer */
123 extern RMATRIX *rmx_from_cmatrix(const CMATRIX *cm);
124
125 /* Convert general matrix to newly allocated CMATRIX buffer */
126 extern CMATRIX *cm_from_rmatrix(const RMATRIX *rm);
127
128 #ifdef __cplusplus
129 }
130 #endif
131 #endif /* _RAD_RMATRIX_H_ */
