root/radiance/ray/src/util/rmatrix.h
Revision: 2.3
Committed: Fri Aug 1 23:37:24 2014 UTC (10 years, 3 months ago) by greg
Maintain header information in matrix structure
1 /* RCSid $Id: rmatrix.h,v 2.2 2014/05/31 19:21:21 greg Exp $ */
2 /*
3 * Header file for general matrix routines.
4 */
5
6 #ifndef _RAD_RMATRIX_H_
7 #define _RAD_RMATRIX_H_
8
9 #include "cmatrix.h"
10
11 #ifdef __cplusplus
12 extern "C" {
13 #endif
14
15 /* General plane-ordered component matrix */
16 typedef struct {
17 int nrows, ncols, ncomp;
18 char *info;
19 double mtx[1]; /* extends struct */
20 } RMATRIX;
21
22 #define rmx_lval(rm,r,c,i) (rm)->mtx[((i)*(rm)->nrows+(r))*(rm)->ncols+(c)]
23
24 #define rmx_free(rm) free(rm)
25
26 /* Allocate a nr x nc matrix with n components */
27 extern RMATRIX *rmx_alloc(int nr, int nc, int n);
28
29 /* Load matrix from supported file type */
30 extern RMATRIX *rmx_load(const char *fname);
31
32 /* Append header information associated with matrix data */
33 extern int rmx_addinfo(RMATRIX *rm, const char *info);
34
35 /* Write matrix to file type indicated by dt */
36 extern long rmx_write(const RMATRIX *rm, int dtype, FILE *fp);
37
38 /* Allocate and assign square identity matrix with n components */
39 extern RMATRIX *rmx_identity(int dim, int n);
40
41 /* Duplicate the given matrix */
42 extern RMATRIX *rmx_copy(const RMATRIX *rm);
43
44 /* Allocate and assign transposed matrix */
45 extern RMATRIX *rmx_transpose(const RMATRIX *rm);
46
47 /* Multiply (concatenate) two matrices and allocate the result */
48 extern RMATRIX *rmx_multiply(const RMATRIX *m1, const RMATRIX *m2);
49
50 /* Sum second matrix into first, applying scale factor beforehand */
51 extern int rmx_sum(RMATRIX *msum, const RMATRIX *madd, const double sf[]);
52
53 /* Scale the given matrix by the indicated scalar component vector */
54 extern int rmx_scale(RMATRIX *rm, const double sf[]);
55
56 /* Allocate new matrix and apply component transformation */
57 extern RMATRIX *rmx_transform(const RMATRIX *msrc, int n, const double cmat[]);
58
59 /* Convert a color matrix to newly allocated RMATRIX buffer */
60 extern RMATRIX *rmx_from_cmatrix(const CMATRIX *cm);
61
62 /* Convert general matrix to newly allocated CMATRIX buffer */
63 extern CMATRIX *cm_from_rmatrix(const RMATRIX *rm);
64
65 #ifdef __cplusplus
66 }
67 #endif
68 #endif /* _RAD_RMATRIX_H_ */
