--- ray/src/util/rmatrix.c 2019/09/04 00:03:05 2.37 +++ ray/src/util/rmatrix.c 2025/04/19 17:12:59 2.98 @@ -1,49 +1,101 @@ #ifndef lint -static const char RCSid[] = "$Id: rmatrix.c,v 2.37 2019/09/04 00:03:05 greg Exp $"; +static const char RCSid[] = "$Id: rmatrix.c,v 2.98 2025/04/19 17:12:59 greg Exp $"; #endif /* * General matrix operations. */ -#include #include -#include -#include #include #include "rtio.h" #include "platform.h" #include "resolu.h" #include "paths.h" #include "rmatrix.h" +#if !defined(_WIN32) && !defined(_WIN64) +#include +#endif -static char rmx_mismatch_warn[] = "WARNING: data type mismatch\n"; +static const char rmx_mismatch_warn[] = "WARNING: data type mismatch\n"; -/* Allocate a nr x nc matrix with n components */ +/* Initialize a RMATRIX struct but don't allocate array space */ RMATRIX * -rmx_alloc(int nr, int nc, int n) +rmx_new(int nr, int nc, int n) { RMATRIX *dnew; - if ((nr <= 0) | (nc <= 0) | (n <= 0)) + if (n <= 0) return(NULL); - dnew = (RMATRIX *)malloc(sizeof(RMATRIX)-sizeof(dnew->mtx) + - sizeof(dnew->mtx[0])*(n*nr*nc)); + + dnew = (RMATRIX *)calloc(1, sizeof(RMATRIX)); if (!dnew) return(NULL); - dnew->nrows = nr; dnew->ncols = nc; dnew->ncomp = n; - dnew->dtype = DTdouble; - dnew->swapin = 0; - dnew->info = NULL; + + dnew->dtype = DTrmx_native; + dnew->nrows = nr; + dnew->ncols = nc; + dnew->ncomp = n; + setcolor(dnew->cexp, 1.f, 1.f, 1.f); + memcpy(dnew->wlpart, WLPART, sizeof(dnew->wlpart)); + return(dnew); } -/* Free a RMATRIX array */ +/* Prepare a RMATRIX for writing (allocate array if needed) */ +int +rmx_prepare(RMATRIX *rm) +{ + if (!rm) return(0); + if (rm->mtx) /* assume it's right size */ + return(1); + if ((rm->nrows <= 0) | (rm->ncols <= 0) | (rm->ncomp <= 0)) + return(0); + rm->mtx = (rmx_dtype *)malloc(rmx_array_size(rm)); + rm->pflags |= RMF_FREEMEM; + return(rm->mtx != NULL); +} + +/* Call rmx_new() and rmx_prepare() */ +RMATRIX * +rmx_alloc(int nr, int nc, int n) +{ + RMATRIX *dnew = rmx_new(nr, nc, n); + + if (!rmx_prepare(dnew)) { + rmx_free(dnew); + return(NULL); + } + return(dnew); +} + +/* Clear state by freeing info and matrix data */ void -rmx_free(RMATRIX *rm) +rmx_reset(RMATRIX *rm) { if (!rm) return; - if (rm->info) + if (rm->info) { free(rm->info); + rm->info = NULL; + } +#ifdef MAP_FILE + if (rm->mapped) { + munmap(rm->mapped, rmx_mapped_size(rm)); + rm->mapped = NULL; + } else +#endif + if (rm->pflags & RMF_FREEMEM) { + free(rm->mtx); + rm->pflags &= ~RMF_FREEMEM; + } + rm->mtx = NULL; +} + +/* Free an RMATRIX struct and data */ +void +rmx_free(RMATRIX *rm) +{ + if (!rm) return; + rmx_reset(rm); free(rm); } @@ -51,8 +103,8 @@ rmx_free(RMATRIX *rm) int rmx_newtype(int dtyp1, int dtyp2) { - if ((dtyp1==DTxyze) | (dtyp1==DTrgbe) | - (dtyp2==DTxyze) | (dtyp2==DTrgbe) + if ((dtyp1==DTxyze) | (dtyp1==DTrgbe) | (dtyp1==DTspec) | + (dtyp2==DTxyze) | (dtyp2==DTrgbe) | (dtyp2==DTspec) && dtyp1 != dtyp2) return(0); if (dtyp1 < dtyp2) @@ -64,17 +116,20 @@ rmx_newtype(int dtyp1, int dtyp2) int rmx_addinfo(RMATRIX *rm, const char *info) { + size_t oldlen = 0; + if (!rm || !info || !*info) return(0); if (!rm->info) { rm->info = (char *)malloc(strlen(info)+1); - if (rm->info) rm->info[0] = '\0'; - } else + } else { + oldlen = strlen(rm->info); rm->info = (char *)realloc(rm->info, - strlen(rm->info)+strlen(info)+1); + oldlen+strlen(info)+1); + } if (!rm->info) return(0); - strcat(rm->info, info); + strcpy(rm->info+oldlen, info); return(1); } @@ -85,202 +140,289 @@ get_dminfo(char *s, void *p) char fmt[MAXFMTLEN]; int i; - if (headidval(fmt, s)) + if (isheadid(s)) return(0); - if (!strncmp(s, "NCOMP=", 6)) { - ip->ncomp = atoi(s+6); - return(0); + if (isncomp(s)) { + ip->ncomp = ncompval(s); + return(ip->ncomp - 1); } if (!strncmp(s, "NROWS=", 6)) { ip->nrows = atoi(s+6); - return(0); + return(ip->nrows - 1); } if (!strncmp(s, "NCOLS=", 6)) { ip->ncols = atoi(s+6); - return(0); + return(ip->ncols - 1); } if ((i = isbigendian(s)) >= 0) { - ip->swapin = (nativebigendian() != i); + if (nativebigendian() != i) + ip->pflags |= RMF_SWAPIN; + else + ip->pflags &= ~RMF_SWAPIN; return(0); } + if (isexpos(s)) { + float f = exposval(s); + scalecolor(ip->cexp, f); + return(f > .0 ? 0 : -1); + } + if (iscolcor(s)) { + COLOR ctmp; + if (!colcorval(ctmp, s)) return(-1); + multcolor(ip->cexp, ctmp); + return(0); + } + if (iswlsplit(s)) + return(wlsplitval(ip->wlpart, s) - 1); + if (!formatval(fmt, s)) { rmx_addinfo(ip, s); return(0); - } + } /* else check format */ for (i = 1; i < DTend; i++) if (!strcmp(fmt, cm_fmt_id[i])) { ip->dtype = i; return(0); } - return(-1); + return(-1); /* bad format */ } static int -rmx_load_ascii(RMATRIX *rm, FILE *fp) +rmx_load_ascii(rmx_dtype *drp, const RMATRIX *rm, FILE *fp) { - int i, j, k; + int j, k; - for (i = 0; i < rm->nrows; i++) - for (j = 0; j < rm->ncols; j++) - for (k = 0; k < rm->ncomp; k++) - if (fscanf(fp, "%lf", &rmx_lval(rm,i,j,k)) != 1) - return(0); + for (j = 0; j < rm->ncols; j++) + for (k = rm->ncomp; k-- > 0; ) + if (fscanf(fp, rmx_scanfmt, drp++) != 1) + return(0); return(1); } static int -rmx_load_float(RMATRIX *rm, FILE *fp) +rmx_load_float(rmx_dtype *drp, const RMATRIX *rm, FILE *fp) { - int i, j, k; - float val[100]; +#if DTrmx_native==DTfloat + if (getbinary(drp, sizeof(*drp)*rm->ncomp, rm->ncols, fp) != rm->ncols) + return(0); + if (rm->pflags & RMF_SWAPIN) + swap32((char *)drp, rm->ncols*rm->ncomp); +#else + int j, k; + float val[MAXCOMP]; - if (rm->ncomp > 100) { + if (rm->ncomp > MAXCOMP) { fputs("Unsupported # components in rmx_load_float()\n", stderr); exit(1); } - for (i = 0; i < rm->nrows; i++) - for (j = 0; j < rm->ncols; j++) { + for (j = 0; j < rm->ncols; j++) { if (getbinary(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp) - return(0); - if (rm->swapin) - swap32((char *)val, rm->ncomp); - for (k = rm->ncomp; k--; ) - rmx_lval(rm,i,j,k) = val[k]; - } + return(0); + if (rm->pflags & RMF_SWAPIN) + swap32((char *)val, rm->ncomp); + for (k = 0; k < rm->ncomp; k++) + *drp++ = val[k]; + } +#endif return(1); } static int -rmx_load_double(RMATRIX *rm, FILE *fp) +rmx_load_double(rmx_dtype *drp, const RMATRIX *rm, FILE *fp) { - int i, j; +#if DTrmx_native==DTdouble + if (getbinary(drp, sizeof(*drp)*rm->ncomp, rm->ncols, fp) != rm->ncols) + return(0); + if (rm->pflags & RMF_SWAPIN) + swap64((char *)drp, rm->ncols*rm->ncomp); +#else + int j, k; + double val[MAXCOMP]; - for (i = 0; i < rm->nrows; i++) - for (j = 0; j < rm->ncols; j++) { - if (getbinary(&rmx_lval(rm,i,j,0), sizeof(double), rm->ncomp, fp) != rm->ncomp) - return(0); - if (rm->swapin) - swap64((char *)&rmx_lval(rm,i,j,0), rm->ncomp); - } + if (rm->ncomp > MAXCOMP) { + fputs("Unsupported # components in rmx_load_double()\n", stderr); + exit(1); + } + for (j = 0; j < rm->ncols; j++) { + if (getbinary(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp) + return(0); + if (rm->pflags & RMF_SWAPIN) + swap64((char *)val, rm->ncomp); + for (k = 0; k < rm->ncomp; k++) + *drp++ = (float)val[k]; + } +#endif return(1); } static int -rmx_load_rgbe(RMATRIX *rm, FILE *fp) +rmx_load_rgbe(rmx_dtype *drp, const RMATRIX *rm, FILE *fp) { - COLOR *scan = (COLOR *)malloc(sizeof(COLOR)*rm->ncols); - int i, j; + COLR *scan; + COLOR col; + int j; + if (rm->ncomp != 3) + return(0); + scan = (COLR *)tempbuffer(sizeof(COLR)*rm->ncols); if (!scan) return(0); - for (i = 0; i < rm->nrows; i++) { - if (freadscan(scan, rm->ncols, fp) < 0) { - free(scan); + if (freadcolrs(scan, rm->ncols, fp) < 0) return(0); - } - for (j = rm->ncols; j--; ) { - rmx_lval(rm,i,j,0) = colval(scan[j],RED); - rmx_lval(rm,i,j,1) = colval(scan[j],GRN); - rmx_lval(rm,i,j,2) = colval(scan[j],BLU); - } + for (j = 0; j < rm->ncols; j++) { + colr_color(col, scan[j]); + *drp++ = colval(col,RED); + *drp++ = colval(col,GRN); + *drp++ = colval(col,BLU); } - free(scan); return(1); } -/* Load matrix from supported file type */ -RMATRIX * -rmx_load(const char *inspec) +static int +rmx_load_spec(rmx_dtype *drp, const RMATRIX *rm, FILE *fp) { - FILE *fp = stdin; - RMATRIX dinfo; - RMATRIX *dnew; + COLRV *scan; + COLORV scol[MAXCOMP]; + int j, k; - if (!inspec) { /* reading from stdin? */ - inspec = ""; - SET_FILE_BINARY(stdin); - } else if (inspec[0] == '!') { - if (!(fp = popen(inspec+1, "r"))) - return(NULL); - SET_FILE_BINARY(fp); - } else { - const char *sp = inspec; /* check suffix */ - while (*sp) - ++sp; - while (sp > inspec && sp[-1] != '.') - --sp; - if (!strcasecmp(sp, "XML")) { /* assume it's a BSDF */ - CMATRIX *cm = cm_loadBTDF((char *)inspec); - if (!cm) - return(NULL); - dnew = rmx_from_cmatrix(cm); - cm_free(cm); - dnew->dtype = DTascii; - return(dnew); - } - /* else open it ourselves */ - if (!(fp = fopen(inspec, "rb"))) - return(NULL); + if ((rm->ncomp < 3) | (rm->ncomp > MAXCOMP)) + return(0); + scan = (COLRV *)tempbuffer((rm->ncomp+1)*rm->ncols); + if (!scan) + return(0); + if (freadscolrs(scan, rm->ncomp, rm->ncols, fp) < 0) + return(0); + for (j = 0; j < rm->ncols; j++) { + scolr2scolor(scol, scan+j*(rm->ncomp+1), rm->ncomp); + for (k = 0; k < rm->ncomp; k++) + *drp++ = scol[k]; } -#ifdef getc_unlocked - flockfile(fp); -#endif - dinfo.nrows = dinfo.ncols = dinfo.ncomp = 0; - dinfo.dtype = DTascii; /* assumed w/o FORMAT */ - dinfo.swapin = 0; - dinfo.info = NULL; - if (getheader(fp, get_dminfo, &dinfo) < 0) { - fclose(fp); - return(NULL); + return(1); +} + +/* Read matrix header from input stream (cannot be XML) */ +int +rmx_load_header(RMATRIX *rm, FILE *fp) +{ + if (!rm | !fp) + return(0); + rmx_reset(rm); /* clear state */ + if (rm->nrows | rm->ncols | !rm->dtype) { + rm->nrows = rm->ncols = 0; + rm->ncomp = 3; + setcolor(rm->cexp, 1.f, 1.f, 1.f); + memcpy(rm->wlpart, WLPART, sizeof(rm->wlpart)); + rm->pflags = 0; } - if ((dinfo.nrows <= 0) | (dinfo.ncols <= 0)) { - if (!fscnresolu(&dinfo.ncols, &dinfo.nrows, fp)) { - fclose(fp); - return(NULL); - } - if (dinfo.ncomp <= 0) - dinfo.ncomp = 3; - else if ((dinfo.dtype == DTrgbe) | (dinfo.dtype == DTxyze) && - dinfo.ncomp != 3) { - fclose(fp); - return(NULL); - } + rm->dtype = DTascii; /* assumed w/o FORMAT */ + if (getheader(fp, get_dminfo, rm) < 0) { + fputs("Bad matrix header\n", stderr); + return(0); } - dnew = rmx_alloc(dinfo.nrows, dinfo.ncols, dinfo.ncomp); - if (!dnew) { - fclose(fp); - return(NULL); - } - dnew->info = dinfo.info; - switch (dinfo.dtype) { - case DTascii: + if ((rm->dtype == DTrgbe) | (rm->dtype == DTxyze) && + rm->ncomp != 3) + return(0); + if (rm->ncols <= 0 && /* resolution string? */ + !fscnresolu(&rm->ncols, &rm->nrows, fp)) + return(0); + if (rm->dtype == DTascii) /* set file type (WINDOWS) */ SET_FILE_TEXT(fp); - if (!rmx_load_ascii(dnew, fp)) - goto loaderr; - dnew->dtype = DTascii; /* should leave double? */ - break; + else + SET_FILE_BINARY(fp); + return(1); +} + +/* Load next row as rmx_dtype (cannot be XML) */ +int +rmx_load_row(rmx_dtype *drp, const RMATRIX *rm, FILE *fp) +{ + switch (rm->dtype) { + case DTascii: + return(rmx_load_ascii(drp, rm, fp)); case DTfloat: - dnew->swapin = dinfo.swapin; - if (!rmx_load_float(dnew, fp)) - goto loaderr; - dnew->dtype = DTfloat; - break; + return(rmx_load_float(drp, rm, fp)); case DTdouble: - dnew->swapin = dinfo.swapin; - if (!rmx_load_double(dnew, fp)) - goto loaderr; - dnew->dtype = DTdouble; - break; + return(rmx_load_double(drp, rm, fp)); case DTrgbe: case DTxyze: - if (!rmx_load_rgbe(dnew, fp)) - goto loaderr; - dnew->dtype = dinfo.dtype; - break; + return(rmx_load_rgbe(drp, rm, fp)); + case DTspec: + return(rmx_load_spec(drp, rm, fp)); default: - goto loaderr; + fputs("Unsupported data type in rmx_load_row()\n", stderr); } - if (fp != stdin) { + return(0); +} + +/* Allocate & load post-header data from stream given type set in rm->dtype */ +int +rmx_load_data(RMATRIX *rm, FILE *fp) +{ + int i; +#ifdef MAP_FILE + long pos; /* map memory for file > 1MB if possible */ + if ((rm->dtype == DTrmx_native) & !(rm->pflags & RMF_SWAPIN) & + (rmx_array_size(rm) >= 1L<<20) && + (pos = ftell(fp)) >= 0 && !(pos % sizeof(rmx_dtype))) { + rm->mapped = mmap(NULL, rmx_array_size(rm)+pos, PROT_READ|PROT_WRITE, + MAP_PRIVATE, fileno(fp), 0); + if (rm->mapped != MAP_FAILED) { + if (rm->pflags & RMF_FREEMEM) + free(rm->mtx); + rm->mtx = (rmx_dtype *)rm->mapped + pos/sizeof(rmx_dtype); + rm->pflags &= ~RMF_FREEMEM; + return(1); + } /* else fall back on reading into memory */ + rm->mapped = NULL; + } +#endif + if (!rmx_prepare(rm)) { /* need in-core matrix array */ + fprintf(stderr, "Cannot allocate %g MByte matrix array\n", + (1./(1L<<20))*(double)rmx_array_size(rm)); + return(0); + } + for (i = 0; i < rm->nrows; i++) + if (!rmx_load_row(rmx_lval(rm,i,0), rm, fp)) + return(0); + return(1); +} + +/* Load matrix from supported file type */ +RMATRIX * +rmx_load(const char *inspec) +{ + FILE *fp; + RMATRIX *dnew; + int ok; + + if (!inspec) + inspec = stdin_name; + else if (!*inspec) + return(NULL); + if (inspec == stdin_name) /* reading from stdin? */ + fp = stdin; + else if (inspec[0] == '!') + fp = popen(inspec+1, "r"); + else + fp = fopen(inspec, "r"); + if (!fp) { + fprintf(stderr, "Cannot open for reading: %s\n", inspec); + return(NULL); + } +#ifdef getc_unlocked + flockfile(fp); +#endif + SET_FILE_BINARY(fp); /* load header info */ + if (!rmx_load_header(dnew = rmx_new(0,0,3), fp)) { + fprintf(stderr, "Bad header in: %s\n", inspec); + if (inspec[0] == '!') pclose(fp); + else fclose(fp); + rmx_free(dnew); + return(NULL); + } + ok = rmx_load_data(dnew, fp); /* allocate & load data */ + + if (fp != stdin) { /* close input stream */ if (inspec[0] == '!') pclose(fp); else @@ -290,152 +432,236 @@ rmx_load(const char *inspec) else funlockfile(fp); #endif + if (!ok) { /* load failure? */ + fprintf(stderr, "Error loading data from: %s\n", inspec); + rmx_free(dnew); + return(NULL); + } + /* undo exposure? */ + if ((dnew->cexp[0] != 1.f) | + (dnew->cexp[1] != 1.f) | (dnew->cexp[2] != 1.f)) { + double cmlt[MAXCOMP]; + int i; + if (dnew->ncomp > MAXCOMP) { + fprintf(stderr, "Excess spectral components in: %s\n", + inspec); + rmx_free(dnew); + return(NULL); + } + cmlt[0] = 1./dnew->cexp[0]; + cmlt[1] = 1./dnew->cexp[1]; + cmlt[2] = 1./dnew->cexp[2]; + for (i = dnew->ncomp; i-- > 3; ) + cmlt[i] = cmlt[1]; /* XXX hack! */ + rmx_scale(dnew, cmlt); + setcolor(dnew->cexp, 1.f, 1.f, 1.f); + } return(dnew); -loaderr: /* should report error? */ - if (inspec[0] == '!') - pclose(fp); - else - fclose(fp); - rmx_free(dnew); - return(NULL); } +#if DTrmx_native==DTdouble static int -rmx_write_ascii(const RMATRIX *rm, FILE *fp) +rmx_write_float(const rmx_dtype *dp, int len, FILE *fp) { - const char *fmt = (rm->dtype == DTfloat) ? " %.7e" : - (rm->dtype == DTrgbe) | (rm->dtype == DTxyze) ? " %.3e" : - " %.15e" ; - int i, j, k; + float val; - for (i = 0; i < rm->nrows; i++) { - for (j = 0; j < rm->ncols; j++) { - for (k = 0; k < rm->ncomp; k++) - fprintf(fp, fmt, rmx_lval(rm,i,j,k)); - fputc('\t', fp); - } - fputc('\n', fp); + while (len--) { + val = (float)*dp++; + if (putbinary(&val, sizeof(val), 1, fp) != 1) + return(0); } return(1); } - +#else static int -rmx_write_float(const RMATRIX *rm, FILE *fp) +rmx_write_double(const rmx_dtype *dp, int len, FILE *fp) { - int i, j, k; - float val[100]; + double val; - if (rm->ncomp > 100) { - fputs("Unsupported # components in rmx_write_float()\n", stderr); - exit(1); - } - for (i = 0; i < rm->nrows; i++) - for (j = 0; j < rm->ncols; j++) { - for (k = rm->ncomp; k--; ) - val[k] = (float)rmx_lval(rm,i,j,k); - if (putbinary(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp) + while (len--) { + val = *dp++; + if (putbinary(&val, sizeof(val), 1, fp) != 1) return(0); - } + } return(1); } +#endif static int -rmx_write_double(const RMATRIX *rm, FILE *fp) +rmx_write_ascii(const rmx_dtype *dp, int nc, int len, FILE *fp) { - int i, j; + while (len-- > 0) { + int k = nc; + while (k-- > 0) + fprintf(fp, " %.7e", *dp++); + fputc('\t', fp); + } + return(fputc('\n', fp) != EOF); +} - for (i = 0; i < rm->nrows; i++) - for (j = 0; j < rm->ncols; j++) - if (putbinary(&rmx_lval(rm,i,j,0), sizeof(double), rm->ncomp, fp) != rm->ncomp) - return(0); - return(1); +static int +rmx_write_rgbe(const rmx_dtype *dp, int nc, int len, FILE *fp) +{ + COLR *scan; + int j; + + if ((nc != 1) & (nc != 3)) return(0); + scan = (COLR *)tempbuffer(sizeof(COLR)*len); + if (!scan) return(0); + + for (j = 0; j < len; j++, dp += nc) + if (nc == 1) + setcolr(scan[j], dp[0], dp[0], dp[0]); + else + setcolr(scan[j], dp[0], dp[1], dp[2]); + + return(fwritecolrs(scan, len, fp) >= 0); } static int -rmx_write_rgbe(const RMATRIX *rm, FILE *fp) +rmx_write_spec(const rmx_dtype *dp, int nc, int len, FILE *fp) { - COLR *scan = (COLR *)malloc(sizeof(COLR)*rm->ncols); - int i, j; + COLRV *scan; + COLORV scol[MAXCOMP]; + int j, k; - if (!scan) + if ((nc < 3) | (nc > MAXCOMP)) return(0); + scan = (COLRV *)tempbuffer((nc+1)*len); + if (!scan) return(0); + for (j = 0; j < len; j++, dp += nc) { + for (k = nc; k--; ) + scol[k] = dp[k]; + scolor2scolr(scan+j*(nc+1), scol, nc); + } + return(fwritescolrs(scan, nc, len, fp) >= 0); +} + +/* Check if CIE XYZ primaries were specified */ +static int +findCIEprims(const char *info) +{ + RGBPRIMS prims; + + if (!info) return(0); - for (i = 0; i < rm->nrows; i++) { - for (j = rm->ncols; j--; ) - setcolr(scan[j], rmx_lval(rm,i,j,0), - rmx_lval(rm,i,j,1), - rmx_lval(rm,i,j,2) ); - if (fwritecolrs(scan, rm->ncols, fp) < 0) { - free(scan); + info = strstr(info, PRIMARYSTR); + if (!info || !primsval(prims, info)) return(0); - } - } - free(scan); - return(1); + + return((prims[RED][CIEX] > .99) & (prims[RED][CIEY] < .01) && + (prims[GRN][CIEX] < .01) & (prims[GRN][CIEY] > .99) && + (prims[BLU][CIEX] < .01) & (prims[BLU][CIEY] < .01)); } -/* Write matrix to file type indicated by dtype */ +/* Finish writing header data with resolution and format, returning type used */ int -rmx_write(const RMATRIX *rm, int dtype, FILE *fp) +rmx_write_header(const RMATRIX *rm, int dtype, FILE *fp) { - RMATRIX *mydm = NULL; - int ok = 1; - - if (!rm | !fp) + if (!rm | !fp || rm->ncols <= 0) return(0); -#ifdef getc_unlocked - flockfile(fp); -#endif - /* complete header */ if (rm->info) fputs(rm->info, fp); - if (dtype == DTfromHeader) + if (dtype == DTfromHeader) { dtype = rm->dtype; - else if ((dtype == DTrgbe) & (rm->dtype == DTxyze)) +#if DTrmx_native==DTfloat + if (dtype == DTdouble) /* but stored as float? */ + dtype = DTfloat; +#endif + } else if (dtype == DTrgbe && (rm->dtype == DTxyze || + findCIEprims(rm->info))) dtype = DTxyze; else if ((dtype == DTxyze) & (rm->dtype == DTrgbe)) dtype = DTrgbe; - if ((dtype != DTrgbe) & (dtype != DTxyze)) { - fprintf(fp, "NROWS=%d\n", rm->nrows); + if ((dtype < DTspec) & (rm->ncomp > 3)) + dtype = DTspec; + else if ((dtype == DTspec) & (rm->ncomp <= 3)) + return(0); + + if (dtype == DTascii) /* set file type (WINDOWS) */ + SET_FILE_TEXT(fp); + else + SET_FILE_BINARY(fp); + /* write exposure? */ + if (rm->ncomp == 3 && (rm->cexp[RED] != rm->cexp[GRN]) | + (rm->cexp[GRN] != rm->cexp[BLU])) + fputcolcor(rm->cexp, fp); + else if (rm->cexp[GRN] != 1.f) + fputexpos(rm->cexp[GRN], fp); + /* matrix size? */ + if ((dtype > DTspec) | (rm->nrows <= 0)) { + if (rm->nrows > 0) + fprintf(fp, "NROWS=%d\n", rm->nrows); fprintf(fp, "NCOLS=%d\n", rm->ncols); - fprintf(fp, "NCOMP=%d\n", rm->ncomp); - } else if (rm->ncomp != 3) { /* wrong # components? */ - double cmtx[3]; - if (rm->ncomp != 1) /* only convert grayscale */ - return(0); - cmtx[0] = cmtx[1] = cmtx[2] = 1; - mydm = rmx_transform(rm, 3, cmtx); - if (!mydm) - return(0); - rm = mydm; } + if (dtype >= DTspec) { /* # components & split? */ + fputncomp(rm->ncomp, fp); + if (rm->ncomp > 3 && + memcmp(rm->wlpart, WLPART, sizeof(WLPART))) + fputwlsplit(rm->wlpart, fp); + } else if ((rm->ncomp != 3) & (rm->ncomp != 1)) + return(0); /* wrong # components */ if ((dtype == DTfloat) | (dtype == DTdouble)) fputendian(fp); /* important to record */ - fputformat((char *)cm_fmt_id[dtype], fp); - fputc('\n', fp); - switch (dtype) { /* write data */ - case DTascii: - ok = rmx_write_ascii(rm, fp); - break; + fputformat(cm_fmt_id[dtype], fp); + fputc('\n', fp); /* end of header */ + if ((dtype <= DTspec) & (rm->nrows > 0)) + fprtresolu(rm->ncols, rm->nrows, fp); + return(dtype); +} + +/* Write out matrix data (usually by row) */ +int +rmx_write_data(const rmx_dtype *dp, int nc, int len, int dtype, FILE *fp) +{ + switch (dtype) { +#if DTrmx_native==DTdouble case DTfloat: - ok = rmx_write_float(rm, fp); - break; + return(rmx_write_float(dp, nc*len, fp)); +#else case DTdouble: - ok = rmx_write_double(rm, fp); - break; + return(rmx_write_double(dp, nc*len, fp)); +#endif + case DTrmx_native: + return(putbinary(dp, sizeof(*dp)*nc, len, fp) == len); + case DTascii: + return(rmx_write_ascii(dp, nc, len, fp)); case DTrgbe: case DTxyze: - fprtresolu(rm->ncols, rm->nrows, fp); - ok = rmx_write_rgbe(rm, fp); - break; - default: - return(0); + return(rmx_write_rgbe(dp, nc, len, fp)); + case DTspec: + return(rmx_write_spec(dp, nc, len, fp)); } - ok &= (fflush(fp) == 0); + return(0); +} + +/* Write matrix using file format indicated by dtype */ +int +rmx_write(const RMATRIX *rm, int dtype, FILE *fp) +{ + int ok = 0; + int i; + /* complete header */ + dtype = rmx_write_header(rm, dtype, fp); + if (dtype <= 0) + return(0); #ifdef getc_unlocked + flockfile(fp); +#endif + if (dtype == DTrmx_native) /* write all at once? */ + ok = rmx_write_data(rm->mtx, rm->ncomp, + rm->nrows*rm->ncols, dtype, fp); + else /* else row by row */ + for (i = 0; i < rm->nrows; i++) { + ok = rmx_write_data(rmx_val(rm,i,0), rm->ncomp, + rm->ncols, dtype, fp); + if (!ok) break; + } + + if (ok) ok = (fflush(fp) == 0); +#ifdef getc_unlocked funlockfile(fp); #endif - if (mydm) - rmx_free(mydm); + if (!ok) fputs("Error writing matrix\n", stderr); return(ok); } @@ -448,14 +674,16 @@ rmx_identity(const int dim, const int n) if (!rid) return(NULL); - memset(rid->mtx, 0, sizeof(rid->mtx[0])*n*dim*dim); - for (i = dim; i--; ) + memset(rid->mtx, 0, rmx_array_size(rid)); + for (i = dim; i--; ) { + rmx_dtype *dp = rmx_lval(rid,i,i); for (k = n; k--; ) - rmx_lval(rid,i,i,k) = 1; + dp[k] = 1.; + } return(rid); } -/* Duplicate the given matrix */ +/* Duplicate the given matrix (may be unallocated) */ RMATRIX * rmx_copy(const RMATRIX *rm) { @@ -463,46 +691,131 @@ rmx_copy(const RMATRIX *rm) if (!rm) return(NULL); - dnew = rmx_alloc(rm->nrows, rm->ncols, rm->ncomp); + dnew = rmx_new(rm->nrows, rm->ncols, rm->ncomp); if (!dnew) return(NULL); + if (rm->mtx) { + if (!rmx_prepare(dnew)) { + rmx_free(dnew); + return(NULL); + } + memcpy(dnew->mtx, rm->mtx, rmx_array_size(dnew)); + } rmx_addinfo(dnew, rm->info); dnew->dtype = rm->dtype; - memcpy(dnew->mtx, rm->mtx, - sizeof(rm->mtx[0])*rm->ncomp*rm->nrows*rm->ncols); + copycolor(dnew->cexp, rm->cexp); + memcpy(dnew->wlpart, rm->wlpart, sizeof(dnew->wlpart)); return(dnew); } -/* Allocate and assign transposed matrix */ -RMATRIX * -rmx_transpose(const RMATRIX *rm) +/* Replace data in first matrix with data from second */ +int +rmx_transfer_data(RMATRIX *rdst, RMATRIX *rsrc, int dometa) { - RMATRIX *dnew; - int i, j, k; + if (!rdst | !rsrc) + return(0); + if (dometa) { /* transfer everything? */ + rmx_reset(rdst); + *rdst = *rsrc; + rsrc->info = NULL; rsrc->mapped = NULL; rsrc->mtx = NULL; + return(1); + } + /* just matrix data -- leave metadata */ + if ((rdst->nrows != rsrc->nrows) | + (rdst->ncols != rsrc->ncols) | + (rdst->ncomp != rsrc->ncomp)) + return(0); +#ifdef MAP_FILE + if (rdst->mapped) + munmap(rdst->mapped, rmx_mapped_size(rdst)); + else +#endif + if (rdst->pflags & RMF_FREEMEM) { + free(rdst->mtx); + rdst->pflags &= ~RMF_FREEMEM; + } + rdst->mapped = rsrc->mapped; + rdst->mtx = rsrc->mtx; + rdst->pflags |= rsrc->pflags & RMF_FREEMEM; + rsrc->mapped = NULL; rsrc->mtx = NULL; + return(1); +} - if (!rm) +/* Transpose the given matrix */ +int +rmx_transpose(RMATRIX *rm) +{ + uby8 *bmap; + rmx_dtype val[MAXCOMP]; + RMATRIX dold; + int i, j; + + if (!rm || !rm->mtx | (rm->ncomp > MAXCOMP)) return(0); - if ((rm->nrows == 1) | (rm->ncols == 1)) { - dnew = rmx_copy(rm); - if (!dnew) - return(NULL); - dnew->nrows = rm->ncols; - dnew->ncols = rm->nrows; - return(dnew); + if (rm->info) + rmx_addinfo(rm, "Transposed rows and columns\n"); + if ((rm->nrows == 1) | (rm->ncols == 1)) { /* vector? */ + j = rm->ncols; + rm->ncols = rm->nrows; + rm->nrows = j; + return(1); } - dnew = rmx_alloc(rm->ncols, rm->nrows, rm->ncomp); - if (!dnew) - return(NULL); - if (rm->info) { - rmx_addinfo(dnew, rm->info); - rmx_addinfo(dnew, "Transposed rows and columns\n"); + if (rm->nrows == rm->ncols) { /* square matrix case */ + for (i = rm->nrows; i--; ) + for (j = rm->ncols; j--; ) { + if (i == j) continue; + memcpy(val, rmx_val(rm,i,j), + sizeof(rmx_dtype)*rm->ncomp); + memcpy(rmx_lval(rm,i,j), rmx_val(rm,j,i), + sizeof(rmx_dtype)*rm->ncomp); + memcpy(rmx_val(rm,j,i), val, + sizeof(rmx_dtype)*rm->ncomp); + } + return(1); } - dnew->dtype = rm->dtype; - for (i = dnew->nrows; i--; ) - for (j = dnew->ncols; j--; ) - for (k = dnew->ncomp; k--; ) - rmx_lval(dnew,i,j,k) = rmx_lval(rm,j,i,k); - return(dnew); +#define bmbyte(r,c) bmap[((r)*rm->ncols+(c))>>3] +#define bmbit(r,c) (1 << ((r)*rm->ncols+(c) & 7)) +#define bmop(r,c, op) (bmbyte(r,c) op bmbit(r,c)) +#define bmtest(r,c) bmop(r,c,&) +#define bmset(r,c) bmop(r,c,|=) + /* loop completion bitmap */ + bmap = (uby8 *)calloc(((size_t)rm->nrows*rm->ncols+7)>>3, 1); + if (!bmap) + return(0); + dold = *rm; + rm->ncols = dold.nrows; rm->nrows = dold.ncols; + for (i = rm->nrows; i--; ) /* try every starting point */ + for (j = rm->ncols; j--; ) { + int i0, j0; + int i1 = i; + size_t j1 = j; + if (bmtest(i, j)) + continue; /* traversed loop earlier */ + memcpy(val, rmx_val(rm,i,j), + sizeof(rmx_dtype)*rm->ncomp); + for ( ; ; ) { /* new transpose loop */ + const rmx_dtype *ds; + i0 = i1; j0 = j1; + ds = rmx_val(&dold, j0, i0); + j1 = (ds - dold.mtx)/dold.ncomp; + i1 = j1 / rm->ncols; + j1 -= (size_t)i1*rm->ncols; + bmset(i1, j1); /* mark as done */ + if ((i1 == i) & (j1 == j)) + break; /* back at start */ + memcpy(rmx_lval(rm,i0,j0), ds, + sizeof(rmx_dtype)*rm->ncomp); + } /* complete the loop */ + memcpy(rmx_lval(rm,i0,j0), val, + sizeof(rmx_dtype)*rm->ncomp); + } + free(bmap); /* all done! */ + return(1); +#undef bmbyte +#undef bmbit +#undef bmop +#undef bmtest +#undef bmset } /* Multiply (concatenate) two matrices and allocate the result */ @@ -512,7 +825,8 @@ rmx_multiply(const RMATRIX *m1, const RMATRIX *m2) RMATRIX *mres; int i, j, k, h; - if (!m1 | !m2 || (m1->ncomp != m2->ncomp) | (m1->ncols != m2->nrows)) + if (!m1 | !m2 || !m1->mtx | !m2->mtx | + (m1->ncomp != m2->ncomp) | (m1->ncols != m2->nrows)) return(NULL); mres = rmx_alloc(m1->nrows, m2->ncols, m1->ncomp); if (!mres) @@ -525,10 +839,11 @@ rmx_multiply(const RMATRIX *m1, const RMATRIX *m2) for (i = mres->nrows; i--; ) for (j = mres->ncols; j--; ) for (k = mres->ncomp; k--; ) { - long double d = 0; + double d = 0; for (h = m1->ncols; h--; ) - d += rmx_lval(m1,i,h,k) * rmx_lval(m2,h,j,k); - rmx_lval(mres,i,j,k) = (double)d; + d += (double)rmx_val(m1,i,h)[k] * + rmx_val(m2,h,j)[k]; + rmx_lval(mres,i,j)[k] = (rmx_dtype)d; } return(mres); } @@ -540,7 +855,8 @@ rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide int zeroDivides = 0; int i, j, k; - if (!m1 | !m2 || (m1->ncols != m2->ncols) | (m1->nrows != m2->nrows)) + if (!m1 | !m2 || !m1->mtx | !m2->mtx | + (m1->ncols != m2->ncols) | (m1->nrows != m2->nrows)) return(0); if ((m2->ncomp > 1) & (m2->ncomp != m1->ncomp)) return(0); @@ -552,35 +868,35 @@ rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide for (i = m1->nrows; i--; ) for (j = m1->ncols; j--; ) if (divide) { - double d; + rmx_dtype d; if (m2->ncomp == 1) { - d = rmx_lval(m2,i,j,0); + d = rmx_val(m2,i,j)[0]; if (d == 0) { ++zeroDivides; for (k = m1->ncomp; k--; ) - rmx_lval(m1,i,j,k) = 0; + rmx_lval(m1,i,j)[k] = 0; } else { d = 1./d; for (k = m1->ncomp; k--; ) - rmx_lval(m1,i,j,k) *= d; + rmx_lval(m1,i,j)[k] *= d; } } else for (k = m1->ncomp; k--; ) { - d = rmx_lval(m2,i,j,k); + d = rmx_val(m2,i,j)[k]; if (d == 0) { ++zeroDivides; - rmx_lval(m1,i,j,k) = 0; + rmx_lval(m1,i,j)[k] = 0; } else - rmx_lval(m1,i,j,k) /= d; + rmx_lval(m1,i,j)[k] /= d; } } else { if (m2->ncomp == 1) { - const double d = rmx_lval(m2,i,j,0); + const rmx_dtype d = rmx_val(m2,i,j)[0]; for (k = m1->ncomp; k--; ) - rmx_lval(m1,i,j,k) *= d; + rmx_lval(m1,i,j)[k] *= d; } else for (k = m1->ncomp; k--; ) - rmx_lval(m1,i,j,k) *= rmx_lval(m2,i,j,k); + rmx_lval(m1,i,j)[k] *= rmx_val(m2,i,j)[k]; } if (zeroDivides) { rmx_addinfo(m1, "WARNING: zero divide(s) corrupted results\n"); @@ -596,7 +912,7 @@ rmx_sum(RMATRIX *msum, const RMATRIX *madd, const doub double *mysf = NULL; int i, j, k; - if (!msum | !madd || + if (!msum | !madd || !msum->mtx | !madd->mtx | (msum->nrows != madd->nrows) | (msum->ncols != madd->ncols) | (msum->ncomp != madd->ncomp)) @@ -615,9 +931,12 @@ rmx_sum(RMATRIX *msum, const RMATRIX *madd, const doub else rmx_addinfo(msum, rmx_mismatch_warn); for (i = msum->nrows; i--; ) - for (j = msum->ncols; j--; ) + for (j = msum->ncols; j--; ) { + const rmx_dtype *da = rmx_val(madd,i,j); + rmx_dtype *ds = rmx_lval(msum,i,j); for (k = msum->ncomp; k--; ) - rmx_lval(msum,i,j,k) += sf[k] * rmx_lval(madd,i,j,k); + ds[k] += (rmx_dtype)sf[k] * da[k]; + } if (mysf) free(mysf); return(1); @@ -629,15 +948,17 @@ rmx_scale(RMATRIX *rm, const double sf[]) { int i, j, k; - if (!rm | !sf) + if (!rm | !sf || !rm->mtx) return(0); for (i = rm->nrows; i--; ) - for (j = rm->ncols; j--; ) + for (j = rm->ncols; j--; ) { + rmx_dtype *dp = rmx_lval(rm,i,j); for (k = rm->ncomp; k--; ) - rmx_lval(rm,i,j,k) *= sf[k]; - + dp[k] *= (rmx_dtype)sf[k]; + } if (rm->info) rmx_addinfo(rm, "Applied scalar\n"); + /* XXX: should record as exposure for COLR and SCOLR types? */ return(1); } @@ -648,71 +969,29 @@ rmx_transform(const RMATRIX *msrc, int n, const double int i, j, ks, kd; RMATRIX *dnew; - if (!msrc | (n <= 0) | !cmat) + if (!msrc | (n <= 0) | !cmat || !msrc->mtx) return(NULL); dnew = rmx_alloc(msrc->nrows, msrc->ncols, n); if (!dnew) return(NULL); if (msrc->info) { char buf[128]; - sprintf(buf, "Applied %dx%d matrix transform\n", + sprintf(buf, "Applied %dx%d component transform\n", dnew->ncomp, msrc->ncomp); rmx_addinfo(dnew, msrc->info); rmx_addinfo(dnew, buf); } dnew->dtype = msrc->dtype; for (i = dnew->nrows; i--; ) - for (j = dnew->ncols; j--; ) + for (j = dnew->ncols; j--; ) { + const rmx_dtype *ds = rmx_val(msrc,i,j); for (kd = dnew->ncomp; kd--; ) { double d = 0; for (ks = msrc->ncomp; ks--; ) - d += cmat[kd*msrc->ncomp + ks] * rmx_lval(msrc,i,j,ks); - rmx_lval(dnew,i,j,kd) = d; + d += cmat[kd*msrc->ncomp + ks] * ds[ks]; + rmx_lval(dnew,i,j)[kd] = (rmx_dtype)d; } - return(dnew); -} - -/* Convert a color matrix to newly allocated RMATRIX buffer */ -RMATRIX * -rmx_from_cmatrix(const CMATRIX *cm) -{ - int i, j; - RMATRIX *dnew; - - if (!cm) - return(NULL); - dnew = rmx_alloc(cm->nrows, cm->ncols, 3); - if (!dnew) - return(NULL); - dnew->dtype = DTfloat; - for (i = dnew->nrows; i--; ) - for (j = dnew->ncols; j--; ) { - const COLORV *cv = cm_lval(cm,i,j); - rmx_lval(dnew,i,j,0) = cv[0]; - rmx_lval(dnew,i,j,1) = cv[1]; - rmx_lval(dnew,i,j,2) = cv[2]; } return(dnew); } -/* Convert general matrix to newly allocated CMATRIX buffer */ -CMATRIX * -cm_from_rmatrix(const RMATRIX *rm) -{ - int i, j; - CMATRIX *cnew; - - if (!rm || rm->ncomp != 3) - return(NULL); - cnew = cm_alloc(rm->nrows, rm->ncols); - if (!cnew) - return(NULL); - for (i = cnew->nrows; i--; ) - for (j = cnew->ncols; j--; ) { - COLORV *cv = cm_lval(cnew,i,j); - cv[0] = (COLORV)rmx_lval(rm,i,j,0); - cv[1] = (COLORV)rmx_lval(rm,i,j,1); - cv[2] = (COLORV)rmx_lval(rm,i,j,2); - } - return(cnew); -}
