fix(rcomb): Added child process to sequence output; seems to finally work
feat: Added facility for app-managed matrix memory
refactor(rmtxcomb): Added library function to transfer matrix data
refactor(rmtxop): Changed rmatrix library interface for by row matrix output
refactor: Added ability to read matrix data a row at a time
refactor: Separated header and data loading from matrices (except XMLs)
refactor(rmtxop): Changed matrix array access macros
perf(rmtxop): Added memory-mapping for double matrices
Minor changes should not affect behavior
Fix potential issues on very large matrices (> 2GB)
Took out unreliable call to ftell()
Bug fixes in matrix concatenation
Maintain header information in matrix structure
Bug fixes
