--- ray/src/util/rmatrix.c 2023/11/28 21:28:11 2.66 +++ ray/src/util/rmatrix.c 2025/04/17 23:30:16 2.96 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rmatrix.c,v 2.66 2023/11/28 21:28:11 greg Exp $"; +static const char RCSid[] = "$Id: rmatrix.c,v 2.96 2025/04/17 23:30:16 greg Exp $"; #endif /* * General matrix operations. @@ -18,9 +18,6 @@ static const char RCSid[] = "$Id: rmatrix.c,v 2.66 202 static const char rmx_mismatch_warn[] = "WARNING: data type mismatch\n"; -#define array_size(rm) (sizeof(double)*(rm)->nrows*(rm)->ncols*(rm)->ncomp) -#define mapped_size(rm) ((char *)(rm)->mtx + array_size(rm) - (char *)(rm)->mapped) - /* Initialize a RMATRIX struct but don't allocate array space */ RMATRIX * rmx_new(int nr, int nc, int n) @@ -31,14 +28,16 @@ rmx_new(int nr, int nc, int n) return(NULL); dnew = (RMATRIX *)calloc(1, sizeof(RMATRIX)); - if (dnew) { - dnew->dtype = DTdouble; - dnew->nrows = nr; - dnew->ncols = nc; - dnew->ncomp = n; - setcolor(dnew->cexp, 1.f, 1.f, 1.f); - memcpy(dnew->wlpart, WLPART, sizeof(dnew->wlpart)); - } + if (!dnew) + return(NULL); + + dnew->dtype = DTrmx_native; + dnew->nrows = nr; + dnew->ncols = nc; + dnew->ncomp = n; + setcolor(dnew->cexp, 1.f, 1.f, 1.f); + memcpy(dnew->wlpart, WLPART, sizeof(dnew->wlpart)); + return(dnew); } @@ -47,11 +46,12 @@ int rmx_prepare(RMATRIX *rm) { if (!rm) return(0); - if (rm->mtx) + if (rm->mtx) /* assume it's right size */ return(1); if ((rm->nrows <= 0) | (rm->ncols <= 0) | (rm->ncomp <= 0)) return(0); - rm->mtx = (double *)malloc(array_size(rm)); + rm->mtx = (rmx_dtype *)malloc(rmx_array_size(rm)); + rm->pflags |= RMF_FREEMEM; return(rm->mtx != NULL); } @@ -61,26 +61,41 @@ rmx_alloc(int nr, int nc, int n) { RMATRIX *dnew = rmx_new(nr, nc, n); - if (dnew && !rmx_prepare(dnew)) { + if (!rmx_prepare(dnew)) { rmx_free(dnew); - dnew = NULL; + return(NULL); } return(dnew); } -/* Free a RMATRIX array */ +/* Clear state by freeing info and matrix data */ void -rmx_free(RMATRIX *rm) +rmx_reset(RMATRIX *rm) { if (!rm) return; - if (rm->info) + if (rm->info) { free(rm->info); + rm->info = NULL; + } #ifdef MAP_FILE - if (rm->mapped) - munmap(rm->mapped, mapped_size(rm)); - else + if (rm->mapped) { + munmap(rm->mapped, rmx_mapped_size(rm)); + rm->mapped = NULL; + } else #endif + if (rm->pflags & RMF_FREEMEM) { free(rm->mtx); + rm->pflags &= ~RMF_FREEMEM; + } + rm->mtx = NULL; +} + +/* Free an RMATRIX struct and data */ +void +rmx_free(RMATRIX *rm) +{ + if (!rm) return; + rmx_reset(rm); free(rm); } @@ -101,13 +116,12 @@ rmx_newtype(int dtyp1, int dtyp2) int rmx_addinfo(RMATRIX *rm, const char *info) { - int oldlen = 0; + size_t oldlen = 0; if (!rm || !info || !*info) return(0); if (!rm->info) { rm->info = (char *)malloc(strlen(info)+1); - if (rm->info) rm->info[0] = '\0'; } else { oldlen = strlen(rm->info); rm->info = (char *)realloc(rm->info, @@ -126,39 +140,41 @@ get_dminfo(char *s, void *p) char fmt[MAXFMTLEN]; int i; - if (headidval(NULL, s)) + if (isheadid(s)) return(0); if (isncomp(s)) { ip->ncomp = ncompval(s); - return(0); + return(ip->ncomp - 1); } if (!strncmp(s, "NROWS=", 6)) { ip->nrows = atoi(s+6); - return(0); + return(ip->nrows - 1); } if (!strncmp(s, "NCOLS=", 6)) { ip->ncols = atoi(s+6); - return(0); + return(ip->ncols - 1); } if ((i = isbigendian(s)) >= 0) { - ip->swapin = (nativebigendian() != i); + if (nativebigendian() != i) + ip->pflags |= RMF_SWAPIN; + else + ip->pflags &= ~RMF_SWAPIN; return(0); } if (isexpos(s)) { float f = exposval(s); scalecolor(ip->cexp, f); - return(0); + return(f > .0 ? 0 : -1); } if (iscolcor(s)) { COLOR ctmp; - colcorval(ctmp, s); + if (!colcorval(ctmp, s)) return(-1); multcolor(ip->cexp, ctmp); return(0); } - if (iswlsplit(s)) { - wlsplitval(ip->wlpart, s); - return(0); - } + if (iswlsplit(s)) + return(wlsplitval(ip->wlpart, s) - 1); + if (!formatval(fmt, s)) { rmx_addinfo(ip, s); return(0); @@ -168,54 +184,79 @@ get_dminfo(char *s, void *p) ip->dtype = i; return(0); } - return(-1); + return(-1); /* bad format */ } static int -rmx_load_ascii(double *drp, const RMATRIX *rm, FILE *fp) +rmx_load_ascii(rmx_dtype *drp, const RMATRIX *rm, FILE *fp) { int j, k; for (j = 0; j < rm->ncols; j++) for (k = rm->ncomp; k-- > 0; ) - if (fscanf(fp, "%lf", drp++) != 1) + if (fscanf(fp, rmx_scanfmt, drp++) != 1) return(0); return(1); } static int -rmx_load_float(double *drp, const RMATRIX *rm, FILE *fp) +rmx_load_float(rmx_dtype *drp, const RMATRIX *rm, FILE *fp) { +#if DTrmx_native==DTfloat + if (getbinary(drp, sizeof(*drp)*rm->ncomp, rm->ncols, fp) != rm->ncols) + return(0); + if (rm->pflags & RMF_SWAPIN) + swap32((char *)drp, rm->ncols*rm->ncomp); +#else int j, k; - float val[100]; + float val[MAXCOMP]; - if (rm->ncomp > 100) { + if (rm->ncomp > MAXCOMP) { fputs("Unsupported # components in rmx_load_float()\n", stderr); exit(1); } for (j = 0; j < rm->ncols; j++) { if (getbinary(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp) return(0); - if (rm->swapin) + if (rm->pflags & RMF_SWAPIN) swap32((char *)val, rm->ncomp); for (k = 0; k < rm->ncomp; k++) *drp++ = val[k]; } +#endif return(1); } static int -rmx_load_double(double *drp, const RMATRIX *rm, FILE *fp) +rmx_load_double(rmx_dtype *drp, const RMATRIX *rm, FILE *fp) { +#if DTrmx_native==DTdouble if (getbinary(drp, sizeof(*drp)*rm->ncomp, rm->ncols, fp) != rm->ncols) return(0); - if (rm->swapin) + if (rm->pflags & RMF_SWAPIN) swap64((char *)drp, rm->ncols*rm->ncomp); +#else + int j, k; + double val[MAXCOMP]; + + if (rm->ncomp > MAXCOMP) { + fputs("Unsupported # components in rmx_load_double()\n", stderr); + exit(1); + } + for (j = 0; j < rm->ncols; j++) { + if (getbinary(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp) + return(0); + if (rm->pflags & RMF_SWAPIN) + swap64((char *)val, rm->ncomp); + for (k = 0; k < rm->ncomp; k++) + *drp++ = (float)val[k]; + } +#endif return(1); } static int -rmx_load_rgbe(double *drp, const RMATRIX *rm, FILE *fp) +rmx_load_rgbe(rmx_dtype *drp, const RMATRIX *rm, FILE *fp) { COLR *scan; COLOR col; @@ -238,15 +279,15 @@ rmx_load_rgbe(double *drp, const RMATRIX *rm, FILE *fp } static int -rmx_load_spec(double *drp, const RMATRIX *rm, FILE *fp) +rmx_load_spec(rmx_dtype *drp, const RMATRIX *rm, FILE *fp) { - uby8 *scan; - SCOLOR scol; + COLRV *scan; + COLORV scol[MAXCOMP]; int j, k; - if ((rm->ncomp < 3) | (rm->ncomp > MAXCSAMP)) + if ((rm->ncomp < 3) | (rm->ncomp > MAXCOMP)) return(0); - scan = (uby8 *)tempbuffer((rm->ncomp+1)*rm->ncols); + scan = (COLRV *)tempbuffer((rm->ncomp+1)*rm->ncols); if (!scan) return(0); if (freadscolrs(scan, rm->ncomp, rm->ncols, fp) < 0) @@ -265,47 +306,35 @@ rmx_load_header(RMATRIX *rm, FILE *fp) { if (!rm | !fp) return(0); - if (rm->info) { /* clear state */ - free(rm->info); - rm->info = NULL; - } - if (rm->mtx) { /* ...and data */ -#ifdef MAP_FILE - if (rm->mapped) { - munmap(rm->mapped, mapped_size(rm)); - rm->mapped = NULL; - } else -#endif - free(rm->mtx); - rm->mtx = NULL; - } + rmx_reset(rm); /* clear state */ if (rm->nrows | rm->ncols | !rm->dtype) { rm->nrows = rm->ncols = 0; rm->ncomp = 3; setcolor(rm->cexp, 1.f, 1.f, 1.f); memcpy(rm->wlpart, WLPART, sizeof(rm->wlpart)); - rm->swapin = 0; + rm->pflags = 0; } - SET_FILE_BINARY(fp); rm->dtype = DTascii; /* assumed w/o FORMAT */ if (getheader(fp, get_dminfo, rm) < 0) { - fputs("Unrecognized matrix format\n", stderr); + fputs("Bad matrix header\n", stderr); return(0); } - /* resolution string? */ - if ((rm->nrows <= 0) | (rm->ncols <= 0)) { - if (!fscnresolu(&rm->ncols, &rm->nrows, fp)) - return(0); - if ((rm->dtype == DTrgbe) | (rm->dtype == DTxyze) && - rm->ncomp != 3) - return(0); - } + if ((rm->dtype == DTrgbe) | (rm->dtype == DTxyze) && + rm->ncomp != 3) + return(0); + if (rm->ncols <= 0 && /* resolution string? */ + !fscnresolu(&rm->ncols, &rm->nrows, fp)) + return(0); + if (rm->dtype == DTascii) /* set file type (WINDOWS) */ + SET_FILE_TEXT(fp); + else + SET_FILE_BINARY(fp); return(1); } -/* Load next row as double (cannot be XML) */ +/* Load next row as rmx_dtype (cannot be XML) */ int -rmx_load_row(double *drp, const RMATRIX *rm, FILE *fp) +rmx_load_row(rmx_dtype *drp, const RMATRIX *rm, FILE *fp) { switch (rm->dtype) { case DTascii: @@ -332,12 +361,16 @@ rmx_load_data(RMATRIX *rm, FILE *fp) int i; #ifdef MAP_FILE long pos; /* map memory for file > 1MB if possible */ - if ((rm->dtype == DTdouble) & !rm->swapin && array_size(rm) >= 1L<<20 && - (pos = ftell(fp)) >= 0 && !(pos % sizeof(double))) { - rm->mapped = mmap(NULL, array_size(rm)+pos, PROT_READ|PROT_WRITE, + if ((rm->dtype == DTrmx_native) & !(rm->pflags & RMF_SWAPIN) & + (rmx_array_size(rm) >= 1L<<20) && + (pos = ftell(fp)) >= 0 && !(pos % sizeof(rmx_dtype))) { + rm->mapped = mmap(NULL, rmx_array_size(rm)+pos, PROT_READ|PROT_WRITE, MAP_PRIVATE, fileno(fp), 0); if (rm->mapped != MAP_FAILED) { - rm->mtx = (double *)rm->mapped + pos/sizeof(double); + if (rm->pflags & RMF_FREEMEM) + free(rm->mtx); + rm->mtx = (rmx_dtype *)rm->mapped + pos/sizeof(rmx_dtype); + rm->pflags &= ~RMF_FREEMEM; return(1); } /* else fall back on reading into memory */ rm->mapped = NULL; @@ -345,11 +378,9 @@ rmx_load_data(RMATRIX *rm, FILE *fp) #endif if (!rmx_prepare(rm)) { /* need in-core matrix array */ fprintf(stderr, "Cannot allocate %g MByte matrix array\n", - (1./(1L<<20))*(double)array_size(rm)); + (1./(1L<<20))*(double)rmx_array_size(rm)); return(0); } - if (rm->dtype == DTascii) - SET_FILE_TEXT(fp); for (i = 0; i < rm->nrows; i++) if (!rmx_load_row(rmx_lval(rm,i,0), rm, fp)) return(0); @@ -372,14 +403,11 @@ rmx_load(const char *inspec, RMPref rmp) fp = stdin; else if (inspec[0] == '!') fp = popen(inspec+1, "r"); - else { - const char *sp = inspec; /* check suffix */ - while (*sp) - ++sp; - while (sp > inspec && sp[-1] != '.') - --sp; - if (!strcasecmp(sp, "XML")) { /* assume it's a BSDF */ - CMATRIX *cm = rmp==RMPtrans ? cm_loadBTDF(inspec) : + else { /* check suffix */ + const char *sp = strrchr(inspec, '.'); + if (sp > inspec && !strcasecmp(sp+1, "XML")) { /* BSDF? */ + CMATRIX *cm = rmp==RMPnone ? (CMATRIX *)NULL : + rmp==RMPtrans ? cm_loadBTDF(inspec) : cm_loadBRDF(inspec, rmp==RMPreflB) ; if (!cm) return(NULL); @@ -390,12 +418,14 @@ rmx_load(const char *inspec, RMPref rmp) } /* else open it ourselves */ fp = fopen(inspec, "r"); } - if (!fp) + if (!fp) { + fprintf(stderr, "Cannot open for reading: %s\n", inspec); return(NULL); + } #ifdef getc_unlocked flockfile(fp); #endif - /* load header info */ + SET_FILE_BINARY(fp); /* load header info */ if (!rmx_load_header(dnew = rmx_new(0,0,3), fp)) { fprintf(stderr, "Bad header in: %s\n", inspec); if (inspec[0] == '!') pclose(fp); @@ -423,122 +453,100 @@ rmx_load(const char *inspec, RMPref rmp) /* undo exposure? */ if ((dnew->cexp[0] != 1.f) | (dnew->cexp[1] != 1.f) | (dnew->cexp[2] != 1.f)) { - double cmlt[MAXCSAMP]; + double cmlt[MAXCOMP]; int i; - cmlt[0] = 1./dnew->cexp[0]; - cmlt[1] = 1./dnew->cexp[1]; - cmlt[2] = 1./dnew->cexp[2]; - if (dnew->ncomp > MAXCSAMP) { + if (dnew->ncomp > MAXCOMP) { fprintf(stderr, "Excess spectral components in: %s\n", inspec); rmx_free(dnew); return(NULL); } + cmlt[0] = 1./dnew->cexp[0]; + cmlt[1] = 1./dnew->cexp[1]; + cmlt[2] = 1./dnew->cexp[2]; for (i = dnew->ncomp; i-- > 3; ) - cmlt[i] = cmlt[1]; + cmlt[i] = cmlt[1]; /* XXX hack! */ rmx_scale(dnew, cmlt); setcolor(dnew->cexp, 1.f, 1.f, 1.f); } return(dnew); } +#if DTrmx_native==DTdouble static int -rmx_write_ascii(const RMATRIX *rm, FILE *fp) +rmx_write_float(const rmx_dtype *dp, int len, FILE *fp) { - const char *fmt = (rm->dtype == DTfloat) ? " %.7e" : - (rm->dtype == DTrgbe) | (rm->dtype == DTxyze) | - (rm->dtype == DTspec) ? " %.3e" : " %.15e" ; - int i, j, k; + float val; - for (i = 0; i < rm->nrows; i++) { - for (j = 0; j < rm->ncols; j++) { - const double *dp = rmx_val(rm,i,j); - for (k = 0; k < rm->ncomp; k++) - fprintf(fp, fmt, dp[k]); - fputc('\t', fp); - } - fputc('\n', fp); + while (len--) { + val = (float)*dp++; + if (putbinary(&val, sizeof(val), 1, fp) != 1) + return(0); } return(1); } - +#else static int -rmx_write_float(const RMATRIX *rm, FILE *fp) +rmx_write_double(const rmx_dtype *dp, int len, FILE *fp) { - int i, j, k; - float val[100]; + double val; - if (rm->ncomp > 100) { - fputs("Unsupported # components in rmx_write_float()\n", stderr); - exit(1); - } - for (i = 0; i < rm->nrows; i++) - for (j = 0; j < rm->ncols; j++) { - const double *dp = rmx_val(rm,i,j); - for (k = rm->ncomp; k--; ) - val[k] = (float)dp[k]; - if (putbinary(val, sizeof(float), rm->ncomp, fp) != rm->ncomp) + while (len--) { + val = *dp++; + if (putbinary(&val, sizeof(val), 1, fp) != 1) return(0); - } + } return(1); } +#endif static int -rmx_write_double(const RMATRIX *rm, FILE *fp) +rmx_write_ascii(const rmx_dtype *dp, int nc, int len, FILE *fp) { - return(putbinary(rm->mtx, sizeof(rm->mtx[0])*rm->ncomp, - rm->nrows*rm->ncols, fp) == rm->nrows*rm->ncols); + while (len-- > 0) { + int k = nc; + while (k-- > 0) + fprintf(fp, " %.7e", *dp++); + fputc('\t', fp); + } + return(fputc('\n', fp) != EOF); } static int -rmx_write_rgbe(const RMATRIX *rm, FILE *fp) +rmx_write_rgbe(const rmx_dtype *dp, int nc, int len, FILE *fp) { - COLR *scan = (COLR *)malloc(sizeof(COLR)*rm->ncols); - int i, j; + COLR *scan; + int j; - if (!scan) - return(0); - for (i = 0; i < rm->nrows; i++) { - for (j = rm->ncols; j--; ) { - const double *dp = rmx_val(rm,i,j); - if (rm->ncomp == 1) + if ((nc != 1) & (nc != 3)) return(0); + scan = (COLR *)tempbuffer(sizeof(COLR)*len); + if (!scan) return(0); + + for (j = 0; j < len; j++, dp += nc) + if (nc == 1) setcolr(scan[j], dp[0], dp[0], dp[0]); else setcolr(scan[j], dp[0], dp[1], dp[2]); - } - if (fwritecolrs(scan, rm->ncols, fp) < 0) { - free(scan); - return(0); - } - } - free(scan); - return(1); + + return(fwritecolrs(scan, len, fp) >= 0); } static int -rmx_write_spec(const RMATRIX *rm, FILE *fp) +rmx_write_spec(const rmx_dtype *dp, int nc, int len, FILE *fp) { - uby8 *scan = (uby8 *)malloc((rm->ncomp+1)*rm->ncols); - int ok = 1; - SCOLOR scol; - int i, j, k; + COLRV *scan; + COLORV scol[MAXCOMP]; + int j, k; - if (!scan) - return(0); - for (i = 0; i < rm->nrows; i++) { - for (j = rm->ncols; j--; ) { - const double *dp = rmx_val(rm,i,j); - for (k = rm->ncomp; k--; ) + if ((nc < 3) | (nc > MAXCOMP)) return(0); + scan = (COLRV *)tempbuffer((nc+1)*len); + if (!scan) return(0); + for (j = 0; j < len; j++, dp += nc) { + for (k = nc; k--; ) scol[k] = dp[k]; - scolor2scolr(scan+j*(rm->ncomp+1), scol, rm->ncomp); - } - if (fwritescolrs(scan, rm->ncomp, rm->ncols, fp) < 0) { - ok = 0; - break; - } + scolor2scolr(scan+j*(nc+1), scol, nc); } - free(scan); - return(ok); + return(fwritescolrs(scan, nc, len, fp) >= 0); } /* Check if CIE XYZ primaries were specified */ @@ -558,41 +566,50 @@ findCIEprims(const char *info) (prims[BLU][CIEX] < .01) & (prims[BLU][CIEY] < .01)); } -/* Write matrix to file type indicated by dtype */ +/* Finish writing header data with resolution and format, returning type used */ int -rmx_write(const RMATRIX *rm, int dtype, FILE *fp) +rmx_write_header(const RMATRIX *rm, int dtype, FILE *fp) { - int ok = 1; - - if (!rm | !fp || !rm->mtx) + if (!rm | !fp || rm->ncols <= 0) return(0); -#ifdef getc_unlocked - flockfile(fp); -#endif - if (rm->info) /* complete header */ + if (rm->info) fputs(rm->info, fp); - if (dtype == DTfromHeader) + if (dtype == DTfromHeader) { dtype = rm->dtype; - else if (dtype == DTrgbe && (rm->dtype == DTxyze || +#if DTrmx_native==DTfloat + if (dtype == DTdouble) /* but stored as float? */ + dtype = DTfloat; +#endif + } else if (dtype == DTrgbe && (rm->dtype == DTxyze || findCIEprims(rm->info))) dtype = DTxyze; else if ((dtype == DTxyze) & (rm->dtype == DTrgbe)) dtype = DTrgbe; + if ((dtype < DTspec) & (rm->ncomp > 3)) + dtype = DTspec; + else if ((dtype == DTspec) & (rm->ncomp <= 3)) + return(0); + + if (dtype == DTascii) /* set file type (WINDOWS) */ + SET_FILE_TEXT(fp); + else + SET_FILE_BINARY(fp); /* write exposure? */ if (rm->ncomp == 3 && (rm->cexp[RED] != rm->cexp[GRN]) | (rm->cexp[GRN] != rm->cexp[BLU])) fputcolcor(rm->cexp, fp); else if (rm->cexp[GRN] != 1.f) fputexpos(rm->cexp[GRN], fp); - if ((dtype != DTrgbe) & (dtype != DTxyze)) { - if (dtype != DTspec) { + /* matrix size? */ + if ((dtype > DTspec) | (rm->nrows <= 0)) { + if (rm->nrows > 0) fprintf(fp, "NROWS=%d\n", rm->nrows); - fprintf(fp, "NCOLS=%d\n", rm->ncols); - } else if (rm->ncomp < 3) - return(0); /* bad # components */ + fprintf(fp, "NCOLS=%d\n", rm->ncols); + } + if (dtype >= DTspec) { /* # components & split? */ fputncomp(rm->ncomp, fp); - if (dtype == DTspec || (rm->ncomp > 3 && - memcmp(rm->wlpart, WLPART, sizeof(WLPART)))) + if (rm->ncomp > 3 && + memcmp(rm->wlpart, WLPART, sizeof(WLPART))) fputwlsplit(rm->wlpart, fp); } else if ((rm->ncomp != 3) & (rm->ncomp != 1)) return(0); /* wrong # components */ @@ -600,30 +617,61 @@ rmx_write(const RMATRIX *rm, int dtype, FILE *fp) fputendian(fp); /* important to record */ fputformat(cm_fmt_id[dtype], fp); fputc('\n', fp); /* end of header */ - switch (dtype) { /* write data */ - case DTascii: - ok = rmx_write_ascii(rm, fp); - break; + if ((dtype <= DTspec) & (rm->nrows > 0)) + fprtresolu(rm->ncols, rm->nrows, fp); + return(dtype); +} + +/* Write out matrix data (usually by row) */ +int +rmx_write_data(const rmx_dtype *dp, int nc, int len, int dtype, FILE *fp) +{ + switch (dtype) { +#if DTrmx_native==DTdouble case DTfloat: - ok = rmx_write_float(rm, fp); - break; + return(rmx_write_float(dp, nc*len, fp)); +#else case DTdouble: - ok = rmx_write_double(rm, fp); - break; + return(rmx_write_double(dp, nc*len, fp)); +#endif + case DTrmx_native: + return(putbinary(dp, sizeof(*dp)*nc, len, fp) == len); + case DTascii: + return(rmx_write_ascii(dp, nc, len, fp)); case DTrgbe: case DTxyze: - fprtresolu(rm->ncols, rm->nrows, fp); - ok = rmx_write_rgbe(rm, fp); - break; + return(rmx_write_rgbe(dp, nc, len, fp)); case DTspec: - fprtresolu(rm->ncols, rm->nrows, fp); - ok = rmx_write_spec(rm, fp); - break; - default: - return(0); + return(rmx_write_spec(dp, nc, len, fp)); } - ok &= (fflush(fp) == 0); + return(0); +} + +/* Write matrix using file format indicated by dtype */ +int +rmx_write(const RMATRIX *rm, int dtype, FILE *fp) +{ + int ok = 0; + int i; + /* complete header */ + dtype = rmx_write_header(rm, dtype, fp); + if (dtype <= 0) + return(0); #ifdef getc_unlocked + flockfile(fp); +#endif + if (dtype == DTrmx_native) /* write all at once? */ + ok = rmx_write_data(rm->mtx, rm->ncomp, + rm->nrows*rm->ncols, dtype, fp); + else /* else row by row */ + for (i = 0; i < rm->nrows; i++) { + ok = rmx_write_data(rmx_val(rm,i,0), rm->ncomp, + rm->ncols, dtype, fp); + if (!ok) break; + } + + if (ok) ok = (fflush(fp) == 0); +#ifdef getc_unlocked funlockfile(fp); #endif if (!ok) fputs("Error writing matrix\n", stderr); @@ -639,16 +687,16 @@ rmx_identity(const int dim, const int n) if (!rid) return(NULL); - memset(rid->mtx, 0, array_size(rid)); + memset(rid->mtx, 0, rmx_array_size(rid)); for (i = dim; i--; ) { - double *dp = rmx_lval(rid,i,i); + rmx_dtype *dp = rmx_lval(rid,i,i); for (k = n; k--; ) dp[k] = 1.; } return(rid); } -/* Duplicate the given matrix */ +/* Duplicate the given matrix (may be unallocated) */ RMATRIX * rmx_copy(const RMATRIX *rm) { @@ -656,49 +704,131 @@ rmx_copy(const RMATRIX *rm) if (!rm) return(NULL); - dnew = rmx_alloc(rm->nrows, rm->ncols, rm->ncomp); + dnew = rmx_new(rm->nrows, rm->ncols, rm->ncomp); if (!dnew) return(NULL); + if (rm->mtx) { + if (!rmx_prepare(dnew)) { + rmx_free(dnew); + return(NULL); + } + memcpy(dnew->mtx, rm->mtx, rmx_array_size(dnew)); + } rmx_addinfo(dnew, rm->info); dnew->dtype = rm->dtype; copycolor(dnew->cexp, rm->cexp); memcpy(dnew->wlpart, rm->wlpart, sizeof(dnew->wlpart)); - memcpy(dnew->mtx, rm->mtx, array_size(dnew)); return(dnew); } -/* Allocate and assign transposed matrix */ -RMATRIX * -rmx_transpose(const RMATRIX *rm) +/* Replace data in first matrix with data from second */ +int +rmx_transfer_data(RMATRIX *rdst, RMATRIX *rsrc, int dometa) { - RMATRIX *dnew; - int i, j; + if (!rdst | !rsrc) + return(0); + if (dometa) { /* transfer everything? */ + rmx_reset(rdst); + *rdst = *rsrc; + rsrc->info = NULL; rsrc->mapped = NULL; rsrc->mtx = NULL; + return(1); + } + /* just matrix data -- leave metadata */ + if ((rdst->nrows != rsrc->nrows) | + (rdst->ncols != rsrc->ncols) | + (rdst->ncomp != rsrc->ncomp)) + return(0); +#ifdef MAP_FILE + if (rdst->mapped) + munmap(rdst->mapped, rmx_mapped_size(rdst)); + else +#endif + if (rdst->pflags & RMF_FREEMEM) { + free(rdst->mtx); + rdst->pflags &= ~RMF_FREEMEM; + } + rdst->mapped = rsrc->mapped; + rdst->mtx = rsrc->mtx; + rdst->pflags |= rsrc->pflags & RMF_FREEMEM; + rsrc->mapped = NULL; rsrc->mtx = NULL; + return(1); +} - if (!rm) +/* Transpose the given matrix */ +int +rmx_transpose(RMATRIX *rm) +{ + uby8 *bmap; + rmx_dtype val[MAXCOMP]; + RMATRIX dold; + int i, j; + + if (!rm || !rm->mtx | (rm->ncomp > MAXCOMP)) return(0); - if ((rm->nrows == 1) | (rm->ncols == 1)) { - dnew = rmx_copy(rm); - if (!dnew) - return(NULL); - dnew->nrows = rm->ncols; - dnew->ncols = rm->nrows; - return(dnew); + if (rm->info) + rmx_addinfo(rm, "Transposed rows and columns\n"); + if ((rm->nrows == 1) | (rm->ncols == 1)) { /* vector? */ + j = rm->ncols; + rm->ncols = rm->nrows; + rm->nrows = j; + return(1); } - dnew = rmx_alloc(rm->ncols, rm->nrows, rm->ncomp); - if (!dnew) - return(NULL); - if (rm->info) { - rmx_addinfo(dnew, rm->info); - rmx_addinfo(dnew, "Transposed rows and columns\n"); + if (rm->nrows == rm->ncols) { /* square matrix case */ + for (i = rm->nrows; i--; ) + for (j = rm->ncols; j--; ) { + if (i == j) continue; + memcpy(val, rmx_val(rm,i,j), + sizeof(rmx_dtype)*rm->ncomp); + memcpy(rmx_lval(rm,i,j), rmx_val(rm,j,i), + sizeof(rmx_dtype)*rm->ncomp); + memcpy(rmx_val(rm,j,i), val, + sizeof(rmx_dtype)*rm->ncomp); + } + return(1); } - dnew->dtype = rm->dtype; - copycolor(dnew->cexp, rm->cexp); - memcpy(dnew->wlpart, rm->wlpart, sizeof(dnew->wlpart)); - for (j = dnew->ncols; j--; ) - for (i = dnew->nrows; i--; ) - memcpy(rmx_lval(dnew,i,j), rmx_val(rm,j,i), - sizeof(double)*dnew->ncomp); - return(dnew); +#define bmbyte(r,c) bmap[((r)*rm->ncols+(c))>>3] +#define bmbit(r,c) (1 << ((r)*rm->ncols+(c) & 7)) +#define bmop(r,c, op) (bmbyte(r,c) op bmbit(r,c)) +#define bmtest(r,c) bmop(r,c,&) +#define bmset(r,c) bmop(r,c,|=) + /* loop completion bitmap */ + bmap = (uby8 *)calloc(((size_t)rm->nrows*rm->ncols+7)>>3, 1); + if (!bmap) + return(0); + dold = *rm; + rm->ncols = dold.nrows; rm->nrows = dold.ncols; + for (i = rm->nrows; i--; ) /* try every starting point */ + for (j = rm->ncols; j--; ) { + int i0, j0; + int i1 = i; + size_t j1 = j; + if (bmtest(i, j)) + continue; /* traversed loop earlier */ + memcpy(val, rmx_val(rm,i,j), + sizeof(rmx_dtype)*rm->ncomp); + for ( ; ; ) { /* new transpose loop */ + const rmx_dtype *ds; + i0 = i1; j0 = j1; + ds = rmx_val(&dold, j0, i0); + j1 = (ds - dold.mtx)/dold.ncomp; + i1 = j1 / rm->ncols; + j1 -= (size_t)i1*rm->ncols; + bmset(i1, j1); /* mark as done */ + if ((i1 == i) & (j1 == j)) + break; /* back at start */ + memcpy(rmx_lval(rm,i0,j0), ds, + sizeof(rmx_dtype)*rm->ncomp); + } /* complete the loop */ + memcpy(rmx_lval(rm,i0,j0), val, + sizeof(rmx_dtype)*rm->ncomp); + } + free(bmap); /* all done! */ + return(1); +#undef bmbyte +#undef bmbit +#undef bmop +#undef bmtest +#undef bmset } /* Multiply (concatenate) two matrices and allocate the result */ @@ -708,7 +838,8 @@ rmx_multiply(const RMATRIX *m1, const RMATRIX *m2) RMATRIX *mres; int i, j, k, h; - if (!m1 | !m2 || (m1->ncomp != m2->ncomp) | (m1->ncols != m2->nrows)) + if (!m1 | !m2 || !m1->mtx | !m2->mtx | + (m1->ncomp != m2->ncomp) | (m1->ncols != m2->nrows)) return(NULL); mres = rmx_alloc(m1->nrows, m2->ncols, m1->ncomp); if (!mres) @@ -723,8 +854,9 @@ rmx_multiply(const RMATRIX *m1, const RMATRIX *m2) for (k = mres->ncomp; k--; ) { double d = 0; for (h = m1->ncols; h--; ) - d += rmx_val(m1,i,h)[k] * rmx_val(m2,h,j)[k]; - rmx_lval(mres,i,j)[k] = d; + d += (double)rmx_val(m1,i,h)[k] * + rmx_val(m2,h,j)[k]; + rmx_lval(mres,i,j)[k] = (rmx_dtype)d; } return(mres); } @@ -736,7 +868,8 @@ rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide int zeroDivides = 0; int i, j, k; - if (!m1 | !m2 || (m1->ncols != m2->ncols) | (m1->nrows != m2->nrows)) + if (!m1 | !m2 || !m1->mtx | !m2->mtx | + (m1->ncols != m2->ncols) | (m1->nrows != m2->nrows)) return(0); if ((m2->ncomp > 1) & (m2->ncomp != m1->ncomp)) return(0); @@ -748,7 +881,7 @@ rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide for (i = m1->nrows; i--; ) for (j = m1->ncols; j--; ) if (divide) { - double d; + rmx_dtype d; if (m2->ncomp == 1) { d = rmx_val(m2,i,j)[0]; if (d == 0) { @@ -771,7 +904,7 @@ rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide } } else { if (m2->ncomp == 1) { - const double d = rmx_val(m2,i,j)[0]; + const rmx_dtype d = rmx_val(m2,i,j)[0]; for (k = m1->ncomp; k--; ) rmx_lval(m1,i,j)[k] *= d; } else @@ -792,7 +925,7 @@ rmx_sum(RMATRIX *msum, const RMATRIX *madd, const doub double *mysf = NULL; int i, j, k; - if (!msum | !madd || + if (!msum | !madd || !msum->mtx | !madd->mtx | (msum->nrows != madd->nrows) | (msum->ncols != madd->ncols) | (msum->ncomp != madd->ncomp)) @@ -812,10 +945,10 @@ rmx_sum(RMATRIX *msum, const RMATRIX *madd, const doub rmx_addinfo(msum, rmx_mismatch_warn); for (i = msum->nrows; i--; ) for (j = msum->ncols; j--; ) { - const double *da = rmx_val(madd,i,j); - double *ds = rmx_lval(msum,i,j); + const rmx_dtype *da = rmx_val(madd,i,j); + rmx_dtype *ds = rmx_lval(msum,i,j); for (k = msum->ncomp; k--; ) - ds[k] += sf[k] * da[k]; + ds[k] += (rmx_dtype)sf[k] * da[k]; } if (mysf) free(mysf); @@ -828,13 +961,13 @@ rmx_scale(RMATRIX *rm, const double sf[]) { int i, j, k; - if (!rm | !sf) + if (!rm | !sf || !rm->mtx) return(0); for (i = rm->nrows; i--; ) for (j = rm->ncols; j--; ) { - double *dp = rmx_lval(rm,i,j); + rmx_dtype *dp = rmx_lval(rm,i,j); for (k = rm->ncomp; k--; ) - dp[k] *= sf[k]; + dp[k] *= (rmx_dtype)sf[k]; } if (rm->info) rmx_addinfo(rm, "Applied scalar\n"); @@ -849,7 +982,7 @@ rmx_transform(const RMATRIX *msrc, int n, const double int i, j, ks, kd; RMATRIX *dnew; - if (!msrc | (n <= 0) | !cmat) + if (!msrc | (n <= 0) | !cmat || !msrc->mtx) return(NULL); dnew = rmx_alloc(msrc->nrows, msrc->ncols, n); if (!dnew) @@ -864,12 +997,12 @@ rmx_transform(const RMATRIX *msrc, int n, const double dnew->dtype = msrc->dtype; for (i = dnew->nrows; i--; ) for (j = dnew->ncols; j--; ) { - const double *ds = rmx_val(msrc,i,j); + const rmx_dtype *ds = rmx_val(msrc,i,j); for (kd = dnew->ncomp; kd--; ) { double d = 0; for (ks = msrc->ncomp; ks--; ) d += cmat[kd*msrc->ncomp + ks] * ds[ks]; - rmx_lval(dnew,i,j)[kd] = d; + rmx_lval(dnew,i,j)[kd] = (rmx_dtype)d; } } return(dnew); @@ -879,7 +1012,6 @@ rmx_transform(const RMATRIX *msrc, int n, const double RMATRIX * rmx_from_cmatrix(const CMATRIX *cm) { - int i, j; RMATRIX *dnew; if (!cm) @@ -887,15 +1019,23 @@ rmx_from_cmatrix(const CMATRIX *cm) dnew = rmx_alloc(cm->nrows, cm->ncols, 3); if (!dnew) return(NULL); - dnew->dtype = DTfloat; - for (i = dnew->nrows; i--; ) - for (j = dnew->ncols; j--; ) { - const COLORV *cv = cm_lval(cm,i,j); - double *dp = rmx_lval(dnew,i,j); - dp[0] = cv[0]; - dp[1] = cv[1]; - dp[2] = cv[2]; - } + + dnew->dtype = sizeof(COLORV)==sizeof(float) ? + DTfloat : DTdouble; + + if (sizeof(COLORV) == sizeof(rmx_dtype)) { + memcpy(dnew->mtx, cm->cmem, rmx_array_size(dnew)); + } else { + int i, j; + for (i = dnew->nrows; i--; ) + for (j = dnew->ncols; j--; ) { + const COLORV *cv = cm_lval(cm,i,j); + rmx_dtype *dp = rmx_lval(dnew,i,j); + dp[0] = cv[0]; + dp[1] = cv[1]; + dp[2] = cv[2]; + } + } return(dnew); } @@ -903,33 +1043,41 @@ rmx_from_cmatrix(const CMATRIX *cm) CMATRIX * cm_from_rmatrix(const RMATRIX *rm) { - int i, j; CMATRIX *cnew; - if (!rm || !rm->mtx | (rm->ncomp == 2)) + if (!rm || !rm->mtx | (rm->ncomp == 2) | (rm->ncomp > MAXCOMP)) return(NULL); cnew = cm_alloc(rm->nrows, rm->ncols); if (!cnew) return(NULL); - for (i = cnew->nrows; i--; ) - for (j = cnew->ncols; j--; ) { - const double *dp = rmx_val(rm,i,j); - COLORV *cv = cm_lval(cnew,i,j); - switch (rm->ncomp) { - case 3: - setcolor(cv, dp[0], dp[1], dp[2]); - break; - case 1: - setcolor(cv, dp[0], dp[0], dp[0]); - break; - default: { - SCOLOR scol; - int k; - for (k = rm->ncomp; k--; ) - scol[k] = dp[k]; - scolor2color(cv, scol, rm->ncomp, rm->wlpart); - } break; - } - } + if ((sizeof(COLORV) == sizeof(rmx_dtype)) & (rm->ncomp == 3)) { + memcpy(cnew->cmem, rm->mtx, rmx_array_size(rm)); + } else { + int i, j; + for (i = cnew->nrows; i--; ) + for (j = cnew->ncols; j--; ) { + const rmx_dtype *dp = rmx_val(rm,i,j); + COLORV *cv = cm_lval(cnew,i,j); + switch (rm->ncomp) { + case 3: + setcolor(cv, dp[0], dp[1], dp[2]); + break; + case 1: + setcolor(cv, dp[0], dp[0], dp[0]); + break; + default: + if (sizeof(COLORV) == sizeof(rmx_dtype)) { + scolor2color(cv, (const COLORV *)dp, + rm->ncomp, rm->wlpart); + } else { + COLORV scol[MAXCOMP]; + int k = rm->ncomp; + while (k--) scol[k] = dp[k]; + scolor2color(cv, scol, rm->ncomp, rm->wlpart); + } + break; + } + } + } return(cnew); }
