root/radiance/ray/src/util/rmatrix.h
Revision: 2.8
Committed: Mon Aug 28 15:59:46 2017 UTC (7 years, 8 months ago) by greg
Changes since 2.7: +4 -1 lines
# User Rev Content
1 greg 2.8 /* RCSid $Id: rmatrix.h,v 2.7 2015/05/04 20:53:21 greg Exp $ */
2 greg 2.1 /*
3     * Header file for general matrix routines.
4     */
5
6     #ifndef _RAD_RMATRIX_H_
7     #define _RAD_RMATRIX_H_
8
9     #include "cmatrix.h"
10
11     #ifdef __cplusplus
12     extern "C" {
13     #endif
14
15     /* General plane-ordered component matrix */
16     typedef struct {
17     int nrows, ncols, ncomp;
18 greg 2.4 int dtype;
19 greg 2.3 char *info;
20 greg 2.1 double mtx[1]; /* extends struct */
21     } RMATRIX;
22
23 greg 2.5 #define rmx_lval(rm,r,c,i) (rm)->mtx[(i)+(rm)->ncomp*((c)+(rm)->ncols*(r))]
24 greg 2.1
25     /* Allocate a nr x nc matrix with n components */
26     extern RMATRIX *rmx_alloc(int nr, int nc, int n);
27
28 greg 2.4 /* Free a RMATRIX array */
29     extern void rmx_free(RMATRIX *rm);
30
31     /* Resolve data type based on two input types (returns 0 for mismatch) */
32     extern int rmx_newtype(int dtyp1, int dtyp2);
33
34 greg 2.7 /* Load matrix from supported file type (NULL for stdin, '!' with command) */
35     extern RMATRIX *rmx_load(const char *inspec);
36 greg 2.1
37 greg 2.3 /* Append header information associated with matrix data */
38     extern int rmx_addinfo(RMATRIX *rm, const char *info);
39
40 greg 2.4 /* Write matrix to file type indicated by dtype */
41 greg 2.6 extern int rmx_write(const RMATRIX *rm, int dtype, FILE *fp);
42 greg 2.1
43     /* Allocate and assign square identity matrix with n components */
44     extern RMATRIX *rmx_identity(int dim, int n);
45
46     /* Duplicate the given matrix */
47     extern RMATRIX *rmx_copy(const RMATRIX *rm);
48
49 greg 2.2 /* Allocate and assign transposed matrix */
50     extern RMATRIX *rmx_transpose(const RMATRIX *rm);
51 greg 2.1
52     /* Multiply (concatenate) two matrices and allocate the result */
53     extern RMATRIX *rmx_multiply(const RMATRIX *m1, const RMATRIX *m2);
54
55 greg 2.8 /* Element-wise multiplication (or division) of m2 into m1 */
56     extern int rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide);
57
58 greg 2.1 /* Sum second matrix into first, applying scale factor beforehand */
59     extern int rmx_sum(RMATRIX *msum, const RMATRIX *madd, const double sf[]);
60
61     /* Scale the given matrix by the indicated scalar component vector */
62     extern int rmx_scale(RMATRIX *rm, const double sf[]);
63
64     /* Allocate new matrix and apply component transformation */
65     extern RMATRIX *rmx_transform(const RMATRIX *msrc, int n, const double cmat[]);
66
67     /* Convert a color matrix to newly allocated RMATRIX buffer */
68     extern RMATRIX *rmx_from_cmatrix(const CMATRIX *cm);
69
70     /* Convert general matrix to newly allocated CMATRIX buffer */
71     extern CMATRIX *cm_from_rmatrix(const RMATRIX *rm);
72
73     #ifdef __cplusplus
74     }
75     #endif
76     #endif /* _RAD_RMATRIX_H_ */
