root/radiance/ray/src/util/rmatrix.h
Fri Apr 18 23:59:03 2025 UTC (2 months, 3 weeks ago) by greg
Changes since 2.26: +2 -6 lines
Diff to previous 2.26 , to selected 2.15
Fri Apr 4 18:06:48 2025 UTC (3 months, 1 week ago) by greg
Changes since 2.25: +12 -2 lines
Diff to previous 2.25 , to selected 2.15
Fri Apr 4 01:48:25 2025 UTC (3 months, 1 week ago) by greg
Changes since 2.24: +3 -3 lines
Diff to previous 2.24 , to selected 2.15
perf(rmtxop): Changed rmx_transpose() call to do in-situ operation on square matrices
Thu Jun 6 17:01:05 2024 UTC (13 months ago) by greg
Changes since 2.23: +15 -14 lines
Diff to previous 2.23 , to selected 2.15
refactor: Switched out "double" for "rmx_dtype" most places
Thu Jun 6 16:46:31 2024 UTC (13 months ago) by greg
Changes since 2.22: +4 -4 lines
Diff to previous 2.22 , to selected 2.15
fix: Minor improvement to logic surrounding memory allocation
Tue Jun 4 21:23:11 2024 UTC (13 months, 1 week ago) by greg
Changes since 2.21: +3 -1 lines
Diff to previous 2.21 , to selected 2.15
fix(rcomb): Added child process to sequence output; seems to finally work
Sun May 19 15:32:24 2024 UTC (13 months, 3 weeks ago) by greg
Changes since 2.20: +10 -2 lines
Diff to previous 2.20 , to selected 2.15
feat: Added facility for app-managed matrix memory
Wed Dec 6 17:57:34 2023 UTC (19 months ago) by greg
Changes since 2.19: +4 -1 lines
Diff to previous 2.19 , to selected 2.15
refactor(rmtxcomb): Added library function to transfer matrix data
Fri Dec 1 02:05:00 2023 UTC (19 months, 1 week ago) by greg
Changes since 2.18: +15 -5 lines
Diff to previous 2.18 , to selected 2.15
refactor(rmtxop): Changed rmatrix library interface for by row matrix output
Tue Nov 28 21:07:20 2023 UTC (19 months, 2 weeks ago) by greg
Changes since 2.17: +4 -1 lines
Diff to previous 2.17 , to selected 2.15
refactor: Added ability to read matrix data a row at a time
Tue Nov 28 00:39:56 2023 UTC (19 months, 2 weeks ago) by greg
Changes since 2.16: +8 -1 lines
Diff to previous 2.16 , to selected 2.15
refactor: Separated header and data loading from matrices (except XMLs)
Tue Nov 21 01:30:20 2023 UTC (19 months, 3 weeks ago) by greg
Changes since 2.15: +2 -1 lines
Diff to previous 2.15
Revision 2.15 - (view) (download) (annotate) - [selected]
Sat Mar 5 01:45:21 2022 UTC (3 years, 4 months ago) by greg
Diff to previous 2.14
refactor(rmtxop): Changed matrix array access macros
Fri Mar 4 01:27:12 2022 UTC (3 years, 4 months ago) by greg
Changes since 2.13: +13 -5 lines
Diff to previous 2.13 , to selected 2.15
perf(rmtxop): Added memory-mapping for double matrices
Tue Jan 19 23:32:00 2021 UTC (4 years, 5 months ago) by greg
Changes since 2.12: +6 -2 lines
Diff to previous 2.12 , to selected 2.15
Wed Mar 25 01:51:09 2020 UTC (5 years, 3 months ago) by greg
Diff to previous 2.11 , to selected 2.15
Tue Sep 3 23:43:07 2019 UTC (5 years, 10 months ago) by greg
Changes since 2.10: +5 -4 lines
Diff to previous 2.10 , to selected 2.15
Minor changes should not affect behavior
Wed Aug 14 18:20:02 2019 UTC (5 years, 11 months ago) by greg
Changes since 2.9: +3 -2 lines
Diff to previous 2.9 , to selected 2.15
Wed Oct 31 22:19:57 2018 UTC (6 years, 8 months ago) by greg
Diff to previous 2.8 , to selected 2.15
Fix potential issues on very large matrices (> 2GB)
Mon Aug 28 15:59:46 2017 UTC (7 years, 10 months ago) by greg
Changes since 2.7: +4 -1 lines
Diff to previous 2.7 , to selected 2.15
Mon May 4 20:53:21 2015 UTC (10 years, 2 months ago) by greg
CVS Tags: rad5R0, rad5R1
Diff to previous 2.6 , to selected 2.15
Thu Sep 18 23:20:12 2014 UTC (10 years, 9 months ago) by greg
CVS Tags: rad4R2P2
Diff to previous 2.5 , to selected 2.15
Took out unreliable call to ftell()
Wed Aug 27 13:33:47 2014 UTC (10 years, 10 months ago) by greg
CVS Tags: rad4R2P1
Diff to previous 2.4 , to selected 2.15
Bug fixes in matrix concatenation
Sat Aug 2 17:10:43 2014 UTC (10 years, 11 months ago) by greg
Changes since 2.3: +9 -4 lines
Diff to previous 2.3 , to selected 2.15
Fri Aug 1 23:37:24 2014 UTC (10 years, 11 months ago) by greg
Diff to previous 2.2 , to selected 2.15
Maintain header information in matrix structure
Sat May 31 19:21:21 2014 UTC (11 years, 1 month ago) by greg
CVS Tags: rad4R2
Changes since 2.1: +4 -6 lines
Diff to previous 2.1 , to selected 2.15
Bug fixes
Sat May 31 05:02:37 2014 UTC (11 years, 1 month ago) by greg
Diff to selected 2.15
