root/radiance/ray/src/util/rmatrix.c
Revision: 2.63
Committed: Tue Nov 28 00:46:23 2023 UTC (20 months, 2 weeks ago) by greg
Changes since 2.62: +8 -7 lines
refactor: Changed return value for rmx_load_header() to true/false
2 static const char RCSid[] = "$Id: rmatrix.c,v 2.62 2023/11/28 00:39:56 greg Exp $";
5 * General matrix operations.
6 */
7
8 #include <stdlib.h>
9 #include <errno.h>
10 #include "rtio.h"
11 #include "platform.h"
12 #include "resolu.h"
13 #include "paths.h"
14 #include "rmatrix.h"
15 #if !defined(_WIN32) && !defined(_WIN64)
16 #include <sys/mman.h>
17 #endif
18
19 static const char rmx_mismatch_warn[] = "WARNING: data type mismatch\n";
20
21 #define array_size(rm) (sizeof(double)*(rm)->nrows*(rm)->ncols*(rm)->ncomp)
22 #define mapped_size(rm) ((char *)(rm)->mtx + array_size(rm) - (char *)(rm)->mapped)
23
24 /* Initialize a RMATRIX struct but don't allocate array space */
25 RMATRIX *
26 rmx_new(int nr, int nc, int n)
27 {
28 RMATRIX *dnew;
29
30 if (n <= 0)
31 return(NULL);
32
33 dnew = (RMATRIX *)calloc(1, sizeof(RMATRIX));
34 if (dnew) {
35 dnew->dtype = DTdouble;
36 dnew->nrows = nr;
37 dnew->ncols = nc;
38 dnew->ncomp = n;
39 setcolor(dnew->cexp, 1.f, 1.f, 1.f);
40 memcpy(dnew->wlpart, WLPART, sizeof(dnew->wlpart));
41 }
42 return(dnew);
43 }
44
45 /* Prepare a RMATRIX for writing (allocate array if needed) */
46 int
47 rmx_prepare(RMATRIX *rm)
48 {
49 if (!rm) return(0);
50 if (rm->mtx)
51 return(1);
52 if ((rm->nrows <= 0) | (rm->ncols <= 0) | (rm->ncomp <= 0))
53 return(0);
54 rm->mtx = (double *)malloc(array_size(rm));
55 return(rm->mtx != NULL);
56 }
57
58 /* Call rmx_new() and rmx_prepare() */
59 RMATRIX *
60 rmx_alloc(int nr, int nc, int n)
61 {
62 RMATRIX *dnew = rmx_new(nr, nc, n);
63
64 if (dnew && !rmx_prepare(dnew)) {
65 rmx_free(dnew);
66 dnew = NULL;
67 }
68 return(dnew);
69 }
70
71 /* Free a RMATRIX array */
72 void
73 rmx_free(RMATRIX *rm)
74 {
75 if (!rm) return;
76 if (rm->info)
77 free(rm->info);
78 #ifdef MAP_FILE
79 if (rm->mapped)
80 munmap(rm->mapped, mapped_size(rm));
81 else
82 #endif
83 free(rm->mtx);
84 free(rm);
85 }
86
87 /* Resolve data type based on two input types (returns 0 for mismatch) */
88 int
89 rmx_newtype(int dtyp1, int dtyp2)
90 {
91 if ((dtyp1==DTxyze) | (dtyp1==DTrgbe) | (dtyp1==DTspec) |
92 (dtyp2==DTxyze) | (dtyp2==DTrgbe) | (dtyp2==DTspec)
93 && dtyp1 != dtyp2)
94 return(0);
95 if (dtyp1 < dtyp2)
96 return(dtyp1);
97 return(dtyp2);
98 }
99
100 /* Append header information associated with matrix data */
101 int
102 rmx_addinfo(RMATRIX *rm, const char *info)
103 {
104 int oldlen = 0;
105
106 if (!rm || !info || !*info)
107 return(0);
108 if (!rm->info) {
109 rm->info = (char *)malloc(strlen(info)+1);
110 if (rm->info) rm->info[0] = '\0';
111 } else {
112 oldlen = strlen(rm->info);
113 rm->info = (char *)realloc(rm->info,
114 oldlen+strlen(info)+1);
115 }
116 if (!rm->info)
117 return(0);
118 strcpy(rm->info+oldlen, info);
119 return(1);
120 }
121
122 static int
123 get_dminfo(char *s, void *p)
124 {
125 RMATRIX *ip = (RMATRIX *)p;
126 char fmt[MAXFMTLEN];
127 int i;
128
129 if (headidval(NULL, s))
130 return(0);
131 if (isncomp(s)) {
132 ip->ncomp = ncompval(s);
133 return(0);
134 }
135 if (!strncmp(s, "NROWS=", 6)) {
136 ip->nrows = atoi(s+6);
137 return(0);
138 }
139 if (!strncmp(s, "NCOLS=", 6)) {
140 ip->ncols = atoi(s+6);
141 return(0);
142 }
143 if ((i = isbigendian(s)) >= 0) {
144 ip->swapin = (nativebigendian() != i);
145 return(0);
146 }
147 if (isexpos(s)) {
148 float f = exposval(s);
149 scalecolor(ip->cexp, f);
150 return(0);
151 }
152 if (iscolcor(s)) {
153 COLOR ctmp;
154 colcorval(ctmp, s);
155 multcolor(ip->cexp, ctmp);
156 return(0);
157 }
158 if (iswlsplit(s)) {
159 wlsplitval(ip->wlpart, s);
160 return(0);
161 }
162 if (!formatval(fmt, s)) {
163 rmx_addinfo(ip, s);
164 return(0);
165 } /* else check format */
166 for (i = 1; i < DTend; i++)
167 if (!strcmp(fmt, cm_fmt_id[i])) {
168 ip->dtype = i;
169 return(0);
170 }
171 return(-1);
172 }
173
174 static int
175 rmx_load_ascii(RMATRIX *rm, FILE *fp)
176 {
177 int i, j, k;
178
179 if (!rmx_prepare(rm))
180 return(0);
181 for (i = 0; i < rm->nrows; i++)
182 for (j = 0; j < rm->ncols; j++) {
183 double *dp = rmx_lval(rm,i,j);
184 for (k = 0; k < rm->ncomp; k++)
185 if (fscanf(fp, "%lf", &dp[k]) != 1)
186 return(0);
187 }
188 return(1);
189 }
190
191 static int
192 rmx_load_float(RMATRIX *rm, FILE *fp)
193 {
194 int i, j, k;
195 float val[100];
196
197 if (rm->ncomp > 100) {
198 fputs("Unsupported # components in rmx_load_float()\n", stderr);
199 exit(1);
200 }
201 if (!rmx_prepare(rm))
202 return(0);
203 for (i = 0; i < rm->nrows; i++)
204 for (j = 0; j < rm->ncols; j++) {
205 double *dp = rmx_lval(rm,i,j);
206 if (getbinary(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp)
207 return(0);
208 if (rm->swapin)
209 swap32((char *)val, rm->ncomp);
210 for (k = rm->ncomp; k--; )
211 dp[k] = val[k];
212 }
213 return(1);
214 }
215
216 static int
217 rmx_load_double(RMATRIX *rm, FILE *fp)
218 {
219 int i;
220 #ifdef MAP_FILE
221 long pos; /* map memory for file > 1MB if possible */
222 if (!rm->swapin && array_size(rm) >= 1L<<20 &&
223 (pos = ftell(fp)) >= 0 && !(pos % sizeof(double))) {
224 rm->mapped = mmap(NULL, array_size(rm)+pos, PROT_READ|PROT_WRITE,
225 MAP_PRIVATE, fileno(fp), 0);
226 if (rm->mapped != MAP_FAILED) {
227 rm->mtx = (double *)rm->mapped + pos/sizeof(double);
228 return(1);
229 } /* else fall back on reading into memory */
230 rm->mapped = NULL;
231 }
232 #endif
233 if (!rmx_prepare(rm))
234 return(0);
235 for (i = 0; i < rm->nrows; i++) {
236 if (getbinary(rmx_lval(rm,i,0), sizeof(double)*rm->ncomp,
237 rm->ncols, fp) != rm->ncols)
238 return(0);
239 if (rm->swapin)
240 swap64((char *)rmx_lval(rm,i,0), rm->ncols*rm->ncomp);
241 }
242 return(1);
243 }
244
245 static int
246 rmx_load_rgbe(RMATRIX *rm, FILE *fp)
247 {
248 COLOR *scan = (COLOR *)malloc(sizeof(COLOR)*rm->ncols);
249 int i, j;
250
251 if (!scan)
252 return(0);
253 if (!rmx_prepare(rm)) {
254 free(scan);
255 return(0);
256 }
257 for (i = 0; i < rm->nrows; i++) {
258 double *dp = rmx_lval(rm,i,0);
259 if (freadscan(scan, rm->ncols, fp) < 0) {
260 free(scan);
261 return(0);
262 }
263 for (j = 0; j < rm->ncols; j++, dp += 3) {
264 dp[0] = colval(scan[j],RED);
265 dp[1] = colval(scan[j],GRN);
266 dp[2] = colval(scan[j],BLU);
267 }
268 }
269 free(scan);
270 return(1);
271 }
272
273 static int
274 rmx_load_spec(RMATRIX *rm, FILE *fp)
275 {
276 uby8 *scan;
277 SCOLOR scol;
278 int i, j, k;
279
280 if (rm->ncomp < 3)
281 return(0);
282 scan = (uby8 *)malloc((rm->ncomp+1)*rm->ncols);
283 if (!scan)
284 return(0);
285 if (!rmx_prepare(rm)) {
286 free(scan);
287 return(0);
288 }
289 for (i = 0; i < rm->nrows; i++) {
290 double *dp = rmx_lval(rm,i,0);
291 if (freadscolrs(scan, rm->ncomp, rm->ncols, fp) < 0) {
292 free(scan);
293 return(0);
294 }
295 for (j = 0; j < rm->ncols; j++) {
296 scolr2scolor(scol, scan+j*(rm->ncomp+1), rm->ncomp);
297 for (k = 0; k < rm->ncomp; k++)
298 *dp++ = scol[k];
299 }
300 }
301 free(scan);
302 return(1);
303 }
304
305 /* Read matrix header from input stream (cannot be XML) */
306 int
307 rmx_load_header(RMATRIX *rm, FILE *fp)
308 {
309 if (!rm | !fp)
310 return(0);
311 if (rm->info) { /* clear state */
312 free(rm->info);
313 rm->info = NULL;
314 }
315 if (rm->mtx) { /* ...and data */
316 #ifdef MAP_FILE
317 if (rm->mapped) {
318 munmap(rm->mapped, mapped_size(rm));
319 rm->mapped = NULL;
320 } else
321 #endif
322 free(rm->mtx);
323 rm->mtx = NULL;
324 }
325 if (rm->nrows | rm->ncols | !rm->dtype) {
326 rm->nrows = rm->ncols = 0;
327 rm->ncomp = 3;
328 setcolor(rm->cexp, 1.f, 1.f, 1.f);
329 memcpy(rm->wlpart, WLPART, sizeof(rm->wlpart));
330 rm->swapin = 0;
331 }
332 SET_FILE_BINARY(fp);
333 rm->dtype = DTascii; /* assumed w/o FORMAT */
334 if (getheader(fp, get_dminfo, rm) < 0) {
335 fputs("Unrecognized matrix format\n", stderr);
336 return(0);
337 }
338 /* resolution string? */
339 if ((rm->nrows <= 0) | (rm->ncols <= 0)) {
340 if (!fscnresolu(&rm->ncols, &rm->nrows, fp))
341 return(0);
342 if ((rm->dtype == DTrgbe) | (rm->dtype == DTxyze) &&
343 rm->ncomp != 3)
344 return(0);
345 }
346 return(1);
347 }
348
349 /* Allocate & load post-header data from stream given type set in rm->dtype */
350 int
351 rmx_load_data(RMATRIX *rm, FILE *fp)
352 {
353 switch (rm->dtype) {
354 case DTascii:
355 SET_FILE_TEXT(fp);
356 return(rmx_load_ascii(rm, fp));
357 case DTfloat:
358 return(rmx_load_float(rm, fp));
359 case DTdouble:
360 return(rmx_load_double(rm, fp));
361 case DTrgbe:
362 case DTxyze:
363 return(rmx_load_rgbe(rm, fp));
364 case DTspec:
365 return(rmx_load_spec(rm, fp));
366 default:
367 fputs("Unsupported data type in rmx_loaddata()\n", stderr);
368 }
369 return(0);
370 }
371
372 /* Load matrix from supported file type */
373 RMATRIX *
374 rmx_load(const char *inspec, RMPref rmp)
375 {
376 FILE *fp;
377 RMATRIX *dnew;
378 int ok;
379
380 if (!inspec)
381 inspec = stdin_name;
382 else if (!*inspec)
383 return(NULL);
384 if (inspec == stdin_name) /* reading from stdin? */
385 fp = stdin;
386 else if (inspec[0] == '!')
387 fp = popen(inspec+1, "r");
388 else {
389 const char *sp = inspec; /* check suffix */
390 while (*sp)
391 ++sp;
392 while (sp > inspec && sp[-1] != '.')
393 --sp;
394 if (!strcasecmp(sp, "XML")) { /* assume it's a BSDF */
395 CMATRIX *cm = rmp==RMPtrans ? cm_loadBTDF(inspec) :
396 cm_loadBRDF(inspec, rmp==RMPreflB) ;
397 if (!cm)
398 return(NULL);
399 dnew = rmx_from_cmatrix(cm);
400 cm_free(cm);
401 dnew->dtype = DTascii;
402 return(dnew); /* return here */
403 } /* else open it ourselves */
404 fp = fopen(inspec, "r");
405 }
406 if (!fp)
407 return(NULL);
408 #ifdef getc_unlocked
409 flockfile(fp);
410 #endif
411 /* load header info */
412 if (!rmx_load_header(dnew = rmx_new(0,0,3), fp)) {
413 fprintf(stderr, "Bad header in: %s\n", inspec);
414 if (inspec[0] == '!') pclose(fp);
415 else fclose(fp);
416 rmx_free(dnew);
417 return(NULL);
418 }
419 ok = rmx_load_data(dnew, fp); /* allocate & load data */
420
421 if (fp != stdin) { /* close input stream */
422 if (inspec[0] == '!')
423 pclose(fp);
424 else
425 fclose(fp);
426 }
427 #ifdef getc_unlocked
428 else
429 funlockfile(fp);
430 #endif
431 if (!ok) { /* load failure? */
432 fprintf(stderr, "Error loading data from: %s\n", inspec);
433 rmx_free(dnew);
434 return(NULL);
435 }
436 /* undo exposure? */
437 if ((dnew->cexp[0] != 1.f) |
438 (dnew->cexp[1] != 1.f) | (dnew->cexp[2] != 1.f)) {
439 double cmlt[MAXCSAMP];
440 int i;
441 cmlt[0] = 1./dnew->cexp[0];
442 cmlt[1] = 1./dnew->cexp[1];
443 cmlt[2] = 1./dnew->cexp[2];
444 if (dnew->ncomp > MAXCSAMP) {
445 fprintf(stderr, "Excess spectral components in: %s\n",
446 inspec);
447 rmx_free(dnew);
448 return(NULL);
449 }
450 for (i = dnew->ncomp; i-- > 3; )
451 cmlt[i] = cmlt[1];
452 rmx_scale(dnew, cmlt);
453 setcolor(dnew->cexp, 1.f, 1.f, 1.f);
454 }
455 return(dnew);
456 }
457
458 static int
459 rmx_write_ascii(const RMATRIX *rm, FILE *fp)
460 {
461 const char *fmt = (rm->dtype == DTfloat) ? " %.7e" :
462 (rm->dtype == DTrgbe) | (rm->dtype == DTxyze) |
463 (rm->dtype == DTspec) ? " %.3e" : " %.15e" ;
464 int i, j, k;
465
466 for (i = 0; i < rm->nrows; i++) {
467 for (j = 0; j < rm->ncols; j++) {
468 const double *dp = rmx_val(rm,i,j);
469 for (k = 0; k < rm->ncomp; k++)
470 fprintf(fp, fmt, dp[k]);
471 fputc('\t', fp);
472 }
473 fputc('\n', fp);
474 }
475 return(1);
476 }
477
478 static int
479 rmx_write_float(const RMATRIX *rm, FILE *fp)
480 {
481 int i, j, k;
482 float val[100];
483
484 if (rm->ncomp > 100) {
485 fputs("Unsupported # components in rmx_write_float()\n", stderr);
486 exit(1);
487 }
488 for (i = 0; i < rm->nrows; i++)
489 for (j = 0; j < rm->ncols; j++) {
490 const double *dp = rmx_val(rm,i,j);
491 for (k = rm->ncomp; k--; )
492 val[k] = (float)dp[k];
493 if (putbinary(val, sizeof(float), rm->ncomp, fp) != rm->ncomp)
494 return(0);
495 }
496 return(1);
497 }
498
499 static int
500 rmx_write_double(const RMATRIX *rm, FILE *fp)
501 {
502 int i;
503
504 for (i = 0; i < rm->nrows; i++)
505 if (putbinary(rmx_val(rm,i,0), sizeof(double)*rm->ncomp,
506 rm->ncols, fp) != rm->ncols)
507 return(0);
508 return(1);
509 }
510
511 static int
512 rmx_write_rgbe(const RMATRIX *rm, FILE *fp)
513 {
514 COLR *scan = (COLR *)malloc(sizeof(COLR)*rm->ncols);
515 int i, j;
516
517 if (!scan)
518 return(0);
519 for (i = 0; i < rm->nrows; i++) {
520 for (j = rm->ncols; j--; ) {
521 const double *dp = rmx_val(rm,i,j);
522 if (rm->ncomp == 1)
523 setcolr(scan[j], dp[0], dp[0], dp[0]);
524 else
525 setcolr(scan[j], dp[0], dp[1], dp[2]);
526 }
527 if (fwritecolrs(scan, rm->ncols, fp) < 0) {
528 free(scan);
529 return(0);
530 }
531 }
532 free(scan);
533 return(1);
534 }
535
536 static int
537 rmx_write_spec(const RMATRIX *rm, FILE *fp)
538 {
539 uby8 *scan = (uby8 *)malloc((rm->ncomp+1)*rm->ncols);
540 int ok = 1;
541 SCOLOR scol;
542 int i, j, k;
543
544 if (!scan)
545 return(0);
546 for (i = 0; i < rm->nrows; i++) {
547 for (j = rm->ncols; j--; ) {
548 const double *dp = rmx_val(rm,i,j);
549 for (k = rm->ncomp; k--; )
550 scol[k] = dp[k];
551 scolor2scolr(scan+j*(rm->ncomp+1), scol, rm->ncomp);
552 }
553 if (fwritescolrs(scan, rm->ncomp, rm->ncols, fp) < 0) {
554 ok = 0;
555 break;
556 }
557 }
558 free(scan);
559 return(ok);
560 }
561
562 /* Check if CIE XYZ primaries were specified */
563 static int
564 findCIEprims(const char *info)
565 {
566 RGBPRIMS prims;
567
568 if (!info)
569 return(0);
570 info = strstr(info, PRIMARYSTR);
571 if (!info || !primsval(prims, info))
572 return(0);
573
574 return((prims[RED][CIEX] > .99) & (prims[RED][CIEY] < .01) &&
575 (prims[GRN][CIEX] < .01) & (prims[GRN][CIEY] > .99) &&
576 (prims[BLU][CIEX] < .01) & (prims[BLU][CIEY] < .01));
577 }
578
579 /* Write matrix to file type indicated by dtype */
580 int
581 rmx_write(const RMATRIX *rm, int dtype, FILE *fp)
582 {
583 int ok = 1;
584
585 if (!rm | !fp || !rm->mtx)
586 return(0);
587 #ifdef getc_unlocked
588 flockfile(fp);
589 #endif
590 /* complete header */
591 if (rm->info)
592 fputs(rm->info, fp);
593 if (dtype == DTfromHeader)
594 dtype = rm->dtype;
595 else if (dtype == DTrgbe && (rm->dtype == DTxyze ||
596 findCIEprims(rm->info)))
597 dtype = DTxyze;
598 else if ((dtype == DTxyze) & (rm->dtype == DTrgbe))
599 dtype = DTrgbe;
600 /* write exposure? */
601 if (rm->ncomp == 3 && (rm->cexp[RED] != rm->cexp[GRN]) |
602 (rm->cexp[GRN] != rm->cexp[BLU]))
603 fputcolcor(rm->cexp, fp);
604 else if (rm->cexp[GRN] != 1.f)
605 fputexpos(rm->cexp[GRN], fp);
606 if ((dtype != DTrgbe) & (dtype != DTxyze)) {
607 if (dtype == DTspec) {
608 if (rm->ncomp < 3)
609 return(0); /* bad # components */
610 fputwlsplit(rm->wlpart, fp);
611 } else {
612 fprintf(fp, "NROWS=%d\n", rm->nrows);
613 fprintf(fp, "NCOLS=%d\n", rm->ncols);
614 }
615 fputncomp(rm->ncomp, fp);
616 } else if ((rm->ncomp != 3) & (rm->ncomp != 1))
617 return(0); /* wrong # components */
618 if ((dtype == DTfloat) | (dtype == DTdouble))
619 fputendian(fp); /* important to record */
620 fputformat(cm_fmt_id[dtype], fp);
621 fputc('\n', fp);
622 switch (dtype) { /* write data */
623 case DTascii:
624 ok = rmx_write_ascii(rm, fp);
625 break;
626 case DTfloat:
627 ok = rmx_write_float(rm, fp);
628 break;
629 case DTdouble:
630 ok = rmx_write_double(rm, fp);
631 break;
632 case DTrgbe:
633 case DTxyze:
634 fprtresolu(rm->ncols, rm->nrows, fp);
635 ok = rmx_write_rgbe(rm, fp);
636 break;
637 case DTspec:
638 fprtresolu(rm->ncols, rm->nrows, fp);
639 ok = rmx_write_spec(rm, fp);
640 break;
641 default:
642 return(0);
643 }
644 ok &= (fflush(fp) == 0);
645 #ifdef getc_unlocked
646 funlockfile(fp);
647 #endif
648 if (!ok) fputs("Error writing matrix\n", stderr);
649 return(ok);
650 }
651
652 /* Allocate and assign square identity matrix with n components */
653 RMATRIX *
654 rmx_identity(const int dim, const int n)
655 {
656 RMATRIX *rid = rmx_alloc(dim, dim, n);
657 int i, k;
658
659 if (!rid)
660 return(NULL);
661 memset(rid->mtx, 0, array_size(rid));
662 for (i = dim; i--; ) {
663 double *dp = rmx_lval(rid,i,i);
664 for (k = n; k--; )
665 dp[k] = 1.;
666 }
667 return(rid);
668 }
669
670 /* Duplicate the given matrix */
671 RMATRIX *
672 rmx_copy(const RMATRIX *rm)
673 {
674 RMATRIX *dnew;
675
676 if (!rm)
677 return(NULL);
678 dnew = rmx_alloc(rm->nrows, rm->ncols, rm->ncomp);
679 if (!dnew)
680 return(NULL);
681 rmx_addinfo(dnew, rm->info);
682 dnew->dtype = rm->dtype;
683 copycolor(dnew->cexp, rm->cexp);
684 memcpy(dnew->wlpart, rm->wlpart, sizeof(dnew->wlpart));
685 memcpy(dnew->mtx, rm->mtx, array_size(dnew));
686 return(dnew);
687 }
688
689 /* Allocate and assign transposed matrix */
690 RMATRIX *
691 rmx_transpose(const RMATRIX *rm)
692 {
693 RMATRIX *dnew;
694 int i, j;
695
696 if (!rm)
697 return(0);
698 if ((rm->nrows == 1) | (rm->ncols == 1)) {
699 dnew = rmx_copy(rm);
700 if (!dnew)
701 return(NULL);
702 dnew->nrows = rm->ncols;
703 dnew->ncols = rm->nrows;
704 return(dnew);
705 }
706 dnew = rmx_alloc(rm->ncols, rm->nrows, rm->ncomp);
707 if (!dnew)
708 return(NULL);
709 if (rm->info) {
710 rmx_addinfo(dnew, rm->info);
711 rmx_addinfo(dnew, "Transposed rows and columns\n");
712 }
713 dnew->dtype = rm->dtype;
714 copycolor(dnew->cexp, rm->cexp);
715 memcpy(dnew->wlpart, rm->wlpart, sizeof(dnew->wlpart));
716 for (j = dnew->ncols; j--; )
717 for (i = dnew->nrows; i--; )
718 memcpy(rmx_lval(dnew,i,j), rmx_val(rm,j,i),
719 sizeof(double)*dnew->ncomp);
720 return(dnew);
721 }
722
723 /* Multiply (concatenate) two matrices and allocate the result */
724 RMATRIX *
725 rmx_multiply(const RMATRIX *m1, const RMATRIX *m2)
726 {
727 RMATRIX *mres;
728 int i, j, k, h;
729
730 if (!m1 | !m2 || (m1->ncomp != m2->ncomp) | (m1->ncols != m2->nrows))
731 return(NULL);
732 mres = rmx_alloc(m1->nrows, m2->ncols, m1->ncomp);
733 if (!mres)
734 return(NULL);
735 i = rmx_newtype(m1->dtype, m2->dtype);
736 if (i)
737 mres->dtype = i;
738 else
739 rmx_addinfo(mres, rmx_mismatch_warn);
740 for (i = mres->nrows; i--; )
741 for (j = mres->ncols; j--; )
742 for (k = mres->ncomp; k--; ) {
743 double d = 0;
744 for (h = m1->ncols; h--; )
745 d += rmx_val(m1,i,h)[k] * rmx_val(m2,h,j)[k];
746 rmx_lval(mres,i,j)[k] = d;
747 }
748 return(mres);
749 }
750
751 /* Element-wise multiplication (or division) of m2 into m1 */
752 int
753 rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide)
754 {
755 int zeroDivides = 0;
756 int i, j, k;
757
758 if (!m1 | !m2 || (m1->ncols != m2->ncols) | (m1->nrows != m2->nrows))
759 return(0);
760 if ((m2->ncomp > 1) & (m2->ncomp != m1->ncomp))
761 return(0);
762 i = rmx_newtype(m1->dtype, m2->dtype);
763 if (i)
764 m1->dtype = i;
765 else
766 rmx_addinfo(m1, rmx_mismatch_warn);
767 for (i = m1->nrows; i--; )
768 for (j = m1->ncols; j--; )
769 if (divide) {
770 double d;
771 if (m2->ncomp == 1) {
772 d = rmx_val(m2,i,j)[0];
773 if (d == 0) {
774 ++zeroDivides;
775 for (k = m1->ncomp; k--; )
776 rmx_lval(m1,i,j)[k] = 0;
777 } else {
778 d = 1./d;
779 for (k = m1->ncomp; k--; )
780 rmx_lval(m1,i,j)[k] *= d;
781 }
782 } else
783 for (k = m1->ncomp; k--; ) {
784 d = rmx_val(m2,i,j)[k];
785 if (d == 0) {
786 ++zeroDivides;
787 rmx_lval(m1,i,j)[k] = 0;
788 } else
789 rmx_lval(m1,i,j)[k] /= d;
790 }
791 } else {
792 if (m2->ncomp == 1) {
793 const double d = rmx_val(m2,i,j)[0];
794 for (k = m1->ncomp; k--; )
795 rmx_lval(m1,i,j)[k] *= d;
796 } else
797 for (k = m1->ncomp; k--; )
798 rmx_lval(m1,i,j)[k] *= rmx_val(m2,i,j)[k];
799 }
800 if (zeroDivides) {
801 rmx_addinfo(m1, "WARNING: zero divide(s) corrupted results\n");
802 errno = ERANGE;
803 }
804 return(1);
805 }
806
807 /* Sum second matrix into first, applying scale factor beforehand */
808 int
809 rmx_sum(RMATRIX *msum, const RMATRIX *madd, const double sf[])
810 {
811 double *mysf = NULL;
812 int i, j, k;
813
814 if (!msum | !madd ||
815 (msum->nrows != madd->nrows) |
816 (msum->ncols != madd->ncols) |
817 (msum->ncomp != madd->ncomp))
818 return(0);
819 if (!sf) {
820 mysf = (double *)malloc(sizeof(double)*msum->ncomp);
821 if (!mysf)
822 return(0);
823 for (k = msum->ncomp; k--; )
824 mysf[k] = 1;
825 sf = mysf;
826 }
827 i = rmx_newtype(msum->dtype, madd->dtype);
828 if (i)
829 msum->dtype = i;
830 else
831 rmx_addinfo(msum, rmx_mismatch_warn);
832 for (i = msum->nrows; i--; )
833 for (j = msum->ncols; j--; ) {
834 const double *da = rmx_val(madd,i,j);
835 double *ds = rmx_lval(msum,i,j);
836 for (k = msum->ncomp; k--; )
837 ds[k] += sf[k] * da[k];
838 }
839 if (mysf)
840 free(mysf);
841 return(1);
842 }
843
844 /* Scale the given matrix by the indicated scalar component vector */
845 int
846 rmx_scale(RMATRIX *rm, const double sf[])
847 {
848 int i, j, k;
849
850 if (!rm | !sf)
851 return(0);
852 for (i = rm->nrows; i--; )
853 for (j = rm->ncols; j--; ) {
854 double *dp = rmx_lval(rm,i,j);
855 for (k = rm->ncomp; k--; )
856 dp[k] *= sf[k];
857 }
858 if (rm->info)
859 rmx_addinfo(rm, "Applied scalar\n");
860 /* XXX: should record as exposure for COLR and SCOLR types? */
861 return(1);
862 }
863
864 /* Allocate new matrix and apply component transformation */
865 RMATRIX *
866 rmx_transform(const RMATRIX *msrc, int n, const double cmat[])
867 {
868 int i, j, ks, kd;
869 RMATRIX *dnew;
870
871 if (!msrc | (n <= 0) | !cmat)
872 return(NULL);
873 dnew = rmx_alloc(msrc->nrows, msrc->ncols, n);
874 if (!dnew)
875 return(NULL);
876 if (msrc->info) {
877 char buf[128];
878 sprintf(buf, "Applied %dx%d component transform\n",
879 dnew->ncomp, msrc->ncomp);
880 rmx_addinfo(dnew, msrc->info);
881 rmx_addinfo(dnew, buf);
882 }
883 dnew->dtype = msrc->dtype;
884 for (i = dnew->nrows; i--; )
885 for (j = dnew->ncols; j--; ) {
886 const double *ds = rmx_val(msrc,i,j);
887 for (kd = dnew->ncomp; kd--; ) {
888 double d = 0;
889 for (ks = msrc->ncomp; ks--; )
890 d += cmat[kd*msrc->ncomp + ks] * ds[ks];
891 rmx_lval(dnew,i,j)[kd] = d;
892 }
893 }
894 return(dnew);
895 }
896
897 /* Convert a color matrix to newly allocated RMATRIX buffer */
898 RMATRIX *
899 rmx_from_cmatrix(const CMATRIX *cm)
900 {
901 int i, j;
902 RMATRIX *dnew;
903
904 if (!cm)
905 return(NULL);
906 dnew = rmx_alloc(cm->nrows, cm->ncols, 3);
907 if (!dnew)
908 return(NULL);
909 dnew->dtype = DTfloat;
910 for (i = dnew->nrows; i--; )
911 for (j = dnew->ncols; j--; ) {
912 const COLORV *cv = cm_lval(cm,i,j);
913 double *dp = rmx_lval(dnew,i,j);
914 dp[0] = cv[0];
915 dp[1] = cv[1];
916 dp[2] = cv[2];
917 }
918 return(dnew);
919 }
920
921 /* Convert general matrix to newly allocated CMATRIX buffer */
922 CMATRIX *
923 cm_from_rmatrix(const RMATRIX *rm)
924 {
925 int i, j;
926 CMATRIX *cnew;
927
928 if (!rm || !rm->mtx | (rm->ncomp == 2))
929 return(NULL);
930 cnew = cm_alloc(rm->nrows, rm->ncols);
931 if (!cnew)
932 return(NULL);
933 for (i = cnew->nrows; i--; )
934 for (j = cnew->ncols; j--; ) {
935 const double *dp = rmx_val(rm,i,j);
936 COLORV *cv = cm_lval(cnew,i,j);
937 switch (rm->ncomp) {
938 case 3:
939 setcolor(cv, dp[0], dp[1], dp[2]);
940 break;
941 case 1:
942 setcolor(cv, dp[0], dp[0], dp[0]);
943 break;
944 default: {
945 SCOLOR scol;
946 int k;
947 for (k = rm->ncomp; k--; )
948 scol[k] = dp[k];
949 scolor2color(cv, scol, rm->ncomp, rm->wlpart);
950 } break;
951 }
952 }
953 return(cnew);
954 }
