--- ray/src/util/rmatrix.h 2023/11/28 21:07:20 2.18 +++ ray/src/util/rmatrix.h 2023/12/06 17:57:34 2.20 @@ -1,4 +1,4 @@ -/* RCSid $Id: rmatrix.h,v 2.18 2023/11/28 21:07:20 greg Exp $ */ +/* RCSid $Id: rmatrix.h,v 2.20 2023/12/06 17:57:34 greg Exp $ */ /* * Header file for general matrix routines. */ @@ -13,8 +13,8 @@ extern "C" { #endif /* Preferred BSDF component: - transmission, reflection front (normal side), reflection back */ -typedef enum {RMPtrans=0, RMPreflF, RMPreflB} RMPref; + none, transmission, reflection front (normal side), reflection back */ +typedef enum {RMPnone=-1, RMPtrans=0, RMPreflF, RMPreflB} RMPref; /* General [row][col][cmp] component matrix */ typedef struct { @@ -41,7 +41,10 @@ extern int rmx_prepare(RMATRIX *rm); /* Call rmx_new() and rmx_prepare() */ extern RMATRIX *rmx_alloc(int nr, int nc, int n); -/* Free a RMATRIX array */ +/* Clear state by freeing info and matrix data */ +extern void rmx_reset(RMATRIX *rm); + +/* Free an RMATRIX struct and data */ extern void rmx_free(RMATRIX *rm); /* Resolve data type based on two input types (returns 0 for mismatch) */ @@ -62,7 +65,14 @@ extern RMATRIX *rmx_load(const char *inspec, RMPref rm /* Append header information associated with matrix data */ extern int rmx_addinfo(RMATRIX *rm, const char *info); -/* Write matrix to file type indicated by dtype */ +/* Finish writing header data with resolution and format, returning type used */ +extern int rmx_write_header(const RMATRIX *rm, int dtype, FILE *fp); + +/* Write out matrix data (usually by row) */ +extern int rmx_write_data(const double *dp, int nc, int len, + int dtype, FILE *fp); + +/* Write matrix using file format indicated by dtype */ extern int rmx_write(const RMATRIX *rm, int dtype, FILE *fp); /* Allocate and assign square identity matrix with n components */ @@ -70,6 +80,9 @@ extern RMATRIX *rmx_identity(int dim, int n); /* Duplicate the given matrix */ extern RMATRIX *rmx_copy(const RMATRIX *rm); + +/* Replace data in first matrix with data from second */ +extern int rmx_transfer_data(RMATRIX *rdst, RMATRIX *rsrc, int dometa); /* Allocate and assign transposed matrix */ extern RMATRIX *rmx_transpose(const RMATRIX *rm);
