--- ray/src/util/rmatrix.c 2023/12/05 21:13:38 2.71 +++ ray/src/util/rmatrix.c 2025/03/22 01:27:22 2.84 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rmatrix.c,v 2.71 2023/12/05 21:13:38 greg Exp $"; +static const char RCSid[] = "$Id: rmatrix.c,v 2.84 2025/03/22 01:27:22 greg Exp $"; #endif /* * General matrix operations. @@ -18,9 +18,6 @@ static const char RCSid[] = "$Id: rmatrix.c,v 2.71 202 static const char rmx_mismatch_warn[] = "WARNING: data type mismatch\n"; -#define array_size(rm) (sizeof(double)*(rm)->nrows*(rm)->ncols*(rm)->ncomp) -#define mapped_size(rm) ((char *)(rm)->mtx + array_size(rm) - (char *)(rm)->mapped) - /* Initialize a RMATRIX struct but don't allocate array space */ RMATRIX * rmx_new(int nr, int nc, int n) @@ -34,7 +31,7 @@ rmx_new(int nr, int nc, int n) if (!dnew) return(NULL); - dnew->dtype = DTdouble; + dnew->dtype = DTrmx_native; dnew->nrows = nr; dnew->ncols = nc; dnew->ncomp = n; @@ -49,11 +46,12 @@ int rmx_prepare(RMATRIX *rm) { if (!rm) return(0); - if (rm->mtx) + if (rm->mtx) /* assume it's right size */ return(1); if ((rm->nrows <= 0) | (rm->ncols <= 0) | (rm->ncomp <= 0)) return(0); - rm->mtx = (double *)malloc(array_size(rm)); + rm->mtx = (rmx_dtype *)malloc(rmx_array_size(rm)); + rm->pflags |= RMF_FREEMEM; return(rm->mtx != NULL); } @@ -63,9 +61,9 @@ rmx_alloc(int nr, int nc, int n) { RMATRIX *dnew = rmx_new(nr, nc, n); - if (dnew && !rmx_prepare(dnew)) { + if (!rmx_prepare(dnew)) { rmx_free(dnew); - dnew = NULL; + return(NULL); } return(dnew); } @@ -79,16 +77,17 @@ rmx_reset(RMATRIX *rm) free(rm->info); rm->info = NULL; } - if (rm->mtx) { #ifdef MAP_FILE - if (rm->mapped) { - munmap(rm->mapped, mapped_size(rm)); - rm->mapped = NULL; - } else + if (rm->mapped) { + munmap(rm->mapped, rmx_mapped_size(rm)); + rm->mapped = NULL; + } else #endif - free(rm->mtx); - rm->mtx = NULL; + if (rm->pflags & RMF_FREEMEM) { + free(rm->mtx); + rm->pflags &= ~RMF_FREEMEM; } + rm->mtx = NULL; } /* Free an RMATRIX struct and data */ @@ -117,13 +116,12 @@ rmx_newtype(int dtyp1, int dtyp2) int rmx_addinfo(RMATRIX *rm, const char *info) { - int oldlen = 0; + size_t oldlen = 0; if (!rm || !info || !*info) return(0); if (!rm->info) { rm->info = (char *)malloc(strlen(info)+1); - if (rm->info) rm->info[0] = '\0'; } else { oldlen = strlen(rm->info); rm->info = (char *)realloc(rm->info, @@ -142,39 +140,41 @@ get_dminfo(char *s, void *p) char fmt[MAXFMTLEN]; int i; - if (headidval(NULL, s)) + if (isheadid(s)) return(0); if (isncomp(s)) { ip->ncomp = ncompval(s); - return(0); + return(ip->ncomp - 1); } if (!strncmp(s, "NROWS=", 6)) { ip->nrows = atoi(s+6); - return(0); + return(ip->nrows - 1); } if (!strncmp(s, "NCOLS=", 6)) { ip->ncols = atoi(s+6); - return(0); + return(ip->ncols - 1); } if ((i = isbigendian(s)) >= 0) { - ip->swapin = (nativebigendian() != i); + if (nativebigendian() != i) + ip->pflags |= RMF_SWAPIN; + else + ip->pflags &= ~RMF_SWAPIN; return(0); } if (isexpos(s)) { float f = exposval(s); scalecolor(ip->cexp, f); - return(0); + return(f > .0 ? 0 : -1); } if (iscolcor(s)) { COLOR ctmp; - colcorval(ctmp, s); + if (!colcorval(ctmp, s)) return(-1); multcolor(ip->cexp, ctmp); return(0); } - if (iswlsplit(s)) { - wlsplitval(ip->wlpart, s); - return(0); - } + if (iswlsplit(s)) + return(wlsplitval(ip->wlpart, s) - 1); + if (!formatval(fmt, s)) { rmx_addinfo(ip, s); return(0); @@ -184,11 +184,11 @@ get_dminfo(char *s, void *p) ip->dtype = i; return(0); } - return(-1); + return(-1); /* bad format */ } static int -rmx_load_ascii(double *drp, const RMATRIX *rm, FILE *fp) +rmx_load_ascii(rmx_dtype *drp, const RMATRIX *rm, FILE *fp) { int j, k; @@ -200,7 +200,7 @@ rmx_load_ascii(double *drp, const RMATRIX *rm, FILE *f } static int -rmx_load_float(double *drp, const RMATRIX *rm, FILE *fp) +rmx_load_float(rmx_dtype *drp, const RMATRIX *rm, FILE *fp) { int j, k; float val[100]; @@ -212,7 +212,7 @@ rmx_load_float(double *drp, const RMATRIX *rm, FILE *f for (j = 0; j < rm->ncols; j++) { if (getbinary(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp) return(0); - if (rm->swapin) + if (rm->pflags & RMF_SWAPIN) swap32((char *)val, rm->ncomp); for (k = 0; k < rm->ncomp; k++) *drp++ = val[k]; @@ -221,17 +221,17 @@ rmx_load_float(double *drp, const RMATRIX *rm, FILE *f } static int -rmx_load_double(double *drp, const RMATRIX *rm, FILE *fp) +rmx_load_double(rmx_dtype *drp, const RMATRIX *rm, FILE *fp) { if (getbinary(drp, sizeof(*drp)*rm->ncomp, rm->ncols, fp) != rm->ncols) return(0); - if (rm->swapin) + if (rm->pflags & RMF_SWAPIN) swap64((char *)drp, rm->ncols*rm->ncomp); return(1); } static int -rmx_load_rgbe(double *drp, const RMATRIX *rm, FILE *fp) +rmx_load_rgbe(rmx_dtype *drp, const RMATRIX *rm, FILE *fp) { COLR *scan; COLOR col; @@ -254,7 +254,7 @@ rmx_load_rgbe(double *drp, const RMATRIX *rm, FILE *fp } static int -rmx_load_spec(double *drp, const RMATRIX *rm, FILE *fp) +rmx_load_spec(rmx_dtype *drp, const RMATRIX *rm, FILE *fp) { uby8 *scan; SCOLOR scol; @@ -287,11 +287,11 @@ rmx_load_header(RMATRIX *rm, FILE *fp) rm->ncomp = 3; setcolor(rm->cexp, 1.f, 1.f, 1.f); memcpy(rm->wlpart, WLPART, sizeof(rm->wlpart)); - rm->swapin = 0; + rm->pflags = 0; } rm->dtype = DTascii; /* assumed w/o FORMAT */ if (getheader(fp, get_dminfo, rm) < 0) { - fputs("Unrecognized matrix format\n", stderr); + fputs("Bad matrix header\n", stderr); return(0); } if ((rm->dtype == DTrgbe) | (rm->dtype == DTxyze) && @@ -307,9 +307,9 @@ rmx_load_header(RMATRIX *rm, FILE *fp) return(1); } -/* Load next row as double (cannot be XML) */ +/* Load next row as rmx_dtype (cannot be XML) */ int -rmx_load_row(double *drp, const RMATRIX *rm, FILE *fp) +rmx_load_row(rmx_dtype *drp, const RMATRIX *rm, FILE *fp) { switch (rm->dtype) { case DTascii: @@ -336,12 +336,16 @@ rmx_load_data(RMATRIX *rm, FILE *fp) int i; #ifdef MAP_FILE long pos; /* map memory for file > 1MB if possible */ - if ((rm->dtype == DTdouble) & !rm->swapin && array_size(rm) >= 1L<<20 && - (pos = ftell(fp)) >= 0 && !(pos % sizeof(double))) { - rm->mapped = mmap(NULL, array_size(rm)+pos, PROT_READ|PROT_WRITE, + if ((rm->dtype == DTrmx_native) & !(rm->pflags & RMF_SWAPIN) & + (rmx_array_size(rm) >= 1L<<20) && + (pos = ftell(fp)) >= 0 && !(pos % sizeof(rmx_dtype))) { + rm->mapped = mmap(NULL, rmx_array_size(rm)+pos, PROT_READ|PROT_WRITE, MAP_PRIVATE, fileno(fp), 0); if (rm->mapped != MAP_FAILED) { - rm->mtx = (double *)rm->mapped + pos/sizeof(double); + if (rm->pflags & RMF_FREEMEM) + free(rm->mtx); + rm->mtx = (rmx_dtype *)rm->mapped + pos/sizeof(rmx_dtype); + rm->pflags &= ~RMF_FREEMEM; return(1); } /* else fall back on reading into memory */ rm->mapped = NULL; @@ -349,7 +353,7 @@ rmx_load_data(RMATRIX *rm, FILE *fp) #endif if (!rmx_prepare(rm)) { /* need in-core matrix array */ fprintf(stderr, "Cannot allocate %g MByte matrix array\n", - (1./(1L<<20))*(double)array_size(rm)); + (1./(1L<<20))*(double)rmx_array_size(rm)); return(0); } for (i = 0; i < rm->nrows; i++) @@ -374,13 +378,9 @@ rmx_load(const char *inspec, RMPref rmp) fp = stdin; else if (inspec[0] == '!') fp = popen(inspec+1, "r"); - else { - const char *sp = inspec; /* check suffix */ - while (*sp) - ++sp; - while (sp > inspec && sp[-1] != '.') - --sp; - if (!strcasecmp(sp, "XML")) { /* assume it's a BSDF */ + else { /* check suffix */ + const char *sp = strrchr(inspec, '.'); + if (sp > inspec && !strcasecmp(sp+1, "XML")) { /* BSDF? */ CMATRIX *cm = rmp==RMPnone ? (CMATRIX *)NULL : rmp==RMPtrans ? cm_loadBTDF(inspec) : cm_loadBRDF(inspec, rmp==RMPreflB) ; @@ -393,8 +393,10 @@ rmx_load(const char *inspec, RMPref rmp) } /* else open it ourselves */ fp = fopen(inspec, "r"); } - if (!fp) + if (!fp) { + fprintf(stderr, "Cannot open for reading: %s\n", inspec); return(NULL); + } #ifdef getc_unlocked flockfile(fp); #endif @@ -428,17 +430,17 @@ rmx_load(const char *inspec, RMPref rmp) (dnew->cexp[1] != 1.f) | (dnew->cexp[2] != 1.f)) { double cmlt[MAXCSAMP]; int i; - cmlt[0] = 1./dnew->cexp[0]; - cmlt[1] = 1./dnew->cexp[1]; - cmlt[2] = 1./dnew->cexp[2]; if (dnew->ncomp > MAXCSAMP) { fprintf(stderr, "Excess spectral components in: %s\n", inspec); rmx_free(dnew); return(NULL); } + cmlt[0] = 1./dnew->cexp[0]; + cmlt[1] = 1./dnew->cexp[1]; + cmlt[2] = 1./dnew->cexp[2]; for (i = dnew->ncomp; i-- > 3; ) - cmlt[i] = cmlt[1]; + cmlt[i] = cmlt[1]; /* XXX hack! */ rmx_scale(dnew, cmlt); setcolor(dnew->cexp, 1.f, 1.f, 1.f); } @@ -446,11 +448,11 @@ rmx_load(const char *inspec, RMPref rmp) } static int -rmx_write_ascii(const double *dp, int nc, int len, FILE *fp) +rmx_write_ascii(const rmx_dtype *dp, int nc, int len, FILE *fp) { while (len-- > 0) { int k = nc; - while (nc-- > 0) + while (k-- > 0) fprintf(fp, " %.7e", *dp++); fputc('\t', fp); } @@ -458,7 +460,7 @@ rmx_write_ascii(const double *dp, int nc, int len, FIL } static int -rmx_write_float(const double *dp, int len, FILE *fp) +rmx_write_float(const rmx_dtype *dp, int len, FILE *fp) { float val; @@ -471,7 +473,7 @@ rmx_write_float(const double *dp, int len, FILE *fp) } static int -rmx_write_rgbe(const double *dp, int nc, int len, FILE *fp) +rmx_write_rgbe(const rmx_dtype *dp, int nc, int len, FILE *fp) { COLR *scan; int j; @@ -490,7 +492,7 @@ rmx_write_rgbe(const double *dp, int nc, int len, FILE } static int -rmx_write_spec(const double *dp, int nc, int len, FILE *fp) +rmx_write_spec(const rmx_dtype *dp, int nc, int len, FILE *fp) { uby8 *scan; SCOLOR scol; @@ -499,7 +501,7 @@ rmx_write_spec(const double *dp, int nc, int len, FILE if (nc < 3) return(0); scan = (uby8 *)tempbuffer((nc+1)*len); if (!scan) return(0); - for (j = len; j--; dp += nc) { + for (j = 0; j < len; j++, dp += nc) { for (k = nc; k--; ) scol[k] = dp[k]; scolor2scolr(scan+j*(nc+1), scol, nc); @@ -539,7 +541,9 @@ rmx_write_header(const RMATRIX *rm, int dtype, FILE *f dtype = DTxyze; else if ((dtype == DTxyze) & (rm->dtype == DTrgbe)) dtype = DTrgbe; - if ((dtype == DTspec) & (rm->ncomp < 3)) + if ((dtype < DTspec) & (rm->ncomp > 3)) + dtype = DTspec; + else if ((dtype == DTspec) & (rm->ncomp <= 3)) return(0); if (dtype == DTascii) /* set file type (WINDOWS) */ @@ -560,8 +564,8 @@ rmx_write_header(const RMATRIX *rm, int dtype, FILE *f } if (dtype >= DTspec) { /* # components & split? */ fputncomp(rm->ncomp, fp); - if (dtype == DTspec || (rm->ncomp > 3 && - memcmp(rm->wlpart, WLPART, sizeof(WLPART)))) + if (rm->ncomp > 3 && + memcmp(rm->wlpart, WLPART, sizeof(WLPART))) fputwlsplit(rm->wlpart, fp); } else if ((rm->ncomp != 3) & (rm->ncomp != 1)) return(0); /* wrong # components */ @@ -576,14 +580,14 @@ rmx_write_header(const RMATRIX *rm, int dtype, FILE *f /* Write out matrix data (usually by row) */ int -rmx_write_data(const double *dp, int nc, int len, int dtype, FILE *fp) +rmx_write_data(const rmx_dtype *dp, int nc, int len, int dtype, FILE *fp) { switch (dtype) { case DTascii: return(rmx_write_ascii(dp, nc, len, fp)); case DTfloat: return(rmx_write_float(dp, nc*len, fp)); - case DTdouble: + case DTrmx_native: return(putbinary(dp, sizeof(*dp)*nc, len, fp) == len); case DTrgbe: case DTxyze: @@ -607,7 +611,7 @@ rmx_write(const RMATRIX *rm, int dtype, FILE *fp) #ifdef getc_unlocked flockfile(fp); #endif - if (dtype == DTdouble) /* write all at once? */ + if (dtype == DTrmx_native) /* write all at once? */ ok = rmx_write_data(rm->mtx, rm->ncomp, rm->nrows*rm->ncols, dtype, fp); else /* else row by row */ @@ -634,9 +638,9 @@ rmx_identity(const int dim, const int n) if (!rid) return(NULL); - memset(rid->mtx, 0, array_size(rid)); + memset(rid->mtx, 0, rmx_array_size(rid)); for (i = dim; i--; ) { - double *dp = rmx_lval(rid,i,i); + rmx_dtype *dp = rmx_lval(rid,i,i); for (k = n; k--; ) dp[k] = 1.; } @@ -659,7 +663,7 @@ rmx_copy(const RMATRIX *rm) rmx_free(dnew); return(NULL); } - memcpy(dnew->mtx, rm->mtx, array_size(dnew)); + memcpy(dnew->mtx, rm->mtx, rmx_array_size(dnew)); } rmx_addinfo(dnew, rm->info); dnew->dtype = rm->dtype; @@ -668,6 +672,37 @@ rmx_copy(const RMATRIX *rm) return(dnew); } +/* Replace data in first matrix with data from second */ +int +rmx_transfer_data(RMATRIX *rdst, RMATRIX *rsrc, int dometa) +{ + if (!rdst | !rsrc || (rdst->nrows != rsrc->nrows) | + (rdst->ncols != rsrc->ncols) | + (rdst->ncomp != rsrc->ncomp)) + return(0); + + if (dometa) { /* transfer everything? */ + rmx_reset(rdst); + *rdst = *rsrc; + rsrc->info = NULL; rsrc->mapped = NULL; rsrc->mtx = NULL; + return(1); + } +#ifdef MAP_FILE /* just matrix data -- leave metadata */ + if (rdst->mapped) + munmap(rdst->mapped, rmx_mapped_size(rdst)); + else +#endif + if (rdst->pflags & RMF_FREEMEM) { + free(rdst->mtx); + rdst->pflags &= ~RMF_FREEMEM; + } + rdst->mapped = rsrc->mapped; + rdst->mtx = rsrc->mtx; + rdst->pflags |= rsrc->pflags & RMF_FREEMEM; + rsrc->mapped = NULL; rsrc->mtx = NULL; + return(1); +} + /* Allocate and assign transposed matrix */ RMATRIX * rmx_transpose(const RMATRIX *rm) @@ -698,7 +733,7 @@ rmx_transpose(const RMATRIX *rm) for (j = dnew->ncols; j--; ) for (i = dnew->nrows; i--; ) memcpy(rmx_lval(dnew,i,j), rmx_val(rm,j,i), - sizeof(double)*dnew->ncomp); + sizeof(rmx_dtype)*dnew->ncomp); return(dnew); } @@ -723,7 +758,7 @@ rmx_multiply(const RMATRIX *m1, const RMATRIX *m2) for (i = mres->nrows; i--; ) for (j = mres->ncols; j--; ) for (k = mres->ncomp; k--; ) { - double d = 0; + rmx_dtype d = 0; for (h = m1->ncols; h--; ) d += rmx_val(m1,i,h)[k] * rmx_val(m2,h,j)[k]; rmx_lval(mres,i,j)[k] = d; @@ -751,7 +786,7 @@ rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide for (i = m1->nrows; i--; ) for (j = m1->ncols; j--; ) if (divide) { - double d; + rmx_dtype d; if (m2->ncomp == 1) { d = rmx_val(m2,i,j)[0]; if (d == 0) { @@ -774,7 +809,7 @@ rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide } } else { if (m2->ncomp == 1) { - const double d = rmx_val(m2,i,j)[0]; + const rmx_dtype d = rmx_val(m2,i,j)[0]; for (k = m1->ncomp; k--; ) rmx_lval(m1,i,j)[k] *= d; } else @@ -815,8 +850,8 @@ rmx_sum(RMATRIX *msum, const RMATRIX *madd, const doub rmx_addinfo(msum, rmx_mismatch_warn); for (i = msum->nrows; i--; ) for (j = msum->ncols; j--; ) { - const double *da = rmx_val(madd,i,j); - double *ds = rmx_lval(msum,i,j); + const rmx_dtype *da = rmx_val(madd,i,j); + rmx_dtype *ds = rmx_lval(msum,i,j); for (k = msum->ncomp; k--; ) ds[k] += sf[k] * da[k]; } @@ -835,7 +870,7 @@ rmx_scale(RMATRIX *rm, const double sf[]) return(0); for (i = rm->nrows; i--; ) for (j = rm->ncols; j--; ) { - double *dp = rmx_lval(rm,i,j); + rmx_dtype *dp = rmx_lval(rm,i,j); for (k = rm->ncomp; k--; ) dp[k] *= sf[k]; } @@ -867,9 +902,9 @@ rmx_transform(const RMATRIX *msrc, int n, const double dnew->dtype = msrc->dtype; for (i = dnew->nrows; i--; ) for (j = dnew->ncols; j--; ) { - const double *ds = rmx_val(msrc,i,j); + const rmx_dtype *ds = rmx_val(msrc,i,j); for (kd = dnew->ncomp; kd--; ) { - double d = 0; + rmx_dtype d = 0; for (ks = msrc->ncomp; ks--; ) d += cmat[kd*msrc->ncomp + ks] * ds[ks]; rmx_lval(dnew,i,j)[kd] = d; @@ -894,7 +929,7 @@ rmx_from_cmatrix(const CMATRIX *cm) for (i = dnew->nrows; i--; ) for (j = dnew->ncols; j--; ) { const COLORV *cv = cm_lval(cm,i,j); - double *dp = rmx_lval(dnew,i,j); + rmx_dtype *dp = rmx_lval(dnew,i,j); dp[0] = cv[0]; dp[1] = cv[1]; dp[2] = cv[2]; @@ -916,7 +951,7 @@ cm_from_rmatrix(const RMATRIX *rm) return(NULL); for (i = cnew->nrows; i--; ) for (j = cnew->ncols; j--; ) { - const double *dp = rmx_val(rm,i,j); + const rmx_dtype *dp = rmx_val(rm,i,j); COLORV *cv = cm_lval(cnew,i,j); switch (rm->ncomp) { case 3:
